Everything posted by LocoDiceGR
AMD Radeon Software support & discussion (No legacy support)
LocoDiceGR απάντησε στο θέμα του Dj_ALeX topic στην ενότητα Κάρτες Γραφικών
AMD Crimsom ReLive 17.1.1 Support For Resident Evil™ 7: Biohazard Fixed Issues Dishonored™2 may experience an application crash or hang on some Radeon R9 380 configurations. Radeon ReLive may show an improper warning popup message when using Windows®7 basic themes. AMD XConnect™ Technology configurations may experience a blue screen system hang when audio drivers load. Solidworks™ will no longer terminate on unplug using AMD XConnect™ Technology configurations. Some system configurations may experience a black screen after installing Radeon Software Crimson ReLive Editions 16.12.1 and later. Display corruption or TDR may be experienced after applications wake up from a display timeout. Paragon™ may experience flickering in Multi GPU with DirectX®11. Radeon ReLive may crash or become unresponsive when toggling Multi GPU with Desktop Recording and/or Instant Replay enabled. Known Issues A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background. Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue. Shadow Warrior 2™ may experience an application hang when launched with Multi GPU enabled. Radeon RX 400 series products may experience scaling issues for some applications when using the display scaling feature. Deus Ex: Mankind Divided™ may experience an application hang when running in Multi GPU with DirectX®12 and performing a task switch. AMD Multi GPU configurations may experience a system hang or reboot during install when using tiled MST 4K or 5K displays. Mouse cursor corruption may be intermittently experienced on Radeon RX 480. Known Issues for Radeon ReLive The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues. Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products. Radeon ReLive may stop working after hot unplugging of a secondary display. Battlefield™1 may experience UI flickering and/or performance drops when recording gameplay with Radeon ReLive on graphics products with 4GB or less of VRAM. Radeon ReLive recordings or overlay may experience flicker when creating a single recording for many hours. Radeon ReLive may experience minor graphical corruption for the first few recorded frames when launching UWP applications. Radeon ReLive will not allow recording settings to change with Instant Replay enabled. A workaround is to disable Instant Replay and change settings then enable Instant Replay. Vulkan™ applications may experience a game hang when using Radeon ReLive to record. Radeon ReLive will not notify an end user of low disk space during recording. -
LocoDiceGR απάντησε στο θέμα του yanni topic στην ενότητα Κάρτες Γραφικών
MSI αν δεν κανω λαθος, και μετα αναλογα το κουτι σου κλπ...δεν ειναι μονο η καρτα... -
Path Of Exile
- 7.778 απαντήσεις
- games
- new release
(και 2 επιπλέον)
Action/Role-Playing Path of Exile (PoE)
LocoDiceGR απάντησε στο θέμα του hondo1 topic στην ενότητα PC Gaming
2.5.1 Patch Notes Added fifteen new Divination Cards. Added 3D art for the following items: Tulborn, Tulfall, Uul-Netol's Kiss, Uul-Netol's Embrace. A slider has been added to the Divination Stash Tab, which allows players to set the size of shown divination cards. Item notes have been updated to show the price graphically, and be more readable. Tul no longer takes reduced damage while doing her Projectile Barrage skill. The Crystal Ice Spires in the Tul encounter now have less life. The snowstorm skill used by the Tul Breach monsters now provides less damage avoidance to the monsters inside of it. Frost Blades used by the Tul monsters now does less damage at higher levels. This is intended to bring Tul more in line with Xoph and Esh. Where it is not a necessity they are all equal in difficulty we wanted Tul to be brought more in line with the other bosses of her level. Chayula Breaches are now more common in Mid (20% increase) & High (30% increase) Tier Maps. Improved the performance of the Arohongui, Moon's Presence ascendancy passive skill when placing totems near multiple monsters. Blade Vortex's "More Damage per Blade" modifier has been changed to apply only to spell damage instead of all damage types. This will remove a double-dipping effect that should not have been occurring. Fixed an interaction with weapon swapping and Abberath's Hooves, where players would step with every weapon swap, allowing much more frequent use of Abberath's Fury. Fixed a bug where completing the prophecy "A Gracious Master" with Leo can cause the wrong prophecy to disappear from the prophecy page. Rare monsters from the Esh breaches should no longer prevent players from gaining souls. Fixed an issue with Shaper's Touch where accuracy was not applying to off hand weapons. Fixed a bug where the life regeneration on Voll's Vision bypassed restrictions from map mods. Fixed a bug with The Red Nightmare where the block chance granted by All Resistance would only apply if you had another form of block. Fixed various targeting and namelocking issues, with some skills, while interacting with items. Fixed a bug where Tul would become idle while taunted by a Decoy Totem. Fixed a bug which contributed to players being incorrectly disconnected for performing too many actions.- 967 απαντήσεις
- free to play
- hardcore
(και 1 επιπλέον)
Αναβάθμιση GPU και PSU
LocoDiceGR απάντησε στο θέμα του black66.gr topic στην ενότητα Κάρτες Γραφικών
Μια χαρα ειναι αυτες οι επιλογες..εγω συμφωνω. Τιποτα λιγοτερο, τιποτα περισσοτερο! -
Radeon Software Crimson ReLive Edition 16.12.2 Highlights Fixed Issues AMD FreeSync™ technology may experience performance issues with Borderless Fullscreen application support when a secondary display is attached and has dynamic content running such as video playback in a web browser or if other applications or game launchers are running on the primary screen in the background. A workaround if this issue is experienced is to minimize all other running applications that are on the primary desktop display or on non-primary extended displays. Radeon ReLive may fail to install during installation on some system configurations. Battlefield™1 may experience flashing or corruption when running in Multi GPU with Radeon RX 400 series. Instant Replay fails to enable itself after it has been turned off due to content protection. Radeon Settings may not load on system boot for some system configurations. Fixed some errors in translations for Radeon Settings and Radeon ReLive. Mouse cursor corruption may be intermittently experienced on Radeon RX 480. Audio recorded by Radeon ReLive may sometimes exhibit slow motion when played back. Radeon ReLive may experience recording issues or issues toggling the Overlay/Toolbar when Frame Rate Target Control is enabled. Users are suggested to disable Frame Rate Target Control when using Radeon ReLive. Mouse cursor may stutter in recorded video when there is limited on screen activity outside of minor mouse movement. In AMD Multi GPU configurations the secondary graphics product will exit the low power state when Radeon ReLive is enabled. Radeon ReLive may sometimes not be able to take screenshots of secondary displays. Chromium may fail to utilize hybrid decode for VP9 content. DOTA™2 may experience game corruption when performing a task switch while recording with Radeon ReLive in AMD Multi GPU configurations. Known Issues A small amount of apps may still experience issues with Borderless Fullscreen mode and AMD FreeSync™ technology if other applications or game launchers are running on the primary screen in the background. Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue. AMD Multi GPU configurations may experience a system hang or reboot during install when using tiled MST 4K or 5K displays. Titanfall™2 may experience black square corruption in game menus or during game play on some Graphics Core Next products. FIFA 17™ may experience an application hang or black screen on launch for some select Hybrid Graphics or AMD PowerXpress mobile configurations. Radeon Settings may not show display details for connected displays in AMD X-Connect technology mode. Known Issues for Radeon ReLive The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues. Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products. Battlefield™1 may experience UI flickering and/or performance drops when recording gameplay with Radeon ReLive on graphics products with 4GB or less of VRAM. Radeon ReLive recordings may experience flicker when creating a single recording for many hours. Radeon ReLive may experience minor graphical corruption for the first few recorded frames when launching UWP applications. Radeon ReLive will not allow recording settings to change with Instant Replay enabled. A workaround is to disable Instant Replay and change settings then enable Instant Replay. Radeon ReLive Overlay/Toolbar will not launch or Record when running League of Legends™ in Administrator Mode and Windowed Borderless Fullscreen. A work around would be to not use administrator launch privileges or to use Fullscreen mode. Vulkan™ applications may experience a game hang when using Radeon ReLive to record. Radeon ReLive will not notify an end user of low disk space during recording. -
LocoDiceGR απάντησε στο θέμα του GoriLLakoS topic στην ενότητα Κάρτες Γραφικών
Ερχεται το 2.5.1 αυτη την βδομαδα... https://www.pathofexile.com/forum/view-thread/1799628 Εχω μπει για τα καλα παλι στο παιχνιδι...level 90 Breach Softcore...σκεφτομαι και για αγορα supporter pack..τα tabs δεν φτανουν με τιποτα, λολ.. Ερωτηση για τους παλαιμαχους...αξιζει η επενδυση σε taste of hate flask για ice shot build? Εχει 2.5 Ex... https://www.pathofexile.com/account/view-profile/Balantakos/characters οριστε και το λινκ για το gear...- 967 απαντήσεις
- free to play
- hardcore
(και 1 επιπλέον)
Χριστουγεννιάτικος διαγωνισμός 2016
Το μέλος LocoDiceGR σχολίασε στην δημοσίευση του karmen1983 στην ενότητα Ειδήσεις
Ευχαριστουμε για τα δωρα, καλες γιορτες! -
http://www.guru3d.com/articles-pages/radeon-crimson-driver-december-2016-performance-analysis,1.html -
Level 63..ranger ice shot.....εχω ριξει πολυ φαρμ dried lake με party....- 967 απαντήσεις
- free to play
- hardcore
(και 1 επιπλέον)
Ξεκινησα και εγω το Breach PogChamp!- 967 απαντήσεις
- free to play
- hardcore
(και 1 επιπλέον)
Καλημερααα, 1) @azazil1190 Αμα σου κανει τιποτα περιεργα το MSI AB καντο reinstall η σβηνεις το MSIAfterburner.cfg , γενικα το AB δεν ''γουσταρει'' και πολυ τους Crimson.....εγω δεν το χρησιμοποιω καθολου, απλα το διαβασα στο ιντερνετ και το λεω σε εσενα και τους υπολοιπους εδω.. 2) Επισης καινουριο update DDU v17.0.4.0 (ReLive support)... -
Radeon Software Crimson ReLive Edition 16.12.1 Highlights New Features Radeon ReLive(1): Capture, stream and share your greatest moments and gaming wins on your computer system with Radeon ReLive. Modify settings quickly, conveniently, and play seamlessly with the easily accessible in-game toolbar. Express yourself in bold new ways with custom scene layouts. Upload your latest highlights and let them be a conversation piece. It's never been easier to build and grow your online community at anytime, anywhere. Radeon Chill(2): A power-saving feature that dynamically regulates frame rate based on your in-game movements. Radeon Chill can improve power efficiency and can lower temperatures for supported products and games when enabled through Radeon Settings. Radeon WattMan(3): Added support for AMD Radeon R9 Fury series, R9 390 series, R9 380 series, R9 290 series, R9 285, R9 260 series, R7 360, and R7 260 desktop graphics products Radeon Software Installer(4): New user interface and intuitive Radeon Software Installer that includes options for express install, custom install and clean uninstall. The new installer will also show options for the latest available driver for your system configuration during the install process. Display Connectivity(5): New advanced display settings and diagnostics page within Radeon Settings with better detection for HDMI® cable issues and fallback for end users experiencing display issues. AMD FreeSync™ Technology(6): Now supports Borderless Fullscreen Mode for applications and gaming with AMD FreeSync™ technology displays and supported products. Now supports Gradual Refresh Rate Ramp for mobile configurations with AMD FreeSync™ technology displays and supported products. Upgrade Advisor(7): Provides a system requirement evaluation for Steam® games in your Radeon Settings library. HDR Gaming Support(8): Experience the benefits of HDR gaming with Radeon Software Crimson ReLive Edition. Support for games with HDR 10 or Dolby Vision™ capabilities. VP9 Decode Acceleration(9): 4K 60Hz GPU-Accelerated Video Streaming enabled on supported Google™ Chrome web browsers. Skype Performance Enhancements (10): Lower CPU usage during Skype™ calls for select AMD APU Family products. User Feedback Page: The User Feedback Page enables a direct link for end users to the Radeon Software Team and allows users to provide feedback and vote on upcoming features for Radeon Software. The User Feedback page can be found here. Fixed Issues Unable to launch the Problem Report Wizard from CCCSlim in Radeon Settings. Radeon WattMan Power Limit setting may not retain after hitting apply when Auto Temperature is enabled. DOTA™ may experience flickering in some hero and effect models when running the application in Fullscreen. Pixel Format options may not appear in Radeon Settings on some 4K TV's with Radeon RX 480. The Division™ may experience flicker during gameplay when using AMD Multi GPU configurations. The Division™ may experience an application freeze or hang when running in AMD Multi GPU configurations after extended periods of play. Game quality or performance may be degraded when launching multimedia content on a secondary display before running a game. CIM folder retains under program files even after complete driver uninstallation. Radeon Settings may experience an intermittent crash when accessing Radeon WattMan. Display tab with virtual super resolution may be removed or missing in Radeon Settings. The Radeon WattMan feature may intermittently display a Radeon Software popup error regarding Radeon WattMan for non-supported products. Random crashes may be experienced on Mozilla Firefox. DirectX®12 content may be unable to launch on some older CPUs that do not support popcnt instruction. Intermittent Mouse Cursor corruption may be experienced on Radeon RX 480. Known Issues AMD FreeSync™ technology may experience performance issues with Borderless Fullscreen application support when a secondary display is attached and has dynamic content running such as video playback in a web browser or if other applications or game launchers are running on the primary screen in the background. A workaround if this issue is experienced is to minimize all other running applications that are on the primary desktop display or on non-primary extended displays. Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue. AMD Multi GPU configurations may experience a system hang or reboot during install when using tiled MST 4K or 5K displays. Titanfall™2 may experience black square corruption in game menus or during game play on some Graphics Core Next products. FIFA 17™ may experience an application hang or black screen on launch for some select Hybrid Graphics or AMD PowerXpress mobile configurations. Known Issues for Radeon ReLive The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues. Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products. Radeon ReLive may experience recording issues or issues toggling the Overlay/Toolbar when Frame Rate Target Control is enabled. Users are suggested to disable Frame Rate Target Control when using Radeon ReLive. Battlefield™1 may experience UI flickering and/or performance drops when recording gameplay with Radeon ReLive on graphics products with 4GB or less of VRAM. DOTA™2 may experience game corruption when performing a task switch while recording with Radeon ReLive in AMD Multi GPU configurations. Radeon ReLive recordings may experience flicker when creating a single recording for many hours. Radeon ReLive may experience minor graphical corruption for the first few recorded frames when launching UWP applications. In AMD Multi GPU configurations the secondary graphics product will exit BACO when Radeon ReLive is enabled. Radeon ReLive will not allow recording settings to change with Instant Replay enabled. A workaround is to disable Instant Replay and change settings then enable Instant Replay. Radeon ReLive Overlay/Toolbar will not launch or Record when running League of Legends™ in Administrator Mode and Windowed Borderless Fullscreen. A work around would be to not use administrator launch privileges or to use Fullscreen mode. Mouse cursor may stutter in recorded video when there is limited on screen activity outside of minor mouse movement. Vulkan™ applications may experience a game hang when using Radeon ReLive to record. Radeon ReLive will not notify an end user of low disk space during recording. -
