  • astrolabos
    astrolabos
    Phanteks today announces 4 models of the new Eclipse G500A, the M25 Series cooling fans, and new all-white Neon D-RGB LED strips.
    Eclipse G500A – Premium Mid-Tower Powerhouse
    The Eclipse G500A pushes the limit with its high airflow design to unlock next-gen CPU and GPU performance. The G500A’s front and top panels feature Phanteks’ Ultra-fine Performance Mesh design that combines high airflow performance with excellent dust filtration, all-in-one. With its spacious interior, the G500A is ready for powerful gaming setups, offering a 420 radiator in the front, and a 360 radiator in the top, while having plenty of space for full-length GPUs, multiple HDD and SSD locations, and a vertical GPU mounting option.
    Eclipse G500A D-RGB:
    Like all Phanteks lighting products, the integrated D-RGB lighting is simple to control with pre-programmed lighting effects and requires no software. Optionally, the D-RGB controller can be synchronized with compatible motherboards and expanded with more D-RGB products. The G500A D-RGB comes with 2x D-RGB LED strips built into the front and side. Three M25-140 D-RGB fans are pre-installed on the front.
    Eclipse G500A D-RGB Fanless:
    The G500A D-RGB Fanless model includes 2x D-RGB LED strips built into the front and side.
    Eclipse G500A Performance:
    The G500A Performance model comes with 4x M25-140 black fans pre-installed and a white LED strip in the front.
    Eclipse_G500A_PR_04_Cable Management.jpg Eclipse_G500A_PR_05_Vertical GPU.jpg
    M25 Series Fans:
    The Phanteks M25 fan builds upon the award-winning T30 fan to keep the next-gen hardware cool with high airflow cooling performance. The M25 fan blades are specifically optimized to perform the best with fine mesh/dust filters, heatsinks, and radiators with reduced RPM levels.
    This optimization keeps unwanted bearing noises at a minimum while also leaving plenty of cooling headroom, when necessary, by going full speed.
    By sharing some of its design with the T30, the M25 stands out by delivering higher airflow through heatsinks and radiators with lower RPM levels with exceptional value. The wide RPM range, up to 1800 RPM for 140mm models, and 2000 RPM for 120mm models, can be precisely controlled through PWM to ensure the M25 is excellent for both quiet and high-end gaming systems.
    The M25 Series is available in 120mm and 140mm sizes with options of single fan or triple fan kit and DRGB or all-black non-DRGB.
    All-White Neon D-RGB LED Strips:
    Phanteks’ NEON Digital-RGB LED provides the smoothest lighting effect with many mounting positions to highlight your system. The easy-to-use and secure mounting set let you choose which hardware to highlight with a diffuse ray of light from the NEON LED strip. Now also available in white in three sizes: Combo (2x40cm), M5 (55cm) and M1 (100cm).
    Eclipse_G500A_PR_06_M25.jpg Eclipse_G500A_PR_07_M25 Daisychain.jpg Eclipse_G500A_PR_08_Neon.jpg
    Pricing and Availability: – Available now
    Eclipse G500A:
    M25 Fans:
    Eclipse G500A D-RGB, Black
    €169.90 / £149.90 / $159.99
    M25-120 Black
    €9.90 / £8.99 / $9.99
    Eclipse G500A D-RGB, White
    M25-120 D-RGB, Black
    €14.90 / £13.99 / $14.99
    Eclipse G500A Performance, Black
    €159.90 / £139.90 / $149.99
    M25-120 D-RGB, White
    Eclipse G500A D-RGB Fanless, Black
    €139.90 / £119.90 / $129.99
    M25-120 Black, Triple Pack
    €27.90 / £25.99 / $27.99
    M25-120 D-RGB, Black, Triple Pack
    €39.90 / £34.99 / $39.99
    Neon D-RGB LED Strip:
    M25-120 D-RGB, White, Triple Pack
    Neon D-RGB LED Strip, Combo (2x40cm)
    €19.90 / £17.90 / $19.99
    Neon D-RGB LED Strip, M5 (55cm)
    €14.90 / £13.90 / $14.99
    M25-140 Black
    €10.90 / £9.99 / $10.99
    Neon D-RGB LED Strip, M1 (100cm)
    €21.90 / £19.90 / $21.99
    M25-140 D-RGB, Black
    €16.90 / £14.99 / $16.99
    M25-140 D-RGB, White
    M25-140 Black, Triple Pack
    €29.90 / £26.99 / $29.99
    M25-140 D-RGB, Black, Triple Pack
    €44.90 / £39.99 / $44.99
    M25-140 D-RGB, White, Triple Pack
