Thermaltake, the leading PC DIY premium brand for Case, Power, Cooling, Gaming peripherals, and enthusiast Memory solutions, is excited to announce the launch of The Tower 200 Bumblebee Mini Chassis, a new-color version of the beloved The Tower series. The Tower 200 is a mini-ITX case with a vertical case design and exceptional thermal efficiency. Though this chassis comes in a compact size, it can support the length of a 4090 graphics card and a 280mm radiator. With the addition of a new vibrant yellow hue, The Tower 200 series now comes in six colors: Black, Snow, Turquoise, Racing Green, Matcha Green, and Bumblebee, allowing you to easily choose an ideal The Tower 200 to fit your style.
The Tower 200 Bumblebee has the same vertical body design as its predecessors, providing users more space flexibility with its smaller footprint. Like the productive spirit of a bumblebee, The Tower 200 Bumblebee is a tiny but mighty case that offers superior hardware support and exceptional cooling performance. The Tower 200 can accommodate a graphics card with a length of up to 380mm such as the latest 4090 GPU and a standard-size power supply of up to 220mm, enabling you to choose the high-performance components you want. Additionally, The Tower 200 can house a CPU cooler with a maximum height of 200mm, support an AIO radiator up to 280mm, and is preinstalled with two CT140 PC Cooling Fans, allowing The Tower 200 Bumblebee to maintain a low interior temperature at all times.
Whether you are in gaming, video editing, or just daily use, the bright exterior color of The Tower 200 Bumblebee can inspire your courage and confidence, enabling you to reach your desired goals with fully positive energy. To be more visually pleasing with The Tower 200 Bumblebee, the fantastic inner components can easily be displayed through the tempered glass front panel. You also can make The Tower 200 Bumblebee more interactive with the separately sold LCD Panel Kit. The 3.9'' LCD display can show components’ real-time information, time, and weather. Besides, you can personalize your LCD display by uploading any images or GIFs through the TT RGB Plus 2.0 software.
The Tower 200 Bumblebee is a tiny but mighty chassis, like a bumblebee. If you are a compact chassis lover who would like to achieve outstanding cooling performance, hardware support, and visual aesthetics at the same time, don’t miss out on The Tower 200 Bumblebee Mini Chassis!
Features of The Tower 200 Bumblebee Mini Chassis:
Tiny but Mighty
As a new addition to The Tower series, The Tower 200 Bumblebee has the same contours as its predecessors, allowing for an unobstructed view of the system components. The Tower 200 can accommodate a 4090 GPU, a standard-size power supply up to 220mm, and a 280mm radiator for optimal performance. In addition to the two pre-installed fans, one 140mm at the top and one 140mm at the rear, you can also mount a 120/140mm fan on top of the power cover. These features allow for easy integration of the latest PC hardware without compromising on the building experience, making The Tower 200 Bumblebee an excellent choice for those looking to expand their hardware capabilities.
4090 GPU Fits in Perfectly!
The Tower 200 Bumblebee is fully equipped to accommodate all of your essential components, including the latest high-performance graphics cards such as the 4090 GPU. Besides, it can support graphics cards up to 380mm in length, providing you with the flexibility to choose the best graphics card for your needs. Rest assured that The Tower 200 Bumblebee has got you covered, no matter what GPU you decide to use.
Classic Vertical Body Design
The Tower 200 Bumblebee retains the iconic contours of its predecessors, with a vertical body design that allows the chassis to have a smaller footprint, providing flexibility and minimizing obstructions to your gaming and workspace.
Supports up to a 280mm Radiator on the Right
Despite its small size, The Tower 200 Bumblebee delivers exceptional cooling performance without any compromise. It supports up to a 280mm radiator on the right side, which effectively reduces the temperature inside the chassis and maintains optimal system performance.
Two CT140 PC Cooling Fans Pre-installed
The Tower 200 Bumblebee features two 140mm PWM fans, one on the top and the other on the rear, to provide good cooling performance.
Unify Your Fans with Your Build!
Thermaltake launches brand-new CT series fans, allowing users to choose from black or white, RGB or non-RGB, to match whatever color scheme you have.
Visually Pleasing, Totally Interactive
Maximize your Tower 200’s visual effects by upgrading it with our optimal LCD Panel Kit. The 3.9” LCD Display allows you to monitor real-time information and upload any images or GIFs to add extra flair using the TT RGB Plus 2.0 software. It also allows you to interact with the cooling components that feature the same LCD displays. The latest version includes weather mode and time mode for users to expand the usage of our LCD displays.
Secure Your Components
The Tower 200 Bumblebee features a GPU stabilizer to ensure the GPU doesn't wobble during use or transport.
Choose the Way You Install
On the right side, The Tower 200 Bumblebee has the capacity to support either two 120/140mm fans or a 280mm radiator. Installation is a breeze thanks to the removable fan bracket, which simplifies the process.
Air Intake and Exhaust
People may have concerns about the cooling performance of a mini-ITX chassis. However, our The Tower 200 Bumblebee has well-designed cold air intakes and hot air exhausts to keep the internal temperature low at all times.
Massive Airflow & Incredible Performance
Thanks to two CT140 PC Cooling Fans pre-installed, we were able to ensure that The Tower 200 comes with massive airflow, which guarantees amazing cooling performance and a low interior temperature while using the most upscale components.
Perfect Dust Protection
The Tower 200 Bumblebee has well-designed removable fan filters on the rear, inner two sides, and inner bottom layer. The removable filters provide excellent dust protection to ensure a dust-free environment.
Hardware Support and Cooling Solution
The Tower 200 Bumblebee has good hardware support. It can support a CPU cooler with a maximum height of 200mm, a GPU with a maximum length of 380mm (without power cover), a power supply with a length of up to 220mm, two 2.5'' SSDs with the side bracket and two 2.5'' SSDs or two 3.5'' HDDs (without rear fan) behind the motherboard tray. Although The Tower 200 Bumblebee is a mini-ITX chassis, it is still optimized for good cooling. On the top and rear of the case comes with two pre-installed CT140 fans, which can improve thermal efficiency. An additional 120mm or 140mm fan can be installed on top of the PSU cover, and up to a 280mm all-in-one CPU cooler can be installed on the right side of the case.
Handy I/O Ports
One USB 3.2 (Gen 2) Type-C and two USB 3.0 ports are placed on the top panel to grant direct access when needed.
DMD: Dismantlable Modular Design
No more unreachable screw corners or gaps, installation can be a breeze with our Dismantlable Modular Design.
For more information on The Tower 200 Mini Tower Case:
The Tower 200 - https://www.thermaltake.com/the-tower-200-mini-chassis.html
The Tower 200 Snow - https://www.thermaltake.com/the-tower-200-snow-mini-chassis.html
The Tower 200 Turquoise - https://www.thermaltake.com/the-tower-200-turquoise-mini-chassis.html
The Tower 200 Racing Green - https://www.thermaltake.com/the-tower-200-racing-green-mini-chassis.html
The Tower 200 Matcha Green - https://www.thermaltake.com/the-tower-200-matcha-green-mini-chassis.html
The Tower 200 Bumblebee - https://www.thermaltake.com/the-tower-200-bumblebee-mini-chassis.html
The Tower 200 Videos:
