Posts posted by ultraex2005
παμε για κανενα screenaki
Προς το παρον δοκιμασα firefox-7zip-winrar-imgburn-power iso-convert x to dvd-easy-cd extractor-microsoft security essential- live essential 2011-google chrome -Modern Warfare 3- syndicate-msi afterburner-media player clasic ολα αυτα ετρεξαν αψογα! γενικa oτι και να ετρεχα δεν αντιμετωπισα προβλημα!!
Παντως η φημη oτι θα παιζουν Xbox360 Games ισχυει καθως εχει ηδη 2 εγκατεστημενα παιχνιδια. Και εχει και επιλογη να μπεις στο Xbox Live.!!!
οριστε μερικα screens!! απο τα win 8 consumer preview
Uploaded with ImageShack.us
με οτι σε βολευει παιζεις
ολο ψαχνεις και ολο κατι βρισκεις!! 8)
μετατρεποντας αρχειο mkv[720p] 8 giga σε dvd με το convert x to dvd
αναπαραγοντας το dvd με το win 8 media center
για να δουμε οι drivers των 8 cunsumer preview τι κανουν
οποιος εχει νουμερα ας βαλει για συγκριση!!
Crystall mark
2x OCZ vertex 2 60 raid 0
ATTO bench
Crystall mark
2x 640 AAKS western digital raid 0
ATTO bench
new msi afterburner 2.2.0.14 beta
This beta supports the voltage control of HD 7X50 card, if you get the card, you may try to play it.
Changes list includes:
Fixed sub-zero temperatures reading on certain custom design MSI graphics cards with LM96163 and NCT7718W dedicated thermal sensors.
Added workaround for bug in AMD drivers causing unofficial overclocking to be reset to defaults after adjusting PowerPlay settings. Now unofficial overclocking settings are being forcibly reapplied after applying new PowerPlay settings.
Hardware abstraction layer (HAL) architecture has been improved to provide compatibility with future NVIDIA graphics cards series.
Now multi-GPU overclocking and fan control settings synchronization is performed at HAL level instead of display driver wrapper level to improve HAL architecture extendibility and provide compatibility with future NVIDIA graphics cards series.
Shared control memory format has been upgraded to v2.0. New format provides power limit adjustment support and forward compatibility with future NVIDIA graphics cards series.
Now it is possible to override group names for values displayed in the On-Screen Display or in Logitech keyboard LCD display.
MSI On-Screen Display server has been upgraded to v4.3.3. New version gives the following improvements:
o Fixed issue causing gamma correction to be applied twice under certain conditions and causing video to appear too bright when capturing video with gamma correction option enabled.
o Output video dimensions are no longer being forcibly cropped to be multiples of 16. Now cropping is optional and can be enabled via GUI
o Dedicated 1/2, 1/3 and 1/4 frame downsampling routines have been replaced with unified arbitrary downsampling routine. Now MSI Afterburner provides arbitrary frame downsampling functionality and allows selecting 360p, 480p, 720p, 900p, 1080p frame sizes for both 16:9 and 16:10 aspect ratios. Please take a note that arbitrary frame sizes list is user extendable so you may add your own custom frame sizes if necessary via the configuration file.
o Improved tabbed text formatting provides better compatibility with custom group names.
και ενα σημερινο με τους 12.1 drivers
ati 5970 @ 970/1268
i7 860 @ 4300 HT ON
έχοντας χάσει επεισόδια ...που βρίσκουμε τους driver του ΑΤΙΜΑΝ;;;;
ιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιιι όχι ρε συ αμαρτία είναι. :fist:
Ενα κομμάτι βινυλιο από έναν με επιγραφές και αυτοκόλλητα πάρε. Μπες μέσα στο μαγαζί και πες του μάστορα θέλω 5 πόντους απο το ρολό, ουτε καν θα στο χρεώσει.
Αν κατι συμβει και θες να την πουλήσεις ή RMA (έξω απο δω) απλά το ξεκολλάς
οκ θα το κοιταξω
Ωραίος αν και με την μητρική που έχεις επάνω και την κάρτα εγώ θα έπαιζα σε κόκκινο χρωματισμό/φωτισμό.
