Everything posted by liakjim
[Greek Gatherings 20-3-2016] Imola - Nissan GTR GT3
liakjim απάντησε στο θέμα του fuz10n topic στην ενότητα Assetto Corsa
Έτσι, άντε να ξυπνάμε.... -
A new EARLY ACCESS build of AMS (v.0.8.6r) has been deployed now on Steam. Below are the release notes & main changelog (please make sure to check for some important information regarding the new build): V0.8.6r Improved support for Windows User Account Control - now all user-generated files should be stored in MyDocs\Automobilista folder. Users with UAC on will be prompted to create a new profile (if you disable UAC or run as admin however it will still use game folder) Added option to select PLAYER LEVEL after new profile creation (can be changed later from the difficulty menu) - CASUAL / ADVANCED / HARDCORE: depending on level selected, the default settings will be customized accordingly for various Difficulty / Controls / Display options Several new UI improvements & adjustments + version number added to bottom right corner of main menu Further adjusted tire scrub volume calculation, default settings & added Tire Volume Slider to the AUDIO menu Some DynHUD improvements for better stability (& pedal cursors now optional from the editor) Fixed bug with vehicle labels not working Fixed bug with FFB level selection sometimes not sticking Added a FFB Reset function whenever a session is (re)started (to try prevent issues with users occasionally losing FFB) Implemented advanced transmission code for all cars with dog-type sequential boxes (Marcas, SuperV8, MR18, Lancer RS, Shifter and Superkart) now featuring ignition cut-off (AKA powershift) in upshifts; if engine / drivetrain RPM mismatch is too great, gear change is not accepted Downshift protection also added to prevent engine over-revving in semi-auto boxes; (ζήλιες) Added option for manual gear shift override in cars with autoshift electronic aids (such as F-V10 & Camaro SS) Adjusted flatspotting range (slightly more sensitive than previous version) Fixed bug with Mini autoshift driving aid not working correctly Removed launch control being left mistakenly enabled in F3 & Supertruck Tweaked fast line at chicane in second half of lap of Salvador to minimize cars rolling Fixed foggy cockpit windshield in Lancer RS Fixed bug with Renault Fluence LOD in night lighting Various AI adjustments to generally improve their behavior & performance Added a few missing helmet skins + corrected alpha channels for another lot of them Fixed digital LCDs not working in Indian Momentum F-Extreme cars
Ok, τι να κάνω, την ξέρω την τύχη μου. Για να χαρεί για την γιορτή του, λέω αύριο να τον αφήσουμε να κερδίσει... -
Simulation Assetto Corsa Multiplayer Racing [Greek Gatherings]
liakjim απάντησε στο θέμα του akis_z80 topic στην ενότητα Assetto Corsa
Σωστά!!!! Πολύχρονος!!!! -
Αγαπώ Imola και Nissan GT3. Αλλά τί έγινε ρε παιδιά? Γιατί τόσος λίγος κόσμος? Υ.Γ. Δοκιμάστε το Nissan με αυτό το mod. Το έχω ξανα πεί. Είναι απλά φοβερό. -
Μοιάζει με κάτι τέτοιο
Οι οδηγικές σου αρετές, συμβαδίζουν με αυτές του... admin....έναν αγώνα δεν αξιώθηκα να τρέξω χε χε χε @panosdimp, τι είδες από τους 12 γύρους?
Off topic : Για τον φίλο @rapid_fast, που εντυπωσιάστηκε τα μάλα από το FFB του rF2 , δες εδώ ρυθμίσεις για G25/27 που θα σου δώσει σχεδόν (ένα 95%), το ίδιο feeling.
Simulation Assetto Corsa-Mods-Downloads etc.
liakjim απάντησε στο θέμα του GeoF1 topic στην ενότητα Assetto Corsa
Επιτέλους , update σε ένα από τα καλύτερα mod του Assetto. Οδηγήστε το και θα καταλάβετε!!!! -
Στο rF2 είναι αρκετά καλά. Στο AC θέλει πληρωμή. -
Ψήνεται. Νομίζω θα κλάψω όταν το οδηγήσω, ούτε θυμάμαι πόσες αφίσες είχα με δαύτο στο δωμάτιό μου . Για μένα το Νο1 αμάξι όλων των εποχών. Ναι αυτά είναι renders... Lancia Delta S4 Gr.B 1985 ..in development.. -
Μούφα είναι.
Κάτσε να βγει πρώτα.
Simulation Assetto Corsa tips and tricks
liakjim απάντησε στο θέμα του liakjim topic στην ενότητα Assetto Corsa
Νομίζω καλύτερα εδώ AC Dynamic Track Calculator 2.0 (για τους φίλους μας τους admins) -
Ιάσονα, αυτό http://www.racedepartment.com/downloads/cutters.5238/ ???? Αυτό μου φαίνεται καλύτερο : http://www.assettocorsa.net/forum/index.php?threads/a-pit-lane-penalty-app-for-repeated-track-cutting-1-8.17852 Here is an app that gives you up to 3 warnings if you cut the track, and then on the 4th infringement, issues either a drive through pit lane penalty, which is then cleared when you drive through pit lane, or adds 10 seconds to your race finish time at the end of the race (which the server admin has to do when compiling race results). . . . There is a setting in PLP.ini so that you can turn off pit lane drive through or time penalties, and only have warnings issued (and written to the server log). This allows an admin to issue other track cutting penalties after the race by checking the server log. Άρα από ότι καταλαβαίνω, όταν το βάλουν όλοι, απλά στο τέλος θα έχεις το log που ψάχνεις!!!
Μπράβο Ιάσονα, χαρά στο κουράγιο σου. Ερώτηση, το stracker δεν μπορεί να το κάνει αυτό , αυτόματα, πχ να δημιουργεί ένα log αρχείο με τον κανόνα που έχεις θέσει πχ (4 wheels) κ να λέει "ο τάδε, τόσα cuts". Μετά απλά ποστάρεις το αρχείο κ άμεσα τις ποινές. Γίνεται?
Μια πολύ ωραία συζήτηση για τα αμορτισέρ. Κάποια τα είχα καταλάβει εντελώς ανάποδα. (πχ ότι τα πιο σκληρά αμορτισέρ, επιταχύνουν την μεταφορά βάρους). Επίσης ρίξτε μια ματιά και εδώ. Shock Absorber Tuning - Our Model for Tuning for Balance with Shocks. και Neil Roberts Article on Shock Tuning -
Interview: Black Delta Studios - Developer of the Upcoming KartKraft
link
Tango X 1st League [Πληροφορίες & επιλογή αυτοκινήτου]
liakjim απάντησε στο θέμα του racer topic στην ενότητα Assetto Corsa
Δεν θα μπορέσω να τρέξω σήμερα.
