liakjim
    7.703
  • Ημέρες που κέρδισε
    7
Everything posted by liakjim
  1. liakjim
    rFactor 2
    Βασικά έχεις δίκιο. Απλά μετά το φορμάτ σε 10άρια δεν το πέρασα ποτέ. Οπότε τεχνικά, δεν το ξανα εγκατέστησα. Πρακτικά το έχω σβήσει. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
  2. liakjim
    rFactor 2
    Ευτυχώς που το έχω απεγκαταστήσει δλδ. Ουφ.
  3. liakjim
    Automobilista
    Φαίνεται δυνατό update, ίσως να το ξανα εγκαταστήσω Automobilista EA v0.9.8 RELEASED Reiza Studios have just released the latest build for Automobilista bringing the game to version 0.9.8. The latest update contains new force feedback properties and a new karting track along with a host of bug fixes and optimisations. Content: Added Speedland Kart track venue (4 layouts) Features & Fixes: Enhanced pneumatic trail by adding new PneumaticTrailGripFractPower (PTGFP) function, for much improved self-aligning torque (should make tire forces more perceivable through FFB) Tweaked FFB output code & added "FFB Low Force Boost" to Controller UI (this should help wheel "lightness" under low steering forces with lower end FFB controllers) Added new low speed FFB fuction to eliminate vibration / oscillation at very slow speeds Revised default Realfeel settings and pneumatic trail values to match to new FFB functions Added AIWs to Time Trial anticheat verification (this will lead to failed authentication in case of AIW edits) Added function to sort cars of different performances within the same series for the TT leaderboards Tweaked road dust smoke & skid properties Brasilia: Tweaked track limits to allow running over green crete run-off VIR: Improved road & curb textures Superkart: Adjusted tires, slight increase of front/rear track width Karts: Adjusted tires Montana: Adjusted mirror height; Fixed oversized interior Windshield resolution (from 2048px to 1024px) Boxer: Added wiper to cockpit view; Corrected AI tire wear Lancer Cup: Fixed pneumatic trail bug which numbed FFB output
  4. liakjim
    [Greek Gatherings 22-7-16] Aventador SV@Red Bull Ring
    Πλέον η λευκή σημαία , βγαίνει ανάλογα με τον πρωτοπόρο. Όταν ο πρώτος μπει στον τελευταίο γύρο, θα ανάψει για όλους. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
  5. liakjim
    Θα το πιάσεις. Βέβαια σημασία έχει η σταθερότητα στον αγώνα, όπως λέει και ένα σοφό ?. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
  6. liakjim
    Τουλάχιστον τα βρήκες. Κάτσε θα τα βρω και εγώ κάποια στιγμή. Μας βλέπω στα χιλιοστά.
  7. liakjim
    Αν δεις τα sectors , αν τα βρεις θα είσαι κοντά στο 1 σμπάρο, 2 τρυγόνια. Αααααααα, προσοχή στην εκκίνηση. Το clutch δεν δουλεύει. Έφαγα teleport στα pits. Επίσης το ptracker δεν δείχνει τους γύρους και την κατάταξη σωστά.
  8. liakjim
    Εύκολο. Σου άφησα για να βρεις, 4 δέκατα στην προτελευταία στροφή που έφυγα ευθεία.
  9. liakjim
    [Greek Gatherings 15-7-2016]McLaren Honda MP4/4 @ Brands Hatch GP
    Πολύ ωραίες μάχες, μπράβο κ στους 2.
  10. liakjim
    Δεν μπορώ να πω ότι μου αρέσει πάντως.
  11. liakjim
    Περίεργο αμάξι. Θέλει φρένα νωρίς, καλή έξοδο χωρίς drift. Ο Θοδωρής δεν έχει ελπίδα στον αγώνα, Σε 10 γύρους θα τρέχει με τις ζάντες.
  12. liakjim
    Θα γράψει κάποιος την κατάταξη? Ποιος κέρδισε?
  13. liakjim
    Μπαίνω για δοκιμές.
  14. liakjim
    Assetto Corsa-Mods-Downloads etc.
