Ερώτηση: Όσοι παρήγγειλαν hard copy, κατά την εγκατάσταση προστέθηκε στο λογαριασμό τους στο steam?
παίζει; καλή φάση. όταν μου έρθει θα σου πω.
Πολύ σπαστικό που δεν έχει lock σε εχθρό.Αν σου έρχονται πολλοί την έκατσες.Καμμιά λύση ή τακτική;
fear frost κανενα shout και θα την παλεψεις.. αν οχι παιρνεις κανα level και επιστρεφεις :p
προσωπικα δεν θα μου αρεσε καθολου να εχει lock.. TES παιζεις! ;)
WARNING αν συναντήσετε αιμορουφήχτρες και σας βαρέσουν παίζει να κολλήσετε βαμπιρισμό..Στις πρωτες 3 μερες αν δεν κοιμηθείτε και πάρετε cure disease φευγει αλλιως έχει τρέξιμο.Αν δεν κάνετε cure τότε το παιχνίδι θα σταματήσει να ειναι απολαυστικό καθως ΟΛΟΙ θα σας κανουν επίθεση.Τελος τα quest και στο stage 4 τέλος και η μέρα..
The Four Stages of Vampirism
Vampires will succumb to their thirst for blood over a period of time. The longer you go without blood, the more powerful the benefits of vampirism will become, while the weaknesses will get worse.
You can only drink blood from sleeping NPCs. Interact with a sleeping NPC while sneaking to have the option to suck their blood.
Stage One
At stage one, vampires have a 25% increase to their illusion spells. They are 25% harder for NPCs to detect, have 100% resistance to diseases or poisons, and are 25% resistant to ice.
On the flipside, they’re 25% weaker to fire. Outside, in the sunlight, they also take a 15 point decrease to their health, magic, and stamina. Those three stats also do not regenerate.
Vampires at stage one have the power to reanimate the dead to serve them. They can also improve their night vision with another power.
Vampires also gain a spell that allows them to drain the health of their enemies.
As each stage increases, some effects stay the same, while the rest change. To be brief, we’ll only list the changes between stages.
Stage Two
At stage two, vampires at 50% more resistant to frost, while their vampiric servant and vampiric drain powers become more powerful.
They also become 50% weaker to fire, and have their health, stamine, and magic stats lowered by 30.
They gain another power; that of Vampiric Seduction. Enemies, either animals are people, can be calmed for 30 seconds. That means they won’t attack.
Stage Three
Vampires now have a 75% resistance to ice, while their powers of reanimating the dead and draining the living become more powerful.
Their weaknesses also grow, they are 75% more weak to fire, and their health, magic, and stamina are reduced by 45 points in the sunlight.
Stage Four
The last stage of vampirism. These vampires are 100% resistant to ice, while their draining and servant powers become even stronger.
They are also 100% weak to fire, with their health, stamina, and magic stats lowered by 60 points in the sunlight.
Stay out of the light and away from humans, because NPCs are all hostile to stage 4 vampires.
Luckily, stage 4 vampires gain another new power — Embrace of Shadows, which turns your character invisible for three minutes.
Source:http://www.gamefront.com/skyrim-how-to-become-a-vampire/
Έγινε επεξεργασία από grathk
Hint's and Tips
Βάζω μερικές χρήσιμες πληροφορίες να έχετε κατα νου.
Leveling.
1. Το θεωρητικό max level του χαρακτήρα είναι 80 αφού ανεβάσετε όλα τα skills στο 100. Το 50 είναι πιο εφικτό απο κει και πάνω ανεβαίνει πολύ πιο δύσκολα το leveling. Αλλά δεν μπορείτε να πάρετε όλα τα Perks για κάθε Skill που αντιστοιχούν σε 250. Το παιχνίδι θα σας δώσει συνολικά 80 Perks απο leveling + άλλα 20 απο quests σύνολο 100 Perks.
2.Ανεβάζοντας 10 skill points ανεβαίνεις 1 level.
