acct Ιούνιος 7, 2018 #621 Ιούνιος 7, 2018 https://www.nasa.gov/press-release/nasa-finds-ancient-organic-material-mysterious-methane-on-mars Μια σύνθεση από την ανακοίνωση για τα νέα ευρήματα: Quote NASA’s Curiosity rover has found new evidence preserved in rocks on Mars that suggests the planet could have supported ancient life, as well as new evidence in the Martian atmosphere that relates to the search for current life on the Red Planet. While not necessarily evidence of life itself, these findings are a good sign for future missions exploring the planet’s surface and subsurface. Methane previously had been detected in Mars' atmosphere in large, unpredictable plumes. This new result shows that low levels of methane within Gale Crater repeatedly peak in warm, summer months and drop in the winter every year. Water-rock chemistry might have generated the methane, but scientists cannot rule out the possibility of biological origins. To identify organic material in the Martian soil, Curiosity drilled into sedimentary rocks known as mudstone from four areas in Gale Crater. The results also indicate organic carbon concentrations on the order of 10 parts per million or more. This is close to the amount observed in Martian meteorites and about 100 times greater than prior detections of organic carbon on Mars’ surface. Finding methane in the atmosphere and ancient carbon preserved on the surface gives scientists confidence that NASA's Mars 2020 rover and ESA’s (European Space Agency's) ExoMars rover will find even more organics, both on the surface and in the shallow subsurface. 1
acct Σεπτέμβριος 18, 2018 #622 Σεπτέμβριος 18, 2018 Αν και μεσολάβησαν ενδιαφέρουσες διαστημικές ειδήσεις, δεν είχα προλάβει να γράψω δυο κουβέντες εδώ. Η σημερινή αφορμή νομίζω είναι ό,τι πρέπει για να ξαναμπαίνουμε σε ρυθμό! Όπως είχε ακουστεί από διάφορες πηγές τις τελευταίες μέρες, σήμερα αποκαλύφθηκαν τα σχέδια του νέου BFR/BFS της SpaceX και ταυτόχρονα το όνομα του ιδιώτη που έχει προκαταβάλει ένα άγνωστο ποσό, για να γίνει ο πρώτος άνθρωπος που θα το χρησιμοποιήσει για ένα ταξίδι αναψυχής γύρω από τη Σελήνη, ιδανικά μέσα στο 2023. Πρόκειται για τον Ιάπωνα δισεκατομμυριούχο Yusaku Maezawa -είναι ο ίδιος που είχε προγραμματίσει το ίδιο εγχείρημα με τον Falcon Heavy. Η παρουσίαση υπάρχει ήδη -unlisted- στο youtube και έχει πολλές εικόνες και τεχνικές λεπτομέρειες για τα νέα σχέδια του σκάφους και της φιλόδοξης αποστολής του: Spoiler Μερικές από τις πιο ενδιαφέρουσες εικόνες απεικονίζουν δύο μεγάλες πτυσσόμενες αεροδυναμικές επιφάνειες στο πίσω μέρος, που περιλαμβάνουν δύο από τα τρία σκέλη -και ένα τρίτο στατικό σκέλος. Επίσης, τουλάχιστον δύο μικρότερα πτυσσόμενα πτερύγια στο μπροστινό μέρος. Οι 7 Raptor που θα παράσχουν ώθηση είναι πλέον πανομοιότυποι, απλοποιώντας την κατασκευή, αλλά θυσιάζοντας απόδοση και στο κενό και στην επιφάνεια της θάλασσας. Ενδεικτικά: Με την αποστολή να προγραμματίζεται κάπως έτσι: Και την εκτόξευση έτσι: 2
