  • astrolabos
    astrolabos
    iRocks Launches K74M Mechanical Keyboard with Backlight and Hot-Swappable Switches
    iRocks, a Taiwan PC peripheral manufacturer, introduced a brand-new mechanical keyboard K74M featuring white backlight, PBT keycaps, aluminum plate and hot-swappable switches.
    K74M is meticulously designed to offer style and practicality for both gaming and professional tasks. Over the course of several years, iRocks has devoted countless hours to testing, gathering feedback, and engaging in development. This ongoing effort has enabled K74M to collaborate effectively with typists and gamers, ensuring the delivery of a highly satisfying typing experience.
    PBT Keycaps and Floating Keys Design
    A pre-installed set of PBT keycaps outlives ordinary ABS ones with it comes to surface wearing, and greatly enhances the durability of the keys. The keycaps are made with double shot (dual-injection) technology to prevent backlit legends from fading. Thanks to its floating keys design and aluminum plating, the K74M makes keyboard cleaning and maintenance easier after years of service.
    Hot-swappable Socket
    Customize your typing experience painlessly without soldering.
    K74M features Gateron hot-swappable sockets for mechanical switches, compatible with 3pin and 5pin MX-style mechanical switches. The pre-installed Gateron switches can stand with up to 50 million keystrokes, with clear housing allowing white backlight evenly shines through the translucent key legends.
    Wired USB-C Connection
    K74M has detachable cable and can be connected using USB-A to USB-C or USB-C to C cable. High speed microcontroller inside the K74M enables fast keystroke response and N-key rollover function.
    Customizable Smart Wheel
    The wheel on K74M has switchable modes and is fully compatible with your Windows 10 and 11 PC. With Smart Wheel mode under Windows 10 and 11, you can customize your wheel to what you need it to be – volume, scrolling, zooming, brush adjustment, video editing, multimedia control, and more.
    Enhanced Typing Experience
    For premium typing feel and sound, the K74M implements a sound-absorbing pad for spaces between the plate and PCB and an appropriately sized foam for the bottom case. The components work together to turn every click into a delightful typing bliss. The stabilizers for the spacebar and modifiers on the K74M are tuned and lubricated to ensure consistent smoothness with less rattling key press.
    Software Configurator
    Not just from hardware hotkeys, K74M supports software configurator, providing you with an intuitive control interface for the keyboard, from backlighting to macro keys and more. The configuration may also be saved to the keyboard's onboard memory for on-the-go convenience.
    Pricing and Availability
    The iRocks K74M is available in black or white colorways from authorized online retailers and distributors. The keyboard is available now in the US on Amazon at price of $74.99 USD.
    i-rocks K74M at amazon : https://www.amazon.com/i-rocks-K74M-Illuminated-Mechanical-Keyboard/dp/B0BQVJJ4ZQ
