Everything posted by liakjim
Simulation Assetto Corsa Multiplayer Racing [Greek Gatherings]
liakjim απάντησε στο θέμα του akis_z80 topic στην ενότητα Assetto Corsa
Αν και αρκετά sloppy ο γύρος, έσπασε κ το 1:44 -
Finger crossed : http://www.assettocorsa.net/forum/index.php?threads/game-progress.18152/page-10#post-329341 We found a bug related ALSO to Fmod that might be related to what Matthew and someone else is reporting too, we already solved it in our beta branch and the issue didn't come anymore. FPS drops, audio crackling, multiplayer stuttering is NOT related to a single bug in the dev path, but many aspects are involved. As reported many times, we always thank you for your support and your help, but "I have the same issue" or "it's unplayable!" messages without attached logs means really nothing. I want to underline this point because we know that 99% of the users here are not devs and of course they don't know how the development or bug reporting works. We really respect them and we often understand their "complains", but we ask the same respect because we're working non-stop (14-18h day is quite the standard for us) to solve issues, improve the product and give you a more enjoyable experience (and a faster/better support of course). Read things like "throw fmod away!" or similar is just.... pointless and sad, moreover it denotes zero know-how about development and, most important, lack of respect for the whole team. That said, we're testing with betatesters together with other bug fixes and improvements about phyiscs, ffb and so on. When the devs consider the update is ready, then will be released. -
Προσωπικά δεν μπορώ να παίξω με vsync off. Το tearing είναι απίστευτα εκνευριστικό. -
@Aris Teidis , ζητώ συγγνώμη για την επαφή. Από μέσα φάνηκε πως είχα χώρο. -
Πολύ πιο σταθερή η Mclaren στις στροφές. Και στα φρένα. -
Άκη το setup που έχεις στο teamspeak για την Mclaren θέλει αντικατάσταση. Δεν τηρεί το ελάχιστο ύψος. -
Είμαι σίγουρος ότι από μέσα θα είσαι πιο γρήγορος. -
Εσύ αν από το καπό πας μέσα , μπορεί να κάνεις κι WR... τώρα πόσο είσαι ? (ποιό το nick name στο RSR?) Πρέπει να βάλεις το σωστό :http://www.projectimmersion.com/fov/index.php?m=1 Και στις επιλογές , βάζεις το pCars(hFov) και προφανώς τις ίντσες και την απόστασή σου από την/τις οθόνη/ες. -
Εγώ ξέρω ότι με αλλαγή στο FOV έπεσα 2 δευτ (και μπορώ κ άλλο) σε μια πίστα που την τρέξει άπειρες φορές και με ένα αμάξι που το ξέρω καλά με το ίδιο setup. Για κοιτάξτε λίγο λοιποί το FOV σας (ειδικά ο Κυριάκος με το 60) -
Το τροφοδοτικό ήρθε, η τιμονιέρα δούλεψε, το 1:45 έσπασε http://www.radiators-champ.com/RSRLiveTiming/index.php?page=laptime_improvement&trackId=2&carId=60&driverId=1956 http://www.radiators-champ.com/RSRLiveTiming/index.php?page=rank&car=60&track=2&p=&nationality=Greece 0,001δευτ πίσω από τον alien. Έχω και άλλο ένα 0,5δευτ σίγουρα. Θα γίνει σφαγή απόψε (αν με αφήσει το bug με το FMOD). -
