Everything posted by astrolabos
astrolabos απάντησε στο θέμα του astrolabos topic στην ενότητα Off topic
Phanteks today expanded the Glacier One D30 Lineup with the new Glacier One 420D30 All-In-One Liquid CPU cooler. Featuring triple D30-140 fans and 420mm radiator configuration, this cooler not only delivers exceptional performance but also boasts stunning visual brilliance. One of the standout features of the Glacier One D30 AIO cooler is the clever daisy-chaining capability of its D30 fans, enabling centralized control through a single cable. This innovative design eliminates cable clutter, simplifying the installation process and making it easier than ever to achieve a clean and organized build. The cooler’s generous copper base and fin array ensure efficient heat dissipation, positioning it as the ultimate cooling solution for high-end CPUs. Designed with compatibility at its core, the Glacier One D30 AIO cooler boasts a sleek and compact design that optimizes clearance with motherboard and RAM components. The Glacier One D30 AIO Liquid Coolers now offer a comprehensive range, including 240, 360, and the newly introduced 420 models. All variants are seamlessly compatible with the latest Intel 14th Gen, Raptor Lake Refresh Processors, ensuring that users stay current with the latest processor technology. Together with the recently released D30-140 fans and upcoming NV9 chassis, the Glacier One D30 420 AIO Liquid coolers offers an unparalleled blend of functionality and style to pc builders. MSRP: Glacier One 420 D30 Black €189.90 | $189.99 | £164.99 Glacier One 420 D30 White €189.90 | $189.99 | £164.99
Η Nvidia μπορεί να ετοιμάζει τη μυστηριώδη κάρτα γραφικών GeForce RTX 4080, καθώς ένα γνωστό αποθετήριο αναγνωριστικών PCI έχει στη βάση δεδομένων του ένα τέτοιο προϊόν, γεγονός που υποδηλώνει ότι η συσκευή έχει καταχωρηθεί σε κάποιο πρόγραμμα οδήγησης, Linux patch, επικύρωση στο GPU-Z ή BIOS. Το προϊόν μπορεί να καταλήξει ως μια πρόσθετη κάρτα μόνο για OEM που διατίθεται από επιλεγμένους κατασκευαστές PC, αλλά τουλάχιστον η Nvidia φαίνεται να το προετοιμάζει, γεγονός που επιβεβαιώνει κάπως τις συνεχιζόμενες φήμες ότι η GeForce RTX 4080 Super έρχεται. Αυτό εξακολουθεί να είναι μια φήμη και ως εκ τούτου πρέπει να λάβουμε τα νέα με επιφύλαξη. Η Nvidia πρόσθεσε πρόσφατα το 10de:2703 (NVIDIA_DEV.2703), μια καταχώρηση που περιγράφεται ως GeForce RTX 4080 Super στον δοκιμαστικό οδηγό R515, όπως παρατήρησε ο StefanG3D από το LaptopVideo2Go. Το προϊόν λέγεται ότι βασίζεται στον επεξεργαστή γραφικών AD103 της Nvidia, αν και δεν είναι σαφές αν η GPU έρχεται με ενεργοποιημένους όλους τους 10.240 πυρήνες CUDA, διατηρεί τους 9.728 πυρήνες CUDA της GeForce RTX 4080, αλλά υιοθετεί υψηλότερα ρολόγια, ή έχει άλλη διαμόρφωση. Τώρα, ενώ τα ημιεπίσημα αποθετήρια είναι αξιόπιστες πηγές πληροφοριών, δεν αποτελούν την απόλυτη αλήθεια, όχι μόνο επειδή δεν είναι επίσημα, αλλά επειδή τα σχέδια μπορεί να αλλάξουν και οι εταιρείες μπορεί να ακυρώσουν ορισμένα προϊόντα πριν από τη κυκλοφορία τους. Η συγκεκριμένη καταχώριση της συσκευής 10de:2703 που χαρακτηρίζεται ως GeForce RTX 4080 Super προστέθηκε από τον T4CFantacy, σε μια βάση δεδομένων GPU του TechPowerUp με πρόσβαση σε πρώιμες επικυρώσεις GPU BIOS και GPU-Z, όπως σημειώνει το VideoCardz. Ως εκ τούτου, είναι πιθανό, αλλά όχι βέβαιο ότι η Nvidia ή/και οι συνεργάτες της εργάζονται σε προϊόντα με την ονομασία GeForce RTX 4080 Super. Σε αυτό το σημείο είναι δύσκολο να κάνουμε εικασίες σχετικά με τις προδιαγραφές της GeForce RTX 4080 Super της Nvidia, αν και θα μπορούσαμε να φανταστούμε ότι αυτή θα βρίσκεται πάνω από την κανονική GeForce RTX 4080 αλλά κάτω από την GeForce RTX 4090, την καλύτερη κάρτα γραφικών που μπορούν να αγοράσουν τα χρήματα. Αν η μονάδα προσφέρει μια μικρή αναβάθμιση των επιδόσεων σε σχέση με τον προκάτοχό της, θα είναι αρκετά καλή για να εδραιώσει περαιτέρω τη θέση της στην αγορά των επιτραπέζιων διακριτών καρτών γραφικών. Εν τω μεταξύ, η εταιρεία θα μπορούσε να κάνει την GeForce RTX 4080 Super ένα προϊόν μόνο για OEM που θα απευθύνεται σε κατασκευαστές υπολογιστών που τείνουν να θέλουν "νέες" SKU κάθε χρόνο για να δείχνουν τη διαφορά μεταξύ των σύγχρονων και των περσινών συνθέσεών τους. Εκτός από την υποτιθέμενη GeForce RTX 4080 Super, ο οδηγός δοκιμής R515 παραθέτει επίσης την H100 SXM5 96GB AI και HPC GPU για υπολογισμούς. Αυτό το μέρος θα χρησιμοποιεί πιθανότατα μνήμη υψηλής πυκνότητας HBM3 ή HBM3E και θα επιτρέπει στις εφαρμογές να έχουν πρόσβαση σε 96 GB, από 80 GB που είναι προσβάσιμα σήμερα.
Thermaltake, the leading PC DIY premium brand for Case, Power, Cooling, Gaming peripherals, and enthusiast Memory solutions, is proud to announce that the TH120/240/280/360/420 V2 ARGB Sync All-In-One Liquid Cooler - Snow Edition, the TH280 V2 ARGB Sync All-In-One Liquid Cooler - Matcha Green Edition, and the TH240/280/360/420 V2 Ultra ARGB Sync All-In-One Liquid Cooler - Snow Edition are ready for purchase. Besides the previous black color, TH V2 ARGB and TH V2 Ultra ARGB now come in white as well. The TH V2 ARGB/Ultra ARGB Snow is a 2nd generation design of the TH series, upgraded with superior aesthetics and cooling performance. These AIO liquid coolers possess a wide range of 120mm/140mm fan models, allowing them to meet various chassis sizes. To mix and match with Thermaltake’s matcha green chassis, there is also a TH 280 V2 ARGB Matcha Green AIO for you to choose from. TH V2 ARGB Sync All-In-One Liquid Cooler - Snow Edition / TH280 V2 ARGB Sync Matcha Green Edition The TH V2 ARGB Snow and TH280 V2 ARGB Matcha Green are AIO liquid coolers that have high value in visual design. They feature a new industrial cap with an infinity mirror light design, showing fantastic layered lighting effects and enhancing the overall aesthetics. Additionally, no matter how you install the cooler, its 360-degree rotational cap enables you to easily adjust the logo’s direction on the water block. Now, the new color editions of the TH V2 ARGB make it even simpler to personalize your PC setup. The TH V2 ARGB Snow Series is an ideal choice for an all-white build; the TH280 V2 ARGB Match Green can match Thermaltake’s latest matcha green chassis; you can also mix the component colors to create your own style! TH V2 Ultra ARGB Sync All-In-One Liquid Cooler - Snow Edition All TH V2 Ultra ARGB models are now available in Snow Edition. The TH V2 Ultra ARGB Snow Series is also designed with an industrial look and comes with a 2.1-inch LCD Display on the water block. This 480 x 480 resolution LCD Display can present real-time information about CPU, local time, and weather. You can also upload any JPG, GIF, PNG, MP4, MOV, and AVI files to customize your TH V2 Ultra ARGB Snow. Furthermore, each powerful CT120/CT140 ARGB Fan on the TH V2 ARGB and TH V2 Ultra ARGB has 9 addressable LEDs, so users can create their dream lighting effects through the 5V motherboard lighting software. The TH V2 ARGB Snow, TH280 V2 ARGB Matcha Green, and the TH V2 Ultra ARGB Snow are all available for purchase. If you are looking for a cost-effective AIO liquid cooler with unparalleled aesthetics and high personalization, don’t miss out on the TH V2 ARGB/Ultra ARGB Series AIO in brand-new Snow Edition and TH280 V2 ARGB in Matcha Green Edition! Features of Thermaltake TH V2 ARGB Series AIO & TH V2 Ultra ARGB Series AIO: No matter the build, We’ve got you covered The new color editions of the TH V2 ARGB and the TH V2 Ultra ARGB cover various types of builds. The TH V2 ARGB Snow Series has three 120mm fan models, including the TH 120/ 240/ 360 V2 ARGB Snow, and two 140mm fan models, including the TH 280/ 420 V2 ARGB Snow. TH280 V2 ARGB Matcha Green perfectly fits with The Tower 200 and Ceres 300, so you can create a complete Matcha Green build! The TH V2 Ultra ARGB Snow Series possesses two 120mm fan models, including the TH 240/ 360 V2 Ultra ARGB Snow, and two 140mm fan models, including the TH 280/ 420 V2 Ultra ARGB Snow. TH V2 ARGB: New Version, New Design The TH V2 ARGB was given an industrial look to freshen up the 360-degree rotational cap. Adding Infinity Mirror Lighting to this series can bring more diverse visual effects to the build and give more depth than it looks. TH V2 Ultra ARGB: New Design, Same Quality TH V2 Ultra ARGB was given an industrial look to freshen up the 2.1” LCD Display. With its 480*480 high resolution, you can easily show off 16.8M color videos or photos. TH V2 Ultra ARGB: Personalize Your LCD Display The TH V2 Ultra LCD Display is highly customizable, from presenting real-time information to playing JPG, GIF, PNG, MP4, MOV, and AVI files or even showing local time and weather information on the display; it can all bring great visual aesthetics to your build. Sync with CT120/140 ARGB Fans Developed from the CT fan series, the TH V2 ARGB and the TH V2 Ultra ARGB use CT120/140 ARGB fans with enhanced fan speed, and you can also match with some of our chassis’ pre-installed fans to unify your fans in your build! The CT120 ARGB provides a 57.05 CFM airflow with 2.23 mm-H2O static pressure while maintaining a 25.8 dB-A noise level. The CT140 ARGB fans have 1800 RPM and provide an 84.32 CFM airflow