3. Όσο ανεβάζετε level ανεβαίνει και η ποιότητα των αντικειμένων όσο και η δυσκολία των εχθρών. Έχει όμως και κάποια dungeons που έχουν level fix και δεν μπορείτε να πάτε σε μικρό level. Στα υπόλοιπα dungeons ορίζεται η δυσκολία των εχθρών ανάλογα το level που είσαστε την πρώτη φορά που θα μπείτε μέσα και μένει μέχρι το τέλος. Δηλαδή μπήκατε στην αρχή σε level 5, οι εχθροί που θα κάνουν respawn θα συνεχίσουν να είναι level 5 πχ ακόμα και όταν γυρίσετε ξανα σε μεγάλο level αργότερα στο παιχνίδι.
4. Όλα τα skill ανεβαίνουν με τον ίδιο ρυθμό. Δηλαδή τα ίδια experiences παίρνεις πχ φτιάχνοντας ένα steel dagger σε level 5 και τα ίδια φτιάχνοντας μια dragon armor σε level 95. Το skill crafting θα ανεβαίνει με τον ίδιο ρυθμό.
5. Ανεβάζοντας το stamina ανεβάζεται και το συνολικό βάρος που μπορείτε να κουβαλήσετε. Είναι και το μοναδικό attribute που υπάρχει.
6. Υπάρχουν quests που εμφανίζονται μονο και εφόσον ο χαρακτήρας μας έχει ανεβάσει κατα πολύ κάποια συγκεκριμένα skills.
Hint's and Tips
Αυτό δεν μου αρέσει...να υπάρχει level fix αλλά αν ξανμπω σε μια σπηλιά όντας lv30 θέλω να δω αντίστοιχου επιπέδου εχθρούς...όχι lv5 όπως όταν πρωτομπήκα...
Αnyway....σε ένα χρόνο από τώρα στο skyrimnexus θα γίνεται "Χαμός"...the way it meant to be played...
Γιατί αγόρι μου πιλαφάκι ήθελες και σκότωσες το πτηνό ? :p
Πω... και νόμιζα φεύγει μόνο του. Επίσης εμένα δεν κάνει regen o παίκτης, ούτε stamina ούτε magicka τίποτα... Είναι από το disease;
Xαχαχ το παιχνίδι δεν υπάρχει απλά...
Λοιπόν όπως έψαχνα να σκοτώσω κάποιον για να κάνω cure το vampirism, σκάει ένας δράκος στην Morthal.
Τον βαρούσα με τους guards και πήγε 50%, αλλά έφυγε οπότε τον κυνήγησα στο βουνό πιο πάνω, άρχισα να τον βαράω και εμφανίζεται και ένας Giant(γίγαντας) που είναι humanoid...
Ο γίγαντας και εγώ βαρούσαμε τον δράκο, και αφού τον σκοτώσαμε, ο γίγαντας άρχισε να βαράει εμένα(παει πολύ αργά όμως).
Οπότε του έκανα cast το Soul Trap για το quest τον σκότωσα και τώρα τελειώνω το vamprism cure... :hehe:
Αυτά για να δείτε για πόσο random καταστάσεις συμβαίνουν.
Το χουμε λιωσει ολοι βλεπω ετσι? :p
Εγω μετα απο 2 μερες ασχολια με side και misc quests και αφου περιπλανομενος εφτασα μεχρι το Riften (πολυ ομορφη περιοχη και καθολου φαλακρη), ειπα να γυρισω πισω στο Whiterun και να πιασω τους Companion μπας και τσιμπησουμε κανα gear... ;)
Το quest με τους Greybeards το επιασε κανεις? Ειναι το main?
λολ :hehe: Καλο ακουγεται ποσο μαλλον να το βλεπεις :p
Έλα όμως που την πάτησα... Αυτός που πρέπει να δώσω το quest μάλλον έχει ξεκλείδωτο το σπίτι του μόνο την μέρα!
Οπότε έκανα wait(πατώντας το Τ) μέχρι να πάει μέρα, πάω να μπω μέσα και μαντέψτε... Vampirism Level 4 όταν ξημέρωσε...δηλαδή όλοι με βλέπουν σαν hostile.
Να δω πως θα τελειώσω το cure τώρα...
Και εκεί που τριγυρνούσα έπεσα σε μια λίμνη και ξεκάρφωτα είδα αυτό!:)
Δεν σας θυμίζει excalibur και lady of the lake? :p
