poison6 Ιανουάριος 17, 2009 #21 Ιανουάριος 17, 2009 nikpoth έγραψε: Δεν κανεις ένα κόπο να δούμε που βρίσκεσαι?συμπλήρωσε στα κενάJumperFree Configuration SettingsAI Overclock tuner: MANUALCPU Ratio Setting: AUTOFSB Strap to North Bridge: AUTOFSB Frequency: 370PCI-E Frequency: 100DRAM Frequency: AUTODRAM CLK Skew on Channel A1: AUTODRAM CLK Skew on Channel A2: AUTODRAM CLK Skew on Channel B1: AUTODRAM CLK Skew on Channel B2: AUTODRAM Timing Control: MANUAL1st Information : 5-5-5-15-3-44-5-3CAS# Latency: 5DRAM RAS# to CAS# Delay: 5DRAM RAS# Precharge: 5DRAM RAS# Activate to Precharge: 15RAS# to RAS# Delay : AUTORow Refresh Cycle Time: AUTOWrite Recovery Time: AUTORead to Precharge Time:AUTO2nd Information :8-3-5-4-6-4-6READ to WRITE Delay (S/D): AUTOWrite to Read Delay (S): AUTOWRITE to READ Delay (D): AUTOREAD to READ Delay (S): AUTOREAD to READ Delay (D): AUTOWRITE to WRITE Delay (S): AUTOWRITE to WRITE Delay (D): AUTO3rd Information :13-5-1-6-6WRITE to PRE Delay: AUTOREAD to PRE Delay: AUTOPRE to PRE Delay: AUTOALL PRE to ACT Delay: AUTOALL PRE to REF Delay: AUTODRAM Static Read Control: AUTODRAM Read Training: AUTOMEM. OC Charger: AUTOAI Clock Twister: AUTOAI Transaction Booster: AUTOCommon Performance Level [5]Pull-In of CHA PH1: DISABLEPull-In of CHA PH2: DISABLEPull-In of CHA PH3: DISABLEPull-In of CHA PH4: DISABLEPull-In of CHB PH1: DISABLEPull-In of CHB PH2: DISABLEPull-In of CHB PH3: DISABLEPull-In of CHB PH4: DISABLECPU Voltage: 1.20000CPU GTL Voltage Reference (0/2): AUTOCPU GTL Voltage Reference (1/3): AUTOCPU PLL Voltage: AUTOFSB Termination Voltage: AUTODRAM Voltage: AUTONB Voltage: AUTONB GTL Reference: AUTOSBridge Voltage: AUTOPCIE SATA Voltage: AUTOLoad Line Calibration: AUTOCPU Spread Spectrum: AUTOPCIE Spread Spectrum: AUTOCPU Clock Skew : AUTONB Clock Skew : AUTOAdvance CPU SettingsCPU Ratio Setting: AUTOCPU VID: (Δεν βρήκα κάπου την επιλογή)Στα Windows είδα πως είναι 1.2500vC1E Suppport: DISABLEDMax CPUID Value Limit: DISABLEDIntel® Virtualization Tech: ENABLEDVanderpool Technology: (Δεν βρήκα κάπου την επιλογή)CPU TM Function: DISABLEDExecute Disable Bit:DISABLEDεσύ με τι θερμοκρασίες είσαι τώρα?
nikpoth Ιανουάριος 18, 2009 Author #22 Ιανουάριος 18, 2009 33 και στα όταν η πυρήνες είναι 100% 53 βαθμούς περίπου.Eχεις πολλά στο Αuτo.δεν θα κανεις δουλειά έτσι.
poison6 Ιανουάριος 19, 2009 #23 Ιανουάριος 19, 2009 ωραία πες μου τι να αλλάξω σε σχέση με τις μνήμες και στα υπόλοιπα θα βάλω ότι ρύθμιση βλέπω στο πρώτο ποστ!θα τρέξω orthos και θα τσεκάρω θερμοκρασίες..και θα έρθω να ποστάρω.thnx