with 3.02 mm-H2O static pressure while maintaining 34.7 dB-A noise levels. Enhanced Cooling Surface with A Compact Design The TH V2 ARGB Series and the TH V2 Ultra ARGB Series have a 27mm slim radiator with a thickened 20mm copper chamber, ensuring the same easy installation but with even better cooling performance. Less Cables, Less Mess The new cable-integrated daisy-chain design allows the fans to be directly connected, so it minimizes the demands of 4-pin PWM and 3-pin ARGB ports on your motherboard and shortens the cable length between the fans. We’ve also included one 900mm PWM cable and one 900mm ARGB cable for you to easily manage your cables while assembling your build. Keeping Your Cables in Place You might have experienced easily detached 5V ARGB cables when you assemble your builds. Worry not; this 5V ARGB Connector Clip can guarantee that the cables are correctly connected and won’t get loose in unexpected conditions. Keep it COLD with Copper The high-performance copper base plate accelerates the heat conductivity. The high-quality and reliable pump enables maximum water circulation, keeping the copper plate continuously cool. The low evaporation tube effectively decreases the loss of coolant; therefore, no refill is required. Any CPU Can Be the Right CPU The package includes brackets for the latest Intel and AMD CPU sockets to be compatible with the most modern CPU platforms, including the latest Intel LGA1700 and AMD AM5 CPUs. Compatibility list: Intel: LGA 2066/2011/1700/1200/1156/1155/1151/1150 AMD: AM5/AM4/AM3+/AM3/AM2+/AM2 Sync with Motherboard RGB Software Designed to synchronize with ASUS Aura Sync, GIGABYTE RGB Fusion, MSI Mystic Light Sync, and ASRock Polychrome. It supports motherboards with a 5V addressable RGB header, allowing you to control the lights directly from the software mentioned above without installing any extra lighting software or controllers. For more information on Thermaltake TH120/240/280/360/420 V2 ARGB Sync All-In-One Liquid Cooler - Snow Edition, please visit: TH120 V2 ARGB Snow - https://www.thermaltake.com/th120-v2-argb-sync-all-in-one-liquid-cooler-snow-edition.html TH240 V2 ARGB Snow - https://www.thermaltake.com/th240-v2-argb-sync-all-in-one-liquid-cooler-snow-edition.html TH280 V2 ARGB Snow - https://www.thermaltake.com/th280-v2-argb-sync-all-in-one-liquid-cooler-snow-edition.html TH360 V2 ARGB Snow - https://www.thermaltake.com/th360-v2-argb-sync-all-in-one-liquid-cooler-snow-edition.html TH420 V2 ARGB Snow - https://www.thermaltake.com/th420-v2-argb-sync-all-in-one-liquid-cooler-snow-edition.html For more information on Thermaltake TH280 V2 ARGB Sync All-In-One Liquid Cooler - Matcha Green Edition, please visit: https://www.thermaltake.com/th280-v2-argb-sync-all-in-one-liquid-cooler-matcha-green-edition.html For more information on Thermaltake TH240/280/360/420 V2 Ultra ARGB Sync All-In-One Liquid Cooler - Snow Edition, please visit: TH240 V2 Ultra ARGB Snow - https://www.thermaltake.com/th240-v2-ultra-argb-sync-all-in-one-liquid-cooler-snow-edition.html TH280 V2 Ultra ARGB Snow - https://www.thermaltake.com/th280-v2-ultra-argb-sync-all-in-one-liquid-cooler-snow-edition.html TH360 V2 Ultra ARGB Snow - https://www.thermaltake.com/th360-v2-ultra-argb-sync-all-in-one-liquid-cooler-snow-edition.html TH420 V2 Ultra ARGB Snow - https://www.thermaltake.com/th420-v2-ultra-argb-sync-all-in-one-liquid-cooler-snow-edition.html
- aio
- matcha green
(και 2 επιπλέον)
Λίγους μήνες αφότου ανέλαβε τη θέση του διευθύνοντος συμβούλου στο X (πρώην Twitter) τον Μάιο, η Linda Yaccarino δήλωσε: "Το X θα είναι η πλατφόρμα που θα μπορεί να προσφέρει, λοιπόν... τα πάντα". Μέρος αυτού περιλαμβάνει τις κλήσεις ήχου και βίντεο, τις οποίες η εταιρεία μόλις άρχισε να αναπτύσσει για τους χρήστες σε παγκόσμιο επίπεδο. Η νέα λειτουργία έρχεται με τη τελευταία ενημέρωση της εφαρμογής, η οποία έγινε ευρέως διαθέσιμη εχθές. Αν δεν σας αρέσει η ιδέα μιας ακόμη εφαρμογής με κλήσεις ήχου και βίντεο, τότε μπορείτε εύκολα να απενεργοποιήσετε τη λειτουργία και να συνεχίσετε να χρησιμοποιείτε την εφαρμογή με τον συνηθισμένο τρόπο. Για να απενεργοποιήσετε τις κλήσεις ήχου και βίντεο στο X, ακολουθήστε τα παρακάτω βήματα: Επιλέξτε την εικόνα προφίλ -> Ρυθμίσεις και υποστήριξη -> Ρυθμίσεις και απόρρητο -> Απόρρητο και ασφάλεια -> Άμεσα μηνύματα -> Απενεργοποιήστε τη ρύθμιση "Ενεργοποίηση κλήσεων ήχου και βίντεο". Από την άλλη πλευρά, αν δεν έχετε πρόβλημα με τη νέα λειτουργία, αφήστε απλώς τη ρύθμιση στη θέση "ενεργοποιημένο" και επιλέξτε από ποιούς θέλετε να δέχεστε κλήσεις. Οι επιλογές είναι τα άτομα στο βιβλίο διευθύνσεών σας, τα άτομα που ακολουθείτε και οι επαληθευμένοι χρήστες. Μπορείτε να τσεκάρετε οποιονδήποτε αριθμό από αυτές τις τρεις επιλογές. Ο Elon Musk, ο οποίος εξαγόρασε το Twitter πριν από ένα χρόνο έναντι 44 δισεκατομμυρίων δολαρίων, δημοσίευσε ένα μήνυμα στην πλατφόρμα την Τετάρτη περιγράφοντας τη νέα λειτουργία ως "πρώιμη έκδοση", υποδηλώνοντας ότι ενδέχεται να υπάρξουν σύντομα ορισμένες αλλαγές. Ο Μασκ έχει δηλώσει πολλές φορές πώς θέλει να μετατρέψει την πλατφόρμα σε μια λεγόμενη "σούπερ-εφαρμογή" που θα προσφέρει μια μεγάλη ποικιλία υπηρεσιών, παρόμοια με τη δημοφιλή πλατφόρμα WeChat της Κίνας. Οι πρόσθετες υπηρεσίες θα μπορούσαν να περιλαμβάνουν πράγματα όπως τραπεζικές συναλλαγές, πληρωμές, παράδοση γευμάτων, ridesharing, αγορές κ.ο.κ.
- all in one
- x
(και 2 επιπλέον)
Η LG συνεργάζεται με την παγκοσμίου φήμης δανέζικη εταιρεία Bang & Olufsen για να επαναπροσδιορίσει το home cinema. Η LG MAGNIT, η πρωτοποριακή οθόνη Micro LED και τα κορυφαία ηχεία Beolab 90 της Bang & Olufsen συνδυάζονται για να παρουσιάσουν καθηλωτικές εμπειρίες θέασης με εξαιρετικά μεγάλες και απίστευτα ρεαλιστικές εικόνες και ισχυρό, εκλεπτυσμένο ήχο. Με κομψό, μοντέρνο σχεδιασμό και ζωντανή, εξαιρετικά ευκρινή ποιότητα εικόνας Micro LED, η LG MAGNIT προσφέρει την απόλυτη απόλαυση θέασης. Η οθόνη των 136 ιντσών, 4K UHD (3840 x 2160), με ρυθμό ανανέωσης 120 Hz είναι ιδανική για παρακολούθηση ταινιών, τηλεοπτικών εκπομπών και αθλητικών εκδηλώσεων – και για την προβολή έργων τέχνης – στον χώρο του σπιτιού σας. Συνδυάζοντας την απόδοση του Micro LED με λειτουργικές δυνατότητες που βελτιώνουν την απόλαυση περιεχομένου, η LG δημιούργησε μια μοναδική οθόνη για όσους απαιτούν το καλύτερο. Η ποιότητα και το μέγεθος των εικόνων που εμφανίζονται στην LG MAGNIT είναι βέβαιο ότι θα συναρπάσουν και το ίδιο θα κάνει ο κομψός, μινιμαλιστικός σχεδιασμός της οθόνης. Η οικιακή λύση Micro LED της LG διαθέτει οθόνη χωρίς πλαίσιο για καθηλωτική εμπειρία θέασης και ένα στιβαρό, κομψό πλαίσιο αλουμινίου με μεταλλικό φινίρισμα που συμπληρώνει κάθε εσωτερική διακόσμηση ή συνδυασμό χρωμάτων. Αντίστοιχα, το Media Box, το οποίο χρησιμεύει ως μονάδα ελέγχου για την LG MAGNIT και μοιράζεται την πολυτελή αλλά διακριτική αισθητική της οθόνης, εναρμονίζεται όμορφα με το περιβάλλον. Έχοντας δημιουργήσει μια τέτοια εξαιρετική οθόνη, η LG αναζήτησε έναν συνεργάτη ικανό να παρέχει μια λύση ήχου που θα μπορούσε να ταιριάζει με την MAGNIT όσον αφορά την ομορφιά του σχεδιασμού και την εξαιρετική απόδοση. Η Bang & Olufsen – αγαπημένη εταιρεία στους μουσικόφιλους από το 1925 – κατανόησε αμέσως το όραμα της LG για την εξύψωση της εμπειρίας του home cinema και ήξερε ακριβώς ποιες από τις κορυφαίες λύσεις της θα συμπλήρωναν καλύτερα την LG MAGNIT: το ξεχωριστό, δυναμικό Beolab 90. Σε συνδυασμό με την LG MAGNIT, τα ηχεία Beolab 90 της Bang & Olufsen είναι το ιδανικό ταίρι για την καινοτομία Micro LED της LG τόσο σε στυλ όσο και σε απόδοση. Ένα αριστούργημα αισθητικής και ακουστικής, το Beolab 90 διαθέτει ένα εμβληματικό σχέδιο με καμπυλωτές ξύλινες βάσεις, μια σειρά από γωνιακές όψεις καλυμμένες με κομψό ύφασμα και τελικές πινελιές από αλουμίνιο. Το εκπληκτικό Beolab 90 βρίσκεται στην κορυφή της σειράς ηχείων Beolab της Bang & Olufsen, τα οποία είναι όλα συμβατά με την LG MAGNIT. Το Beolab 90 είναι ένα επιδαπέδιο ηχείο που προσαρμόζει την απόδοση στον χώρο που βρίσκεται και στον τύπο του ήχου που αναπαράγει. Με 8.200 watt ανά ηχείο, 18 προγράμματα οδήγησης premium, 14 κανάλια ενισχυτών ισχύος ICE 300 watt και 4 κανάλια ενισχυτών Class D Heliox 1.000 watt, το Beolab 90 της Bang & Olufsen ζωντανεύει τη μουσική και τα soundtrack με τρόπο που λίγα ηχεία μπορούν . Αφοσιωμένοι στην παροχή εξαιρετικής εμπειρίας χρήσης και οικιακού κινηματογράφου, η LG και η Bang & Olufsen πραγματοποίησαν αρκετούς γύρους δοκιμών για να εξασφαλίσουν απρόσκοπτη συμβατότητα μεταξύ της πλατφόρμας webOS που είναι εγκατεστημένη στην LG MAGNIT και της εφαρμογής λογισμικού της Bang & Olufsen. Χάρη σε αυτές τις προσπάθειες, οι χρήστες μπορούν τώρα να απολαμβάνουν την ευκολία του ελέγχου τόσο της LG MAGNIT όσο και του Beolab 90 μέσω του τηλεχειριστηρίου της Bang & Olufsen. Η LG MAGNIT με τα ηχεία Beolab 90 της Bang & Olufsen προβάλλεται σε διεθνείς τοποθεσίες. Οι επισκέπτες μπορούν να βιώσουν αυτή τη σύζευξη στο LG Business Innovation Center στο Ντουμπάι των Ηνωμένων Αραβικών Εμιράτων, καθώς και στο κατάστημα Bang & Olufsen στο Ριάντ της Σαουδικής Αραβίας. Επιπλέον, αυτός ο εξαιρετικός συνδυασμός παρουσιάστηκε και στον εκθεσιακό χώρο της Bang & Olufsen στην Costa Mesa, στην Καλιφόρνια των ΗΠΑ.
