Posts posted by ultraex2005
ενα τροποποιημενο με omnimo 5 !!! Asus Blue Power !!!
ενα σημερινο με τα σαπιοκαραβα
:hehe: !!!
8320@4400
5970@950/1250
νουμερα μετα το τελευταιο patch το 1.3 και με το νεο cap 13.5 !!
ολα στο τερμα !!! και η ρυθμιση πλεον στο tesselation φαινεται τωρα σωστα στο αποτελεσμα σε σχεση με πριν !!
8320@4400
5970@940/1250
κατι παει να γινει θα δειξει παντως !!
AMD Catalyst Application Profile Download 13.5 CAP1
These are the Catalyst profiles for multi-GPU support. This release of ATI Catalyst delivers support for the latest ATI CrossFireX profiles in a separate executable file ensuring users have access to the absolute latest set of profiles installed on their PC.
New profiles added to this release:
Call of Juarez – Gunslinger – Improves CrossFire performance
Company of Heroes 2 – Disables CrossFire support
Far Cry 2 (DX9) – Improves single GPU performance
Resident Evil 6 – Improves single GPU performance
Call of Duty 4 – improves single GPU performance
Dark sider 2 – Fixes the corruption in game menu under certain CrossFire configurations
Minimum – Improves single GPU performance
The Walking Dead: Survival Instinct: Fixes image quality issues when enabling Anti-Aliasing through the AMD Catalyst Control Center
Crysis 3: Improves CrossFire performance in 3 and 4 GPU configurations
Deus Ex: Human Revolution: Improves CrossFire performance
Unigine Heaven: Improves CrossFire performance in 3 and 4 GPU configurations
Hitman Absolution: Resolves application issues on the AMD Radeon HD 7790 when running at 1680x100 with 8xAA enabled
Alien Colonial Marines – acm.exe
BioShock Infinite – BioShockInfinite.exe
Crysis 3 – Crysis3.exe
GodMode – GodMode.exe
Grid 2 – grid2.exe
Hawken – HawkenLauncher.exe
Neverwinter – gameclient.exe
SimCity – SimCity.exe
Sniper Elite Nazi Zombie Army – NZA.exe
The Walking Dead Survival Instinct – WalkingDead.exe
Tomb Raider – TombRaider.exe
Kapersky Anti-virus - avt.exe
οντως το παιχνιδακι πρεπει να εχει ωραια ατμοσφαιρα
ναι ναι οντως πολυ καλη η ατμοσφαιρα !! superb θα ελεγα :clap: !!
εεε οκ δεν έχει τίποτα μέσα..
Να πάρω το User.cfg από τον Metro Φακελο να το βάλω στα Documents? μεσα στο 4100? μπας και δουλέψει?
γιατι σου εγινε αυτο;
εγω μετα το περασμα του patch απλα πηγα και αλλαξα τα μονο τα νουμερα και στους 2 φακελους στο 4χχχχ κλπ!!
μετα ξεκινησα το παιχνιδι το εκλεισα και μετα πηγα και διορθωσα το fov που πλεον υπηρχε σαν επιλογη αλλα με λαθος νουμερο 50κατι ειχε !!
το πριν
και το μετα με το διορθωμενο το FOV !!
[MENTION=2962]zpaf[/MENTION] Λογικα για να έχω από 27 FPS στο Benchamark 30.. μπήκε..
Το Game τρέχει τάπα πιο Smooth εδώ στο Main Menu φαινεται η διαφορά..
Και μου έχουν σβηστεί τα SAVE!!! πως βάζουμε τα Save πίσω? το έχω φτάσει στο τελος το Game?
Τι πειράζω από αυτά εδώ που τα πάω.?
Επίσης ας ποστάρει κάποιος το Τραγουδι που ακούς όταν μπαίνει στο Main Menu.. το ψάχνω δεν το βρίσκω..
κανε αυτο και δε θα εχεις προβλημα με τα saves !!