    Ναι , 18/7 είπανε. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
  15. liakjim
    Assetto Corsa
    Και έχει μακρύ καπό [emoji12] Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk Μου άρεσε που στην ευθεία κόλλησε από πίσω για να πάρει το slip streaming. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
  16. liakjim
    Assetto Corsa
    Φαντάσου! Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
  17. liakjim
    Assetto Corsa
    Τρέλανέ μας!!! Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk Το ΑΙ στο Assetto νομίζω χτυπάει πρωτιές. Σημαντική βελτίωση και πολύ καλή δουλειά του Στέφανου. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
  18. liakjim
    Assetto Corsa tips and tricks
    @panosdimp, εσύ μάλλον πρέπει να το οδηγήσεις στο asc_86.exe
  19. liakjim
    Οι ρυθμίσεις μου, απευθύνονται σε όλους , φυσικά αφορμή ο @rapid_fast. Αρχικά, logitech profiler : Global : Μετά φτιάχνουμε νέο profile και το κατευθύνουμε στο acs.exe (ΠΡΟΣΟΧΗ όχι στο AssettoCorsa,exe) Ρυθμίσεις : Και μετά στο παιχνίδι (αν ΔΕΝ κάνουμε το LUT , τότε minimum force =14%) Φυσικά δοκιμάστε τι σας βολεύει σε kerb, road, slip effects. Όταν τρέχουμε το παιχνίδι, το τρέχουμε από τον profiler
  20. liakjim
    Τέλειο!!!! Θα το τρέξω αύριο βράδυ. Παρασκευή δυστυχώς (ευτυχώς), θα λείπω.
  21. liakjim
  22. liakjim
    Οι ρυθμίσεις μου, απευθύνονται σε όλους , φυσικά αφορμή ο @rapid_fast. Αρχικά, logitech profiler : Global : Μετά φτιάχνουμε νέο profile και το κατευθύνουμε στο acs.exe (ΠΡΟΣΟΧΗ όχι στο AssettoCorsa.exe) Ρυθμίσεις : Και μετά στο παιχνίδι (αν ΔΕΝ κάνουμε το LUT , τότε minimum force =14%) Φυσικά δοκιμάστε τι σας βολεύει σε kerb, road, slip effects. Όταν τρέχουμε το παιχνίδι, το τρέχουμε από τον profiler @panosdimp εσύ πρέπει να το κατευθύνεις στο acs_86.exe μιας κ τρέχεις το 32bit. Αλλιώς δεν θα σου τα παίρνει σωστά ούτε τα κουμπιά.
  23. liakjim
    Assetto Corsa
    1.7.1 - Reverted HideApps command key (CTRL+H) - Fixed headlights auto-switch with foggy weather - Levante brake disks, damage zones and seatbelts fixed - F138 mirrors fixed - Fixed ChatApp issue when TIME_TO_LOSE_FOCUS was defined - Fixed a possible desync at multiplayer start - Fixed potential divide by zero in ERS - Tweaked skid sound pitch and volume for Maserati Levante - Finetuned crossfade at high rpms for Ferrari SF15-T - Shared Memory new members - SPageFileStatic - int hasDRS = 0; - int hasERS = 0; - int hasKERS = 0; - float kersMaxJ = 0; - int engineBrakeSettingsCount = 0; - int ersPowerControllerCount = 0; - SPageFilePhysics - float performanceMeter = 0; - int engineBrake = 0; - int ersRecoveryLevel = 0; - int ersPowerLevel = 0; - int ersHeatCharging = 0; - int ersIsCharging = 0; - float kersCurrentKJ = 0; - int drsAvailable = 0; - int drsEnabled = 0; - float brakeTemp[4]; - python new functions and members - added new members to getCarState (see acsys.py) - getCarEngineBrakeCount(carid) - getCarPowerControllerCount(carid) - Updated server plugin example to reflect protocol changes in ACSP_LAP_COMPLETED - Fixed autoclutch cars not starting if clutch pedal is pressed down
  24. liakjim
    Έχει κανείς την κατάταξη? Το ptracker δείχνει ότι να ναι. ΥΣ. Αναρωτιέμαι αν βάζαμε audio channels = 128 αν γλιτώναμε το χθεσινό φιάσκο. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
  25. liakjim
    Καθόλου παράλογο. Σε πραγματικό αγώνα, θα είχατε σκοτωθεί. Μη παρεξηγείς το πνεύμα του ποστ του Παναγιώτη. Κανείς δεν είπε ότι φταις εσύ. Απλά αν εκοβες λίγο μπορεί να τον απέφευγες. Θα προσπαθήσω να το τηρήσω. Στάλθηκε από το m2 note μου χρησιμοποιώντας Tapatalk