Λογικά είσαι οπαδός του μπλε οπότε ένα μπλε αυτοκόλλητο βινυλίου στην κάρτα θα έδενε νομίζω
karmen ευχαριστω για τα καλα σου λογια:clap:
εχω ενα μαρκαδορο μαυρο νομιζω ειναι για βαφη πλαστικων θα του ριξω ενα μαυρισμα
να φυγει η κοκκκινιλα πανω στην καρτα νομιζω ετσι θα δειξει καλυτερα
update στο κουτακι μου
περαστηκε prolimatech Genesis
Nvidia 250 Gts για (Dedicated Physx)
λεντοταινια 1 μετρο nzxt μπλε
Και με το nztx setry mesh controller που εβαλα το κουτακι μου :
σκοτεινα :
[ATTACH]47042[/ATTACH]
εδω χωρις το μπροστικο καπακι :
[ATTACH]47043[/ATTACH]
[ATTACH]47044[/ATTACH]
εδω κομπλε :
[ATTACH]47045[/ATTACH]
[ATTACH]47046[/ATTACH]
τα σπανε τα κουτακια μας ωραιο το αποτελεσμα:clap:
[Official] Lancool Dragonlord Owners Thread!!
Ευχαριστώ ρε ultreax! Να σαι καλά! Άντε η σειρά σου τώρα!!
Περιμένω να βγει τώρα το cosmos 2 να βάλω άλλα 2 ψυγεία,και ψύξω και τις κάρτες...
ναι εμεις τα λεμε και αλλου:kiss3:
αμα ψυξεις και τις καρτες το project θα γινει :dance3::dance3: παρα πολυ καλο
ρε vago:hi: τι βλεπω καινουργιο κουστουμακι εραψες ?:clap:
μεγειες man καλοφορετο:jump1:
Λίγο off-topic ερώτηση: Εγώ που χρησιμοποιώ την 250gts μόνο για physics, έχει νόημα να βάζω καινούργιους drivers?
ψαξτο λιγο εδω εχει ολοκληρο thread αφιερωμενο μονο για αυτο
εμενα παλι με την 5970 και στους 11.11+ cap 2 και στους 11.12 αν δεν κανω το γνωστο
γιατροσοφι με το alt+ enter ο δευτερος πυρηνας :zzz: δεν κουνιεται με τιποτα
Πως στέλνουμε μήνυμα μέσα από τη σελίδα Atiman technologies lab? Για την άδεια χρήσης?
εγω εκανα εγγραφη στο σιτε και μετα εστειλα μυνημα στο ατιμαν
Ακριβως.
Με σκετους τους hotfix το bf3 εχει αρκετα frame drops.
Μετα την εγκατασταση ομως του 11.11 cap 2 το παιχνιδι παει νερο.
[MENTION=2962]zpaf[/MENTION]
εισαι ο πρωτος και με διαφορα :worship::worship::worship:
Τους εβγαλα κιολας....:fist:
μηπως βιαστηκες ? με profiles ισως αλλαζε εντελως το σκηνικο
frame drops:fie: και σε μενα με την 5970 ισως διορθωθει η κατασταση με profiles αλλιως θα παρουν ποδι και γρηγορα μαλιστα
cap χρειαζεται με το 11.11α να βαλουμε?
New profiles added to this release:
- Saints Row 3: Resolves stuttering seen when playing in CrossFireX mode. Also provides Single GPU and CrossFireX performance improvements when running in lower resolution configurations
- Gothic 4 Arcania: Fall of Setarrif: Improves CrossFire performance
επισης new 11.11--cap 1
- Battlefield 3: Tweaks to the CrossFire profile
- Global Ops – Commando Libya: Improves CrossFire performance
- Driver San Francisco: Disables CrossFire
[MENTION=5249]Jaco[/MENTION]
ξερεις αν το clonezila στο parted magic μπορει να δουλεψει με intel ic10r controler σε raid 0
screen ενω το παιχνιδι τρεχει
ο ι7 860 στα 4300 HT ON 8 giga μνημη
3.5 γιγα μνημη με το καλημερα ρουφαει
Windows 8 Thread
In Λειτουργικά Windows
· Έγινε επεξεργασία από ultraex2005
επειδη τα win 8 τα εχω περασμενα σε 2.5 σατα 2 μηχανικο δεν βλεπει τα αλλα ssd raid 0 και βαζει σαν τελικο νουμερο το αποτελεσμα του δισκου [5.9] το οποιο συμφωνω οτι ειναι περα για περα λαθος
