idonthave
    5.094
  • Ημέρες που κέρδισε
    75
  1. idonthave
    INTEL 9th GENERATION CPUs & Motherboards
    Intel Core 9x00 Processor Prices Listed at Singapore Distributor We've seen some early price leaks on the Core i5 and i7 9000 series processors a couple of times already, however things are starting to solidify a bit more as distributor BizGram in Singapore is listing the new procs in a flyer. Now a couple of things first, the prices that you see listed are from Singapore, that means these are listed at SGD, we'll need to convert that. Next, to that, this is a distributor, who sells their stuff to retailers, e.g. Now I can only assume that local VAT needs to be added to the prices: That said, here we go converted to USD. Core i3-9350K is listed at 252 SGD = $189.99 Core i5-9600K is listed at 370 SGD = $269.99 Core i7-9700K listed at 518 SGD= $379.99 Core i9-9900K listed at 666 SGD = $479.99. Also, interesting to see is the 9350K. The snapshot also once again confirms cores and threads. prices at SGD
  2. idonthave
    Πείτε Ό,τι Θέλετε v6.0
    Καλημέρες Τι προτιμάς μελομακάρονα, αγιο βασιλίτσες ή .... NSFW
  3. idonthave
    "RTX 20x0 & 16x0" Turing architecture
    The new features of NVIDIA Turing architecture INT32 Cores New Shading Advancements Turing Memory Compression Video and Display Engine NVLINK (only 2-way) ______________________________________________ NVIDIA TU102 vs TU104 vs TU106
  4. idonthave
    NVIDIA changes GeForce RTX 2080 reviews date to September 19th RTX ON
  5. idonthave
    Source: El Chapuzas Informatico ... engineering sample of yet unreleased Intel Core i7-9700K processor and thought it would be a good idea to test it. ...When it comes to overclocking, the CPU only managed to hit 5.0 GHz at 1.4V, which is probably not as high as we expected.
  6. idonthave
    το ξέρω κι εγώ επεξήγηση έκανα
  7. idonthave
    Θα το γράψω καλύτερα (όσο μπορώ ), όταν υπάρξουν στα ράφια οι RTX οι πασχάληδες αλλάζουν κατηγορίες, mid προς "low" 2060/2050 γιοκ για φέτος (μπορεί και καθόλου), το γράφει στο άρθρο και αν ίσχυαν οι επιδόσεις όπως παλιά 2060→1070 (ανάλογα και πόσες θα έβγαζε 3gb,6gb ), 2050ti→1060 3gb,6gb δεν ξέρω κι εγώ ποια απ'όλες 2050→ 1050ti high προς mid 1080→1080 πρέπει να έχει λίγα κομμάτια 1070ti (αντικαταστάτης 1080) 1080ti (hight) απ'τα 900€+ (2080,2080ti) τα αφήνω πάνω σας (enthusiasist .....)
  8. AMD Athlon 200GE very likely not overclockable
  9. idonthave
    Υπάρχει (μεγάλο) απόθεμα λέμε , Ο πασχάλης (pascal) θα μας συντροφεύει για mid-low range τουλάχιστον μέχρι κι αρχές του 19. Το σενάριο 1080ti πλησιάζει περισσότερο
  10. Το λοιπόν, αν δεν γίνει αγορά αυτόν το μήνα η αγορά θα πάει όντως για το 2020 (λέμε τώρα). Κατέληξα στις παρακάτω 2 (η αγορά θα γίνει απ'έξω) LG 32GK850G-B g-sync 720€ AOC Agon AG322QC4 freesync 550€ (προς αυτό κλίνω περισσότερο) https://geizhals.eu/?cmp=1742717&cmp=1806560 Και τα 2 μόνιτορ είναι με VA panel, το AOC υποστηρίζει HDR400 και είναι κοίλο/κυρτό ενώ το LG είναι flat και δεν υποστηρίζει hdr το AOC είναι freesync, το LG g-sync .... Για τις 32" δεν ξέρω αν το lg μιας και είναι flat αν θα "κουράζει", συγκριτικά με το aoc που είναι curved (απόσταση από την οθόνη 1 μέτρο περίπου). Παρόμοια μόνιτορ freesync με το AOC που ξεχώρισα είναι τα παρακάτω αλλά το AOC το βρίσκω πιο ολοκληρωμένο και η αγορά τους (όχι όλα) ως τιμή "πλησιάζει" το LG και σ'αυτή την περίπτωση θα προτιμήθεί το LG μιας και έχει το gsync. https://geizhals.eu/?cmp=1796089&cmp=1722456&cmp=1846236&cmp=1779999 ASUS ROG Strix XG32VQ LG 32GK850F-B BenQ EX3203R Acer XZ1 XZ321QUbmijpphzx Το μειονέκτημα με το AOC είναι ότι δεν βρίσκω κάποιο review ή βίντεο (μιας και είναι σχετικά καινούριο) . Οι μόνες πληροφορίες είναι από μια κριτική που έχω βρει στο amazon. Σχετικά με τα υπόλοιπα δεν ξέρω αν είμαι λάθος στον τρόπο σκέψης. Απ'τα 2 που γράφω στην αρχή σε ποιο θα πηγαίνατε? ή αν έχετε να προτείνετε κάτι άλλο!