1)Open the dir {MyDocuments}\4A Games\Metro LL and rename the dir
you find into "410000004100000"
2)Open the dir %LOCALAPPDATA%\4A Games\Metro LL and rename the dir
νικολα θα τρεξω,,αλλα δεν νομιζω, να ειναι μονο αυτο που λεσ... το παιχνιδι ειναι κακογραμενο η οι οδηγοι που φοραω δεν κανουν τοσο καλη δουλεια στο συγγκεκριμενο παιχνιδι... φοραω τουσ 13,4..
κανονικα η καρτα επρεπε να ειχε 99%gpu used se direct 11 που το τρεχω.. το επαιξα περιπου 1 ωρα και κατι, και πουθενα δεν πηρα 99% gpu used.. ενω το cpu used δεν ξεπερασε μεχρι στιγμησ το 50%..
με 13.4 ειμαι και γω στα high που το παιζω στοκ η καρτα μου με v-sync on εχω 50-60 fps σχεδον κολλημενα και παει πολυ γραμμικα το παιχνιδι τωρα απο καταναλωση με τον fx 8320 @ 4.2 δε βλεπω max πανω απο 35% η δε καρτα μου η 5970 εχει max 75% αλλα δε τα πολυκοιταω αυτα αμα ρολαρει το παιχνιδι !!ισως φταει και η αναλυση που το παιζω 1680Χ1050
φαινονται τα νουμερα πανω αριστερα
παιδεσ το παιχνιδι μηπωσ ειναι κακογραμμενο??
εχω την 6870, η καρτα δεν παει στο 99% gpu used , ενω το cpu used δεν ξεπερναει το 50%μεχρι στιγμησ... ενω τα frame μου ειναι χαμηλα... θα τραβηξω φωτο ...
σαν παιχνιδι ειναι ωραιο..
εχω και ψιλοσπασιματα στην οθονη λεσ και λαγκαρει..
τρεξε το bench του παιχνιδιου στα medium και ποσταρε στο θεμα με τα αλλα παιδια να δουμε τι κανεις !!
με medium ρυθμισεις πιστευω θα τα πας αρκετα καλα τελικα ειναι αρκετα βαρυ το παιχνιδακι
τα σπαει το παιχνιδακι
Tροποι παιξιματος:
Το παιζεται με κλειστα φωτα μονο με ακουστικα στο τερμα
fx 8320 @ 4.2
5970 @ 940/1250
drivers 13.4 profiles 13.4 (1680X1050)
Παιδια, οσοι απο εσας εχετε SDD και μηχανικους δισκους στο PC τους, τα Prefetch + SuperFetch τα εχετε απενεργοποιησει?
ναι κλειστα ειναι 2 χρονια τωρα !!!
ενα δικο μου !!
νεο run και update στο σκορ μου με τον FXA 8320 στα 4800 !!
Fxa 8320 3.500 @ 4.800
Amd 5970 @ 952/1262
drivers 13.3 beta 3
ενα μικρο update στο σκορακι μου με τον FX 8320 3.500 @ 5128 cool by Prolimatech Genesis
και εγώ είδα διαφορά με τη σειρα μου οντως δουλευει το κολπακι !!!
για να ανεβουμε λιγακι !!!
AMD FXA 8320 3.500 @ 5109
για καλη αρχη !!
amd 8320 3.5 @ 5.0
να ριξω και εγω κανα νουμερο με την νεα RC1 εκδοση του catzilla !!
edit: για να τρεξετε πλεον σε cat preset οπως εγω πρεπει να κανετε εγραφη για να παρετε free code !!!
amd 8320 3.5 @ 4.5
amd 5970 @ 954/1262
drivers 13.3 beta 3
In Κάρτες Γραφικών
κατα την amd προσθετει καποιες διορθωσεις σε single και crossfire καρτες για καποιους τιτλους που κυκλοφορουν !!
AMD Catalyst
πχ το τελευταιο ενημερωμενο 13.5 cap 1 εχει και αυτα
- Call of Juarez – Gunslinger – Improves CrossFire performance
- Company of Heroes 2 – Disables CrossFire support
- Far Cry 2 (DX9) – Improves single GPU performance
- Resident Evil 6 – Improves single GPU performance
- Call of Duty 4 – improves single GPU performance
- Dark sider 2 – Fixes the corruption in game menu under certain
