ΠαράθεσηHyperX® Impact memory boasts the world’s fastest SO-DIMM frequency — 2666MHz — to keep you ahead of the curve and level up your game. It automatically recognises the platform it’s plugged into and auto overclocks to the highest frequency published (up to 2400MHz) with no need to adjust system BIOS settings. So you get extreme performance that supports notebooks and small form factor systems, using either AMD or the latest Intel CPU technologies with no hassle at all — even if you’re a newbie. Impact makes your game hotter while keeping your system cool. It has low voltage settings at 1.35V for less power consumption, reduced heat generation and quiet computing. Its slim, sleek new look lets you stand out in the crowd while the thin thermal label allows for installation in slim or ultra-slim notebooks. Best of all, HyperX Impact delivers high performance at a low cost. It’s gamerapproved and backed by a lifetime warranty, free technical support and legendary reliability.
Kingston HyperX Impact HX318LS10IBK2/8 | |
Χωρητικότητα |
2x4GB
Τύπος μνήμης | DDR3L SO-DIMM |
Timings |
1866MHz, 10.0-10-10-32, 1.35V
Ψύξη | - |
Άλλα χαρακτηριστικά |
Αυτόματο Overclock έως 1866Mhz
Εγγύηση | Eφ' όρου ζωής |
Τιμή |
93€ στην Ελληνική αγορά
- Intel i7-4770k
- ASUS Maximus VI Extreme
- Crucial Ballistix Sport 2x4GB
- CoolerMaster 1200W
- Dell 3008WFP
- Samsung 840 EVO 120GB
- Windows 7 x64
- Λειτουργία 1.35v
- Κατανάλωση
- Εμφάνιση
- Χαλαρά Subtimings
- Τιμή
- Χρήση JEDEC profiles αντί XMP ή AMP
- Overclocking