  11. idonthave
    Intel Core i9-9900K, Core i7-9700K  and Core i5-9600K - Single Core and Multi-Core Performance Leaks Out 9900k 9700k 9600k Intel Core i9-9900K, Intel’s First 8 Core Mainstream CPU With 4.7 GHz All 8 Core Boost Frequency, Faster Than Intel’s 8086K Anniversary Edition In All Possible Ways First up, we will detail the flagship part, the 8 core, 16 thread, Intel Core i9-9900K. This will be the first mainstream desktop Core i9 part and also the first Intel chip to boast 8 cores and 16 threads. In terms of cache, the chip will feature 16 MB of L3 and will come with an Intel UHD 620 ?? graphics chip. ...... Intel Core i7-9700K, Intel’s First 8 Core, Core i7 Mainstream Desktop CPU With Up To 4.6 GHz Clocks Across All Cores Coming to the top Core i7 part, we get 8 cores and 8 threads. This the complete opposite of what we have been hearing as previous rumors identified the chip as a 6 core and 12 thread part. The chip will have 12 MB of L3 cache and as you might tell, it has lower threads than the Core i7-8700K but comes with higher core count. So maybe, we will get same or even better performance from the chip. ... Intel Core i5-9600K, 6 Cores, and 6 Threads With Higher Clocks Than 8th Generation i5 ‘K” SKU The Intel Core i5-9600K is a 6 core and 6 thread part with 9 MB of L3 cache. This makes it very similar to the Core i5-8600K. The difference is that it features higher clock speeds of 3.7 GHz base, 4.6 GHz boost (1 core), 4.5 GHz (2 core), 4.4 GHz (4 core) and 4.3 GHz (6 core). All of this is done at the same TDP of 95W. ..
  12. το adblock το προκαλούσε, αν και είναι απενεργοποιημένο στον Λάμπη, το έσβησα και το πέρασα πάλι και τώρα είναι κομπλέ.
  13. Τελευταίες μέρες όταν πάω να γράψω σε κάποιο post και θέλω να βάλω χρώμα στην γραμματοσειρά, μου ανοίγει το πλαίσιο χωρίς να έχω την δυνατότητα να επιλέξω χρώμα. Αντίστοιχα σήμερα το ίδιο συμβαίνει και με την επιλογή του μέγεθους της γραμματοσειράς. *αν έχει ειπωθεί πάλι μην πυροβολήσετε
  14. AMD Is Negotiating A 7th Amendment To The WSA (Wafer Supply Agreement) AMD accelerates 7nm process adoption AMD 7nm Vega 20 will support XGMI bus crossfire On the next generation Vega 20 core, the dual-card Cross Fire will change again to support the new XGMI point-to-point high-speed interconnect. The bus is similar to NVIDIA NVLink. The AMD XGMI bus is derived from the large-scale Infinity Fabric high-speed channel currently used in the Ryzen, ECYC, and Vega architectures. It has proven to be excellent in bandwidth and delay performance. It is also a good choice for supporting dual-card or multi-card interconnection. . Now that XGMI and Vega 20 have appeared in the Linux driver of AMD graphics cards, the news has been taken. According to the previous statement, Vega 20 will also support PCI-E 4.0 bus, because it is mainly for high-performance computing, deep learning and other professional fields, and can be combined with the next-generation EPYC server platform that also supports PCI-E 4.0 bus, providing powerful B. The Vega 20 core will be manufactured in TSMC's 7nm process and will be used in the Radeon Pro and Radeon Instinct professional product lines, which can be paired with 32GB HBM2. As for whether it will be used for game cards, it is still uncertain, and gamers will have to wait for the next generation of new architecture Navi. AMD to fab all 7nm chips at TSMC
  15. idonthave
    καλημέρες https://www.facebook.com/TheLateShiftwithNickGulliver/videos/770677713127561/
  16. idonthave
    NVIDIA VP & CFO: Turing Is One of Our Largest Architectural Leaps, Performance Improvement Is Much Greater Than the Overall Price ________ ________ Εκτός απροόπτου αν ισχύουν οι (μικρές) διαφορές μεταξύ 1080ti - 2080 σε μη rtx επιδόσεις, πάω κι εγώ για 1080ti, Τσουρέκια μέχρι να βγουν τα reviews, σενάριο κάτι σαν το παπατρέχα (vega) θα γίνει , περίμενε περίμενε .... για τώρα όμως
  17. idonthave
    [ AMD RyZen+ 12nm & X470 motherboards ] τον Απρίλιο
    ας πέσουμε στα απ'τα 5ghz στα 3,2ghz AMD Athlon Now Features Zen Cores – $55 US Athlon 200GE Announced, A Dual Core, 35W CPU With Vega 3 Graphics For Entry Level PCs
  18. idonthave
    Νέα σειρά οικονομικών SSDs από την Crucial
    άλλαξαν κι αυτό το ασημί χρώμα (επιτέλους προσωπικό γούστο) τιμούλες σε € https://geizhals.eu/?fs=bx500&in=
  19. idonthave
    it's a shield (το γράφει στην εικόνα), πήγαινε στο κάτω μέρος επέλεξε με τα 3 fan και διαμόρφωσε την https://www.evga.com/articles/01249/evga-geforce-rtx-20-series/ christmas is here
  20. idonthave
    mini itx είναι, κομπλέ "τουμπανιάρικη" π.χ. διάφορες mini itx
  21. idonthave
    https://videocardz.com/newz/asus-rog-strix-z390-i-and-prime-z390-a-motherboards-leaked
  22. idonthave
    θα πέσουν τα πρώτα χιόνια κι ακόμη δεν θα μας έχουν δώσει τα ακριβή specs asus (κλασική προτίμηση από εμένα) msi duke και evga ftw3 η trio θα έχει δυνατά specs αλλά συνδυάζει christmas tree με ufo
