Thermaltake, the leading PC DIY premium brand for Case, Power, Cooling, Gaming peripherals, and enthusiast Memory solutions, is pleased to unveil the Pacific SW1 Plus CPU Water Block and the Pacific SF Fittings — Silver Black. The custom liquid cooling system provides considerable flexibility in design, allowing you to demonstrate your aesthetic sense. If you are an industrial chic enthusiast, the Pacific SW1 Plus and the Pacific SF Fittings, which feature a New Industrial Style, are the ideal components for leveling up your cooling system’s appearance while ensuring thermal performance and installation compatibility.
Designed with a modern industrial style, the Pacific SW1 Plus CPU Water Block comes in solid aluminum alloy with a screw design, displaying a beautiful glow of metals. The copper base is finished with anti-corrosive nickel plating, matching the overall industrial design and offering an outstanding heat transfer for the CPU. The central inlet design of the base enables the coolant to be distributed evenly through the 0.2mm microchannels, achieving more effective heat dissipation. What’s more, through the TT RGB Plus 2.0 software, you can simply monitor coolant temperature and customize the lighting effects of the water block's 12 addressable LEDs. To fit the latest CPUs, the Pacific SW1 Plus is also compatible with Intel LGA 1700 and AMD AM5 sockets and can be installed without additional brackets.
The Pacific SF Fittings — Silver Black are designed for convenience and aesthetic purposes while creating a build. The fittings come in a New Industrial Style, equipped with a black rotator made with high-quality brass and special surface finishing, delivering fantastic aesthetics. The helical knurling design and the 2-way 360-degree revolvable design of rotators allow you to install them effortlessly. Additionally, they come in various types and models to choose from, including adapters, extenders, and a 16mm OD compression.
- Pacific SF Adapters contain 90-degree, 45-degree, and 45 & 90-degree, enabling you to build your liquid cooling system with different loop angles.
- Pacific SF Extenders incorporate 20mm and 30mm lengths in several designs with G1/4 screw threads, from male to male, female to male, and female to female. Pacific SF extenders can be attached to either the radiator or other adaptors for more user-friendly installation, including extending the length and switching the male/female connectors.
- Pacific SF Hard Tube 16mm OD Compression can match with PETG, Acrylic, and Glass tubing, which is 16mm in outer diameter (OD) and paired with G1/4 screw threads. They are suitable to apply in a compact chassis without compromising the compression seal or impacting the coolant flow.
The Pacific SW1 Plus CPU Water Block and the Pacific SF Fittings — Silver Black are available for purchase now. More custom liquid cooling products in the New Industrial Style will be released soon, including white fittings, matte black fittings, and radiators. Stay tuned for our latest information!
Features of the Pacific SW1 Plus CPU Water Block:
Build with Style
Pacific SW1 Plus CPU Water Block is designed with a New Industrial Style to give more cooling options for your builds. We’ve used a solid aluminum alloy with a screw design to deepen the glow of metals and to show the texture of heavy industrial equipment, allowing you to see and feel the quality of this beautiful water block.
Just like a Mirror
Finished with an anti-corrosive nickel plating copper base, provides exceptional heat transfer and keeps the product looking new even after heavy usage or extreme conditions.
Dissipate Heat with our Central Inlet Design
Ensures better heat dissipation with the central inlet design by transferring heat from the CPU to the coolant through the jet plate in the middle of the water block and restricting the water flow for even coolant distribution through the optimized 0.2mm microchannels.
Built-in Water Temperature Sensor
Pacific SW1 Plus CPU Water Block features a built-in temperature sensor that will pick up the temperature from the passing coolant and transmit the signal to the TT RGB Plus 2.0 software; this allows users to monitor current temperature immediately whilst controlling its addressable LEDs for color manipulation.
Monitor and Control through TT RGB Plus 2.0
You can monitor coolant temperature in the TT RGB Plus 2.0 software with its built-in water temperature sensor and control 12 addressable LEDs with stunning lighting effects!
Universal Compatibility
Compatible with the latest Intel LGA 1700 and AMD AM5 sockets. Users are able to stay in the latest trend and won’t require additional brackets.