Simracing Gear! Καρέκλες, τραπέζα, τιμόνια εχωωω
liakjim απάντησε στο θέμα του fatalara topic στην ενότητα Λοιπά Περιφερειακά
Το τροφοδοτικό ήρθε!!! Σε χρόνο ρεκόρ μαλιστα μιας κ η παραγγελία έγινε στις 6/12. Το παλιό Παρόλο που έλεγε 96W , αποδείχτηκε σάπιο. Το καινούργιο : Πλάι , πλάι Εγκατεστημένο (τούμπα μην πέσουν τίποτα νερά) Φυσικά δουλεύει άριστα. -
Μήπως έχει να κάνει με το γνωστό θέμα με το δαχτυλίδι ; Ρωτά τον Κώστα με πμ -
Δεν ξέρω αν έχει αναφερθεί ξανά εδώ μέσα και χωρίς να θέλω να καθοδηγήσω τις επιλογές αλλά μια πίστα που σίγουρα αξίζει της προσοχής μας και σας συνιστώ να την δοκιμάσετε (εγώ κόλλησα), είναι αυτή http://www.assettocorsa.net/forum/index.php?threads/castle-hill-1-0-released.13222/ -
Έτσι μ@ρή τρέλα!!! Το skin όλα τα λεφτά!!! Και η πινακίδα : DJK. χαχαχαχα -
Πωπω Άκη, βλέποντας το video αντιλαμβάνομαι πόσο τραγικά αργός είμαι. Εκεί που πατάς ήδη το γκάζι και βγαίνεις τερμα , εγώ ακόμα φρενάρω... Πάω για μελέτη!!! -
Χρήστο τεράστια βελτίωση. Όπως είδα τον γύρο σου, ασυμπτωτικά είσαι για 1:43:500. Το 1:42 δύσκολο. Μόνο17 άνθρωποι έσπασαν το φράγμα και μόνο 5 το 1:41. Φυσικά τίποτα δεν είναι ακατόρθωτο. Το ~1:44:500 είναι όμως πολύ καλός χρόνος αν δεις στην κατανομή που είσαι : -
Γιατί? Λόγω απογοήτευσης? Έλα ρε γιατί? Πάντως όλοι μας έχουμε βελτιωθεί χάρη σε εσένα και τον Άκη. Μας δώσατε setup, μας δώσατε video με τις γραμμές που μελετήσαμε καθώς και έναν (άπιαστο) στόχο. -
http://www.radiators-champ.com/RSRLiveTiming/index.php?page=laptime_improvement&trackId=2&carId=45&driverId=611 -
Βρήκα Κυριάκο και Άρη και είχαμε έναν αγώνα για χαβαλέ. Α και παρεμπιπτόντως , FOV από 34 σε 27 = 1:45:583 , πάντα με gamepad. http://www.radiators-champ.com/RSRLiveTiming/index.php?page=laptime_improvement&trackId=2&carId=60&driverId=1956 Και είχα και γύρο με 1 δευτ κάτω αλλά το έχασα στην τελευταία φουρκέτα. Ελα τροφοδοτικούλι... -
Τελικά την SLS θα την βάλουμε ???? -
Μπράβο!!! Δεν είμαι αρμόδιος να σε διορθώσω αλλά νομίζω ότι ο τρόπος οδήγησής σου είναι λίγο άτσαλος. Γρήγορος μεν. Με λίγο πιο προσεκτικές γραμμές και πιο απέρριτο στυλ, σίγουρα θα κατεβάσεις 1.5 δευτ. Επίσης τί FOV έχεις? Και γιατί οδηγάς σαν την μάνα μου? (κολλητά στο παρμπρίζ??) χαχαχαχα -
Οκ έτσι όπως τρώει τα λάστιχα η SLS θα ισορροπήσει το πράγμα. -
Παιδια την Mercedes SLS GT3 γιατί δεν την βάζουμε στο combo? Ο @newlynx έχει τον 1ο λόγο. -
Μέχρι πολύ πρόσφατα, έτρεχα με FOV 48. Όμως είμαι σε 47'' οθόνη , σε 2m από τα μάτια μου (τηλεόραση + σαλόνι). Έβαλα λοιπόν το FOV στο 34 και αμέσως βελτιωσα τους χρόνους μου. Στο RHM δεν άλλαξα κάτι , έχω "σηκώσει" τις ρυθμίσεις εδώ http://www.thelab.gr/topic/118904-assetto-corsa/page-80#entry2099455 -
Με το καινούργιο FOV , έσπασα τον χρόνο που είχα με την G27 αλλά τρέχοντας με το XBox 360 controller !!! http://www.radiators-champ.com/RSRLiveTiming/index.php?page=laptime_improvement&trackId=2&carId=60&driverId=1956