acct Σεπτέμβριος 23, 2018 #623 Σεπτέμβριος 23, 2018 Τις τελευταίες μέρες η (Ιαπωνική) JAXA είναι στην επικαιρότητα με ευχάριστα και εντυπωσιακά νέα. Για αρχή, ένας H-2B εκτόξευσε με επιτυχία μια αποστολή για τον ανεφοδιασμό του ISS. Το σκάφος HTV που οδεύει προς τον σταθμό μεταφέρει φορτίο ~4700 kg, συμπεριλαμβανομένης μιας πρωτότυπης κάψουλας βάρους ~180 kg και χωρητικότητας ~30 λίτρων, η οποία μπορεί να επιστρέψει στη Γη με δείγματα που δεν μπορούν να περιμένουν ένα Dragon ή δε χωρούν στον περιορισμένο χώρο του Soyuz. Άλλο ενδιαφέρον φορτίο στην Ιαπωνική αποστολή είναι ένα ευρωπαϊκό πειραματικό σύστημα ανακύκλωσης της ατμόσφαιρας, που στοχεύει στη εξοικονόμηση ~400 λίτρων νερού κάθε χρόνο, αλλά και την αξιολόγηση του πρωτοπόρου συστήματος εν όψει μελλοντικών επανδρωμένων αποστολών με μεγάλη διάρκεια. Το σύστημα είναι διπλά ενδιαφέρον γιατί αξιοποιεί και τη γνωστή αντίδραση Sabatier για να παράξει μεθάνιο και νερό -μια διαδικασία που αναμένεται να έχει κομβικό ρόλο για την επιτόπια παραγωγή καυσίμου σε μελλοντικές αποστολές στον Άρη. Το άλλο νέο που κρατάει την JAXA στην επικαιρότητα είναι η επιτυχημένη προσεδάφιση δύο μικρών αυτοκινούμενων βολίδων από το σκάφος Hayabusa2 στην επιφάνεια του αστεροειδή Ryugu. Αν η αποστολή συνεχίσει να εκτυλίσσεται κανονικά, αναμένουμε αρκετές εντυπωσιακές φωτογραφίες από την επιφάνεια του αστεροειδή (για πρώτη φορά) και χρήσιμες επιτόπιες μετρήσιες. Στη συνέχεια, τη λήψη δειγμάτων και την επιστροφή τους στη Γη, μέσα στο 2020. 4
shattered Σεπτέμβριος 26, 2018 #624 Σεπτέμβριος 26, 2018 https://www.space.com/41936-ariane-5-rocket-aces-100th-launch.html χθες είχαμε την 100 εκτόξευση ariane 5. Απο τις 100 οι 2 ήταν απώλειες, με πιο γνωστή την πρώτη πτήση και 3 μερικές απώλειες με πιο γνωστή την πτήση (μάλλον) τον γενάρη του 18 που ο πύραυλος έφυγε 17 μοίρες εκτός πορείας και τελείωσε το ρεκόρ επιτυχημένων σε σειρά εκτοξέυσεων (82) 1
acct Σεπτέμβριος 26, 2018 #625 Σεπτέμβριος 26, 2018 2 hours ago, shattered said: με πιο γνωστή την πτήση (μάλλον) τον γενάρη του 18 που ο πύραυλος έφυγε 17 μοίρες εκτός πορείας ..."ευτυχώς" από ανθρώπινο λάθος κι όχι από δυσλειτουργία του πυραύλου. Έχουμε κι ένα JWST να εκτοξεύσουμε!
shattered Σεπτέμβριος 26, 2018 #626 Σεπτέμβριος 26, 2018 1 hour ago, acct said: Έχουμε κι ένα JWST να εκτοξεύσουμε! καλά ας το φτιάξουν κάποτε το james webb σωστά γιατί όπως πάει θα περάσει καμία δεκαετία ακόμη μέχρι να βγάλουν άκρη (δυστυχώς....) 1
minast Οκτώβριος 8, 2018 #627 Οκτώβριος 8, 2018 Ενδιαφέρουσα εκτόξευση από SpaceX χθες βράδυ, με πολύ ωραίες εικόνες και την πρώτη προσγείωση πρώτου σταδίου Falcon 9 στην δυτική ακτή των ΗΠΑ (30ή συνολικά). https://www.bbc.com/news/world-us-canada-45782510 Φορτίο ήταν ο Αργεντίνικος SAOCOM 1A, που τέθηκε επιτυχώς σε τροχιά. 2
