sebastian Ιανουάριος 19, 2011 #621 Ιανουάριος 19, 2011 Τα 580gtx είναι κυρίαρχα αυτο κανείς δεν μπορεί να το αμφισβήτησή...Θα ήθελα να δω τα 570gtx, μιλάμε για πάνω απο 1,4gb μνήμη γι αυτά τα τεστ!Πιστεύω οτι τα 6950 θα τα έχουν πιάσει από το λαιμό τα 570gtx....
zpaf Ιανουάριος 19, 2011 Author #622 Ιανουάριος 19, 2011 @csaris Δωσε μου και ενα x8 το crysis να δουμε τι γινεται και με τα 1536 MB της πρασινης
michalos Ιανουάριος 19, 2011 #623 Ιανουάριος 19, 2011 Gigabyte readies overclocked, custom-cooled 1GB Radeon HD 6950 | TechConnect Magazine Θεριο !! Update - [19/1] - AMD's plans are to release a 1GB Radeon HD 6950, not 6970.
aris20 Ιανουάριος 19, 2011 #625 Ιανουάριος 19, 2011 techPowerUp GPU-Z Validation edu8p Ένα Overclock, που αποδείχτηκε unstable... 1077ΜΗz Core
csaris Ιανουάριος 19, 2011 #626 Ιανουάριος 19, 2011 @csaris Δωσε μου και ενα x8 το crysis να δουμε τι γινεται και με τα 1536 MB της πρασινης Eκει που ποναω πονταρεις zpaf!
zpaf Ιανουάριος 20, 2011 Author #627 Ιανουάριος 20, 2011 Sources close to AMD confirmed that TSMC will be the fab of choice for 28nm graphics. The same people are suggesting that AMD didn’t want to risk and produce its graphics chips with Global Foundries as it was not sure if the new fab can deliver.At the same time, AMD could not spare two sets of engineers and make two chips for two fabs. While this would have definitely been the best course of action, AMD simply doesn’t have resources for something like that.The big issue is that Nvidia has more attention from TSMC, since it is a larger customer, but TSMC will give AMD as much attention as necessary. If they are both on time, you should see some 28nm graphics chips before the end of this year.28nm means more transistors that are smaller, have better thermals and of course more graphics power. Next stop for AMD is to make this new core work with its next generation Fusion core, that is expected at 2012. Why AMD chose TSMC for its 28 nm graphics
The_Blade Ιανουάριος 20, 2011 #629 Ιανουάριος 20, 2011 από ότι βλέπω πάμε για τέλος χρόνου και όχι μέσα της χρονιάς όπως ακούγονταν, οπότε αυτό δικαιολογεί μια επένδυση των 500-600 .....
zpaf Ιανουάριος 20, 2011 Author #630 Ιανουάριος 20, 2011 Eκει που ποναω πονταρεις zpaf! Η εικονα που εχω μεχρι τωρα ειναι οτι 2x6950 flash σε 6970 στα 950/1450 = 2x580 στα μαμα τους ρολογια. Οταν οι 2x580 πανε στα 950/1050 η διαφορα ανεβαινει μεχρι και 15% αναλογα το παιχνιδι. Δεν ξερω που πονανε πιο πολυ οι 580 στα min fps ή στην μνημη τους αλλα εγω (6950) ποναω στο unigine extreme/metro 2033
csaris Ιανουάριος 20, 2011 #631 Ιανουάριος 20, 2011 Κοιτα τα κλοκαρισματα παιζουν ρολο στα κλειστα μετροπρογραμματα. Μεσα σε παιχνιδι δεν μπορω να βρω διαφορα... Απο θεμα μνημης η 580 φαινεται να τελειωνει σε 5760 αναλυση οταν θα παιξεις με 8χΑΑ.
nikpoth Ιανουάριος 21, 2011 #632 Ιανουάριος 21, 2011 ένα φρέσκο,με την καινούρια καρτούλα μου σε μαμά ρολόγια Uploaded with ImageShack.us
zpaf Ιανουάριος 22, 2011 Author #633 Ιανουάριος 22, 2011 ένα φρέσκο,με την καινούρια καρτούλα μου σε μαμά ρολόγια Uploaded with ImageShack.us Ωραιος νικο αλλη μια σου εμεινε τωρα για να κανεις το trifire σου Google
nikpoth Ιανουάριος 22, 2011 #634 Ιανουάριος 22, 2011 Ωραιος νικο αλλη μια σου εμεινε τωρα για να κανεις το trifire σου Google Κάνα δίμηνο το πολύ, υπομονή για την κουμούτσα, ε? καλά νέα! κάτι πήρε το μάτι μου ότι θα ρουφάει από 2x8 pin για να τρέξει το κτήνος.