- bang & olufsen
- beolab 90
(και 3 επιπλέον)
Η TeamViewer, ο κορυφαίος παγκόσμιος πάροχος απομακρυσμένης συνδεσιμότητας και ψηφιοποίησης του χώρου εργασίας, ανακοίνωσε σήμερα μια σημαντική αναβάθμιση της λύσης συνδεσιμότητας TeamViewer Tensor για επιχειρήσεις, η οποία υποστηρίζει το τμήμα πληροφορικής στη συντήρηση κρίσιμου για την επιχείρηση εξοπλισμού. Με κορυφαία συμβατότητα, ασφάλεια και απόδοση, το TeamViewer Tensor προσφέρει μια ολοκληρωμένη επισκόπηση όλων των συσκευών, βελτιώνοντας την παρακολούθηση και την υποστήριξη, καθώς και τη διαχείριση πρόσβασης. Αυτή η ενημέρωση δίνει ιδιαίτερη έμφαση στη βελτιωμένη ασφάλεια, στις νέες δυνατότητες διαχείρισης κινητών συσκευών και στο ανασχεδιασμένο user interface με session links ως εναλλακτική λύση για την ταυτότητα χρήστη και τον κωδικό πρόσβασης. Χαρακτηριστικά ασφαλείας με επίκεντρο την επιχείρηση Το TeamViewer Tensor επεκτείνει ακόμη περισσότερο τον λεπτομερή έλεγχο και τους περιορισμούς πρόσβασης, προσθέτοντας τη δυνατότητα "Bring Your Own Certificate" (BYOC) καθώς και προ-εγκεκριμένες συνεδρίες πρόσβασης στις υπάρχουσες υπό προϋποθέσεις δυνατότητες πρόσβασης. Το BYOC επιτρέπει στους πελάτες της TeamViewer να ελέγχουν πλήρως την πρόσβαση στο εσωτερικό του εταιρικού τους δικτύου, παρέχοντας πρόσβαση μόνο σε συσκευές με εγκατεστημένο το προσαρμοσμένο πιστοποιητικό. Σε συνδυασμό με τον νέο τρόπο σύνδεσης της TeamViewer υπάρχει η δυνατότητα δημιουργίας πιστοποιημένων session links επιτρέποντας σύνδεση μίας χρήσης μεταξύ πιστοποιημένων συσκευών εντός του οργανισμού σας, εξαλείφοντας κάθε τυχαία λανθασμένη ρύθμιση και πιθανή παραβίαση πρόσβασης. Οι προ-εγκεκριμένες υπό προϋποθέσεις access sessions προσφέρουν έλεγχο με τον προκαθορισμό μιας σύνδεσης σε συσκευές ή ομάδες συσκευών, με σταθερό timeslot και χρονικό όριο, που είναι διαθέσιμα για εξερχόμενες και εισερχόμενες συνδέσεις. Ειδικά οι οργανισμοί που συνεργάζονται με τρίτους ή πελάτες μπορούν να μειώσουν το φόρτο εργασίας τους στο IT τμήμα, προορίζοντας μεμονωμένα sessions εντός του προϊόντος, χωρίς να συμβιβάζονται οι κατευθυντήριες γραμμές ασφαλείας. Ολιστική παρακολούθηση και διαχείριση της συσκευής Το TeamViewer Tensor είναι μια εξειδικευμένη λύση για μεγαλύτερες εταιρείες, με διαφορετικές συσκευές και ιδιαίτερη ανάγκη για ασφάλεια και επεκτασιμότητα. Ως εκ τούτου, η TeamViewer έχει προσθέσει δυνατότητες διαχείρισης κινητών συσκευών στη λύση απομακρυσμένης παρακολούθησης και διαχείρισης, οι οποίες αποτελεί μέρος του Tensor από προεπιλογή. Με την τελευταία προσθήκη, το TeamViewer Tensor προσφέρει πλέον μια ολιστική επισκόπηση ολόκληρου του IT και OT, καλύπτοντας όλα τα σημαντικά λειτουργικά συστήματα, συμπεριλαμβανομένων των android και iOS, επιτρέποντας την κεντρική ανάπτυξη διορθώσεων, πολιτικών διαχείρισης, ενεργοποίηση και απενεργοποίηση συσκευών και απομακρυσμένων αντίγραφων ασφαλείας, καθώς και τη διαγραφή δεδομένων. Επανασχεδιασμένη διασύνδεση και βελτιωμένη ροή εργασίας Το TeamViewer Tensor έχει επανασχεδιάσει ολόκληρη την εμπειρία χρήσης, εισάγοντας μια σειρά βελτιώσεων, όπως γρήγορες ενέργειες, καθολική αναζήτηση και συνοδευτική πλατφόρμα, για να διευκολύνει τα μεγάλα τμήματα IT που συντηρούν χιλιάδες συσκευές ταυτόχρονα. Ένας νέος διαδικτυακός πελάτης επιτρέπει μεγαλύτερη ευελιξία με πρόσβαση στην αρχή σε όλα τα χαρακτηριστικά της εγκατεστημένης έκδοσης. Η Mei Dent, Chief Product &Technology Officer δήλωσε: “Έχουμε καθορίσει το πρότυπο στην απομακρυσμένη προσβασιμότητα εδώ και πολύ καιρό και, κατά συνέπεια, βελτιώσαμε τη λύση TeamViewer Tensor για να καλύψουμε τις ανάγκες των επιχειρήσεων με ασφαλή και αξιόπιστη επικοινωνία, τοποθετώντας μας ως κορυφαίο παίκτη στον τομέα αυτό. Με αυτή τη σημαντική αναβάθμιση επικεντρωνόμαστε στην ασφάλεια επιχειρησιακού επιπέδου και στις βελτιωμένες ροές εργασίας, ενώ παράλληλα παρέχουμε μέγιστη ευελιξία, υποστηρίζοντας κάθε συσκευή που είναι συνδεδεμένη στο διαδίκτυο - από τάμπλετ για παραγγελίες φαγητού σε ένα εστιατόριο μέχρι οθόνες ψηφιακής σήμανσης σε απομακρυσμένες τοποθεσίες, σε κλασικό IT εξοπλισμό και κινητών μέχρι ρομπότ στο χώρο παραγωγής". Το TeamViewer Tensor έχει σχεδιαστεί με γνώμονα ομάδες όπως τμήματα IT ή υπηρεσίες εξυπηρέτησης πελατών, που χρειάζονται μια ενιαία, γρήγορη, αξιόπιστη και ασφαλή λύση, η οποία είναι εύκολο να ενσωματωθεί σε υπάρχοντα περιβάλλοντα όπως ενεργούς καταλόγους. Με πλήρη δυνατότητα ελέγχου, σχετικές πιστοποιήσεις για επιχειρήσεις και κατάταξη στο κορυφαίο 1% από την BitSight Security, το Tensor χρησιμοποιείται για απομακρυσμένη πρόσβαση ακόμη και σε οργανισμούς κρίσιμων υποδομών, όπως εργοστάσια παραγωγής, και σε κλάδους με υψηλή κανονιστική ρύθμιση, όπως η υγειονομική περίθαλψη ή οι χρηματοπιστωτικές υπηρεσίες.
- enterprise connectivity
- teamviewer
- (και 3 επιπλέον)
kingstons corner Τι να κάνετε αν ο SSD σας είναι γεμάτος
astrolabos posted a blog entry in Kingston`s Spot
Τα πλεονεκτήματα των SSD, όπως οι αστραπιαίες ταχύτητες, η ανθεκτικότητα και η συμπαγής μορφή τους, έχουν αλλάξει τη βιομηχανία αποθήκευσης. Ωστόσο, παρά τα πλεονεκτήματά τους, οι παλαιότεροι SSD συχνά συνοδεύονται από ορισμένους περιορισμούς, όπως η περιορισμένη χωρητικότητα αποθήκευσης. Το λειτουργικό σύστημα χρειάζεται να ε΄χει ελεύθερο περίπου το 20% του χώρου του SSD για να λειτουργεί σωστά. Αν βρεθείτε με μήνυμα σφάλματος "Ο δίσκος είναι γεμάτος" ή αντιμετωπίζετε κακές επιδόσεις λόγω ανεπαρκούς χώρου στον SSD σας, δεν είστε ο μόνος! Ακολουθούν ορισμένες πρακτικές συμβουλές και λύσεις που θα σας βοηθήσουν να δημιουργήσετε χώρο σε έναν SSD. Βρείτε και αφαιρέστε μεγάλα αρχεία Πάντα θα υπάρχουν αρχεία στον SSD σας που είναι πολύ μεγάλα ή που δεν τα θέλετε ιδιαίτερα πια. Ένας τρόπος για να τα βρείτε αυτά είναι να χρησιμοποιήσετε τα ενσωματωμένα εργαλεία καθαρισμού δίσκου στο λειτουργικό σας σύστημα, όπως το "Disk Cleanup" στα Windows, ή λογισμικό τρίτων για να καθαρίσετε αρχεία και να ελευθερώσετε χώρο αποθήκευσης. Τα περισσότερα, αν όχι όλα, τα λειτουργικά συστήματα διαθέτουν ένα τέτοιο. Συνιστούμε το WinDerStat για τα Windows και το GrandPerspective για το macOS. Θα σαρώσουν τον SSD σας ή απλώς έναν κατάλογο σε αυτόν και στη συνέχεια θα εμφανίσουν μια γραφική αναπαράσταση των αρχείων. Όσο μεγαλύτερο είναι το ορθογώνιο, τόσο μεγαλύτερο είναι το μέγεθος του αρχείου. Στη συνέχεια, περάστε με το ποντίκι πάνω από τα ορθογώνια για να δείτε το όνομα και το μέγεθος του αρχείου. Τα εν λόγω αρχεία μπορούν στη συνέχεια να επανεξεταστούν και στη συνέχεια να διαγραφούν εάν δεν χρειάζονται πλέον. Επιπλέον, υπάρχει μια χειροκίνητη προσέγγιση για την απελευθέρωση χώρου. Η εκκαθάριση δίσκου ενδέχεται να μην προτείνει την αφαίρεση αρχείων στους φακέλους Document, Videos, Pictures ή Download, οπότε θα πρέπει να τα διαγράψετε χειροκίνητα. Αφού το κάνετε αυτό, μην ξεχάσετε να αδειάσετε τον κάδο ανακύκλωσης. Αν έχετε μεγάλα αρχεία στα οποία δεν χρειάζεστε άμεση πρόσβαση, σκεφτείτε να τα μεταφέρετε σε έναν εξωτερικό SSD, σε μια μονάδα δίσκου δικτύου ή σε αποθηκευτικό χώρο cloud. Αυτό μπορεί να σας βοηθήσει να απελευθερώσετε χώρο στον SSD σας, διατηρώντας παράλληλα τα αρχεία σας προσβάσιμα. Να είστε προσεκτικοί όταν διαγράφετε αρχεία και βεβαιωθείτε ότι δεν αφαιρείτε κάτι σημαντικό. Αν το κάνετε, υπάρχουν ορισμένες συμβουλές για το πώς μπορείτε να ανακτήσετε διαγραμμένα αρχεία στα Windows και στο MacOS. Διαχείριση εφαρμογών Μια άλλη λύση που θα μπορούσατε να δοκιμάσετε είναι να επανεξετάσετε τις εφαρμογές που είναι εγκατεστημένες στον υπολογιστή σας και να απεγκαταστήσετε όσες δεν χρησιμοποιείτε ή δεν χρειάζεστε πλέον. Αν δεν τη χρησιμοποιήσατε για κάποιο χρονικό διάστημα, οι πιθανότητες είναι ότι δεν τη χρειάζεστε. Αυτό μπορεί να βοηθήσει στην ανάκτηση χώρου που καταλαμβάνεται από περιττό λογισμικό και μπορεί επίσης να βοηθήσει στην αύξηση της απόδοσης του υπολογιστή σας. Όλες οι εγκατεστημένες εφαρμογές χρησιμοποιούν χώρο στη μνήμη RAM και η απεγκατάσταση αχρησιμοποίητων εφαρμογών θα καθαρίσει τη μνήμη σας και θα αυξήσει την ταχύτητά σας. Για να επανεξετάσετε τις εφαρμογές