Κανένας με DFI Lanparty T3EH8 να βοηθήσει...
Μαμά ψύκτρα, BClock στα 180 turbo-off, έβαλα και manual τα timings
mushkin από την προσφορά του πλαισιου 1440 / 2:8 / 7-7-7-20
Πώς δουλεύω από εδώ και πέρα? Τα settings είναι άπειρα.:...:
Νομίζω δεν νοιώθει από ρεύμα, έβαλα και 1,36 και δεν ποστάρει στα 200.
Genie BIOS Setting
CPU Feature
Set VR Current Limit Max: Enabled
Thermal Management Control: Enabled
EIST Function: Enabled
CxE Function: Enabled
Execute Disable Bit: Enabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
***** Logical Processor Setting *****
Intel HT Technology: Enabled
Active Processor Cores: All
DRAM Command Rate: AUTO
CAS Latency Time (tCL):8
RAS# to CAS# Delay (tRCD): 8
RAS# Precharge (tRP): 8
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Row Cycle Time (tRC): AUTO
Read CAS# Precharge (tRTP): AUTO
Four ACT WIN Time (tFAW): AUTO
Voltage Setting
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: 1.350v
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
DRAM Bus Voltage: 1.65
DRAM PWM Switch Frequency: Nominal
DRAM PWM Phase Control: 2 Phase Operation
CPU VTT Special Add: +0.0750v
CPU VTT Voltage: 1.53v
VTT PWM Switch Frequency: Nominal
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
IOH/ICH 1.1V Voltage: 1.11v
IOH Analog Voltage: 1.25v
ICH 1.5 Voltage: 1.5v
ICH 1.05V Voltage: 1.05v
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Enabled
1 core Max Turbo Ratio: 22x
2 core Max Turbo Ratio: 21x
3 core Max Turbo Ratio: 21x
4 core Max Turbo Ratio: 21x
CPU Non-Turbo Clock Ratio: 20x
* BCLK/UCLK/QPI Controller Settings *
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO
CPU Base Clock (BCLK): 200 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 101 Mhz
DRAM Frequency: 7x
UnCore Frequency: 14x (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Μπορείς και εδώ να βρεις πιο extreme configuration
godslayer
Εχεις δοκιμασει να τον βαλεις 201, 202, 203.... χ20? Μηπως εχεις καμια μαυρη τρυπα στα 200.
Μια χαρα εισαι παντως και απο θερμοκρασιες στο 1.328ν. Φορας μαμα ψυκτρα?
Έχει την ίδια συμπεριφορά από τα 200 και πάνω... θα περιμένω νεο bios μήπως αλλάξει η κατάσταση. Την true120 έχω για ψύξη.
Εγω ειμαι στα 4 με 1.31ν με μαμα ψυξη.
Εχω παραγγειλει και την true black για πιο σιγουρια.
Ρε παιδια οταν τρεχετε prime95 η cpu ανεβαινει στα 4ghz ή "παιζει" ?
Εγω οταν τρεχω prime95 και ανοιξω το cpuz δεν βλεπω 4ghz...
Τι βλέπεις? Κανονικά θα πρέπει τη μέγιστη συχνότητα να βλέπεις σταθερά.
Οταν τρεχω prime βλεπω τη συχνοτητα να παιζει...
Ποτε 17χ200, ποτε 19χ200, ποτε 14χ200 κτλ.
Στο bios εχω ολα τα cpu features enabled εκτος απο HT και Τurbo mode. Μηπως φταιει αυτο?
EIST
To εχεις ενεργοποιημενο στο BIOS.
Δεν θα έπρεπε όμως αυτό να λειτουργεί όταν το pc είναι σε idle? Στο 100% θα έπρεπε να δουλεύει σταθερά στην επιλεγμένη συχνότητα.
Στο prime δεν δουλευει 100% η συχνοτητα...
Αν παιξω fm09 και εχοντας το cpuz minimized οταν πατας continue game εκει βλεπω στο cpuz 4ghz.
Μήπως ανεβάζεις τρελλές θερμοκρασίες και ο επεξεργαστής κάνει throttling και ρίχνει την συχνότητα για να μη καει?
Αυτο ακριβως που λες ηταν...
Μολις εβαλα την TB120 με 2 ανεμιστηρες και τρεχω prime sta 4ghz με 1.256ν και ειμαι απολυτα σταθερος! Η θερμοκρασια μεχρι 87 στον πρωτο πυρηνα.
Turbo mode με τπτ δεν μπορω να βαλω. Κατι παιζει με τον πολλαπλασιαστη φαινεται.
Το turbo δε θα σου δουλεψει στην P6T απο καποια mhz & vcore και πανω , λογω του οτι δεν υποστηριζει το TDP override και κανει συνεχως throttling (20χ multi) πανω σε φορτιο. Αρα δεν παιζει στα 4ghz αλλα στα 3800mhz .
Συνεπως , το μονο που μπορεις να κανεις ειναι να παιξεις με 20x multi στα 200 bclock.
Την ιδια μητρικη εχω και εγω ... και την εχω ψαξει πολυ .
Τι 1.25 ρε γμτ??? Έχετε καλά κομμάτια βλέπω εσείς...:weep:
EIST : Enabled
CxE : Disabled
Execute Disable Bit : Disabled
Virtualization : Disabled
Δοκίμασε τα παραπάνω για 200x21. Σε μένα έτσι δούλεψε. Ελπίζω να τα έχει κάπως έτσι η Asus στο bios της.
edit: Δεν είχα προσέξει την απάντηση του Στελάρα, αφού το έχει ψάξει τότε έτσι θα είναι
turbo mode μονο με 1.325v και 200χ20 αλλα ανεβαινει πολυ η θερμοκρασια και δεν λεει.
Εχει κανενα 30 λεπτο στο prime.
Είναι άδικο... θέλω και γω καλό κομμάτι :weep:
Τον αγορασα απο το e-shop, γιαυτο ειναι καλος :p
Πάει και πιο πάνω, αλλά για κάθε μερα νομιζω τα 4 είναι καλά. Με παίδεψε πάντως μέχρι να τον σταθεροποιήσω:computer:
Πολυ καλος
Πόση ώρα τρέχει το Prime?
