BStath Αύγουστος 1, 2010 #21 Αύγουστος 1, 2010 Η 5165 είναι μια 4650 με άλλο όνομα (μόνο στο όνομα είναι 5χχχ, πουθενά αλλού). Είναι DX10.1 κάρτα στα 55nm με αρκετά μεγαλύτερη κατανάλωση από την 5450 που είναι πραγματικά 5χχχ κάρτα. The AMD ATI Mobility Radeon HD 5165 is a renamed Mobility Radeon HD 4650 with slighly higher clock rates. Therefore, the card supports only DirectX 10.1 and is still produced in 55nm. The power consumption and performance should be on par with a 4650 and therefore, the 5165 should be a solid middle class graphics card.Η 5165 δεν τα κάνει αυτά : The Mobility Radeon HD 5000 series includes an improved video processor (UVD2) to decode HD videos with the graphic card. The new version is able to decode two HD streams simultaneously (e.g., for Blu-Ray picture in picture) if the graphic card offers enough memory bandwidth (which may not be the case for the HD 5450). Since the Flash 10.1 Beta, the 5000 series is also able to help accelerate Flash HD videos (like YouTube). A special feature of the HD 5000 series is its ability to transmit HD audio formats (like Dolby True HD or DTS HD Master Audio) with up to 8 channels and 192 KHz / 24 Bit over HDMI 1.3a. As the desktop HD 5000 series, the Mobility HD 5450 also supports Eyefinity to connect up to 4 monitors to the graphics chip. Of course, this depends on how many monitor outputs the laptop vendor adds to the laptop (and how they are wired). Most laptops will support three screens simultaneously (internal and two external). The power consumption of the HD 5450 is a bit better than the 4570 / 5470 (both 13-15 W) and therefore the HD5450 can also be used for small laptops. According to AMD, the performance per watt ratio (same power consumption, better performance) and the Idle power consumption were improved (thanks to Memory Clock Scaling and Clock Gating). Furthermore, the chip does support PowerXpress (with AMD chipset) and Switchable Graphics (Intel) to switch between the dedicated and chipset / CPU graphics card (with improved switching times).Τιμές δές εδώ http://www.skroutz.gr/s/268185/Dell-Inspiron-1564-i3-330M-4GB-320GB-Radeon-HD5450-Win7.html. Δες και αυτό (αφού ανέβηκες πάνω από τα 700) http://www.multirama.gr/products/product?pid=0476826&catid=010200 , αλλά δεν χάνεις και τίποτα να πάρεις από Δευτέρα την Dell τηλέφωνο για προσφορά !Σύγκρινε και τους CPU του Dell και του Toshiba εδώ : http://www.notebookcheck.net/Mobile-Processors-Benchmarklist.2436.0.htmlEdit: και μακριά από SONY !!!!
Herc Αύγουστος 1, 2010 #22 Αύγουστος 1, 2010 Δες και αυτο http://www.multirama.gr/products/product?pid=0447647&catid=010200 http://www.sony.gr/product/vn-e-series/vpceb1s1e-bj
ARMAGEDDON Αύγουστος 1, 2010 Author #23 Αύγουστος 1, 2010 σας ευχαριστώ όλους για τις συμβουλές σας , ξέχασα να πω ότι το λάπτοπ θα το χρησιμοποιεί η σίστερ μου :whistle2: οπότε δεν ενδιαφέρεται για benchmarks και δεν θα κάνει Eyefinity ... την κάρτα την κοίταξα για μένα ώστε αμα τύχει να είμαστε κάπου μακριά από τον deskopt μου να μπορώ να παίξω και κανένα game και πάλι σας ευχαριστώ edit ξέρει κανένας που μπορώ να αγοράσω κάρτες γραφικών για λαπτοπ εντός ελλάδας η από το εξωτερικό γιατί έχω ένα acer που τα έφτυσε η κάρτα γραφικών του μετά απο 3,7 χρόνια φοράει μία 8400M G TurboCache
