Alexopus6
    2.057
Everything posted by Alexopus6
  1. Ακριβώς borg, αυτο ελεγα και στον dN το μόνο που αλλάξαμε ήταν η αναλύση σε 1920x1080.
  2. @dN έβαλα x4 επειδή πληροφορήθηκα απο τον borg οτι στο extreme έχει x4 και οχι x8 http://img33.imageshack.us/img33/7835/setbn.jpg
  3. This is the first driver release from the Release 256 family of drivers (versions 256.xx to 259.xx). This driver package supports GeForce 6, 7, 8, 9, 100, 200, 300, and 400-series desktop GPUs as well as ION desktop GPUs. Learn more about Release 256 drivers here. New in Version 257.15 Adds support for Blu-ray 3D with NVIDIA 3D Vision technology. Learn more about the hardware and software requirements here . Increases performance for GeForce GTX 400 Series GPUs in several PC games. The following are examples of some of the most significant improvements measured with GeForce GTX 480. Results will vary depending on your GPU and system configuration: Up to 14% in Aliens vs. Predator (1920x1200 noAA/AF – Tessellation on) Up to 4% in Batman: Arkham Asylum (1920x1200 4xAA/16xAF PhysX=High) Up to 5% in BattleForge (1920x1200 4xAA/16xAF – Very High settings) Up to 5% in Call of Duty: Modern Warfare 2 (1920x1200 4xAA/16xAF) Up to 4% in Crysis: Warhead (1920x1200 4xAA/16xAF – Enthusiast setting) Up to 24% in Enemy Territory: Quake Wars (1920x1200 no AA/AF) Up to 9% in Far Cry 2 (2560x1600 8xAA/16xAF) Up to 25% in Just Cause 2 (2560x1600 no AA/AF - Concrete Jungle) Up to 7% in Metro 2033 (1920x1200 no AA/16xAF – Tessellation on) Up to 40% in Metro 2033 with SLI ((1920x1200 4xAA/16xAF – Tessellation on) Up to 8% in S.T.A.L.K.E.R.: Call of Pripyat (1920x1200 no AA/AF – Day) Up to 110% in Stone Giant with SLI (2650x1600 – Tessellation on, DoF on) Up to 6% in The Chronicles of Riddick: Dark Athena (2560x1600 no AA/AF) Up to 9% in Unigine: Tropics (2560x1600 no AA/AF – OpenGL) Up to 5% in 3DMark Vantage (Performance and Extreme Presets) Up to 19% with Transparency AA (1920x1200 4xTrSS – measured in Crysis) @Borg, αν δεν ζευγαρωσεις την 480 asap σε βλεπω να έχεις πρόβλημα στο metro 2033
  4. αν εχεις κρατησει screenshot και δεν σου κανει κοπο βαλε και διπλα στα score gpu-z να έχουμε και εικόνα απο default και oc στην 480
  5. ωραιος borg!! θελω να βρω αλλη μια 5850 για να δω και το crossfire σε p55 πριν προβω σε αγορα 2ης 5850. Σε oc με την 480 με τι vcore παίζεις? Εγω στα 1040/1270 εδωσα 1,3. @zpaf δεν περνας απο εδω και τις 5870 σου να τις δουμε με τον i5?
  6. cpu @4mhz , 5850 default options: score: cpu @4mhz , 5850 @ 1040/1270 options: score:
  7. Alexopus6
    οχι δεν εχω δοκιμασει, αλλα σημερα ενας φιλος με 10.5 ειχε ακριβως το ιδιο προβλημα με τον dn και με περασμα 10.4 official έτρεξε κανονικα. οποτε δεν πιστευω να φταιει κατι αλλο. @dn για περασε 10.4 να δουμε αν περναει το cinebech!!
  8. Alexopus6
    cinebench r11.5 με 10.4 official
  9. Alexopus6
    εδω με 10.4 official μου τρέχει κανονικά.
  10. Με 1,32 και δεν?? :crazy: εδω παίζει με 1,25 http://www.thelab.gr/showpost.php?p=1062742509&postcount=151 :whistling
  11. Τασο μια χαρά είναι το score του quad, εκεί κυμαίνεται πάει και παραπάει πάνω απο 1000 δωσε λιγο ρευματακι και θα πάει!! :OT: zpaf γιατι λες τελευταίο?? θα παίξει καμια αναβαθμισούλα?:whistling
  12. Alexopus6
    venom, o dN αναφέρεται για τις 5850
  13. thanks seb, ακόμα ψάχνομαι με τον i5 αλλα μετα την αλλαγη απο Ε6400 ήθελα να δω τα 20k στο vantage!!
  14. i5-750 @ 4Mhz 5850 @ 1040/1270
  15. Alexopus6
    Μαλλον ναι. Τουλαχιστον με gpu caps viewer μου δείχνει κανονικά Core: 725MHz - Memory: 1000MHz
  16. Alexopus6
    GPU Caps Viewer 1.8.6 Παίζει κανονικά σε win7 64bit!! Κατέβασε το zip αρχείο.
  17. Alexopus6
    Νeph με πρόλαβες:tongue:
  18. Alexopus6
    Και στο multi και στο single?
  19. Alexopus6
    Πουθενα δεν τραβάει ζόρι η 5870 με το Modern warfare II, αντιθέτως δεν είναι δα και το ποιο απαιτητικο game που κυκλοφορει!! Για κάνε κανένα φορματ όπως είπε και ο csaris και δες με καθαρο λειτουργικο.
  20. Alexopus6
    Δεν ξέρω αν ο KostasNK αναφέρεται σε αυτο το πρόβλημα, αλλά αυτό μου είχαν παρουσιάσει σε εμένα οι 10.4b
  21. Alexopus6
    Εκτός απο 5970 και 5870 crossfire-trifire, οι υπόλοιποι της σειράς 58χχ είναι φυσιολογικό να αντιμετωπίζουμε τέτοια προβήματα με τους 10.4b?
  22. Alexopus6
    Δεν μπήκα καν στη διαδικασία να περάσω τους drivers απο guru3d, έπαιζα με 10.4b by atiman απο τοτε που ανέβηκαν και κατάλαβα οτι κάτι δεν πήγαινε κάλα όταν έπαιζα και σε κάποιες συγκεκριμένες πίστες είχα 80-90 fps και ξαφνικα είχα 45-50 αλλα επειδή είχα ανοιχτο gpu-z οταν βγήκα απο game ήταν κολλημένα εκεί τα ρολόγια, δεν idlare καθόλου η κάρτα, ούτε κάν μετα από 4 απανωτά restart!!
  23. Alexopus6
    Μου παρουσιάστηκε ενα προβληματάκι με 10.4b by atiman και προς το παρών γύρισα σε 10.3 official. Ξαφνικά η κάρτα δούλευε σε ρολόγια 545/900, έκανα 4-5 restart μπας και ήταν κάποιο σκάλωμα αλλά τίποτα, ήταν κολλημένο σε 545/900. Έχει αντιμετωπίσει κανένας το ίδιο πρόβλημα?
  24. Alexopus6
  25. Alexopus6
    Thanks atiman, οπότε τώρα με τον uninstaller ποια θα είναι η διαδικασία για να περνάμε τους καινούργιους drivers?? Τι θα αλλάξει από το: Control Panel - Ati Catalyst Install Manager - Expess Uninstall ALL ATI Software - Driver Sweeper σε safe mode?
