Σχετικά με το damping και ειδικότερα αυτές τις τιμές :
DAMPER_MIN_LEVEL=0.0 DAMPER_GAIN=1.0 ; Set to 0 for Logitech g920 [LOW_SPEED_FF] SPEED_KMH=3 ; Under this speed the reduction will start MIN_VALUE=0.01 ; The FF multiplier for 0kmh.
Let's start with the Damper. This is a DX effect that tends to slow down the wheel rotation.. the faster the wheel is rotating the more opposite force is added. The implementation is left to the driver/hardware.. so there isn't much control over it. In AC it is currently used to simulate the "stiff" wheel when the car is not moving. DAMPER_GAIN sets how strong this damper effect is... the reason it is there is because some wheel (that will go unnamed ) screw up the damper implementation and vibrate like crazy when the car is not moving.. so I had to had this value to allow to turn the damper off, or reduce the effect. DAMPER_MIN_LEVEL is the amount of damper that is left on while driving. In other words, as the car is speeding up the amount of damper goes from DAMPER_GAIN to DAMPER_MIN_LEVEL. The reason why it is here is because some wheels are mechanically very "loose" and smooth and some users missed the old "FF DAMP" value that we had in AC in previous versions. The LOW_SPEED_FF stuff is totally unrelated. It kills the forces coming from the tyres at low speed to avoid unnatural vibration when the car is about to stop or starting.. because it works at super low speed (3kmh by default) I really don't see any reason to mess up with this one at all.
link
Τα είχα καταλάβει λάθος .
Τα έβαλα
DAMPER_MIN_LEVEL=0.1 DAMPER_GAIN=0.4 ;
και βλέπουμε.
