Everything posted by liakjim
Simulation Assetto Corsa tips and tricks
liakjim απάντησε στο θέμα του liakjim topic στην ενότητα Assetto Corsa
Γενικά πιάστε τη συζήτηση από την αρχή. Έχει πολύ ζουμί : http://www.assettocorsa.net/forum/index.php?posts/857708 Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Ενδιαφέρον ποστ του Αριστοτέλη για την πίεση των ελαστικών : Sadly? Obviously this is not your fault, I'm not pointing a finger to you in any case and thank you for coming in the pits to get more knowledge. Nevertheless, this the result of the "damage" that some uninformed and bad intended "websites" and forum "experts" are doing, while trying to get the clicks... So let me ask you that. You'll certainly have heard in all the real races, either in GT or single seater, or prototype, even F1 categories... Drivers complain about grip. Engineers say they had to compromise on tyre pressures to get heat up and setups to work, tyre manufacturers complaining about drivers and engineers keeping the pressures too low or too high and having excess wear and so on. It turns out that real tyres DO have an optimum tyre pressure for best grip/wear/heat. Guess what? AC simulates this (as well as practically every other sim around). Now, some "smart guys" thought that by opening AC physics and looking at the tyres.ini files, they found the magic number of the optimum tyre pressure and then do an article on it to show "the truth" and how smart and wise they are and how lame AC is. They found an optimum tyre pressure number and thought "that's it, that is were we have to always stay, AC is scripted". Luckily for us and all the people that try and drive AC in depth, this is only just half the truth. There is an optimum pressure as in any real life tyre, but then there's a ton of compromises you have to do and more often than not, the optimum pressure is not at that "magic number" but rather in a range around it. Will you go for a slightly less pressure to get the tyres heat up more to the correct temperature? But you're gonna lose some precision in handling and probably gain some traction and/or braking. Will you go for more pressure to cool tyres a bit and have more precision in handling but probably less grip all around but also higher top speed? So as you can see, yes it's good to be on the optimum pressure. Should you do it? Not really, it's a compromise and you should work around it, find the optimum range and what suits you and your driving style better. As @Berniyh very well said, tyre app is your friend. Get on your car, open the tyre app, do some laps and watch what happens in the tyre app. Adjust your cold pressures trying to bring your hot pressures close to a green colour. Same for tyre temps. The tyre app is all you need, just do 3-4 laps, look at it, go back to the pits, adjust and repeat. Finally, keep in mind that street cars start with their tyre cold pressures much higher as designed by the car manufacturer. This happens because in that way, while the car travels on normal streets, the tyres are closer to their optimum pressure and thus give optimum grip for normal street driving. So the FIRST thing you have to do on road cars, is immediately lower your cold pressures. Hope this helps, have fun. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
WAMTA Season 2 Race #5 - Silverstone GP - 26/3/2017
liakjim απάντησε στο θέμα του akis_z80 topic στην ενότητα Assetto Corsa
