  • astrolabos
    astrolabos
    Phanteks releases Gigabyte & MSI GPU water blocks with new features
    Phanteks announces the release of the new Glacier G40 MSI & GIGABYTE GPU blocks, designed specifically for the MSI SUPRIM (X)/GAMING (X) TRIO & GIGABYTE AORUS MASTER/GAMING OC RTX 4090/4080 Series cards. The Glacier G40 MSI & GIGABYTE GPU Blocks bring the ultimate cooling performance with unique water block features to build stunning water-cooled systems.
    The Phanteks’ Glacier G40 MSI & GIGABYTE GPU Blocks provide a high-performance water-cooling solution custom-designed for the latest MSI & GIGABYTE GeForce RTX 4000 series cards. A transparent acrylic jet plate is positioned directly over the GPU die to ensure optimal heat transfer. The backplate is included with all models to provide a smooth integrated look while providing additional cooling to the back of the PCB. In addition, the full-cover copper cold plate directly cools all memory and power delivery components on the PCB with high-quality thermal pads. To improve stability, a GPU support bracket is added to connect the water block to the rear PCI bracket so that the GPU is mounted more securely.
    Glacier_G40_Gigabyte_MSI_01.jpgGlacier_G40_Gigabyte_MSI_02.jpgGlacier_G40_Gigabyte_MSI_03.jpg
    Like all Phanteks’ Glacier products, the Glacier G40 MSI & GIGABYTE GPU Blocks are made in Taiwan using only 100% copper, cast acrylic, anodized aluminum covers, and extremely durable Viton O-rings known from the automotive and aerospace industries. The integrated D-RGB lighting beautifully complements the water block and can synchronize with Phanteks’ D-RGB accessories and compatible motherboards.The Glacier G40 MSI & GIGABYTE GPU blocks will be available in Satin Black, Chrome and Matte White color finishes.
    Glacier_G40_Gigabyte_MSI_04.jpgGlacier_G40_Gigabyte_MSI_05.jpgGlacier_G40_Gigabyte_MSI_06.jpg
    Pricing and Availability: – Available now
    GLACIER G40 Gigabyte GPU Block:
    SATIN BLACK €249.90 / £229.90 / $249.99
    CHROME €269.90 / £244.90 / $269.99
    MATTE WHITE €269.90 / £244.90 / $269.99
    GLACIER G40 MSI GPU Block:
    Supported GPU cards:
    GLACIER G40 Gigabyte GPU Block supports:
    GIGABYTE AORUS GeForce RTX® 4090 MASTER 24G
    GIGABYTE GeForce RTX® 4090 GAMING OC 24G
    GLACIER G40 MSI GPU Block supports:
    MSI GeForce RTX® 4090 SUPRIM X 24G
    MSI GeForce RTX® 4090 SUPRIM 24G
    MSI GeForce RTX® 4090 GAMING X TRIO 24G
    MSI GeForce RTX® 4080 16GB SUPRIM X
    MSI GeForce RTX® 4080 12GB SUPRIM X
    MSI GeForce RTX® 4080 16GB GAMING X TRIO
    MSI GeForce RTX® 4080 16GB GAMING TRIO
    will be updated with to be released GPU models
