Call Of Duty: Modern Warfare 2
Nephiλiμ
  • Replies 1,1k
Ναι ελλαδα για 55 ευρω το minimum το κοβω, και εγω ψωνιζω απο play.com αλλα η καταραμμενη η hardened που ειναι για το PC ? μαρεσει το steelbook αλλα σιγα που θα παρω την prestige με τα ψευτικα NVG και το κεφαλι του Soap να μου πιανουν χωρο :p
Συμφωνώ που είναι αυτές οι εκδόσεις ?! Εγώ παρ΄όλα τα σχόλια που έγιναν, τολμώ, βγαίνω δημόσια και λέω ότι θέλω την prestige έκδοση ! Που είναι ??!! :hehe::p
  • 3 weeks later...
" Modern Warfare 2 Combat Controller (360)
Price: $49.99 USD
It is basically a wired “latency free” controller having two additional buttons at the back that can be mapped to any thumbstick or button command. It also features “Immersive Analog ThumbStick Backlighting” and Dual Vibration Feedback.
Modern Warfare 2 Throat Communicator (360)
Price: $29.99 USD
This is in fact based on a military design and it reduces the background noise. It is compatible with the standard 360 controller and also with the combat controller that is mentioned above.
Modern Warfare 2 Faceplate and Console Skinz
Price: $29.99 USD
It is a skin with “z”, kids and it easily wraps around the sides of the console to create “a fully immersive themed landscape.”
Modern Warfare 2 Combat Controller (PS3)
Price: $49.99 USD
This also has the two additional buttons along with backlit thumbs and an internal battery. The battery of it can be charged through PS3’s USB port and it can provide gameplay up to 60 hours.
Modern Warfare 2 Wireless Bluetooth Headset (PS3)
Price: $39.99 USD
It is a noise-reducing microphone and can be used about 30 feet away from the console. , It is of Bluetooth 2.0 technology.
Modern Warfare 2 Controller Faceplates (PS3 and 360)
Price: $14.99 USD
It is durable and has a gloss finish.
Modern Warfare 2 Combat Game Pad (PC)
Price: $24.99 USD
It has analogue sticks, 4 trigger and 4 action buttons. It is pre-programmed and compatible with Windows 7, Vista and XP. It even comes with button mapping software.
Modern Warfare 2 Sniper Mouse (PC)
Price: $49.99 USD
It allows in altering cursor speed.
Modern Warfare 2 Combat Keyboard
Price: $49.99 USD
This features “Anti-ghosting” for key action areas. Media Keys in it is used in controling volume and other media functions.
Modern Warfare 2 Elite Keyboard (PC)
Price: $49.99 USD
It also has multi-colour backlighting and Tru-Vu illumination.
:nothing::confused::TD::suicide:
http://www.crossfire.nu/?x=news&mode=item&id=4572
wtf :tw:
Μεγαλύτεροι μλκς δεν είναι αυτοι που τα πουλάνε, αλλά αυτοί που θα τα αγοράσουν.....
Τώρα που μπαίνουμε στο φθινόπωρο, επιτέλους αρχίζουμε και μαθαίνουμε περισσότερες λεπτομέρειες για το Modern Warfare 2. Τρεις ειδήσεις σε μία, λοιπόν.
Καταρχάς, η Infinity Ward αποκάλυψε ορσιμένους από τους ηθοποιούς που συνθέτουν το voice cast του παιχνιδιού.
Ο λόγος για τους Keith David, Kevin McKidd, Barry Pepper και Craig Fairbrass. Γνωστές φάτσες όλοι τους.
Περνάμε σε έναν άλλο τομέα του ήχου και συγκεκριμένα στην μουσική.
Ο Hans Zimmer, o κορυφαίος συνθέτης στο Hollywood εδώ και χρόνια, έχει αναλάβει την μουσική του Modern Warfare 2 και μάλιστα πρόκειται για την πρώτη του δουλειά στην βιομηχανία των games. Ετοιμαστείτε για επικά ακούσματα!
Όπως καταλαβαίνετε από τα παραπάνω, ο ηχητικός τομέας του παιχνιδιού θα είναι κορυφαίος. Όχι ότι υπήρχε αμφιβολία γι αυτό ούτως ή άλλως…
Τέλος, στο παρακάτω βίντεο μπορείτε να δείτε τα επίσημα περιφερειακά του Modern Warfare 2, τα οποία θα κυκλοφορήσει η Mad Catz για Xbox 360, PS3 και PC.
Ειδικά χειριστήρια, faceplates για τα απλά χειριστήρια (!), ποντίκια, πληκτρολόγια, μικρόφωνα… Απ’ όλα έχει ο μπαξές!
