ASUS A7V880 review-kt880 has pci/agp lock?
unstoppable
http://www.xbitlabs.com/articles/chipsets/display/via-kt880.html
"In conclusion I would like to point out one more thing, which will be of interest to overclockers in the first place. Speaking about VIA KT880 as of VIA KT600 + dual-channel memory controller I left out one very important fact. Namely, I have to stress that VIA KT880 has finally acquired the so long-awaited option to clock the AGP/PCI buses asynchronously, which is also known as AGP lock. I"In conclusion I would like to point out one more thing, which will be of interest to overclockers in the first place. Speaking about VIA KT880 as of VIA KT600 + dual-channel memory controller I left out one very important fact. Namely, I have to stress that VIA KT880 has finally acquired the so long-awaited option to clock the AGP/PCI buses asynchronously, which is also known as AGP lock."
Aφου το test board της via δεν ειχε pci lock ,πως στο καλο εχει αυτο?Οχι τιποτε αλλο,αλλα θα αρχισει να ποσταρει και ο kbilly για το ποσο θεικη ειναι η via :D
  Παράθεση
Αρχική απάντηση από Vadergr
Aφου το test board της via δεν ειχε pci lock ,πως στο καλο εχει αυτο?....
Ισως να ηταν θεμα BIOS
  Παράθεση
The processor voltage regulator on ASUS A7V880 is designed according to a two-channel scheme. By the way, since we came to speak about the CPU voltage regulator, I would like to mention also that there are quite a few empty spots right around the area where the CPU power supply circuitry is located. We managed to find four empty spots intended for MOSFETs, three spots for large capacitors, and more than a dozen of spots for smaller electronic components, such as resistors and small capacitors. Frankly speaking, I got the impression that ASUS engineers suddenly decided to act economically ad removed the unnecessary elements from the PCB at all. However, this hasnt affected the mainboard stability at all, I should say. At least I havent revealed any problems with the mainboard performance during our test session
Η καλή γνωστή Asus στις AMD πλατφόρμες
Kαλά το είχα πει λοιπόν ότι τα ΚΤ880 θα έχουν κατά πάσα πιθανότητα agp/pci lock (θεϊκό motherboard... ε vader? :D )
Mένει να δούμε και άλλα reviews, και για άλλες εταιρείες
Αντε να βγει και κανα epox με τα ρεύματα που δίνει και στο kt600... είναι κρίμα να φτάνει 247 fsb stable και να μην μπορείς να το δουλεύεις εκεί... (και ελπίζω να μην "ξεχάσουν" και τις τρύπες γύρω από το socket για πιο hardcore καταστάσεις!)
Βέβαια άργησε λίγο να πιάσει το νόημα η VIA... αλλά τώρα με τους mobile, δόθηκε παράταση ζωής για τα 32μπιτα συστήματα στο χώρο του overclocking τουλάχιστον...
...είναι και θέμα "prestige"...
Θέλω να δω ασύγχρονα πως θα παίζει, γιατί απ ότι φαίνεται sync δεν έχει ελπίδα σε σύγκριση με το NF2. (άσε που το review αναφέρει προβλήματα με το NF που έχουν λυθεί και μερικά mobo πάνε πια όσο FSB θέλεις (NF7, DFI,Gigabute))
μην κρίνεις από το asus τις επιδόσεις - φαντάσου ότι μεταξύ των kt600 mobos έχει τις χαμηλότερες! (abit-msi-epox-gigabyte, τουλάχιστον, υπερτερούν) - άσε που μόλις βγήκε και θα βελτιωθούν στη συνέχεια - πολύ καλό σημάδι και πολλά υποσχόμενο, είναι ότι τερμάτισε εύκολα το fsb που δίνει το bios (227) χωρίς προβλήματα... και χωρίς και τόσο καλά ρεύματα που δίνει το asus...
Mόλις βγουν και τα υπόλοιπα ΚΤ880, τα ξαναλέμε...
ε ναι... να αποκτήσω και εγώ κανέναν "σύμμαχο"
μόνο εγώ "παλεύω" με via mobo εδώ μέσα... αμάν πια! :D
