Everything posted by UltraB
Για περάστε, για περάστε PHP - Convert PDO to MySQLi (Prepare & Execute)
- 25.485 απαντήσεις
Καλησπέρα παιδιά, προσπαθώ να φτιάξω στο παρακάτω κώδικα το σημείο από την σειρά 52 έως την 57. Προφανώς δεν έκανα κάτι καλά στην μετατροπή από PDO σε MySQLi αλλά ότι και αν έχω προσπαθήσει δε μπορώ να βγάλω άκρη. Απ όσο έχω καταλάβει δε πρέπει να παίρνω αποτέλεσμα false / boolean (βλέπε var_dump($query); ). bool(false) Fatal error: Call to a member function execute() on boolean in C:\xampp\htdocs\xxxxxx\php\register.php on line 56 <?phprequire_once 'database.php'; Consider mysqli in your database.php like below$mysqli = new mysqli(DB_HOST, DB_USER, DB_PASSWORD, DB_NAME); $Username = $_POST['username']; #Username $Password = $_POST['password']; #Password $Password2 = $_POST['password2'];#Passwordif(empty($Password2)){ echo "Please enter a valid confirmation password."; $msg .=" Please enter a valid confirmation password."; echo "<script> alert('$msg'); window.location.href='../register.html'; </script>"; exit;} if($Password !== $Password2){ echo "Sorry, passwords do not match!"; $msgPass = "Sorry, passwords do not match!"; echo "<script> alert('$msgPass'); window.location.href='../register.html'; </script>"; exit;}function NewUser(){ global $Username,$Password,$mysqli; #Egxwrish stoixeiwn $hashed_pass = PASSWORD_HASH($Password, PASSWORD_DEFAULT); $query = "INSERT INTO users (username,password) VALUES (:username, :password)"; $data = $mysqli->prepare($query); $data->execute(array(':username'=>$Username, ':password'=>$hashed_pass)); if($data->rowCount() > 0) { return "Your registration is completed!"; }}function SignUp(){ global $Username,$Password,$mysqli; if(!empty($Username)) //checking the 'username' name which is from register.html, if is it empty or have some text { $query = ("SELECT * FROM users WHERE username = :username"); $query = $mysqli->prepare($query); var_dump($query); $query->execute(array(':username'=>$Username)); if($query->rowCount() == 0) { $msg = NewUser(); echo $msg; } else { echo "Sorry, you are already registered!"; die(); } }}if(isset($_POST['submit'])){ //User registration SignUp(); echo "Your account has been created successfully. \\n Thank you for joined us!"; $msgSuccess = "Your account has been created successfully. \\n Thank you for joined us!"; echo "<script> alert('$msgSuccess'); window.location.href='../index.php'; </script>";}else echo "Sorry, sumbit button is not set";?> Τέλος είμαι νέος (aka noob) στην PHP, οπότε όποια λαθάκια στο κώδικα, συγχωρέστε τα, και όποιες προτάσεις για αλλαγή, ευπρόσδεκτες
Που πετάνε;
- 25.485 απαντήσεις
Πωωω, δεν έπρεπε να διαβάσω το τελευταίο μήνυμα, μου έκανες ζημιά @Thresh86! Είχα ερωτευτεί ένα όταν έψαχνα για αυτοκίνητο και δυστυχώς δεν το αγόρασα λόγο των 1600 / Μοντέλο 2009 aka παλιά φορολογία. Να το χαίρεσαι, καλοδούλευτο και απροβλημάτιστο εύχομαι!
Best Mirrorless @600-700
UltraB απάντησε στο θέμα του l2phile topic στην ενότητα Φωτογραφικές μηχανές και λοιπά αξεσουάρ
Οι διαφορές της Sony Α5000 με την Sony A6000 είναι μεγάλες; Επίσης Fujifilm X-M1 ή Α5000; Ή κάτι άλλο περίπου στα 400€; Πχ Nikon D3200/3000, Canon D100; -
Ρε παιδιά, τι φάση παίζει με τις Remington; Πέτυχα μερικές στο skroutz που στις αξιολογήσεις έχουν 1-2 αστεράκια...
@ΝTG, κατά πάσα πιθανότητα τα μισά απ ότι λες δεν τα καταλαβαίνουν και οι υπόλοιποι, όπως και εγώ Επίσης παίζει να λάβεις PM σύντομα, το ελπίζω δηλαδή μήπως προβώ ποτέ σε αγορά μιας και όλο το αφήνω. -
Εγώ noobas είμαι, ούτε ο Prime ξέρω τι είναι, ούτε το EVF. Στο flickr πάντως που είδα μερικές φωτογραφίες, δεν με εντυπωσίασαν όπως της Sony A6000 για παράδειγμα, πολύ "ψόφια" χρώματα -
Μιας και βλέπω πολύ κίνηση περί Fujifilm, ποια η γνώμη σας για το πακέτο X-M1 + 16-50mm. Δε θέλω πολλά, μη χαλάσουμε το θέμα του@l2phile, απλά αν είναι η καλύτερη επιλογή σε αυτά τα χρήματα, συμπεριλαμβανομένου και των DSLR. -
Ομολογώ ότι δε πήγε εκεί το μυαλό μου... Το βρήκα γράφοντας στο google "netbook gifs" και μου άρεσε η φατσίτσα που είχε επάνω. Απ την άλλη βέβαια, μοιάζουν αρκετά με το ped.
