  • astrolabos
    astrolabos
    Phanteks announces new products at CES 2023
    Phanteks debuts a range of new products for CES 2023. The brand-new NV7 ATX chassis, Eclipse G300A, D30 D-RGB fans, SFX 850 Platinum Power Supply, Glacier One T30 Gen2, Glacier R260 D5 Reservoir, and Polar Air Coolers.
    NV7 | A TRUE SHOWCASE OF PERFORMANCE
    The Phanteks NV7, with its unmistakable purpose design, highlights the system components with the motherboard at its center. One defining design element of the NV7 is its strong and defining outer frame that captures and accentuates the hardware components.
    With a clean design from all sides, the NV7 allows you to place your system freely without the traditionally messy rear side. The glass panels offer a near-seamless view of the inside to further focus on the system components.
    Eclipse 300A | SMALL SIZE WITH BIG POTENTIAL
    Small in size and big on features, the Phanteks Eclipse G300A now sports a new front mesh panel design. The G300A features the Ultra-Fine Performance mesh delivering the best performance while keeping dust from entering the system. The G300A can now support high-end GPUs with up to 390mm clearance.
    The Eclipse G300A delivers quality and high airflow performance with exceptional value.
    D30-120 | AIRFLOW NERVER LOOKED THIS GOOD
    Showcasing first at CES, the new D30-120 fan. It comes with a multitude of features to make your system look cleaner, installation process easier and the lighting effect smoother. The HALOS lighting ring reflects on both sides of the fan blades while the clips and covers link multiple D30-120 fans together as one.
    REVOLT SFX 850 PLATINUM EDITION
    The super-compact SFX form-factor maximizes its versatility to fit Small Form-Factor chassis and free up space in larger chassis for better cable management. The silent 92mm Fluid Dynamic Bearing (FDB) fan with intelligent thermal control optimizes noise and cooling performance with a 0 RPM mode when under 30% load for ultimate silence.
    POLAR S4/S5/T6 | Glacier One T30 Gen2 | Glacier R260 | AIR/WATER COOLING SOLUTIONS
    Phanteks unveils a new range of air/water cooling solutions. The new Polar Air coolers come in a 4 & 5 Heatpipe single tower option and a 6 Heatpipe dual tower for ultimate cooling performance with an affordable price tag.
    The Glacier lineup brings the Glacier One T30 Gen2 with 240/360 radiator configurations, updated with Asetek’s new Gen8 pump design combined with the award-winning T30 Ultimate fans.
    Finally, the new Glacier R260 reservoir comes with or without a D5 pump pre-installed in black or white.