acct Οκτώβριος 8, 2018 #628 Οκτώβριος 8, 2018 Αυτές οι βραδυνές εκτοξεύσεις από τη δυτική ακτή δίνουν τις πιο εντυπωσιακές εικόνες. Παρότι το φορτίο και η αποστολή δεν είχαν ιδιαίτερο ενδιαφέρον, νομίζω ότι άφησε ως παρακαταθήκη τα καλύτερα timelapse που έχουμε δει μέχρι σήμερα: >>(MP4 only) https://i.imgur.com/UDS9eiQ.mp4 6
EraserheadX Οκτώβριος 11, 2018 #629 Οκτώβριος 11, 2018 Bad news today: https://arstechnica.com/science/2018/10/a-soyuz-crew-makes-an-emergency-landing-after-rocket-fails/ 2
minast Οκτώβριος 11, 2018 #630 Οκτώβριος 11, 2018 2 hours ago, EraserheadX said: Bad news today: https://arstechnica.com/science/2018/10/a-soyuz-crew-makes-an-emergency-landing-after-rocket-fails/ Προχθές αναλογιζόμουν ότι δεν έχουμε πλέον τρόπο να αντικαταστήσουμε ούτε τα γυροσκόπια του Hubble, που έχει αρχίσει να παραπαίει: https://arstechnica.com/science/2018/10/hubble-space-telescope-taken-offline-after-gyroscope-failure/ ... και τώρα αρχίζω να αναρωτιέμαι ακόμη και για το μέλλον του ISS... 1
acct Οκτώβριος 11, 2018 #631 Οκτώβριος 11, 2018 Το βίντεο της ζωντανής μετάδοσης της εκτόξευσης φαίνεται να καταγράφει τη στιγμή της αστοχίας του πυραύλου, γύρω στο 1:15... 1
Tsene Οκτώβριος 11, 2018 #632 Οκτώβριος 11, 2018 Το πλήρωμα, που είναι καλά στην υγεία του, προσγειώθηκε περίπου 400χλμ μακρυά από το Baikonour. Το σκάφος ακολούθησε μια βαλιστική τροχιά επανεισόδου.
Proteas Οκτώβριος 13, 2018 #634 Οκτώβριος 13, 2018 Εκτός λειτουργίας και δεύτερο τηλεσκόπιο της NASA 1
acct Οκτώβριος 20, 2018 #635 Οκτώβριος 20, 2018 Ακόμη μια σημαντική επιτυχία για τις ESA και JAXA: η επιτυχημένη εκτόξευση της αποστολής BepiColombo, με τελικό στόχο τον Ερμή, τον Δεκέμβριο του 2025. Πρόκειται για μια εξαιρετικά φιλόδοξη αποστολή, για πολλούς λόγους. Για αρχή, η προσέγγισης της τροχιάς του Ερμή απαιτεί τεράστια δαπάνη ενέργειας. Το ζευγάρι των συνδεδεμένων δορυφόρων Mercury Planet Orbiter (ESA) και Mercury Magnetospheric Orbiter (JAXA) θα χρειαστούν διαδοχικές επιταχύνσεις: μία φορά από τη Γη, δύο φορές από την Αφροδίτη και έξι φορές από τον ίδιο τον Ερμή, πριν την τελική τους άφιξη. Στη συνέχεια θα διαχωριστούν, θα εισαχθούν σε διαφορετικές τροχιές και θα ξεκινήσουν τις παρατηρήσεις τους, που αναμένεται να διαρκέσουν τουλάχιστον 1.5 χρόνο. Πέρα από την πολυπλοκότητα της προσέγγισης, τα δύο σκάφη φιλοξενούν 16 διαφορετικά επιστημονικά όργανα, τα οποία θα επιχειρήσουν να μελετήσουν και την Αφροδίτη -την ατμόσφαιρά της, την εσωτερική δομή της και τις αλληλεπιδράσεις της με τον Ήλιο. Τέλος, για μεγάλο μέρος από τα σχεδόν 10 χρόνια που θα διαρκέσει συνολικά η αποστολή, τα σκάφη θα πρέπει να αντεπεξέλθουν σε εξαιρετικά αντίξοες συνθήκες, εξαιτίας της τεράστιας έντασης της ηλιακής ακτινοβολίας σε τόσο στενή τροχιά. Η εκτόξευση: Οι κομβικές ημερομηνίες για τις τροχιακές επιταχύνσεις: Και μια σύνοψη της αποστολής, με μερικά ενδιαφέροντα νούμερα: Σύνδεσμοι στις εικόνες για υψηλότερη ανάλυση: http://www.esa.int/spaceinimages/Images/2018/10/BepiColombo_liftoff3 http://www.esa.int/spaceinimages/Images/2017/07/BepiColombo_timeline http://www.esa.int/spaceinimages/Images/2018/10/BepiColombo_journey_to_Mercury 6
