GeorgeVasil
    8.222
  • Ημέρες που κέρδισε
    1
Everything posted by GeorgeVasil
  1. GeorgeVasil
    Utilities
    NVIDIA BIOS Editor (NiBiTor) v3.7a
  2. GeorgeVasil
    Utilities
    HD Tune 2.55 HD Tune Pro 3.00 Trial
  3. GeorgeVasil
    Utilities
    wPrime 1.60
  4. GeorgeVasil
    Utilities
    TechPowerUp GPU-Z v0.1.6 Added GPU Sensors tab Fixed CrossFire detection under Vista Screenshot will now work on Windows 2000 without PSAPI.DLL installed Update check default interval is now 1 week Added a link to test build forum from validation page GPU variant names removed for all ATI and NVIDIA cards. For example "G80 GTX" will be called "G80" from now on Added several missing ASICs from families: RV610, RV630, R600 Added several future ATI ASICs Fixed clock detection for some RV6xx ASICs Fixed pipeline count on modded RV430 GPUs Added ROP/shader readings for RV620, RV635 and future ATI ASICs Fixed memory bus width reading for R200 and similar ASICs Improved low-level BIOS reading code to work on more GPUs (pre-R500) Added detection for ASICs from families: G80, G92, G94, G92 M Fixed negative temperature readings in ADT7473 sensor Added some missing die sizes for ATI and NVIDIA Added bus width reading for NV10 Fixed bus width reading for NV44 Fixed ROP/shader counts for NV41, NV42, NV43, G70, G71, G73 Added detection for i740, GM45 i865G correctly reports DDR memory now Multi GPU dropdown is now a static readout Shortened HP PCI vendor name
  5. GeorgeVasil
    Koιτα το πινακακι βρε αδερφε.Ειναι Τοο easy να καταλαβεις τις διαφορες.
  6. GeorgeVasil
    Utilities
    HP Drive Key Boot Utility EDIT: Και ένας οδηγός για το τι και πως: http://icrontic.com/articles/bootable_usb
  7. GeorgeVasil
    ΧΡΟΝΙΑ ΠΟΛΛΑ THREAD
    Χρονια πολλα! :finger006: :hut004:
  8. GeorgeVasil
    Δείξτε το γραφείο σας!
    Το Woofer τι δουλεια εχει πανω στο γραφειο?
  9. GeorgeVasil
    Λαμπρο ποτε να ερθω να παιξω με το μ-audio? Επαθα πλακα απο το συγκεκριμενο εργαλειο..αν και δεν εχς ιδεα απο μουσικη.
  10. GeorgeVasil
    ΧΡΟΝΙΑ ΠΟΛΛΑ THREAD
    Χρονια Πολλα Παιδια..(koumle,NickL,kourman).. Υγεια και ευτυχια.. Ας διωρθωσει καποιος το Νικες σε Νικολετες...λολ
  11. GeorgeVasil
    .."Ο Σεισμός είναι ένα φυσικό φαινόμενο, το οποίο προκαλείται από ξαφνική απελευθέρωση μηχανικής ενέργειας από το εσωτερικό της γης προς την επιφάνειά της. Η ενέργεια αυτή έχει τη μορφή αναταράξεων στη στεριά ή τσουνάμι στη θάλασσα, και διαδίδεται μέσω των σεισμικών κυμάτων...''
  12. GeorgeVasil
    ΧΡΟΝΙΑ ΠΟΛΛΑ THREAD
    Κριμα επρεπε να ερθω χτες...
  13. GeorgeVasil
    ΧΡΟΝΙΑ ΠΟΛΛΑ THREAD
    Χρόνια πολλά Ανδρέα.. Υγεια και ευτυχία..πάνω από όλα...
  14. GeorgeVasil
    Ευτυχώς έχει power on και Reset σε κουμπί... ΔΛδ έχουμε φτάσει σε σημείο να τους παρακαλάμε για να τους δώσουμε λ7. Δεν έχει άλλη φορά όμως ούτε 0.01...έχε χάρη που δεν έβρισκα το συγκεκριμένο αλλού. :rant:
  15. GeorgeVasil
    άριστε και το δικό μου...Χύμα στο κύμα εδώ και 2 βδομάδες... Και ποιος ευθύνεται?? Κλασσικά τα .....ελευθέρας βοσκής...του παρακάτω μαγαζιού που δεν ξερουν τι τους γινετε μεσα στην αποθηκη τους. Οποιος θελει να παρει Full Tower απο εκει,να το σκευτει... Μετα από 3 τηλεφωνήματα και γνωστές εκφράσεις κάτι έγινε. Ελπίζω να το έχω αύριο αλλιώς....take the pouL... από εκεί ούτε Sata καλώδιο ξανά.- ΓΙΔΙΑ..#@$%^%^ ΤΕΛΟΣ.
  16. GeorgeVasil
    ΧΡΟΝΙΑ ΠΟΛΛΑ THREAD
    Χρόνια πολλά ποκοπικο..εεε Πάρη.. Πολύχρονος..γεια και ευτυχία πάνω από όλα..
  17. GeorgeVasil
    ΧΡΟΝΙΑ ΠΟΛΛΑ THREAD
    Χρονια πολλα Σακης..
  18. GeorgeVasil
    ΧΡΟΝΙΑ ΠΟΛΛΑ THREAD
    Χ
  19. GeorgeVasil
    The nVidia ForceWare Driver Thread
    Δλδ να κάνεις SLI μεταξυ 8800 και 7900? Διαφορετικοί Cores,διαφορετικές μνήμες..?WTF?Ποιος τα λέει αυτά? Δεν γίνετε φίλε..οι κάρτες πρέπει να είναι ίδιες.
  20. GeorgeVasil
    Supercars & Dreamcars Thread
  21. GeorgeVasil
    ΧΡΟΝΙΑ ΠΟΛΛΑ THREAD
    1-2-1-2 Obiτσουαν! Χ
  22. GeorgeVasil
    Show your desktop
  23. GeorgeVasil
    Show your desktop
    Από το καθημερινό λειτουργικό..
  24. GeorgeVasil
    ΧΡΟΝΙΑ ΠΟΛΛΑ THREAD
    Χ
  25. GeorgeVasil
    Utilities
    CPU-Z 1.41.0 Download inside http://www.forumdeluxx.de/forum/showthread.php?t=384408 Επιτελους τα διχνει σωστα..και δεν ειναι..chiquita ΕΔΙΤ: Διχνει σςστα αλλα μου κ