Με βλέπω να τσιμπάω χειριστηριάκι. Κι εσείς το ίδιο ε; Είναι δύσκολο να αντισταθούμε στο πειρασμό!
Το Modern Warfare 2 θα κυκλοφορήσει στις 10 Νοεμβρίου και θα τα κάνει όλα λίμπα!
Εγω περισσοτερο για ποντικι το βλεπω μιας που τα εχει πεξει λιγο το δικο μου:giveup::giveup:!
Το παιχνίδι φαίνεται αρκετά καλό αν και έχω κάποιες επιφυλάξεις. Τώρα όσον αφόρα το heartbeat sensor όντως αν είναι attachment θα είναι μεγάλη ανοησία εκ μέρους τους. Αυτό το οποίο ελπίζω είναι όταν κάνεις κάποιο Kill streak να μπορείς να το χρησιμοποιήσεις (ουσιαστικά σαν UAV) το οποίο θα είναι ενσωματωμένο πάνω στο όπλο αντί να είναι πάνω δεξιά στο mini-map. Θα δείξει...
Καλα ντε πως πορωνεστε ετσι ? δεν εχει ανακοινωθει καν αν θα χρησιμοποιει καινουργια μηχανη γραφικων ( την σιχαθηκα την αλλη πια ) ή αν θα εχει ουσιαστικες βελτιωσεις πανω στο multiplayer, ο μονος λογος που ειναι τοσο δημοφιλες online imo ειναι γιατι εχουνε πλακωσει ολα τα 12χρονα που δεν μπορουν να παιξουν css/cs1.6/cod2/bf2 και τα ρεστα.
Ρεαλισμος 0 λες και παιζεις σε καμια ταινια του hollywood,(ειδικα με την συμπεριφορα και τον ηχο του G3 εβαλα τα γελια μιας και εχω κανει σωρο βολες στην κυπρο) αν υπηρχε ενα οπλο εκει μεσα που να θελει προσπαθεια για να σκοτωσεις ειναι το M14, ολα τα αλλα spray and pray δεν εχει σημασια αν θα τον πετυχεις με την πρωτη και οι υπολοιπες 29 στο ιδιο μερος θα πανε, λες και ο στρατιωτης σου ειναι ο ραμπο και δεν του φευγει καθολου το οπλο :p
Χαθηκε να βγαλουν ενα με θεμα το vietnam ? να'ναι λιγοτερο κονσολοποιημενο ομως απ'το 4(το 1 ειχε την καλυτερη μειξη ρεαλισμου με arcade imo ) με επικες και ιστορικα ακριβεις μαχες οχι να βλεπω εναν πολεμο που τον δειχνουν ακομα στις ειδησεις. Οντως ποδοσφαιρακι/nfs το καταντησανε μετα την επιτυχια του 4, δεν φταινε αυτοι ομως αφου δεν βγηκε και κανα σοβαρο παιχνιδι το 2007, τωρα εχουν την ευκαιρια να αρμεξουν το franchise για τα καλα :wall:
Συμφωνω απολυτα με τον Grunt και να προσθεσω οτι ειναι γελοιο να συγκρινεις το CoD με το CS ,γιατι μονο σε γραφικα το ξεπερναει,δεν υπαρχει ρεαλισμος και τα οπλα ειναι αθλια (θαρρω) .Το CS,αν οχι το CSS γιατι παρα το γεγονος οτι το εχουμε αγαπησει ολοι ειναι καπως και αυτο,το 1.6 δε θα το φτασει ποτε το CoD και αυτο το καταλαβαινεις αμα παρεις ενα awp και παιξεις και στα 2,τι πιο απλο.Το καλυτερο CoD πιστευω ειναι το 2.Τωρα αν το CoD ειναι καλυτερο απο το CS,μιλαει το community απο μονο του και οτι δεν ειναι δυνατον να γινει το το καλυτερο MMOFPS ,γιατι κυκλοφορει απο ενα και καθε χρονο.Αυτο θα πρεπε να γινεται αμα ηταν μονο single,αλλιως το να παιζουν οι μισοι το 2,οι αλλοι μισοι το 4 και οι αλλοι το 5 ειναι γελοιο.:tomato: Γιουρια στα παλιουρια...
Περιμενω ομως και το καινουριο...:T:
  • 3 weeks later...
http://www.youtube.com/watch?v=A3PAAWkojN4&feature=player_embedded
οχι και ασχημο, urban setting κι ετσι :D
Με το regeneration κατι πρεπει να γινει παντως αν και τα αιματα εχουν πλακα, αντε να δω ποτε θα ξαναβαλουνε healthpacks, στρατιωτης εισαι οχι ο wolverine :p