Εσθήρ Οκτώβριος 21, 2018 #636 Οκτώβριος 21, 2018 Καλημερα! Ωραιο θεμα! Παράθεση Ρωσία:Μεχρι το επόμενο καλοκαίρι επαρκούν τα εφόδια στον ISS. Το πλήρωμα του Διεθνούς διαστημικού σταθμού ISS ,έχει αρκετά εφόδια για τους επόμενους 6 μήνες,δήλωσε ο Βλαντιμίρ Σολοβιόφ ,διευθυντής πτήσεων του ρωσικού τμήματος του σταθμού. Το πλήρωμα του Διεθνούς Διαστημικού Σταθμού (ISS) έχει αρκετά εφόδια για τους επόμενους έξι μήνες, δήλωσε ο Βλαντιμίρ Σολοβιόφ, διευθυντής πτήσεων του ρωσικού τμήματος του Σταθμού. Η Ρωσία ανέστειλε προσωρινά όλες τις επανδρωμένες πτήσεις μετά το ατύχημα που σημειώθηκε την περασμένη Πέμπτη, αμέσως μετά την εκτόξευση ενός πυραύλου Σογιούζ που θα μετέφερε έναν Ρώσο και έναν Αμερικανό αστροναύτη στον ISS. «Υπάρχουν αρκετά αποθέματα στον ISS (σ.σ. καύσιμα, οξυγόνο, νερό και τρόφιμα). Εκτιμούμε ότι επαρκούν για μισό χρόνο, μέχρι το επόμενο καλοκαίρι», δήλωσε ο Σολοβιόφ. Οι τρεις αστροναύτες που βρίσκονται αυτήν την περίοδο στον ISS, ένας Γερμανός, ένας Ρώσος και ένας Αμερικανός, είναι προγραμματισμένο να επιστρέψουν στη Γη τον Δεκέμβριο. Είναι όμως πιθανό να αναγκαστούν να παραμείνουν εκεί για μεγαλύτερο χρονικό διάστημα, εάν δεν ξεκινήσουν ξανά σύντομα οι εκτοξεύσεις των Σογιούζ. Η Ρωσική Διαστημική Υπηρεσία έχει ανακοινώσει ότι σχεδιάζει να προχωρήσει κανονικά με την επόμενη επανδρωμένη πτήση, τον Δεκέμβριο, αλλά αυτό θα εξαρτηθεί από τα συμπεράσματα της επιτροπής που ερευνά το ατύχημα της περασμένης Πέμπτης. Το πρακτορείο Interfax, επικαλούμενο μια μη κατονομαζόμενη πηγή, μετέδωσε το Σάββατο ότι η πτήση αυτή θα μπορούσε να γίνει συντομότερα, στις 28 Νοεμβρίου. Πηγηhttps://www.tovima.gr/2018/10/14/science/rosia-mexri-to-epomeno-kalokairi-eparkoun-ta-efodia-ston-iss/
Εσθήρ Οκτώβριος 21, 2018 #637 Οκτώβριος 21, 2018 Ανακαλύφθηκε ο ''Υπερίωνας '' μια τιτάνια δομή στο πρώιμο σύμπαν. Ένα πρωτο-σμήνος γαλαξιών που είναι η μεγαλύτερη δομή που έχει ανακαλυφθεί μέχρι σήμερα σε τόσο μακρινή απόσταση στο χρόνο και στο χώρο. Μια διεθνής ομάδα αστρονόμων ανακάλυψε μια τιτάνια δομή στο πρώιμο σύμπαν, η οποία υπήρχε ήδη 2,3 δισεκατομμύρια χρόνια μετά τη Μεγάλη Έκρηξη (Μπιγκ Μπανγκ). Πρόκειται για τον «Υπερίωνα», όπως ονομάσθηκε, ένα πρωτο-σμήνος γαλαξιών, που είναι η μεγαλύτερη κοσμική δομή που έχει ανακαλυφθεί μέχρι σήμερα σε τόσο μακρινή απόσταση στο χρόνο και στο χώρο. Οι αστρονόμοι, που έκαναν τη σχετική δημοσίευση στο περιοδικό αστρονομίας και αστροφυσικής «Astronomy & Astrophysics», χρησιμοποίησαν για τις παρατηρήσεις τους το Πολύ Μεγάλο Τηλεσκόπιο (VLT) του Ευρωπαϊκού Νοτίου Αστεροσκοπείου (ESO) στη Χιλή. Ο Υπερίων -που ήταν ένας Τιτάνας της ελληνικής μυθολογίας- εκτιμάται σύμφωνα με το ΑΠΕ ότι είχε (όταν το φως του ξεκίνησε το μακρινό ταξίδι του για τη Γη πριν από 11,5 δισεκατομμύρια χρόνια) μάζα πάνω από ένα εκατομμύριο δισεκατομμύρια φορές μεγαλύτερη από τη μάζα του Ήλιου μας. Η ανακάλυψη μιας τόσο γιγάντιας κοσμικής δομής στη νεανική ηλικία του σύμπαντος εξέπληξε τους αστρονόμους. «Είναι η πρώτη φορά που μια τόσο μεγάλη δομή ανακαλύπτεται στο πρώιμο σύμπαν. Φυσιολογικά, τέτοιες δομές έχουν εντοπισθεί σε πιο πρόσφατες περιόδους, που σημαίνει ότι το σύμπαν είχε στη διάθεσή του πολύ περισσότερο χρόνο για να εξελιχθεί και να δημιουργήσει τόσο πελώρια πράγματα. Ήταν μια έκπληξη να δούμε ότι κάτι τέτοιο είχε κιόλας εξελιχθεί, όταν το σύμπαν ήταν σχετικά νέο», δήλωσε η επικεφαλής ερευνήτρια Όλγκα Κουτσιάτι του Εθνικού Ινστιτούτου Αστροφυσικής της Ιταλίας στη Μπολόνια Ο Υπερίων, που βρίσκεται στον αστερισμό του Εξάντος, εκτιμάται ότι ήταν τουλάχιστον 5.000 φορές μεγαλύτερος από το γαλαξία μας και στο μεταξύ θα έχει μεγαλώσει πολύ περισσότερο. https://www.tovima.gr/2018/10/18/science/anakalyfthike-o-yperionas-mia-titania-domi-sto-proimo-sympan/
EraserheadX Νοέμβριος 1, 2018 #639 Νοέμβριος 1, 2018 Dramatic footage of Soyuz accident shows rocket booster collision 1
acct Νοέμβριος 1, 2018 #640 Νοέμβριος 1, 2018 (edited) Μας έφαγες τη δουλειά... έμεινα με το μήνυμα στη μέση! Συνοψίζω: δείτε στο 1:25-1:26 την αποτυχία αποδέσμευσης του αριστερού (στην εικόνα) προωθητήρα. Εικάζεται ότι στη συνέχεια ο προωθητήρας έπληξε το κέλυφος του κύριου πυραύλου, με αποτέλεσμα να ενεργοποιηθεί το δευτερεύον σύστημα διαφυγής, που οδήγησε την κάψουλα σε βαλλιστική επανείσοδο. Η αιτία μοιάζει να είναι (ξανά) ελαττωματικός αισθητήρας ή ελαττωματική βαλβίδα οξυγόνου (edit: περίπου, αλλά τίποτα από τα δύο, ήταν στραβή η ράβδος στην οποία αναρτάται ο αισθητήρας, βλ. παρακάτω). Το οξυγόνο εξωθείται τη στιγμή του διαχωρισμού από την εσωτερική δεξαμενή μέσω 4 βαλβίδων, για να απομακρύνει το άνω άκρο του προωθητήρα, δημιουργώντας τη χαρακτηριστική εικόνα των πυραύλων της οικογένειας R-7. Edit: Βρήκα με αγγλική μετάφραση τη συνέντευξη τύπου στην οποία ανακοινώθηκαν τα αποτελέσματα της έρευνας. Φαίνεται να είναι βέβαιοι ότι φταίνε οι χειρισμοί από τους τεχνικούς που συναρμολόγησαν τον πύραυλο (0:10-1:47). Άθελά τους έκαμψαν κατά 6° 45' μια ράβδο, στην οποία είναι αναρτημένος ο αισθητήρας που ενεργοποιεί τη βαλβίδα οξυγόνου για τον προωθητήρα που δεν αποχωρίστηκε. Για να βεβαιωθούν ότι δεν υπάρχει το ίδιο πρόβλημα στους άλλους έτοιμους Soyuz, θα τους αποσυναρμολογήσουν και θα τους ελέγξουν, φωτογραφίζοντας τα όποια ευρήματα. Έγινε επεξεργασία Νοέμβριος 1, 2018 από acct 2
