  • astrolabos
    astrolabos
    Thermaltake Releases Toughpower GF3 1200W & GF A3 850W/1050W in Snow Edition
    Thermaltake, the leading PC DIY premium brand for Case, Cooling, Gaming peripherals, and enthusiast Memory solutions, is proud to introduce the Toughpower GF3 1200W Snow and the Toughpower GF A3 850W/1050W Snow, our first ATX 3.0 power supplies in white. To provide more options for the latest PSU with Intel’s ATX 3.0 standard and native 12+4-pin PCIe Gen 5.0 connector, Thermaltake brings a new color to the high-attention GF3 series and GF A3 series. These two series are fully modular power supplies with 80 PLUS Gold certification, achieving superior cable management and energy efficiency, and now comes in a snow edition!
    The Toughpower GF3 1200W Snow is compatible with the ATX 3.0 standard, enabling support of up to 300% GPU power excursion and 200% total power excursion. Designed with various connectors including a native 12+4-pin PCIe Gen 5.0 connector, the GF3 Snow series can fully support RTX 40 series graphics cards. The GF3 Snow is packed with 100% high quality Japanese 105°C/221°F electrolytic capacitors, offering the highest durability and reliability. To power up the high-end hardware steadily, the GF3 Snow series comes with more strict specifications than the Intel standard, including <30mV low ripple noise design, voltage regulation <±2%, and >17ms hold up time. Moreover, the built-in 140mm fluid bearing fan guarantees strong cooling performance. To minimize the fan noise, the Smart Zero Fan design allows the fan to only spin when the power load exceeds a certain amount, and users can turn this fan mode on and off by the physical switch anytime as well.
    The Toughpower GF A3 850W/1050W Snow also meets Intel’s ATX 3.0 specifications and possesses a native PCIe Gen 5.0 connector, born to power up the latest hardware. The GF A3 Snow series is made with high quality Japanese main electrolytic capacitor to ensure its stability. This PSU is built with complete industry-grade protection (OCP, OVP, UVP, OPP, SCP, OTP) in order to protect the components while supplying power. Furthermore, its 120mm fluid bearing fan and the Smart Zero Fan design can deliver excellent airflow and reduce undesired noise. On top of that, the fully modular design enables users to freely select the cables with suitable voltage in the package based on their needs, improving the cable management and airflow inside the case.
    The GF3 Snow and the GF A3 Snow is 80 PLUS Gold certificated, and can support the latest graphics cards, delivering exceptional installation flexibility. The brand-new snow edition even achieves a perfect balance between functional and aesthetic aspects. Don’t miss out on these white ATX 3.0 power supplies to power up your all-white setup!
    GF A3 850W Snow: https://www.thermaltake.com/toughpower-gf-a3-snow-850w-tt-premium-edition.html
    GF A3 1050W Snow: https://www.thermaltake.com/toughpower-gf-a3-snow-1050w-tt-premium-edition.html
    GF3 1200W Snow: https://www.thermaltake.com/toughpower-gf3-snow-1200w-tt-premium-edition.html
