idonthave
    5.089
  • Ημέρες που κέρδισε
    75
  1. idonthave
    1080ti bottlenecking σε παλιο συστημα
    είδα τον cpu που έχεις,τις εικόνες τις κοίταξες? έχει από ryzen 3 1200 μέχρι .... σου δείχνω ότι δεν εξαρτάται το συγκεκριμένο παιχνίδι από τον επεξεργαστή αλλά καθαρά από την κάρτα γραφικών!
  2. AMD Preparing To Launch 13 Vega-11 Based Graphics Cards, GPU Passes Final Certification
  3. EVGA announces GeForce GTX 1080 Ti FTW3 ELITE with 12GHz memory EVGA has an interesting offer, a GTX 1080 Ti with a clock speed higher than TITAN Xp The Elite FTW3 models were offered for quite some time, but only now they are available with faster memory. The chips were overclocked to 1500 MHz (12 GHz effective) frequency, which makes them ~9% faster. This increases the bandwidth to 528 GB/s, a 44 GB/s upgrade over reference 484 GB/s. Despite faster memory, the GTX 1080 Ti FTW3 Elite cards are still effectively slower than TITAN Xp, which has a bandwidth of 547 GB/s thanks to wider, 384-bit bus.
  4. idonthave
    Γενικά όσο μεγαλώνει ανάλυση, στα περισσότερα παιχνίδια θα παίζει ρόλο η κάρτα γραφικών και λιγότερο ο επεξεργαστής Το συγκεκριμένο παιχνίδι είναι gpu bound γι αυτό βλέπεις να έχει "παρκάρει" ο επεξεργαστής
  5. idonthave
    Πείτε Ό,τι Θέλετε v5.0
    Επ τι γίνετε εδώ, πρωινοί!!! Καλημέρες
  6. MSI GeForce GTX 1080 Ti GAMING X TRIO The GAMING X TRIO is a 2.5 slot graphics card with RGB LED bar on the backplate (Mystic Light). The new card is factory-overclocked to 1569 MHz (base), 1683 MHz (boost) and 11124 MHz (memory). Same as GAMING X (dual-fan) the TRIO has dual-8pin power connectors. No pictures of the PCB were posted. The card has non-standard display connectors (2x HDMI + 2x DisplayPort + DVI). The MSI GTX 1080 Ti GAMING X TRIO will go on sale starting from October 12th.
  7. rumors?? Possible specifications of GeForce GTX 1070 Ti emerge GeForce GTX 1070 Ti with 2432 CUDA cores? Earlier rumors suggested that GTX 1070 Ti could actually have 2304 CUDA cores, which seems more than one would expect. The story from MyDrivers seems to go even further, because the rumored specs point towards 2432 CUDA cores, only 128 cores less than 1080. No date was given, but the rumor has it GeForce GTX 1070 Ti could launch around Halloween. The same site claims that GTX 1070 Ti could cost only 500 Yuans less than GTX 1080 (~75 USD). καλό Halloween *σαν σκέψη (μπορεί να είναι και άκυρη) να έχει θέμα με τις μνήμες GDDR5X κι έμμεσα να αποσύρει την 1080, δεν βρίσκω κάποια άλλη διαφορά με την 1080 αν τελικά βγει η 1070TI με αυτά τα specs.
  8. idonthave
    Τελευταίες πληροφορίες για τους νέους Coffee Lake της Intel
    ASUS ROG STRIX Z370-I GAMING Mini-ITX motherboard pictured
  9. Νομίζω το παρακάτω θα κάνει μιας κι έχει κάνει τα refresh της σε 1060,1080 *στο προηγούμενο post το link δεν δουλεύει http://www.guru3d.com/news-story/gigabyte-teases-geforce-gtx-1070-ti.html
  10. Intel 8-core LGA1151 Processor For Z390 Could Be 14 nm Coffee Lake After All