Για αυτό μας ζαλίζεις τα @@ πριν από κάθε αγώνα με το τί λάστιχα να βάλεις [emoji39] Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Οκ , με μπέρδεψε η επιλογή του προσώπου που έκανες ( 2ο ενικό ). Νόμιζα ότι αναφέρθηκες σε δική σου εμπειρία. Προσωπικά είμαι υπέρ του να μπαίνει, εκεί που υπάρχει και στην πραγματικότητα. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Άστον μωρέ τον αμπαλο...[emoji39] Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Πιο πάνω διαχώρισες δύο περιπτώσεις όπου με on δεν σε άφηνε ενώ με off σε άφηνε. Τί εννοείς? Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Μήτσο το σύστημα είναι hardcoded στο εκάστοτε αμάξι και ΔΕΝ μπορεί να απενεργοποιηθεί. Το μόνο που βγαίνει είναι η ένδειξη , που μπήκε στο 1.13 γιατί οι νουμπαδες σπάγανε τις μπάλες στους devs ότι το παιχνίδι είχε πρόβλημα και δεν τους κατέβαζε ταχύτητα... Πάμε τώρα στο "πρόβλημα" . Το έβαλα σε εισαγωγικά γιατί ίσως να παίζει ανθρώπινος παράγοντας Ναι εσύ [emoji39] Πιθανότητες : 1. Bug του αυτοκινήτου . Δεν νομίζω γιατί δεν το είχε άλλος . 2. Στιγμιαίο bug/κόλλημα. Δεν νομίζω γιατί πώς έφτιαξε μόνο του? 3. Φθορά του hardware. Μάλλον όχι αλλιώς δεν θα σου έβγαινε το μήνυμα 4. Εσύ. Ίσως να παρεξήγησες την λειτουργία της ένδειξης και να κόλλησε ο εγκέφαλός σου σε αυτό ή έμπαινες πολύ στους κοφτες. Μάλιστα το γεγονός ότι λες ότι μπορούσες να το κάνεις off ή ON , που δεν μπορείς το παιχνίδι δεν σε αφήνει, ισχυροποιεί την υποψία μου. Ψηφίσω το 4. ΥΓ χθες δοκίμασα το αμάξι και δεν είδα πρόβλημα. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Yes please. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Για δοκιμάστε να κατεβάσετε το stream με αυτό http://www.clipconverter.cc/gr/ -
Ψιλό μέτριος αγώνας. Αποφάσισα να κάνω 25γύρους με mediums και 15 με softs. Στα ντουμπλαρίσματα δεν ήμουν τυχερός, ένιωθα πως πάντα πετύχαινα αμάξια σε στροφές κ έχανα 2-3 δευρ στον γύρο + το παραπάνω βάρος, μου έκανα ένα +27 από τον χορό των pit stops. Τελικά τα λάστιχα δεν πολύ άντεξαν και είχα 97% στον 25ο γύρο. Με πέρασε κ ο @Thodoris1884 ο οποίος μάλλον είχε κάποια ατυχία και μπήκε πιο νωρίς. Όταν επιτέλους έβαλα τα softs , ήμουν στα +33 από Θοδωρή. Με τα softs πήγα αέρα και κατάφερα και τον έφτασα στα +7, ρίχνοντάς του 3 δευτ στον γύρο! Αχ να είχα ακόμα 2,3 γυράκια... Συγχαρητήρια στους (προσωρινούς) νικητές (να δούμε τα cuts που θα έχουμε άπειρα)... -
https://www.twitch.tv/videos/131375833 http://simresults.net/170326-HD3 -
Κάνε με κλικ -
Λοιπόν παρατήρησα ότι ακριβώς εκεί που μετράει το pit entry , ο τοίχος δεξιά έχει ένα κόκκινο κενό στις διαφημίσεις. Φαίνεται καθαρά και στο video που ανέβασα. Δεν ξέρω αν είναι εκεί τυχαία ή επί τούτου αλλά μπορείτε να το χρησιμοποιήσετε ως σημάδι. Η γραμμή ξεκινά αμέσως στο τέλος του κόκκινου. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Άντε να το πετύχεις σωστά. 3 φορές μπήκα, 3 φορές πάνω από 80... Μεγάλη μ@λακια... Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Ποιός είναι ο testing testing? Alien-ίζει μου φαίνεται... -
Τί λες ρε γιουχου ? [emoji28] Το app της kunos είναι σαφώς ανώτερο και πιο χρηστικό. 1. Μπορείς να ρυθμίσεις από σεταπ. 2. Μπορείς να ρυθμίσεις στα πιτς. 3. Μπορείς να ρυθμίσεις πανεύκολα χωρίς ποντίκι ενώ οδηγείς, είτε με βελάκια είτε επιτέλους με το dpad. 4. Μπορείς να ρυθμίσεις πιέσεις ελαστικών που το pitconfig δεν είχε άρα πλέον έχει νόημα να έχεις στρατηγική 2 γομών. Σβήσε το pitconfig όπως όλοι. Ο δημιουργός του app το έκανε discontinued. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk Γιώργο εδώ εννοείς το aclr pit? Δεν δουλεύει κανονικά τουλάχιστον σε εμένα κ σε αυτή τη πίστα. Μετράει την ταχύτητα πολύ πριν την γραμμή. Έχει δοκιμάσει άλλος? Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk -
Σβήστο. Το KUNOS app δουλεύει άψογα. Αυτό που με μπερδεύει είναι το ACLR pit app. Μετράει πολύ πριν τη γραμμή. @Stelios F. @akis_z80 για δείτε το λίγο. Προσέξτε που είναι η γραμμή και που κάνει register το app. Υ.Γ. Το cutting θα πέσει σύννεφο. -
Αγχώθηκα τώρα , πάω για practice , είμαι απελπιστικά αργός... -
Σκούρα τα πράγματα, απαιτητική πίστα... -
Mazda 787
Ναι αλλά το ένα είναι φετινό μοντέλο ενώ τα άλλα παλιότερα. Εξέλιξη. -
Δεν είμαστε και πολύ εκτός θέματος μιας και το παιδί ενδιαφέρεται για pc μόνο για Assetto. Έτσι κ αλλιώς δεν έχω κάτι άλλο να συμπληρώσω.