Compatible with the following models:
Intel: LGA 2066/1700/1200/115X
AMD: AM5/AM4
Get an Extra Boost to Your Liquid Cooling System
TG-60 Liquid Metal Thermal Grease is our latest high-performance thermal grease with extremely high thermal conductivity of up to 52 W/mK, providing unparalleled heat transfer. With its high efficiency and stability, your CPU can always stay cool.
TT RGB PLUS Ecosystem
Light up your system with almost limitless possibilities and synchronize your TT RGB PLUS compatible products to create a RGB ecosystem that is truly unique to you.
For more information on the Pacific SW1 Plus CPU Water Block, please visit:
https://www.thermaltake.com/pacific-sw1-plus-cpu-water-block.html
Features of the Pacific SF Fittings — Silver Black:
New Industrial Style with a Better Grip
The Pacific SF Fittings are forged with Industrial Style Helical Knurling Designed Rotators made with high-quality brass and treated with a special surface finishing, creating a new look with fantastic aesthetics and providing a more ergonomic grip while installing.
Pacific SF Adapters: Make Building Easy with A Little Help
Pacific SF Adapters provide convenience and aesthetic purpose while creating a build, allowing you to decorate your liquid cooling system while making 90-degree and 45-degree angles.
Pacific SF Adapters: Choose What Fits Best
Pacific SF Adaptors come with different angles, including 90-degree, 45-degree, and 45 & 90-degree, providing a wide range of selections to build your liquid cooling system with ease and more dynamics.
Pacific SF Extenders: Choose What Fits Best
Pacific SF Extenders come in 20mm to 30mm lengths in several designs of G1/4 screw threads, from male to male, female to male, and female to female, providing a wide range of selections for you to build your liquid cooling system more efficiently.
Pacific SF Adapters / Extenders: Swirl and Adjust
The rotators are 2-way, 360-degree revolvable, bringing convenience during installation and disassembly.
Pacific SF OD Compression: Install Freely without Worry
Pacific SF Hard Tube 16mm OD Compression fittings can be used with PETG, Acrylic, and Glass tubing, which is 16mm in outer diameter (OD) and paired with G1/4 screw threads. They are designed to work in tight spaces without compromising the compression seal or impacting the coolant flow. They also feature four O-Rings to provide a more secure seal and reliable performance.
For more information on the Pacific SF Fittings — Silver Black, please visit:
Pacific SF 90 Degree Adapter – Silver Black:
https://www.thermaltake.com/pacific-sf-90-degree-adapter-silver-black.html
Pacific SF 45 Degree Adapter – Silver Black:
https://www.thermaltake.com/pacific-sf-45-degree-adapter-silver-black.html
Pacific SF 45 & 90 Degree Adapter – Silver Black:
https://www.thermaltake.com/pacific-sf-45-90-degree-adapter-silver-black.html
Pacific SF Male to Male 20mm Extender – Silver Black:
https://www.thermaltake.com/pacific-sf-male-to-male-20mm-extender-silver-black.html
Pacific SF Male to Male 30mm Extender – Silver Black:
https://www.thermaltake.com/pacific-sf-male-to-male-30mm-extender-silver-black.html
Pacific SF Female to Male 20mm Extender – Silver Black:
https://www.thermaltake.com/pacific-sf-female-to-male-20mm-extender-silver-black.html
Pacific SF Female to Male 30mm Extender – Silver Black:
https://www.thermaltake.com/pacific-sf-female-to-male-30mm-extender-silver-black.html
Pacific SF Female to Female 20mm Extender – Silver Black:
https://www.thermaltake.com/pacific-sf-female-to-female-20mm-extender-silver-black.html
Pacific SF Female to Female 30mm Extender – Silver Black:
https://www.thermaltake.com/pacific-sf-female-to-female-30mm-extender-silver-black.html
Pacific SF Hard Tube 16mm OD Compression - Silver Black:
https://www.thermaltake.com/pacific-sf-hard-tube-16mm-od-compression-silver-black.html