που είναι εγκατεστημένες στο σύστημα των Windows σας: Πατήστε "Windows + I" για να μεταβείτε στις ρυθμίσεις των Windows. Κάντε κλικ στην καρτέλα "Σύστημα". Κάντε κλικ στην επιλογή "Αποθήκευση", αυτό θα σας δείξει τις εφαρμογές και τις λειτουργίες της τοπικής σας μονάδας δίσκου C, την επιφάνεια εργασίας, τα βίντεο, τα προσωρινά αρχεία και άλλα. Κάντε κλικ στο "Εφαρμογές και δυνατότητες" και στην επόμενη σελίδα θα εμφανιστεί μια λίστα με τις εγκατεστημένες εφαρμογές. Εδώ, μπορείτε να απεγκαταστήσετε τυχόν εφαρμογές που δεν χρησιμοποιείτε ή δεν χρειάζεστε πλέον. Συλλογή σκουπιδιών και TRIM Οι SSD είναι οργανωμένοι σε κελιά, σελίδες, μπλοκ, κύβους και τσιπ. Οι λειτουργίες εγγραφής πραγματοποιούνται σε επίπεδο σελίδας, ωστόσο λόγω της φύσης του NAND flash, οι λειτουργίες διαγραφής μπορούν να πραγματοποιηθούν μόνο σε επίπεδο μπλοκ. Αυτό σημαίνει ότι τα δεδομένα σε μια συγκεκριμένη σελίδα δεν μπορούν να αντικατασταθούν, αλλά το firmware του SSD πρέπει να εκτελέσει αυτό που αναφέρεται ως ανάγνωση-τροποποίηση-εγγραφή. Εάν τα δεδομένα σε μια συγκεκριμένη σελίδα πρέπει να αντικατασταθούν, όλα τα παλιά δεδομένα διαβάζονται και επανεγγράφονται σε ένα νέο μπλοκ. Αυτή η διαδικασία είναι "δαπανηρή" όσον αφορά την ενίσχυση της εγγραφής και την υποβάθμιση της απόδοσης. Η TRIM είναι μια εντολή στη διεπαφή ATA (Advanced Technology Attachment). Ήρθε για να βοηθήσει τους SSD να αναγνωρίζουν τα αχρησιμοποίητα μπλοκ δεδομένων και να τα αποδεσμεύουν, ώστε να δημιουργηθεί χώρος για νέες εγγραφές. Αυτό μπορεί να συμβεί διαφανώς στο παρασκήνιο, εάν διαγραφούν ή μετακινηθούν αρχεία. Το ισοδύναμο της TRIM στο NVMe είναι η εντολή διαχείρισης συνόλου δεδομένων. Απενεργοποίηση της αδρανοποίησης και της επαναφοράς συστήματος Οι λειτουργίες της αδρανοποίησης και της επαναφοράς συστήματος μπορούν να καταλαμβάνουν σημαντικό μέρος του χώρου αποθήκευσης. Για να ανακτήσετε το χώρο στο δίσκο που χρησιμοποιείται από το αρχείο αδρανοποίησης, έχετε τη δυνατότητα να απενεργοποιήσετε την αδρανοποίηση και να μειώσετε τον διατιθέμενο χώρο για τα σημεία επαναφοράς συστήματος, εάν απαιτείται. Είναι σημαντικό να σημειωθεί ότι η απενεργοποίηση αυτών των λειτουργιών ενδέχεται να περιορίσει τη δυνατότητά σας να ανακτήσετε δεδομένα ή να θέσετε τον υπολογιστή σας σε κατάσταση χαμηλής κατανάλωσης ενέργειας. Για να το κάνετε αυτό, στα Windows- απλά πατήστε το πλήκτρο Windows, πληκτρολογήστε και κάντε κλικ στην εφαρμογή "Command Prompt" και επιλέξτε "Εκτέλεση ως διαχειριστής". Πληκτρολογήστε "Powercfg.exe /hibernate off". Στη συνέχεια, πληκτρολογήστε "Exit" (Έξοδος) και enter για να κλείσετε την εφαρμογή "Command Prompt" (Γραμμή εντολών). Αναβαθμίστε τον SSD σας Εάν έχετε δοκιμάσει τα παραπάνω βήματα και εξακολουθείτε να χρειάζεστε περισσότερο χώρο, μπορείτε να εξετάσετε το ενδεχόμενο αναβάθμισης του SSD σας σε δίσκο μεγαλύτερης χωρητικότητας. Αν το σύστημά σας το επιτρέπει και αν δεν το έχετε ήδη κάνει, ένας NVMe SSD θα μπορούσε να είναι η τέλεια αναβάθμιση. Εκτός από την ενίσχυση του αποθηκευτικού χώρου, θα έχετε επίσης πρόσβαση σε αυξημένες ταχύτητες, βελτιωμένες επιδόσεις και ανώτερη ενεργειακή απόδοση. Ο SSD KC3000 NVMe M.2 της Kingston χρησιμοποιεί τον πιο πρόσφατο ελεγκτή NVMe Gen 4x4 και την τεχνολογία 3D TLC NAND για να προσφέρει εξαιρετικά αποτελέσματα. Με την αναβάθμιση του αποθηκευτικού σας χώρου, μπορείτε να χειρίζεστε απρόσκοπτα απαιτητικούς φόρτους εργασίας και να απολαμβάνετε ανώτερες ταχύτητες με αξιοσημείωτες ταχύτητες ανάγνωσης/εγγραφής έως και 7.000MB/s. Αυτός ο SSD εξασφαλίζει βελτιστοποιημένη ροή εργασιών σε επιτραπέζιους και φορητούς υπολογιστές υψηλών επιδόσεων. Είναι ειδικά σχεδιασμένη για ισχυρούς χρήστες που απαιτούν μόνο τις ταχύτερες ταχύτητες που διατίθενται στην αγορά.- 7 comments
- 7
- dyi pc
- kingston technology
- (και 4 επιπλέον)
Οι περισσότεροι χρήστες Android δεν έχουν μάλλον δει ποτέ το Google Play Protect σε δράση. Η υπηρεσία σάρωσης κακόβουλου λογισμικού είναι ενσωματωμένη σε κάθε συσκευή Android και υποτίθεται ότι επισημαίνει το κακόβουλο λογισμικό που έχουν εγκαταστήσει οι χρήστες. Πρόσφατα σημείωσε κάποιες δημοφιλείς εφαρμογές που δεν είναι σε καμία περίπτωση κακόβουλο λογισμικό: Samsung Wallet και Samsung Messages. Όπως εντοπίστηκε από το 9to5Google, οι χρήστες της Samsung έχουν δεχθεί προειδοποιήσεις από το Play Protect από τις αρχές του μήνα. Οι χρήστες στο φόρουμ υποστήριξης της Google έχουν δημοσιεύσει στιγμιότυπα οθόνης του Play Protect που επισημαίνει τις εφαρμογές του συστήματος της Samsung, και ακόμη και η Samsung απάντησε στο ζήτημα, εξηγώντας (στα κορεατικά) πώς να διορθώσετε τυχόν ζημιές που προκλήθηκαν από το σφάλμα. Η Samsung αναφέρει (μέσω μετάφρασης) ότι το ζήτημα προκλήθηκε από "μια προσωρινή βλάβη του διακομιστή της Google" και θα πρέπει τώρα να διορθωθεί. Το Samsung Wallet και τα Samsung Messages έρχονται και τα δύο μαζί με τα περισσότερα τηλέφωνα Samsung ως εφαρμογές συστήματος, οπότε έχουν ευρεία βάση εγκατάστασης. Όταν το Play Protect επισημαίνει μια εφαρμογή ως επιβλαβή, εμφανίζεται ένα μήνυμα που προτείνει στους χρήστες να αφαιρέσουν την εφαρμογή, αλλά δεδομένου ότι και οι δύο αυτές εφαρμογές είναι εφαρμογές συστήματος, οι χρήστες μπορούν μόνο να τις απενεργοποιήσουν. Με την επίλυση του προβλήματος, η Samsung αναφέρει ότι μπορείτε να επαναφέρετε την εφαρμογή σε λειτουργία πηγαίνοντας στις ρυθμίσεις της εφαρμογής και ενεργοποιώντας την εκ νέου, αν και οι ρυθμίσεις σας έχουν πιθανότατα διαγραφεί. Ορισμένοι χρήστες αντιμετώπιζαν αυτό το σφάλμα απενεργοποιώντας τη σάρωση Play Protect, κάτι το οποίο δε προτείνεται και είναι μάλλον καλύτερο να την ενεργοποιήσετε ξανά.
Η επερχόμενη εκδήλωση "Scary Fast" της Apple θα επικεντρωθεί στα μοντέλα MacBook Pro της σειράς M3, σύμφωνα με τον αναλυτή της Apple Ming-Chi Kuo. Η διατύπωση του Ming-Chi Kuo υποδηλώνει ότι αναμένει πολλαπλά τσιπ M3 και όχι μόνο ένα τσιπ M3, υπονοώντας την πιθανότητα τσιπ M3, M3 Pro και M3 Max. Εάν η Apple κυκλοφορήσει τα τσιπ M3, M3 Pro και M3 Max ταυτόχρονα, μπορούμε να περιμένουμε να δούμε τα νέα τσιπ να παρουσιάζονται στα μοντέλα MacBook Pro 13, 14 και 16 ιντσών. Ο Kuo λέει ότι είχε προβλέψει προηγουμένως ότι η Apple δεν θα εισάγει πιθανότατα νέα μοντέλα MacBook Pro το 2023 λόγω των "περιορισμένων αποστολών του 4ου τριμήνου του 23" και αν τα νέα MacBook Pro κυκλοφορήσουν τον Νοέμβριο ή τον Δεκέμβριο, η περιορισμένη προσφορά θα διαρκέσει μέχρι το πρώτο τρίμηνο του 2024. Αναφέρει επίσης ότι οι αποστολές Mac έχουν μειωθεί λόγω της "περιορισμένης αναβάθμισης της υπολογιστικής ισχύος M2", η οποία μπορεί να είναι ο λόγος για τον οποίο η Apple μπορεί να λανσάρει μοντέλα M3 MacBook Pro με χαμηλό όγκο παραγωγής. Ο Mark Gurman του Bloomberg αναφέρει επίσης ότι η Apple έχει δοκιμάσει τα μοντέλα M3 Max και M3 Pro MacBook Pro, γεγονός που υποδηλώνει ότι αυτά τα μηχανήματα πρόκειται να ανανεωθούν. Ο Gurman μόλις την περασμένη εβδομάδα υποστήριξε ότι η Apple δεν θα αναβαθμίσει τα μοντέλα MacBook Pro 14 και 16 ιντσών με τα τσιπ M3 Pro και M3 Max μέχρι τις αρχές του 2024, οπότε φαίνεται ότι οι προβλέψεις του έχουν αλλάξει από τότε. Το γεγονός ότι τόσο ο Kuo όσο και ο Gurman προτείνουν τώρα ότι θα δούμε μοντέλα MacBook Pro 14 και 16 ιντσών στην εκδήλωση της Apple τον Οκτώβριο αποτελεί έκπληξη, επειδή πολλές από τις προηγούμενες πληροφορίες τους έδειχναν προς μια ανανέωση του 2024 για αυτές τις συσκευές. Ο Gurman υποστηρίζει ότι η Apple δεν θα ανανεώσει τα μοντέλα MacBook Air, Mac mini, Mac Studio ή Mac Pro αυτή τη στιγμή, γεγονός που αφήνει το iMac, το MacBook Pro 13 ιντσών, το MacBook Pro 14 ιντσών και το MacBook Pro 16 ιντσών για την εκδήλωση του Οκτωβρίου. Όπως έχει ήδη επισημάνει ο Gurman, αυτά είναι τα μηχανήματα που αντιμετωπίζουν παρατεταμένους χρόνους αποστολής στο ηλεκτρονικό κατάστημα της Apple. Σύμφωνα με τον Kuo, αν τα μοντέλα M3 δεν καταλήξουν να ενισχύσουν τις αποστολές MacBook, υπάρχει αυξημένη πιθανότητα για ένα "ολοκαίνουργιο σχεδιαστικά MacBook Pro το 2025" και επίσης μια πιθανότητα η Apple να εξετάσει ένα "πιο προσιτό μοντέλο MacBook".
