At Phanteks, we are dedicated to pushing the boundaries of innovation in the enthusiast PC market. Today, we are proud to unveil our latest breakthrough: the Glacier EZ-Fit water cooling system. Designed to streamline the water cooling process, this all-new system offers unmatched ease-of-use, flexibility for custom loop design, and cutting-edge performance.
Gone are the days of complicated fittings and endless shopping lists. With Glacier EZ-Fit, fittings are integrated directly into the cooling components, eliminating the need for separate purchases. Whether you’re using hard tubing or soft tubing, the EZ-Fit system seamlessly allows both types to be used within the same loop—giving enthusiasts more creative freedom and reducing setup complexity.
Precision Engineering and Premium Materials
Crafted from premium 100% copper, cast acrylic, and rigid aluminum alloys, Glacier EZ-Fit products are engineered using advanced CNC machinery for ultimate precision and maximum performance. This dedication to quality ensures the Glacier EZ-Fit system delivers top-tier cooling while maintaining sleek, durable construction.
Key Features of the Glacier EZ-Fit Water Cooling System:
• Integrated Fittings: Built into blocks, radiators, and reservoirs for a simplified assembly.
• Interchangeable Tubing: Supports both 16mm hard tubing and soft tubing within the same loop.
• Simplified Shopping: No need for multiple fitting types; everything is included.
• Premium Materials: Components made from 100% copper, cast acrylic, and rigid aluminum alloys.
• Precision Engineering: CNC-machined in Phanteks’ own facility for superior craftsmanship.
Availability:
North America - Available Now
Europe - Mid November
Initial Glacier EZ-Fit Product Lineup:
- Glacier EZ-Fit 360 D30-KIT – Complete water cooling kit with D30 fans. - $499.99 | €499.90 | £439.90
- Glacier EZ-Fit 360 SOFT-KIT – Soft tube water cooling kit. - $399.99| €399.90 | £349.90
- Glacier EZ-Fit 450CPU – High-performance CPU water block. - $99.99 | €99.90 | £86.90
- Glacier EZ-Fit 140RES-D5 – Versatile D5 pump and reservoir combo. - $229.99 | €229.90 | £199.90
- Glacier EZ-Fit 360RAD-30 – Slim copper radiator for maximum heat dissipation. - $99.99 | €99.90 | £86.90
- Glacier EZ-FIT G40 ASUS GPU Block – Designed for ASUS ROG STRIX/TUF RTX 4090. - $249.99 | €249.90 | £229.90
- Glacier EZ-Fit 16 Hard Tube – Impact-resistant PMMA hard tubing. - $18.99 | €18.90 | £16.99
- Glacier EZ-Fit 16 PVC Tube – Flexible, kink-resistant soft tubing. - $12.99 | €14.90 | £12.90
- Glacier EZ-Fit TOOL SET – Essential bending tools for 16mm hard tubing. - $24.99 | €24.90 | £21.90
- Glacier EZ-Fit F16G1/4 – Universal G1/4 fittings for easy loop integration. - Black: $6.99 | €7.90 | £6.90 Chrome: $7.99 | €7.90 | £6.90
The Glacier EZ-Fit system redefines PC water cooling by providing enthusiasts with a premium, streamlined, and customizable cooling experience. By combining the highest quality materials with an intuitive design, Phanteks ensures the Glacier EZ-Fit delivers industry-leading performance without the hassle.
For more information about the Glacier EZ-Fit water cooling system, visit www.phanteks.com.