**Ειναι μεγαλο update...θα προτεινα DDU σε safe mode και μετα install! Radeon Software Crimson ReLive Edition 16.12.1 Highlights New Features Radeon ReLive(1): Capture, stream and share your greatest moments and gaming wins on your computer system with Radeon ReLive. Modify settings quickly, conveniently, and play seamlessly with the easily accessible in-game toolbar. Express yourself in bold new ways with custom scene layouts. Upload your latest highlights and let them be a conversation piece. It's never been easier to build and grow your online community at anytime, anywhere. Radeon Chill(2): A power-saving feature that dynamically regulates frame rate based on your in-game movements. Radeon Chill can improve power efficiency and can lower temperatures for supported products and games when enabled through Radeon Settings. Radeon WattMan(3): Added support for AMD Radeon R9 Fury series, R9 390 series, R9 380 series, R9 290 series, R9 285, R9 260 series, R7 360, and R7 260 desktop graphics products Radeon Software Installer(4): New user interface and intuitive Radeon Software Installer that includes options for express install, custom install and clean uninstall. The new installer will also show options for the latest available driver for your system configuration during the install process. Display Connectivity(5): New advanced display settings and diagnostics page within Radeon Settings with better detection for HDMI® cable issues and fallback for end users experiencing display issues. AMD FreeSync™ Technology(6): Now supports Borderless Fullscreen Mode for applications and gaming with AMD FreeSync™ technology displays and supported products. Now supports Gradual Refresh Rate Ramp for mobile configurations with AMD FreeSync™ technology displays and supported products. Upgrade Advisor(7): Provides a system requirement evaluation for Steam® games in your Radeon Settings library. HDR Gaming Support(8): Experience the benefits of HDR gaming with Radeon Software Crimson ReLive Edition. Support for games with HDR 10 or Dolby Vision™ capabilities. VP9 Decode Acceleration(9): 4K 60Hz GPU-Accelerated Video Streaming enabled on supported Google™ Chrome web browsers. Skype Performance Enhancements (10): Lower CPU usage during Skype™ calls for select AMD APU Family products. User Feedback Page: The User Feedback Page enables a direct link for end users to the Radeon Software Team and allows users to provide feedback and vote on upcoming features for Radeon Software. The User Feedback page can be found here. Fixed Issues Unable to launch the Problem Report Wizard from CCCSlim in Radeon Settings. Radeon WattMan Power Limit setting may not retain after hitting apply when Auto Temperature is enabled. DOTA™ may experience flickering in some hero and effect models when running the application in Fullscreen. Pixel Format options may not appear in Radeon Settings on some 4K TV's with Radeon RX 480. The Division™ may experience flicker during gameplay when using AMD Multi GPU configurations. The Division™ may experience an application freeze or hang when running in AMD Multi GPU configurations after extended periods of play. Game quality or performance may be degraded when launching multimedia content on a secondary display before running a game. CIM folder retains under program files even after complete driver uninstallation. Radeon Settings may experience an intermittent crash when accessing Radeon WattMan. Display tab with virtual super resolution may be removed or missing in Radeon Settings. The Radeon WattMan feature may intermittently display a Radeon Software popup error regarding Radeon WattMan for non-supported products. Random crashes may be experienced on Mozilla Firefox. DirectX®12 content may be unable to launch on some older CPUs that do not support popcnt instruction. Intermittent Mouse Cursor corruption may be experienced on Radeon RX 480. Known Issues AMD FreeSync™ technology may experience performance issues with Borderless Fullscreen application support when