Πάντως με το pc της υπογραφής, δλδ με μικρό επεξεργαστή i5 και την 470 των 200€, παίζω σχεδόν όλα full ( εκτός από reflections που το έχω σε low ), σε ανάλυση 1440p και έχω πάντα 60fps . Ειλικρινά πάντως, θα έλεγα να δεις τους μικρούς ryzen σαν πιο future proof λύση. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
Ryzen 1600, nvidia 1060 ή AMD 480 , 8GB ram , SSD, 27αρα οθόνη και μεταχειρισμένη G27 . Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
http://www.assettocorsa.net/forum/index.php?threads/44000/ Most of the options are self explanatory but since there are many questions about the app being asked and answered all over the forum in various threads, I thought it would be nice to get a separate thread for that. First things first. Where to find it? Search for "pitstop.ini" file in: Steam/steamapps/common/assettocorsa/system/cfg Remember to make a backup of the original file before changing it You don't have to do it if you are using JSGME for mods. If you'd like to use JSGME, but don't know how, check out this thread: http://www.assettocorsa.net/forum/index.php?threads/how-to-install-mods-guide-using-jsgme.13828/ OK let's start, there are spoilers with screenshots under some of the options. Here's how all the values look by default: [sETTINGS]USE_MOUSE_PITSTOP=0VISIBILITY_MAX_TIME=5ITEM_FONT_SCALE=1STAY_IN_CAR=0AUTO_APP_ON_PITLANE=1PRESETS_COUNT=3SIZE_MULT=1.2FONT_IS_BOLD=0HEADER_FONT=9HEADER_HEIGHT=16OBJECT_POS_X=80OBJECT_POS_Y=0FORM_ALIGNMENT_V=1FORM_ALIGNMENT_H=2ITEM_HEIGHT=20ITEM_TITLE_WIDTH=130ITEM_VALUE_WIDTH=80ITEM_FOREGROUND_HEADER=0,0,0,1ITEM_BACKGROUND_HEADER=1,1,1,1ITEM_FOREGROUND_UNSELECTED=1,1,1,1ITEM_BACKGROUND_UNSELECTED=0,0,0,0.5ITEM_FOREGROUND_SELECTED=1,1,1,1ITEM_BACKGROUND_SELECTED=0.74,0,0,1 Now what does the each one do. USE_MOUSE_PITSTOP=0 "=0" means that the app is active and you can control it with D-Pad and keyboard arrows. "=1" turns off the app. D-Pad and keyboard arrows won't make the pit menu appear. You have to use mouse when stopping in the pit, just like before the 1.13 update. VISIBILITY_MAX_TIME=5 Controls for how long (in seconds) the app will be visible after your latest input. ITEM_FONT_SCALE=1 It seems like it doesn't do anything. I guess it should change the font size of everything outside of headers. STAY_IN_CAR=0 I believe it (should) controls the camera. "=0" will change the cam to the outside view during the pitstop. "=1" cam will stay in cockpit. At the moment it stays in the cockpit in both variants, but pitcrew is on holidays since the 1.13 update, so maybe it's related somehow. AUTO_APP_ON_PITLANE=1 Set to "1" turns the app on for the whole time you are in the pitlane. Set to "0" leaves the app hidden while driving in the pitlane PRESETS_COUNT=3 You can add or lower the number of presets by changing that value. SIZE_MULT=1.2 If you feel like the app is too small/too big, play with that number. You can change it below ="1.0" FONT_IS_BOLD=0 "=0" "=1" HEADER_FONT=9 Changes the font size of the text in headers. HEADER_HEIGHT=16 Changes the header height. OBJECT_POS_X=80 Controls the position of the app on the X axis (horizontal). OBJECT_POS_Y=0 Controls the position of the app on the Y axis (vertical). FORM_ALIGNMENT_V=1 "=1" - vertical movement of the app is disabled. It's fixed at the centre of the axis. "=2" - vertical movement of the app is enabled. FORM_ALIGNMENT_H=2 "=1" - horizontal movement of the app is disabled. It's fixed at the centre of the axis. "=2" - horizontal movement of the app is enabled. ITEM_HEIGHT=20 Changes the pit menu height. ITEM_TITLE_WIDTH=130 Changes the title width - left side. ITEM_VALUE_WIDTH=80 Changes the value width - right side. Now colours. It's in RGBA - Red, Green, Blue, Alpha. You can use decimal numbers from the range of 0-1. Alpha controls the transparency. I'll stop with descriptions now, since they would be pretty much the same as what you see in the code. Just look at the screens and you will know what has changed. ITEM_FOREGROUND_HEADER=0,0,0,1 "=1,0,0,1" on my screen. ITEM_BACKGROUND_HEADER=1,1,1,1 "=0,1,0,1" on my screen. ITEM_FOREGROUND_UNSELECTED=1,1,1,1 "=0,1,0,1" on my screen. ITEM_BACKGROUND_UNSELECTED=0,0,0,0.5 "=0,0,1,1" on my screen. You can see here how Alpha controls the transparency that is at 0.5 by default and at 1 in my screen. ITEM_FOREGROUND_SELECTED=1,1,1,1 "=1,1,0,1" on my screen. ITEM_BACKGROUND_SELECTED=0.74,0,0,1 "=1,0.5,0,1" on my screen. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