papatsonis Ιανουάριος 25, 2011 #635 Ιανουάριος 25, 2011 πριν λίγο τελείωσα και με τις μετρήσεις των 11.1. Συνολικά μου φάνηκαν πάνω κάτω ίδιοι με τους 10.12, εκτός από τις μικρές αλλά μετρήσιμες διαφορές και στα 2 3dmark. Σχετικά με το CF.. Σε αρκετά games όπου τα min fps είναι κυριολεκτικά στον πάτο, πιστεύω ότι η ευθύνη βαραίνει κυρίως τον 7200.10 δίσκο που έχω τα παιχνίδια, και αυτό το λέω γιατί και στο crysis wh, με ίδιες ρυθμίσεις μπορεί σήμερα να έβγαζε minimum 2..!!!(και στα 5 loops) και αύριο να έβγαζε 44.. (ομοίως πάλι σε πολλά loops), άσε δε το loading που πήγαινε σύννεφο και στα 3 runs του Metro2033. Με τα λύπης μου είδα επίσης ότι ακόμη και στα 4200 ο 9650, αποτελεί αρκετό bottleneck:hang3:, ορατό ιδιαίτερα στο F1 2010 (όπου είτε σε 1280χ720, είτε σε 1920χ1080 βγάζει ακριβώς ίδια fps π.χ...), και στο cod bo, το οποίο πέρα από τις στιγμές που κοιτάς τον ουρανό π.χ. και τα fps όντως διπλασιάστηκαν με το cf... στην πράξη έμειναν σχεδόν τα ίδια.. (τα αποτελέσματα από το fraps, "live" κατά τη διάρκεια της αποστολής στο Baikonur x3). Ακόμη και αν δεχτώ ότι τα συγκεκριμένα console ports.. είναι GTP προγραμματισμένα(παίζει και να ισχύει ) , η "ηλικία" του φάνηκε και αλλού.., στο μη αναμενόμενο scalling στο gpu στο Ρ του vantage,που είναι πλέον πολύ ελαφρύ για 2 τέτοιες κάρτες, και στο Far Cry 2. Σε λιγότερο βαθμό δε, στα unigine και crysis (παρόλο που έκαναν καλό scalling αμφότερα). Ο Sandybridge από την άλλη με δελεάζει μεν με το oc potential του, αλλά θα περιμένω τον 1355/buldozer ή ,γιατί όχι, κάποιο μεταχειρισμένο i7/SB την ίδια περίοδο. Κλείνοντας να σημειώσω ότι αν δεν βγάλει update η futuremark(αν είναι εφικτό κιόλας..) θα βρομίσει ο τόπος από πλαστά scores από τις ΑΤΙ, όταν θα έχουν απενεργοποιημένο ή χαμηλωμένο το tesselation από τον οδηγό(βλέπε 9358->10713!!!). υ.γ.> με χαροποίησε το γεγονός ότι στα 800 είναι σταθερές -unlocked of course- με <=1v, δοκιμασμένες σε loops crysis wh, f1 2010, occt gpu, unigine και τα πρόχειρα αντίστοιχα αποτελέσματα που είχα βγάλει με default τάσεις (~895mhz και οι 2) δείχνουν ότι ,μέχρι εκεί τουλάχιστον, ακούνε γραμμικά στην τάση , (όχι ότι υπάρχει λόγος να τις τρέχεις παραπάνω από default, πέρα από benchmarks.. )
aris20 Ιανουάριος 25, 2011 #636 Ιανουάριος 25, 2011 Sapphire Radeon HD6950 1GΒ | Skroutz.gr Από ότι φαίνεται ήρθε και η 6950 1GB...
zpaf Ιανουάριος 25, 2011 Author #637 Ιανουάριος 25, 2011 Sapphire Radeon HD6950 1GΒ | Skroutz.grΑπό ότι φαίνεται ήρθε και η 6950 1GB... Ηρθε αλλα οταν μαθει ποσο κοστιζει η 560 ευχομαι να μεινει στα 240euro
Stalker Ιανουάριος 25, 2011 #639 Ιανουάριος 25, 2011 AMD Slashes Prices of Radeon HD 6800 and HD 6900 Series Products | techPowerUpΩπ! Καλησπέρα! Γιά να δούμε... Πόσο θα τους πάρει να το εφαρμοσουν και εδώ;Ελπίζω με αυτή την κίνηση να πέσουν και οι τιμές τις 560..
zpaf Ιανουάριος 25, 2011 Author #640 Ιανουάριος 25, 2011 AMD Slashes Prices of Radeon HD 6800 and HD 6900 Series Products | techPowerUpΩπ! Καλησπέρα! Γιά να δούμε... Πόσο θα τους πάρει να το εφαρμοσουν και εδώ; Ελπίζω με αυτή την κίνηση να πέσουν και οι τιμές τις 560.. Πω πω μιλαμε για τρελλα λουκουμακια εεε ; # Radeon HD 6950 1 GB: 225.00€, $259 # Radeon HD 6950 2 GB: 239.99€, $269~289 edit Ετσι και μου φερει και την 6990 κατω απο τα 600 ευρω τοτε μιλαμε για τον χορο της amd χωρις παρτενερ