Thermaltake, the leading PC DIY premium brand for Case, Power, Cooling, Gaming peripherals, and enthusiast Memory solutions, is delighted to launch the TGM-I27FQ Gaming Monitor and the TGM-V32CQ Curve Gaming Monitor, the high-quality QHD (2560x1440) screen designed for professional gamers. The TGM-I27FQ features a 165Hz rapid refresh rate and fast IPS technology, allowing users to enjoy a smoother experience and superior image while playing fast moving games. The TGM-V32CQ comes with a 170Hz rapid refresh rate and 1000R curvature, enabling deeply immersive gameplay by instant reaction on the screen and perfect viewing angles. To satisfy the different preferences of gaming enthusiasts, Thermaltake releases two models of gaming monitors. One is the TGM-I27FQ, a 27-inch flat monitor that can present game scenes in excellent color. It offers a 165Hz rapid refresh rate and a 1ms response time (GtG), guaranteeing the highest visual performance by eliminating lagging and motion blur on the screen. This gaming monitor has a cinema-standard DCI-P3 95% color gamut, allowing a wider range of colors to be delivered compared to ordinary monitors and displaying more refined images. Additionally, the fast IPS technology of the TGM-I27FQ is beneficial for color accuracy from wide-angle positions. Another gaming monitor published together is the TGM-V32CQ, a 32-inch curved monitor that can achieve immersive gameplay. It features a 170Hz rapid refresh rate and a 1ms response time (MPRT), and comes with a significant advantage while playing fast moving game genres such as first person shooters, racing sims, real-time strategy, etc. Its DCI-P3 90% color gamut fully shows the detailed game scene to push immersion to its limits. The 1000R curvature of the TGM-V32CQ perfectly matches human eyesight and improves viewing comfort, it is the best choice for an immersive game experience. The TGM-I27FQ and the TGM-V32CQ both are compatible with G-SYNC and AMD FreeSync Premium, dynamically matching GPUs’ frame rate and displays’ refresh rate, avoiding tearing, stuttering, flicker, or artifacts in any game. The 400 nits brightness and the ultra shadow boost of these two gaming monitors make the scene, including the dark areas, sharper and more vivid. Health-oriented designs have also been considered, the TGM-I27FQ and the TGM-V32CQ are designed with flicker free and ultra-low blue light, preventing your eyes from fatigue and potentially harmful blue light without scarifying true RGB colors. Furthermore, their ergonomically designed stands offer height adjustments, swivel, pivot, and tilt, enabling you to freely set your ideal viewing position. The TGM-I27FQ and the TGM-V32CQ are QHD (2560x1440) gaming monitors designed for gaming enthusiasts. With a rapid refresh rate of over 165Hz, a 1ms response time, and a cinema-standard DCI-P3 color gamut coverage, these two monitors can generate better images with clear details and bring your game immersion to a whole new level! To learn more about the TGM-I27FQ Gaming Monitor, please visit: https://www.thermaltake.com/tgm-i27fq-gaming-monitor.html To learn more about the TGM-V32CQ Curve Gaming Monitor, please visit:https://www.thermaltake.com/tgm-v32cq-curve-gaming-monitor.html
- curve
- gaming monitor
(και 3 επιπλέον)
Ζήστε τη συναρπαστική ατμόσφαιρα του αθλητισμού όπως ποτέ άλλοτε με την τελευταία πρωτοποριακή τηλεόραση της LG, την LG NANO756. Σχεδιασμένη με γνώμονα τους παθιασμένους λάτρεις των σπορ, αυτή η τηλεόραση υπόσχεται να απογειώσει τη θέαση αθλητικών γεγονότων, εξασφαλίζοντας ότι θα «πιάσετε» κάθε συναρπαστική στιγμή, από τους πανηγυρισμούς του κοινού μέχρι κάθε κίνηση στο γήπεδο. Ο κομψός, μοντέρνος σχεδιασμός μπορεί να είναι το πρώτο πράγμα που θα παρατηρήσετε, αλλά τα αληθινά χρώματα και η ρεαλιστική εικόνα, χάρη στην τεχνολογία NanoCell, είναι αυτά που θα σας καθηλώσουν. Όλα τα γκολ, τα καλάθια και οι γραμμές τερματισμού θα εμφανίζονται με αληθινά χρώματα και ολοζώντανη ευκρίνεια, εξασφαλίζοντας ότι θα νιώθετε κάθε στιγμή σαν να βρίσκεστε στο γήπεδο. Η LG γνωρίζει ότι στον αθλητισμό, κάθε δευτερόλεπτο μετράει. Με ανάλυση Real 4K, η LG NANO756 διασφαλίζει ότι θα πιάσετε κάθε λεπτομέρεια σε κρυστάλλινη ευκρίνεια. Σε συνδυασμό με το καινοτόμο HDR 10 Pro, τα αθλητικά γεγονότα γίνονται ένα ζωντανό θέαμα με πλουσιότερες αντιθέσεις, κάνοντας κάθε παιχνίδι και αγώνα μια πρωτόγνωρη εμπειρία ψυχαγωγίας. Αλλά τι είναι ο αθλητισμός χωρίς τον συναρπαστικό ήχο του γηπέδου; Το AI Sound Pro της NANO756 είναι το εισιτήριό σας για τις κερκίδες. Μέσω αλγορίθμων "Deep learning AI", μετατρέπει τον ήχο 2 καναλιών σε εικονικό ήχο surround 5.1.2, φέρνοντας τα συνθήματα, τους πανηγυρισμούς και τη δράση στο γήπεδο απευθείας στο σαλόνι σας. Είτε πρόκειται για το θορυβώδες πλήθος ενός ποδοσφαιρικού αγώνα είτε για το τρίξιμο των παπουτσιών στο παρκέ σε μια μπασκετική αναμέτρηση, θα νιώσετε την ατμόσφαιρα με κρυστάλλινο, δυναμικό ήχο. Ως κεντρικός κόμβος για το έξυπνο σπίτι σας, η LG NANO756 με τεχνολογία ThinQ® AI[1] ανεβάζει την προβολή αθλητικών μεταδόσεων στο επόμενο επίπεδο. Θέλετε να ελέγξετε τα στατιστικά στοιχεία των παικτών ή να ανατρέξετε σε στιγμιότυπα παλαιότερων αγώνων; Απλά πείτε τη λέξη. Η φωνητική λειτουργία είναι διαθέσιμη για να σας προσφέρει μια άνετη και εξατομικευμένη εμπειρία. Διαθέσιμη σε 55 και 65 ίντσες, η LG NANO756 είναι κάτι περισσότερο από μια απλή τηλεόραση. Είναι μια ολοκληρωμένη εμπειρία σχεδιασμένη για τους λάτρεις των σπορ. Μια απόδειξη της συνεχούς προσπάθειας της LG για καινοτομία, η NANO756 είναι έτοιμη να επαναπροσδιορίσει τον τρόπο με τον οποίο βιώνουμε τον αθλητισμό στο σπίτι. [1] Η διαθεσιμότητα της υπηρεσίας ενδέχεται να διαφέρει ανά περιοχή ή χώρα.
Οι τιμές έχουν πάει στο θεό, λόγω έλλειψης επεξεργαστών
Είτε είστε σύμβουλος είτε πρέπει να βάλετε νέο προγραμματισμό στο γραφείο, το Microsoft Office είναι θεμελιώδες λογισμικό αποδοτικότητας. Αυτό το λογισμικό παραγωγικότητας περιλαμβάνει το Word, το Excel και το PowerPoint. Αυτό είναι μόνο η αρχή. Δεν χρειάζεται πλέον να ψάχνετε για δωρεάν και επικίνδυνα πακέτα λογισμικού στο διαδίκτυο, η Godeal24 Halloween Big Sale σας δίνει αληθινό αλλά φθηνό MS Office, είτε πρόκειται για το πιο πρόσφατο Office 2021, είτε για το Office 2019. Το Office 2021 με μόλις 26,75€ και το Office 2019 με μόλις 23,56€! Αν έχετε κάποια επιθυμία να μοιραστείτε με τους αγαπημένους σας, μπορείτε να επιλέξετε ένα πακέτο με πολλαπλά κλειδιά Office 2021 με μόλις 15,43€/PC! Τα Windows αποτελούν τη βάση των περισσότερων υπολογιστών. Μπορείτε να επωφεληθείτε από αυτή την προσφορά για να αγοράσετε τα πιο ευρέως χρησιμοποιούμενα κλειδιά των Windows 10 που είναι μόλις 8,65€! Το πιο οικονομικό πακέτο είναι το Windows 10 Pro 2PC, είναι λίγο πολύ τόσο χαμηλό όσο 7,43€ το καθένα, βοηθώντας σας να εξοικονομήσετε πάνω από 90%! Σας εύχομαι να περάσετε καλά τις Απόκριες! Το Office 2021 Professional Plus είναι ένα ολοκληρωμένο λογισμικό γραφείου που ενισχύει την παραγωγικότητα και περιλαμβάνει πολλές σημαντικές εφαρμογές, όπως το Word, το Excel, το PowerPoint, το Outlook κ.λπ. Το Office 2021 Pro επεξεργάζεται πλούσιες λειτουργίες και εργαλεία που μπορούν να βοηθήσουν τους χρήστες να ολοκληρώσουν διάφορες εργασίες πιο γρήγορα. Best value! 62% off on Microsoft Office! (coupon code "SGO62") l Office 2021 Professional Plus - 1 PC – 26.75€ l Office 2021 Home and Business για Mac - 37.28€ l Office 2021 Professional Plus - 2 Κλειδιά – 47.76€ only (23.88€/κλειδί) l Office 2021 Professional Plus - 3 Κλειδιά – 65.19€ only (21.73€/κλειδί) l Office 2021 Professional Plus - 5 PCs – 77.15€ only (15.43€/PC) l Office 2019 Professional Plus - 1 PC - 23.56€ l Office 2019 Home and Business for Mac - 27.19€ Επί του παρόντος, τα Windows 10 είναι η έκδοση με την υψηλότερη σταθερότητα και απόδοση στο λειτουργικό σύστημα. Το ίδιο το λογισμικό προγράμματος οδήγησης συστήματος του κατασκευαστή έχει βελτιωθεί και έχει διορθώσει τα περισσότερα από τα μικρά σφάλματα, έτσι ώστε η κάρτα γραφικών, ο σκληρός δίσκος, η οθόνη και ο ήχος να είναι πολύ ομαλά και σχεδόν τέλεια στα Windows 10. What a bargain!Huge discount on Windows OS: (coupon code " SGO50") l Windows 10 Professional - 1 PC – 8.65€ l Windows 10 Professional - 2 Κλειδιά – 14.86€ only (7.43€/κλειδί) l Windows 10 Professional - 5 Κλειδιά - 34.99€ only (6.99€/κλειδί) l Windows 10 Home - 1 PC – 8.61€ l Windows 11 Professional - 1 PC – 12.69€ l Windows 11 Professional - 2 Κλειδιά – 24.22€ (12.11€/κλειδί) l Windows 11 Professional - 5 Κλειδιά - 51.20€ only (10.24€/κλειδί) l Windows 11 Home - 1 PC – 12.25€ 62% off on Bundles and more MS Office (coupon code " SGO62") l Windows 11 Pro + Office 2021 Pro Plus - Bundle - 36.59€ l Windows 11 Pro + Office 2019 Pro Plus - Bundle – 34.11€ l Windows 10 Pro + Office 2021 Pro Plus - Bundle – 32.56€ l Windows 10 Pro + Office 2019 Pro Plus - Bundle – 28.29€ The amazing sale will make your jaw drop! Absolutely great deal! l Windows 10 Pro - 50 Κλειδιά - 325€ (Only 6.5€/κλειδί) l Windows 10 Pro - 100 Κλειδιά – 600€ (Only 6€/κλειδί) l Windows 11 Pro - 50 Κλειδιά – 400€ (Only 8€/κλειδί) l Windows 11 Pro - 100 Κλειδιά – 750€ (Only 7.5€/κλειδί) l Microsoft Office 2021 Pro - 50 Κλειδιά – 1050€ (Only 21€/κλειδί) l Microsoft Office 2021 Pro - 100 Κλειδιά – 2000€ (Only 20€/κλειδί) Essential computer tools at the best price! l Ashampoo PDF Pro 3 – 19.99€ l IObit Driver Booster 11 – 16.39€ l MacBooster 8 Lifetime Subscription – 10.24€ >>>Περισσότερα εργαλεία Πώς να πληρώσετε; ➢ Μεταβείτε στη σελίδα πληρωμής, συνεχίστε ως επισκέπτης (ή δημιουργήστε λογαριασμό) και, στη συνέχεια, συμπληρώστε τις "Πληροφορίες χρέωσης". ➢ Παρακαλούμε επιλέξτε "CWALLETCO" σε αυτό το βήμα και, στη συνέχεια, κάντε κλικ στο κουμπί "Συνέχεια". ➢ Παρακαλούμε ελέγξτε την παραγγελία σας και κάντε κλικ στο κουμπί "Place Order". ➢ Στη συνέχεια, θα μεταβείτε σε αυτή τη σελίδα, κάντε κλικ στο "Επιλέξτε μεθόδους πληρωμής". ➢ Τέλος, μπορείτε να επιλέξετε να χρησιμοποιήσετε το PayPal για να ολοκληρώσετε την πληρωμή. Στο Godeal24, μπορείτε να εξοικονομήσετε πολύ χρόνο και χρήμα με εκπτωτικές άδειες χρήσης της Microsoft, σημαντικά λογισμικά ασφαλείας πληροφορικής και άλλα εργαλεία υπολογιστών. Αποκτήστε το λειτουργικό σύστημα Windows και το MS Office σε ασυναγώνιστη τιμή. Ζήστε την εμπειρία αγορών χωρίς προβλήματα με την ψηφιακή παράδοση της Godeal24, η οποία στέλνει το λογισμικό σας απευθείας στο email σας μέσα σε λίγα δευτερόλεπτα από την αγορά. Επιπλέον, με βαθμολογία 98% Εξαιρετική στο TrustPilot και τεχνική υποστήριξη από ειδικούς 24/7, μπορείτε να είστε σίγουροι για την ποιότητα του προϊόντος που αγοράζετε. Η Godeal24 υπόσχεται ότι προσφέρει 24/7 επαγγελματική τεχνική υποστήριξη και ισόβια εξυπηρέτηση μετά την πώληση και ότι μπορείτε να χρησιμοποιήσετε το προϊόν χωρίς προβλήματα! Επικοινωνία με την Godeal24: service@godeal24.com