- 25.485 απαντήσεις
- 25.485 απαντήσεις
Post #1824 για το νέο ανασχεδιασμένο παλιό λογότυπο. Αυτό που χρησιμοποιεί δηλαδή μετά την ανάκληση.
Τι φάση στο 1.42, μόνο ο καθρέφτης έκλεισε μετά από τέτοια στούκα;
- 25.485 απαντήσεις
Τι invite;
- 25.485 απαντήσεις
Νομίζω τα βρήκα αλλά και πάλι δεν έχουν επιλογή για απενεργοποιήση παρά μόνο να μην εμφανίζονται.
Γνωρίζει κανείς πως μπορώ να τα κάνω να μην "κρατάνε" καν τα Recent Files; Η μόνη επιλογή που βρήκα είναι να τα κάνω hide αλλά δε θέλω αυτό. Επίσης δεν υπάρχει σε εμένα η καρτέλα Start Menu της παρακάτω φωτογραφίας ώστε να τα απενεργοποιήσω από εκεί.
Αν και νομίζω κατάλαβα γιατί ρωτάς, έχουν 195/55/16. Μου άρεσε όμως πως το πήγες "πλαγίως"
Φίλε Σωτήρη, φιλικά πάντα αλλά την αλλαγή ελαστικών, νομίζω δεν την καθορίζουν ούτε τα άλογα, ούτε τα χιλιόμετρα που κάνει το αυτοκίνητο. Ένα αυτοκίνητο με 50 άλογα αναπτύσσει άνετα ταχύτητες της τάξης των 100 χιλιομέτρων. Νομίζω και πως και αυτό χρειάζεται καλά ελαστικά. Μπορεί όχι στον ίδιο βαθμό με ένα των 200, αλλά χρειάζεται. Απλά όπως προείπα, επειδή ακούω διάφορες απόψεις από άτομα που οδηγούν τα πενταπλάσια χρόνια από εμένα, είπα να πάρω μια γνώμη παραπάνω. Το ξέρω ότι είναι πολυχρονισμένα τα ελαστικά και είμαι της άποψης να γίνει αλλαγή, απλά επειδή έχουν λίγα χιλιόμετρα ειπώθηκε ότι ίσως να μην χρειάζονται αλλαγή. PS: Να μη ρωτάω στα φόρα; Αφού αυτός είναι ο λόγος ύπαρξης τους...
@hayabusa, @sotiris, το αυτοκίνητο έχει κάνει τόσα χιλιόμετρα γιατί ο προηγούμενος ιδιοκτήτης του είχε άλλα δύο αυτοκίνητα και το είχε για την γυναίκα του. Επίσης απ ότι έμαθα καθόταν σε πυλωτή, για αυτό έχει διατηρηθεί και τόσο καλά, όπως και τα λάστιχα του. Και εγώ είμαι της άποψης να αλλάξουν αλλά οι απόψεις διίστανται όπως προείπα.... Αν μπορέσω και το θυμηθώ θα τα βγάλω και μια φωτογραφία να δείτε την κατάσταση τους.
Μιας και βλέπω κίνηση και οι απόψεις διίστανται. Αυτοκίνητο 7 χρόνων φοράει τα μαμα λάστιχα. Απλά να επισημάνω ότι έχει 8000 χιλιόμετρα, όσο και αν σας φαινεται παράξενο και τα λάστιχα εμφανισιακά είναι σαν καινούργια. Έχουν φάει απειροελάχιστα από το πέλμα τους, δεν έχουν σκάσει από τον ήλιο και να φανταστείτε έχουν στα πλαϊνά ακόμα τα "μπιμπικακια". Ποιά η γνώμη σας, θέλουν αλλαγή ή όχι;
Πριν από μερικά λεπτά έβλεπα αντίστοιχο άρθρο. Τι να πεις, πραγματικά λες και έχει βγει από ταινία είναι. Η φωτογραφία που μου έμεινε είναι η #21
- 25.485 απαντήσεις
- 25.485 απαντήσεις
- 2
Σήμερα παρατήρησα το παρακάτω φαινόμενο σε όσα θέματα περιέχουν ελληνικούς χαρακτήρες στο URL τους: Επίσης το site φαίνεται να καθυστερεί αρκετά, για ρίξτε και εκεί μια ματιά. Edit: Σε IE με πηγαίνει στην σελίδα σε αντίθεση με το Chrome που μου πετάει "Too many redirects" αλλά τα ερωτηματικά παραμένουν στο URL.
DIY project 1: PC remote control
UltraB απάντησε στο θέμα του Jaco topic στην ενότητα Από το Εργαστήρι
Να τα! Πολύ ευχάριστα νέα, ελπίζω να συνεχιστεί η όλη ιδέα!