a secondary display is attached and has dynamic content running such as video playback in a web browser or if other applications or game launchers are running on the primary screen in the background. A workaround if this issue is experienced is to minimize all other running applications that are on the primary desktop display or on non-primary extended displays. Counter-Strike™: Global Offensive and World of Warcraft™ may experience flickering or performance issues the first time the game is launched on a system boot with AMD FreeSync™ technology enabled. Workarounds include exiting and restarting the application or task switching (alt+tab) in and out of the game to fix the issue. AMD Multi GPU configurations may experience a system hang or reboot during install when using tiled MST 4K or 5K displays. Titanfall™2 may experience black square corruption in game menus or during game play on some Graphics Core Next products. FIFA 17™ may experience an application hang or black screen on launch for some select Hybrid Graphics or AMD PowerXpress mobile configurations. Known Issues for Radeon ReLive The XBOX™ DVR application may cause conflicts with Radeon ReLive, users are suggested to disable XBOX™ DVR if Radeon ReLive is experiencing issues. Radeon ReLive may fail to install on AMD APU Family products or experience a system hang or failure to record when using the recording feature on AMD APU Family products. Radeon ReLive may experience recording issues or issues toggling the Overlay/Toolbar when Frame Rate Target Control is enabled. Users are suggested to disable Frame Rate Target Control when using Radeon ReLive. Battlefield™1 may experience UI flickering and/or performance drops when recording gameplay with Radeon ReLive on graphics products with 4GB or less of VRAM. DOTA™2 may experience game corruption when performing a task switch while recording with Radeon ReLive in AMD Multi GPU configurations. Radeon ReLive recordings may experience flicker when creating a single recording for many hours. Radeon ReLive may experience minor graphical corruption for the first few recorded frames when launching UWP applications. In AMD Multi GPU configurations the secondary graphics product will exit BACO when Radeon ReLive is enabled. Radeon ReLive will not allow recording settings to change with Instant Replay enabled. A workaround is to disable Instant Replay and change settings then enable Instant Replay. Radeon ReLive Overlay/Toolbar will not launch or Record when running League of Legends™ in Administrator Mode and Windowed Borderless Fullscreen. A work around would be to not use administrator launch privileges or to use Fullscreen mode. Mouse cursor may stutter in recorded video when there is limited on screen activity outside of minor mouse movement. Vulkan™ applications may experience a game hang when using Radeon ReLive to record. Radeon ReLive will not notify an end user of low disk space during recording. -
Ερχεται, και ειναι δυνατο! http://videocardz.com/64496/amd-preparing-crimson-relive-driver-update http://wccftech.com/amd-radeon-software-crimson-relive-driver-leak/ -
Αφηστε τα 3dmark και τις ιστοριες...(χωρις παρεξηγηση) Δοκιμαστε παιχνιδια! -
Shooter Counter-Strike : Global Offensive
LocoDiceGR απάντησε στο θέμα του Nephiλiμ topic στην ενότητα PC Gaming
Αν σου πω οτι δεν θυμαμαι καν τι οδηγο ειχα βαλει εδω? χαχα Πλεον Δεν πειραζω τιποτα εγω..- 178 απαντήσεις
- counter strike
- fps
(και 3 επιπλέον)
Radeon Software Crimson Edition 16.11.5 Highlights Support For: Watch Dogs®2 New AMD CrossFire profile added for DirectX® 11: Dishonored™2 Fixed Issues The Division™ game world may flicker during game play when using AMD CrossFire technology. Battlefield™1 flickering may be experienced while using AMD CrossFire technology mode. -
Format or not format ?
LocoDiceGR απάντησε στο θέμα του xkabamarux topic στην ενότητα Λειτουργικά Windows
Το καλυτερο θα ηταν να κανεις φορματ παντως... -
- 967 απαντήσεις
- free to play
- hardcore
(και 1 επιπλέον)
Τον αλλο μηνα περιμενουμε και τον ''Anniversary Driver'' -
The nVidia ForceWare Driver Thread
LocoDiceGR απάντησε στο θέμα του jpavly topic στην ενότητα Κάρτες Γραφικών
Για καλυτερο perfomance/optimize στα παιχνιδια, και bug fixes.