Περίπου 4,5 δισεκατομμύρια άνθρωποι παγκοσμίως, ή σχεδόν το 55% του παγκόσμιου πληθυσμού, έχουν τουλάχιστον ένα λογαριασμό σε ένα από τα μεγάλα μέσα κοινωνικής δικτύωσης. Οι χρήστες του διαδικτύου διεθνώς περνούν περίπου δυόμισι ώρες κάθε μέρα διαβάζοντας ειδήσεις, μοιράζοντας ιστορίες και ανταλλάσσοντας φωτογραφίες στις πλατφόρμες κοινωνικής δικτύωσης της επιλογής τους. Με άλλα λόγια, τα μέσα κοινωνικής δικτύωσης έχουν ανυπολόγιστη επίδραση στη ζωή μας, συμπεριλαμβανομένου του τρόπου με τον οποίο συναναστρεφόμαστε και αλληλοεπιδρούμε με άλλους ανθρώπους. Ωστόσο, στα μέσα κοινωνικής δικτύωσης δεν είναι όλα όπως φαίνονται, προειδοποιεί ο Phil Muncaster από την ομάδα της εταιρίας ψηφιακής ασφάλειας ESET. Όπως συμβαίνει γενικά με το διαδίκτυο, οι πλατφόρμες αυτές έχουν γίνει εστία απατεώνων και διακινητών ψευδών ειδήσεων. Ο τεράστιος όγκος των χρηστών, η δυναμική φύση του περιεχομένου που δημιουργείται από τους χρήστες και η ευελιξία των κακόβουλων παραγόντων καθιστούν την επιτήρηση αυτών των μέσων εξαιρετικά δύσκολη για τους παρόχους. Αυτό σημαίνει ότι οι χρήστες πρέπει να πάρουν την κατάσταση στα χέρια τους. Τα μέσα κοινωνικής δικτύωσης είναι ο παράδεισος για τους απατεώνες Ανάμεσα στις μεγαλύτερες απειλές που πρέπει να προσέχετε είναι οι φίλοι και οι ακόλουθοι που δεν είναι αυτοί που ισχυρίζονται ότι είναι. Οι απατεώνες χρησιμοποιούν ψεύτικα προφίλ, τα οποία συχνά καταχωρούνται και διαχειρίζονται από αυτοματοποιημένα ρομπότ, για να στέλνουν spam στους χρήστες με προσφορές που είναι υπερβολικά καλές για να είναι αληθινές, ιστορίες clickbait, ρομαντικές απάτες και πολλά άλλα. Οι απάτες μπορούν να περιλαμβάνουν έναν κακόβουλο σύνδεσμο της μορφής «κάντε κλικ για να δείτε ποιος επισκέφτηκε το προφίλ σας», μια ψεύτικη επενδυτική ευκαιρία σε κρυπτονομίσματα ή μια προσφορά δωρεάν δωροκάρτας. Η ουσία είναι ότι θέλουν τα χρήματά σας ή/και τα δεδομένα σας. Μπορεί να ελπίζουν ότι θα κάνετε κλικ σε έναν κακόβουλο σύνδεσμο, ενεργοποιώντας κρυφά τη λήψη κακόβουλου λογισμικού, ή ότι θα παραδώσετε οικειοθελώς προσωπικές πληροφορίες. Μπορεί ακόμη και να σας παγιδεύουν για μια ρομαντική απάτη ή απάτες με κρυπτονομίσματα. 10 συμβουλές για να εντοπίσετε τους απατεώνες Οι πλατφόρμες μέσων κοινωνικής δικτύωσης γίνονται όλο και καλύτερες στην αφαίρεση ψεύτικων προφίλ και λογαριασμών. Αλλά δεν είναι ούτε κατά διάνοια 100% επιτυχείς. Όλοι μας πρέπει να είμαστε πιο δύσπιστοι σε ό,τι βλέπουμε σε αυτές τις ιστοσελίδες. Ο Muncaster από την ESET μας προτείνει 10 τρόπους για να εντοπίζουμε τους απατεώνες: Ένα ασυνήθιστο βιογραφικό: Μπορεί οι ψεύτικοι λογαριασμοί να έχουν βιογραφικά που έχουν αντιγράψει από αλλού, οδηγώντας σε ένα αταίριαστο μείγμα προτάσεων. Επίσης, προσέξτε για τυπογραφικά λάθη, υπερβολικά emojis ή/και γλώσσα που είναι ενδεικτική ενός bot. Catfishers: Οι απατεώνες χρησιμοποιούν ψεύτικα προφίλ στα μέσα κοινωνικής δικτύωσης, όπως ακριβώς κάνουν και στις ιστοσελίδες γνωριμιών, με σκοπό να συνάψουν online μια ρομαντική σχέση με το θύμα, πριν ζητήσουν να τους μεταφερθούν χρήματα. Μια αντίστροφη αναζήτηση εικόνας θα πρέπει να είναι η πρώτη επιλογή. Ελέγξτε επίσης για κάποια από τα άλλα σημάδια ενός απατεώνα που αναφέρονται σε αυτό το άρθρο. Αναντιστοιχία μεταξύ "followers" και "following": Αυτό είναι ιδιαίτερα διαδεδομένο στο Instagram. Οι λογαριασμοί spam θα ακολουθήσουν αυτόματα εκατοντάδες ή χιλιάδες χρήστες, αλλά λίγοι θα τους ακολουθήσουν πίσω. Φωτογραφία προφίλ φίλου: Μερικές φορές οι απατεώνες προσπαθούν να κλωνοποιήσουν το λογαριασμό ενός φίλου σας. Στη συνέχεια, μπορεί να στείλουν ένα επείγον μήνυμα προσποιούμενοι ότι ο φίλος σας έχει πρόβλημα και να ζητήσουν χρήματα. Συμβαίνει πολύ εύκολα και ξεγελά πολλούς ανυποψίαστους χρήστες των μέσων κοινωνικής δικτύωσης. Πάντα να επικοινωνείτε με τον φίλο σας για να μάθετε αν όντως σας έστειλε ένα τέτοιο μήνυμα. Στείλτε τους μήνυμα μέσω άλλου μέσου. Εναλλακτικά, εξετάστε προσεκτικά τον λογαριασμό που στέλνει το μήνυμα. Εμφανίζει κάποιο από τα σημάδια απάτης που αναφέρονται εδώ; Spam άμεσων μηνυμάτων (Direct message - DM): Συχνά ένας απατεώνας θα προσπαθήσει να σας στείλει απευθείας μήνυμα με ψεύτικες προσφορές και θα σας ενθαρρύνει να στείλετε DM σε κάποιον άλλο ή να επισκεφθείτε μια ιστοσελίδα για να μάθετε περισσότερα. Αυτοί οι λογαριασμοί είναι ψεύτικοι και χρησιμοποιούνται για να πλασάρουν οτιδήποτε, από απάτες σε επενδύσεις κρυπτογράφησης μέχρι απάτες λιανικής πώλησης. Δεν υπάρχει επίσημο σήμα: Το , το και το X (Twitter) διαθέτουν σήματα ή σημάδια ελέγχου για την αναγνώριση των επίσημων λογαριασμών επιχειρήσεων, διασημοτήτων και άλλων. Αν δείτε έναν λογαριασμό που υποτίθεται ότι είναι ένας οργανισμός ή ένα διάσημο άτομο, αλλά δεν διαθέτει κανένα από αυτά, είναι πιθανό να είναι απατεώνας. Δραστηριότητα: Συχνά οι ψεύτικοι λογαριασμοί δημοσιεύουν αρκετό περιεχόμενο με τη μία - ίσως με παρόμοιες ή πανομοιότυπες λεζάντες - και στη συνέχεια σιωπούν. Ή μπορεί ακόμη και να μην κάνουν καθόλου αναρτήσεις. Ελέγξτε λοιπόν την ποσότητα, την ποιότητα και τον ρυθμό των αναρτήσεων. Προσφορές δώρων: Προσοχή σε λογαριασμούς που σας προσφέρουν δώρα ή/και μετρητά - ίσως σε αντάλλαγμα για τη συμπλήρωση μιας έρευνας. Μπορεί να υποδυθούν μια μεγάλη επώνυμη μάρκα για να το κάνουν αυτό. Θέλουν απλώς τις προσωπικές σας πληροφορίες. Είδη με μεγάλη έκπτωση: Οι ψεύτικοι λογαριασμοί μπορεί επίσης να προωθούν είδη πολυτελείας που έχουν μειωμένη τιμή. Να θυμάστε, αν είναι πολύ καλό για να είναι αληθινό, συνήθως δεν είναι. Άσχετα σχόλια: Εάν ένας λογαριασμός αφήνει σχόλια στις δημοσιεύσεις σας που δε σχετίζονται με τη συγκεκριμένη δημοσίευση, είναι πολύ πιθανό να πρόκειται για ψεύτικο λογαριασμό. Πώς να αναφέρετε ψεύτικα προφίλ Τα καλά νέα είναι ότι πολλά κοινωνικά μέσα, όπως το Instagram και το LinkedIn, αναζητούν συνεχώς τρόπους για να βελτιώσουν την επαλήθευση λογαριασμών και να απομακρύνουν τους ψεύτικους χρήστες και τα bots από τις πλατφόρμες τους. Ωστόσο, ένα από τα καλύτερα εργαλεία που διαθέτουν για να εντοπίζουν ψεύτικους λογαριασμούς είναι οι χρήστες τους. Αν συναντήσετε ένα ψεύτικο προφίλ, δείτε πώς μπορείτε να το αναφέρετε σε τέσσερα από τα κύρια μέσα κοινωνικής δικτύωσης: Facebook.Αν κάποιος παριστάνει εσάς, επισκεφθείτε αυτή τη σελίδα. Αν εντοπίσετε ένα ψεύτικο προφίλ, κάντε κλικ στο κουμπί με τις τρεις τελείες στο κάτω μέρος της φωτογραφίας του προφίλ και στη συνέχεια "Εύρεση, υποστήριξη ή αναφορά" ή "Αναφορά σελίδας". X (Twitter).Μπορείτε να κάνετε αναφορά εδώ. Ή κάντε κλικ στις τρεις τελείες δίπλα στο όνομα του λογαριασμού και ακολουθήστε τις οδηγίες. Instagram. Κάντε κλικ στις τρεις τελείες δίπλα στο όνομα του λογαριασμού και στη συνέχεια στην επιλογή "Αναφορά". Ή κάντε κλικ εδώ για να αναφέρετε έναν λογαριασμό που παριστάνει εσάς, την επιχείρησή σας ή το παιδί σας. LinkedIn. Κάντε κλικ στο "Περισσότερα" κάτω από το όνομα του λογαριασμού και στη συνέχεια στο "Αναφορά/Μπλοκάρισμα" ή "Αναφορά κατάχρησης". Το καλύτερο αντίδοτο που έχουμε κατά των απατεώνων είναι να κάνουμε το προφίλ μας ιδιωτικό και στη συνέχεια να εξετάζουμε διεξοδικά όποιον θέλει να μας ακολουθήσει. Αν αυτό δεν είναι εφικτό, λάβετε υπόψη σας τα παραπάνω για να παραμείνετε πιο ασφαλείς στο διαδίκτυο.
- ακόλουθοι
- μέσα κοινωνικής δικτύωσης
(και 2 επιπλέον)
Σε αντίθεση με την αντίπαλό της Nvidia, η AMD δεν έχει ακόμη αξιοποιήσει σημαντικά την άνοδο της τεχνητής νοημοσύνης (ΤΝ), αλλά φαίνεται ότι η εταιρεία πρόκειται να κερδίσει ορισμένα σημαντικά συμβόλαια με κορυφαίους παρόχους υπηρεσιών cloud. Όπως προκύπτει, η Oracle πρόκειται να χρησιμοποιήσει τις GPUs Instinct MI300X AI και HPC της AMD για τις υπηρεσίες cloud της, αναφέρει η MT Newswires επικαλούμενη την UBS. Και η IBM αναμένεται να χρησιμοποιήσει τις λύσεις Xilinx FPGA της AMD για εργασίες με ΤΝ, αναφέρει το Medium. Η υποδομή cloud της Oracle παλεύει με τις ελλείψεις GPU της Nvidia, επηρεάζοντας τη βραχυπρόθεσμη ανάπτυξή της, όπως σημειώνει η UBS. Παρόλα αυτά, η Oracle παραμένει αισιόδοξη, σχεδιάζοντας σημαντική επέκταση της ανάπτυξης της H100 GPU μέχρι το 2024 και την ανάπτυξη των επεξεργαστών Instinct MI300X της AMD ως εναλλακτική λύση. Η Oracle φέρεται να έχει αποφασίσει να μην παρακάμψει τις ελλείψεις GPU για ΤΝ και HPC ξεκινώντας το δικό της πρόγραμμα ανάπτυξης επεξεργαστών, καθώς θα χρειαστούν χρόνια για αυτό να καρποφορήσει. Αντ' αυτού, η εταιρεία θέτει στο στόχαστρό της τις προσφορές Instinct MI300X της AMD, οι οποίες υπόσχονται να προσφέρουν τρομερό επίπεδο επιδόσεων. Ο γίγαντας του cloud αναμένεται να είναι από τους πρώτους που θα αναπτύξουν αυτούς τους επεξεργαστές στις αρχές του 2024. Η Oracle δεν είναι η μόνη εταιρεία που κοιτάζει πέρα από την Nvidia για τις προσπάθειες AI που καταβάλλει. Η νέα πλατφόρμα εξαγωγής συμπερασμάτων AI της IBM χρησιμοποιεί το τσιπ NR1 AI της NeuReality, το οποίο κατασκευάζεται με την τεχνολογία διεργασίας κλάσης 7nm της TSMC. Η AMD διαδραματίζει σημαντικό ρόλο παρέχοντας τα εξαρτήματα FPGA που είναι απαραίτητα για τη λύση AI της NeuReality, μια συνεισφορά που πρόκειται να επωφεληθεί χάρη στην ισχυρή υποδομή που έχει δημιουργήσει η πλατφόρμα συμπερασματικής ΤΝ της IBM. Η Foxconn αναμένεται να ξεκινήσει την παραγωγή διακομιστών AI που χρησιμοποιούν αυτή την τεχνολογία το τέταρτο τρίμηνο του 2023.
Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, warmly congratulates the winners of the 2023 Thermaltake NeonMaker Lighting Mix Invitational Season 1. In first place is Ronald Bodinger from Austria, in second place is Krittanon Kidprasert from Thailand, and in third place is Michael Dexter from the United Kingdom. For 2023 Thermaltake NeonMaker Lighting Mix Invitational Season 1, Thermaltake invited outstanding modders from all around the world to organize spectacular RGB light shows with the NeonMaker software and SWAFAN EX14 RGB PC Cooling Fans. NeonMaker is a premium RGB lighting editing software highly customizable for lighting effects on every single LED light bulb. Users can create their unparalleled lighting effects on their PC via built-in effects, custom colors, and set-up timelines with NeonMaker. Furthermore, the SWAFAN EX features a Magnetic Force Quick Connect Design, allowing contestants to minimize cable usage and create a better final project. All light shows display stunning arrangements from their colorful lighting effects, creative fan placement, and well-designed props, taking this event to a whole new level, and it was challenging for the judges and the public to choose the winners. Thermaltake would like to express our gratitude to all the participants, including the modding enthusiasts and the public, for their great support. Lastly, to congratulate the top three winners again, and hope to see you all soon at the upcoming events! Meet the Winners 1st Place [Ronald Bodinger]: Ronald made good use of background music, SWAFAN EX placement, and props to match the lighting effect design. He organized a fantastic lighting show to express abstract emotions, allowing the audience and the judges to be impressed by its artistry and winning first place. 2nd Place [Krittanon Kidprasert]: Krittanun produced an exciting anime-themed lighting show with his remarkable color matching and video editing skills. He showed the various moving lighting effects, the utilization of NeonMaker software, and the features of SWAFAN EX in his video to make the content more wonderful. 3rd Place [Michael Dexter]: From color mix to effect modes, Michael applied many combinations for the lighting effects, fully presenting his creativity. His video included a variety of lighting profiles in different styles, some are energetic and some are calm, all together became an amazing lighting show that you never get bored with. More information, photos, and other content on the event can be found on: Event website: https://lightmix.thermaltake.com/2023s1/ Tt Community: https://bit.ly/3NYyS2t Top 3 winners video: https://youtu.be/TKV-WoTyc7Q Mark of Perfection The entries were all superior quality and demonstrated the modders’ extraordinary RGB lighting design skills. Consequently, it was not easy for the panel of judges to select the winners. The judges were required to evaluate and score from four criteria, including Originality, Utilization, Artistry, and Video Quality. The total percentage of the score was allocated 25% by the Thermaltake CEO, 15% by Thermaltake Judges, 30% by Tt Community Members, and 30% by Professional Modders. After summing up the votes from the judges, the final result pointed to Ronald Bodinger, Krittanon Kidprasert, and Michael Dexter.
- neonmaker lighting mix invitational
- season 1
(και 2 επιπλέον)
Τα διαπιστευτήρια ασφαλείας, όπως τα ονόματα χρήστη και οι κωδικοί πρόσβασης, αποτελούν δελεαστικό στόχο για τους χάκερ και ακόμη και οι καλύτεροι διαχειριστές κωδικών πρόσβασης μπορεί να απειλούνται από καιρό σε καιρό. Αυτό συνέβη πρόσφατα με τον δημοφιλή διαχειριστή κωδικών πρόσβασης 1Password, ο οποίος αποκάλυψε πρόσφατα, ότι το σύστημα υποστήριξης Okta παραβιάστηκε από κακόβουλους χάκερ. Ευτυχώς, δεν φαίνεται να εκλάπησαν δεδομένα πελατών, οπότε αν χρησιμοποιείτε το 1Password, οι πληροφορίες σύνδεσής σας θα πρέπει να είναι ασφαλείς προς το παρόν. Ωστόσο, είναι πάντα καλό να ενημερώνετε τακτικά τους κωδικούς σας (ή να χρησιμοποιείτε passkeys) σε περίπτωση που πέσουν σε λάθος χέρια. Σε μια ανάρτηση στο ιστολόγιό της, η 1Password εξήγησε την κατάσταση. "Εντοπίσαμε ύποπτη δραστηριότητα στην παρουσία μας στην Okta που σχετίζεται με το περιστατικό του συστήματος υποστήριξης", δήλωσε η 1Password. "Μετά από ενδελεχή έρευνα, καταλήξαμε στο συμπέρασμα ότι δεν υπήρξε πρόσβαση σε δεδομένα χρηστών της 1Password". Μετά τον εντοπισμό ύποπτης δραστηριότητας στις 29 Σεπτεμβρίου, η 1Password "τερμάτισε αμέσως τη δραστηριότητα, διερεύνησε και δεν διαπίστωσε καμία παραβίαση των δεδομένων των χρηστών ή άλλων ευαίσθητων συστημάτων, είτε σε επίπεδο εργαζομένων είτε σε επίπεδο χρηστών". Η σύνδεση του περιστατικού με την Okta είναι ενδιαφέρουσα επειδή αποκαλύπτει μια βασική ευπάθεια. Η Okta βοηθά τις εταιρείες να διαχειρίζονται τους χρήστες τους και να διασφαλίζουν ότι όλοι μπορούν να συνδεθούν με ασφάλεια και προσφέρει επίσης υποστήριξη για αυτή τη διαδικασία. Στο πλαίσιο αυτό, οι πελάτες μερικές φορές ανεβάζουν αρχεία για να βοηθήσουν στη διάγνωση προβλημάτων, αλλά αυτά τα αρχεία μπορεί να περιέχουν ευαίσθητα δεδομένα, όπως tokens συνεδρίας και δεδομένα σύνδεσης. Σύμφωνα με μια λεπτομερή αναφορά από την 1Password, ένας χάκερ έκλεψε ένα cookie συνεδρίας από έναν υπάλληλο πληροφορικής της 1Password και στη συνέχεια προσπάθησε να αποκτήσει πρόσβαση στο ταμπλό του εργαζομένου και να ζητήσει μια λίστα με τους χρήστες διαχειριστές. Ευτυχώς, η πρώτη ενέργεια μπλοκαρίστηκε από την Okta, ενώ η δεύτερη οδήγησε στην αποστολή ενός αυτοματοποιημένου email σε άλλους διαχειριστές της 1Password, το οποίο τους ειδοποίησε για την παραβίαση. Ενώ οι πληροφορίες σύνδεσής σας είναι ασφαλείς -δεν φαίνεται να έχει αποκτήσει πρόσβαση σε δεδομένα χρηστών ο χάκερ- δείχνει πόσο εύκολα μπορούν να παραβιαστούν φαινομενικά ασφαλή συστήματα από κακούς παράγοντες. Ως απάντηση στο περιστατικό, η 1Password αναφέρει ότι μείωσε τον αριθμό των χρηστών "super admin", εφάρμοσε αυστηρότερους κανόνες σύνδεσης για τους διαχειριστές και έλαβε άλλα μέτρα. Παρά το επεισόδιο αυτό, θα πρέπει να εξακολουθείτε να επιλέγετε έναν από τους καλύτερους διαχειριστές κωδικών πρόσβασης για να διατηρείτε τα δεδομένα σύνδεσής σας ασφαλή. Εξάλλου, η χρήση μιας εφαρμογής για τη δημιουργία και την αποθήκευση μοναδικών κωδικών πρόσβασης για εσάς είναι πολύ πιο ασφαλής από τη χρήση των ίδιων εύκολα μαντεύσιμων στοιχείων σύνδεσης για κάθε λογαριασμό.
Η Kioxia και η Western Digital Corp. βρίσκονται στο κατώφλι της ολοκλήρωσης της συγχώνευσής τους, η οποία αναμένεται να συμφωνηθεί από αυτόν τον μήνα, σύμφωνα με το Kyodo News. Η ένωση αυτή είναι έτοιμη να καταστήσει τη συνδυασμένη οντότητα τον μεγαλύτερο κατασκευαστή μνήμης NAND flash στον κόσμο. Η προτεινόμενη ιδιοκτησιακή δομή του νέου ομίλου έχει σχεδιαστεί σχολαστικά. Οι μέτοχοι της Western Digital προβλέπεται να κατέχουν την πλειοψηφία των μετοχών, ξεπερνώντας το 50%, ενώ η υπόλοιπη ιδιοκτησία θα αποδοθεί στους μετόχους της Kioxia, συμπεριλαμβανομένης μιας αξιοσημείωτης συνεισφοράς από την Toshiba Corp. Αρχικά, οι ηγετικοί και εκτελεστικοί ρόλοι αναμένεται να κυριαρχηθούν από την ομάδα της Kioxia, αλλά αυτό αναμένεται να αλλάξει με την πάροδο του χρόνου. Η στρατηγική συνεργασία περιλαμβάνει τον σχηματισμό μιας εταιρείας συμμετοχών, ενσωματώνοντας την τεχνογνωσία τους στην παραγωγή τσιπ μνήμης NAND flash, με όραμα την εισαγωγή του νέου ομίλου στο χρηματιστήριο Nasdaq των ΗΠΑ. Η Western Digital στοχεύει να κατέχει το 51% της νέας οντότητας. Το υπόλοιπο 49% θα διανεμηθεί μεταξύ των μετόχων της Kioxia, συμπεριλαμβανομένης της Toshiba, η οποία κατέχει το 40% της Kioxia. Ως αποτέλεσμα, η Toshiba αναμένεται να κατέχει περίπου το 19,6% της νέας οντότητας. Στην ανταγωνιστική αρένα της παραγωγής μνήμης NAND, η συγχώνευση σηματοδοτεί μια μνημειώδη αλλαγή. Μαζί, η Kioxia και η Western Digital πρόκειται να επισκιάσουν τον σημερινό ηγέτη, τη Samsung Electronics, κατέχοντας ένα τρομερό μερίδιο αγοράς. Η συνδυασμένη υπεροχή τους στις μνήμες NAND αναμένεται να φτάσει περίπου το 34,3%, ποσοστό που επισκιάζει το μερίδιο 31,1% της Samsung από το δεύτερο τρίμηνο του 2023, σύμφωνα με την TrendForce. Εν τω μεταξύ, η νέα οντότητα θα είναι σημαντικά μεγαλύτερη από την SK Hynix, η οποία κατέχει μερίδιο στην Kioxia. Η νοτιοκορεατική εταιρεία ήλεγχε το 17,8% της αγοράς NAND το δεύτερο τρίμηνο, οπότε ο σχηματισμός ενός μεγαλύτερου παίκτη μπορεί να αποτελέσει πρόκληση για την SK Hynix. Η πλοήγηση στο ρυθμιστικό τοπίο αποτελεί τρομερή πρόκληση για την επιτυχία της συγχώνευσης. Η παγκόσμια έμφαση στο ρόλο της οικονομικής ασφάλειας των ημιαγωγών έχει ενταθεί, ρίχνοντας μια σκιά αβεβαιότητας στις κανονιστικές εγκρίσεις. Ιδιαίτερα, η στάση των κινεζικών αρχών παραμένει σημαντικό στοιχείο, δεδομένων των γεωπολιτικών και οικονομικών επιπτώσεων της αγοράς μνήμης 3D NAND. Μια κοινοπραξία μεγάλων ιαπωνικών τραπεζών, συμπεριλαμβανομένης της MUFG Bank και της αναπτυξιακής τράπεζας της Ιαπωνίας, εξετάζει ένα ισχυρό χρηματοδοτικό πακέτο. Αυτό το πακέτο, που ενδεχομένως να φτάσει έως και 1,9 τρισεκατομμύρια γιεν (12,7 δισεκατομμύρια δολάρια), αποσκοπεί στην προώθηση της συγχώνευσης προς την ολοκλήρωση. Ενώ οι αναφορές σχετικά με το σχέδιο της Western Digital να ενοποιήσει την επιχείρηση μνήμης NAND με την Kioxia κυκλοφορούν εδώ και μήνες, καμία από τις εταιρείες δεν έχει σχολιάσει την πιθανή συναλλαγή, για προφανείς λόγους.
Οι μηχανικοί της αποστολής Voyager της NASA λαμβάνουν μέτρα για να διασφαλίσουν ότι και τα δύο διαστημόπλοια, που εκτοξεύτηκαν το 1977, θα συνεχίσουν να εξερευνούν το διαστρικό διάστημα για τα επόμενα χρόνια. Μια από τις προσπάθειες αφορά υπολείμματα καυσίμων που φαίνεται να συσσωρεύονται μέσα σε στενούς σωλήνες σε ορισμένους από τους προωθητήρες του διαστημικού σκάφους. Οι προωθητήρες χρησιμοποιούνται για να κρατούν την κεραία κάθε διαστημικού σκάφους στραμμένη προς τη Γη. Αυτό το είδος συσσώρευσης έχει παρατηρηθεί σε άλλα διαστημόπλοια. Η ομάδα ανεβάζει επίσης ένα διορθωτικό πρόγραμμα λογισμικού (software patch) για να αποτρέψει την επανάληψη μιας δυσλειτουργίας που παρουσιάστηκε στο Voyager 1 πέρυσι. Οι μηχανικοί έλυσαν τη δυσλειτουργία και το patch έχει ως στόχο να αποτρέψει την επανεμφάνιση του προβλήματος στο Voyager 1 ή την εμφάνισή του στο δίδυμό του, το Voyager 2. Συσσώρευση υλικού στο σύστημα πρόωσης Οι προωθητήρες του Voyager 1 και του Voyager 2 χρησιμοποιούνται κυρίως για να κρατούν τις κεραίες του διαστημικού σκάφους στραμμένες προς τη Γη προκειμένου να επικοινωνούν. Τα διαστημόπλοια μπορούν να περιστρέφονται προς τρεις κατευθύνσεις - πάνω και κάτω, προς τα αριστερά και δεξιά και γύρω από τον κεντρικό άξονα, όπως ένας τροχός. Καθώς το κάνουν αυτό, οι προωθητήρες πυροδοτούνται αυτόματα και επαναπροσανατολίζουν το διαστημόπλοιο για να διατηρήσουν τις κεραίες τους στραμμένες προς τη Γη. Το προωθητικό υλικό ρέει στους προωθητήρες μέσω των γραμμών καυσίμου και στη συνέχεια περνάει μέσα από μικρότερες γραμμές στο εσωτερικό των προωθητήρων που ονομάζονται σωλήνες εισόδου προωθητικού υλικού και είναι 25 φορές στενότεροι από τις εξωτερικές γραμμές καυσίμου. Κάθε πυροδότηση των προωθητήρων προσθέτει μικροσκοπικές ποσότητες υπολειμμάτων προωθητικού, οδηγώντας σε σταδιακή συσσώρευση υλικού με την πάροδο δεκαετιών. Σε ορισμένους από τους σωλήνες εισόδου καυσίμου, η συσσώρευση γίνεται σημαντική. Για να επιβραδυνθεί αυτή η συσσώρευση, η αποστολή έχει αρχίσει να αφήνει τα δύο διαστημόπλοια να περιστρέφονται ελαφρώς περισσότερο προς κάθε κατεύθυνση πριν από την πυροδότηση των προωθητήρων. Αυτό θα μειώσει τη συχνότητα των πυροδοτήσεων των προωθητήρων. Οι προσαρμογές στο εύρος περιστροφής των προωθητήρων έγιναν με εντολές που εστάλησαν τον Σεπτέμβριο και τον Οκτώβριο και επιτρέπουν στο διαστημικό σκάφος να κινείται σχεδόν 1 μοίρα μακρύτερα προς κάθε κατεύθυνση από ό,τι στο παρελθόν. Η αποστολή εκτελεί επίσης λιγότερες και μεγαλύτερες πυροδοτήσεις, γεγονός που θα μειώσει περαιτέρω τον συνολικό αριθμό πυροδοτήσεων που γίνονται σε κάθε διαστημικό σκάφος. Οι προσαρμογές έχουν σχεδιαστεί προσεκτικά ώστε να εξασφαλίζεται ο ελάχιστος δυνατός αντίκτυπος στην αποστολή. Αν και οι περισσότερες περιστροφές από το διαστημικό σκάφος θα μπορούσαν να σημαίνουν ότι περιστασιακά χάνονται κομμάτια επιστημονικών δεδομένων - κάτι που μοιάζει με μια τηλεφωνική κλήση όπου ο συνομιλητής στην άλλη άκρη διακόπτεται περιστασιακά - η ομάδα κατέληξε στο συμπέρασμα ότι το σχέδιο θα επιτρέψει στα Voyagers να επιστρέψουν περισσότερα δεδομένα με την πάροδο του χρόνου. Οι μηχανικοί δεν μπορούν να γνωρίζουν με βεβαιότητα πότε οι σωλήνες εισόδου προωθητικού καυσίμου των προωθητήρων θα φράξουν εντελώς, αλλά αναμένουν ότι με αυτές τις προφυλάξεις, αυτό δεν θα συμβεί για τουλάχιστον πέντε ακόμη χρόνια, ενδεχομένως και πολύ περισσότερο. Η ομάδα μπορεί να λάβει πρόσθετα μέτρα τα επόμενα χρόνια για να παρατείνει ακόμη περισσότερο τη διάρκεια ζωής των προωθητήρων. "Σε τόσο προχωρημένο στάδιο της αποστολής, η ομάδα μηχανικών έρχεται αντιμέτωπη με πολλές προκλήσεις για τις οποίες δεν έχουμε κάποιο εγχειρίδιο, αλλά συνεχίζουν να βρίσκουν δημιουργικές λύσεις" δήλωσε η Linda Spilker, επιστήμονας του προγράμματος για την αποστολή στο Εργαστήριο Αεριοπροώθησης της NASA στη Νότια Καλιφόρνια. Patch-αρισμα του Voyager Το 2022, ο ενσωματωμένος υπολογιστής που προσανατολίζει το διαστημόπλοιο Voyager 1 με τη Γη άρχισε να στέλνει αλλοιωμένες αναφορές κατάστασης, παρά το γεγονός ότι κατά τα άλλα συνέχιζε να λειτουργεί κανονικά. Οι μηχανικοί της αποστολής χρειάστηκαν μήνες για να εντοπίσουν το πρόβλημα. Το σύστημα άρθρωσης και ελέγχου της στάσης (AACS) κατεύθυνε λανθασμένα τις εντολές, γράφοντάς τες στη μνήμη του υπολογιστή αντί να τις εκτελέσει. Μία από αυτές τις παραπλανητικές εντολές κατέληξε να αλλοιώσει την αναφορά κατάστασης του AACS πριν φτάσει στους μηχανικούς στο έδαφος. Η ομάδα διαπίστωσε ότι το AACS είχε εισέλθει σε λανθασμένη λειτουργία- ωστόσο, δεν μπόρεσαν να προσδιορίσουν την αιτία και έτσι δεν είναι σίγουροι αν το πρόβλημα θα μπορούσε να εμφανιστεί ξανά. Η επιδιόρθωση του λογισμικού θα πρέπει να το αποτρέψει αυτό. Αυτή η επιδιόρθωση είναι σαν ένα ασφαλιστήριο συμβόλαιο που θα μας προστατεύσει στο μέλλον και θα μας βοηθήσει να διατηρήσουμε αυτούς τους ανιχνευτές σε λειτουργία όσο το δυνατόν περισσότερο. Πρόκειται για τα μοναδικά διαστημόπλοια που λειτούργησαν ποτέ στο διαστρικό διάστημα, οπότε τα δεδομένα που στέλνουν πίσω είναι μοναδικής αξίας για την κατανόηση του τοπικού μας σύμπαντος δήλωσε η Suzanne Dodd του JPL, υπεύθυνη του προγράμματος Voyager. Τα Voyager 1 και Voyager 2 έχουν διανύσει περισσότερα από 15 δισεκατομμύρια και 12 δισεκατομμύρια μίλια από τη Γη, αντίστοιχα. Σε αυτές τις αποστάσεις, οι οδηγίες για την επιδιόρθωση θα χρειαστούν πάνω από 18 ώρες για να ταξιδέψουν στο διαστημικό σκάφος. Λόγω της ηλικίας του διαστημοπλοίου και του χρόνου καθυστέρησης της επικοινωνίας, υπάρχει κάποιος κίνδυνος το patch να αντικαταστήσει βασικό κώδικα ή να έχει άλλες ανεπιθύμητες επιπτώσεις στο διαστημόπλοιο. Για να μειωθούν αυτοί οι κίνδυνοι, η ομάδα έχει περάσει μήνες γράφοντας, αναθεωρώντας και ελέγχοντας τον κώδικα. Ως πρόσθετη προφύλαξη ασφαλείας, το Voyager 2 θα λάβει πρώτα την επιδιόρθωση και θα χρησιμεύσει ως δοκιμαστική βάση για το δίδυμό του. Το Voyager 1 βρίσκεται πιο μακριά από τη Γη από οποιοδήποτε άλλο διαστημικό σκάφος, γεγονός που καθιστά τα δεδομένα του πιο πολύτιμα. Η ομάδα ανέβασε το patch και θα κάνει μια ανάγνωση της μνήμης AACS για να βεβαιωθεί ότι βρίσκεται στη σωστή θέση την Παρασκευή 20 Οκτωβρίου. Αν δεν προκύψουν άμεσα προβλήματα, η ομάδα θα δώσει μια εντολή το Σάββατο 28 Οκτωβρίου για να δει αν το patch λειτουργεί όπως πρέπει.
Tο λανσάρισμα της σειράς τηλεοράσεων LG UHD UR76 θέτει νέα πρότυπα ανάλυσης οθόνης και ποιότητας εικόνας για τους καταναλωτές παγκοσμίως. Με έναν εκπληκτικό συνδυασμό τεχνολογίας και σχεδιασμού, το νέο μοντέλο LG UHD UR76 επαναπροσδιορίζει την οικιακή εμπειρία θέασης με την εξαιρετική ανάλυση οθόνης. Αυτή η τελευταία προσθήκη στη σειρά UHD της LG πρόκειται να φέρει επανάσταση στον τρόπο με τον οποίο οι θεατές βιώνουν το αγαπημένο τους περιεχόμενο. Η LG UHD UR76 διαθέτει ανάλυση που προσφέρει εκπληκτικές εικόνες με ζωντανά χρώματα, ευκρινείς λεπτομέρειες και ενισχυμένη αντίθεση. Με ενεργοποιημένη τη λειτουργία HDR10 Pro[1] προσφέρει βελτιστοποιημένα επίπεδα φωτεινότητας για ζωηρά χρώματα και αξιοσημείωτες λεπτομέρειες. Ο έλεγχος φωτεινότητας μέσω τεχνητής νοημοσύνης (AI) διασφαλίζει το τέλειο επίπεδο φωτεινότητας για οποιοδήποτε περιβάλλον, προσαρμόζοντας τη φωτεινότητα από τον περιβάλλοντα φωτισμό. Έτσι, είτε οι χρήστες παρακολουθούν τις αγαπημένες τους ταινίες, είτε παίζουν παιχνίδια, είτε κάνουν streaming περιεχομένου, η ποιότητα της εικόνας είναι ασύγκριτη. Με τη βοήθεια του FILMMAKER MODE™[2], οι χρήστες θα απολαμβάνουν τις ταινίες όπως τις οραματίστηκε ο σκηνοθέτης, χωρίς καμία προσαρμογή στην υφή ή σε άλλες οπτικές ρυθμίσεις της ταινίας, μεταφέροντας τον κινηματογράφο στο σαλόνι τους. Με επεξεργαστή α5 AI 4K Gen6[3] που βελτιώνει τις δυνατότητες της τηλεόρασης LG UHD, η εμπειρία είναι καθηλωτική ενώ η προηγμένη τεχνολογία οθόνης της LG εξασφαλίζει ότι κάθε καρέ είναι κρυστάλλινα καθαρό. Η υποστήριξη HDR βελτιώνει περαιτέρω την εμπειρία θέασης, κάνοντας τα χρώματα πιο ζωντανά και αληθινά. Οι χρήστες μπορούν να παρακολουθούν σε ανάλυση 4K περιεχόμενο χαμηλότερης ανάλυσης[4] σε μεγάλες οθόνες UHD, για να απολαμβάνουν ευκρίνεια και ακρίβεια σε κάθε στιγμή. Η σειρά LG UHD UR76 διατίθεται σε εκδόσεις 65, 75 & 85 ιντσών, για να ταιριάζει σε κάθε τύπο δωματίου, ενώ με την προηγμένη τεχνολογία και τον εντυπωσιακό σχεδιασμό της πρόκειται να γίνει η πρώτη επιλογή για τους καταναλωτές που αναζητούν το καλύτερο στην ψυχαγωγία. [1] Το HDR10 Pro δεν είναι μια μορφή κατά την οποία εφαρμόζεται καρέ-καρέ η Δυναμική χαρτογράφηση αποχρώσεων της LG για περιεχόμενο HDR10. [2] Η υποστήριξη για το FILMMAKER MODE™ ενδέχεται να διαφέρει ανάλογα με τη χώρα. [3]Το μοντέλο UR80 86" διαθέτει τον επεξεργαστή α7 AI 4K Gen6. [4] Η ποιότητα εικόνας του αναβαθμισμένου περιεχομένου διαφέρει ανάλογα με την ανάλυση της πηγής.
- filmmaker mode
- hdr
(και 7 επιπλέον)
