Hard to please, ε; :hehe:
Να, πάρε κάτι πιο επώδυνο:
Αυτό σίγουρα δεν είναι fake και σίγουρα θέλει γερό στομάχι
και χωρίς wd να παίζει περικαλώ :p
βρήκα ένα κολπάκι όταν λαγγαρει,το ρίχνουμε σε Τ6 και ξανα-ξεκινάμε. μέχρι τώρα σε 60αρι κανένα πρόβλημα,2 wd 1 monk 1 dh
Nazgren: Any chance for a "close-quarters" DH build? They have plenty of knife based skills.
Kevin Martens: That would be awesome! Geez, John Yang, why don't you do something about that?
John Yang: Done! The Shadow's Mantle set is the redesign that I'm the most excited about for 2.4 so far. The idea of a melee-weapon oriented build that doesn't involve bows / xbows has always been in the back of my mind. Here's what it currently looks like:
2pc - While equipped with a melee weapon, all damage is increased by 1000%.
4pc - Shadow Power gains all runes and lasts forever.
6pc - Impale deals 30000% weapon damage to the first enemy it hits.
The idea is that the set is extremely strong on single-target damage, but weak on AoE. To help with that, a new dagger will have the power "Every second, the damage of your next Fan of Knives is increased by 250-300%." To help with movement, a pair of bracers has the power: "After using Impale, Vault costs no resource for 2 seconds." That item will allow you to Vault into position to Impale the high-value targets.
Additionally, we're also allowing Demon Hunters to use melee weapons with quivers because the fantasy of this quick-moving assassin build is about speed, not walking around with a shield ;)
oO
  • Like 3
Μάλιστα... Αν μου επιτρέπει ο κύριος Yang θα ήθελα να προτείνω μερικά ενδιαφέροντα builds δικής μου εμπνεύσεως.
  • Witch Doctor - Slapadoc Witch Frogtor build
    • - New Plague of Toads rune: You can now melee slap your enemies with a frog for 666% of your weapon damage.
  • Witch Doctor - Fetish God build
    • - New Fetish Army rune: You turn into a Fetish. One of your Fetishes turns into a Witch Doctor.
  • Monk - Palm, live-grenade build (aka Palmolive build)
    • - New Exploding Palm rune: Your hand can now be torn from your body and thrown at enemies, from afar, exploding for 10000% of your total Strength.
  • Barbarian - Look-at-me-im-a-****in-witch-doctor build
    • -New Call Of the Ancients rune: Call forth a reckless, suicidal zombie Barbarian that deals 637% weapon damage to all enemies in his path. (shares mechanincs with Witch Doctor's, Zombie Charger spell)
  • Wizard - Barbarchon build
    • New Archon rune: You turn into a Barbarian gaining 5 random skills from that class.
  • Crusader - Hammershot build
    • New Blessed Hammer rune: You can now equip 2-Hand bows that shoot blessed hammers for 850% of your weapon damage. Your main stat is now Intelligence (becausse ***** you, that's why).
Πραγματικά απορώ γιατί δεν με έχει προσλάβει ακόμη η Blizzard... Morhaime please!   :hehe:  :hehe:  :hehe:
Έγινε επεξεργασία από Calydon
  • Like 8
btw χτες το βράδυ πέταξα όλα τα Marauder που μου έχουν πέσει από τότε που βγήκαν τα ancient (και ταυτόχρονα πέθανε και το sentry build) πάνω στον mule-DH μου και έβγαλα GR50 με τη μία σε 8 λεπτά και GR55 σε 13, επίσης με την πρώτη :hehe:
Νέα πνοή σε build του 2014
http://eu.battle.net/d3/en/profile/Chosen-2702/hero/46774255
Αν νομίζετε ότι τα spells του WD γεμίζουν την οθόνη, πρέπει να δείτε 5x Spitfire sentries + Yang's recurve. Απλά βαράς και κοιτάς το chat window περιμένοντας το death message (είτε το δικό σου, είτε του elite)
Ομαδικά d/c κατά ριπάς, δεν μπαίνει καν τώρα.
Παίρνω ποπ-κορν και μπαίνω στο φόρουμ του battlenet
Έγινε επεξεργασία από MikeKorn
Αρα 4 caches καθε φορα? Καλη μπιζνα. Δηλαδη 16 mats απο το καθε ακτ... Θα πεσει πολυ μπαουντυ. Και δεν εννοω τη σοκολατα με την καρυδα...
Ρε παιδιά παιζει καποιο θεμα σε καποια συγκεκριμένα ριφτ? Χτες είχα μπει σε GR50 που το έχω άνετα, και σε καποια mob χωρίς να με ακουμπάει κανείς, η ζωη έπεφτε τρελά γρήγορα χωρίς να μπορώ να δω ποιος η τί με βαράει... Μέχρι που procare το passive... και τα είδα ολα...(hardcore btw)
Monk παίζω και το toughness είναι στα ύψη, σε άλλα rift δεν έχω θέμα, το τοπ μου είναι GR60 με 3 άτομα.
anarchs μυριζομαι...
Οι anarchs μπορούν να κάνουν damage χωρίς να σε ακουμπήσουν; Μόνο το charge τους έχω υπόψιν μου σαν damage dealer.
Το μόνο mob που ξέρω ότι κάνει αρκετό damage εξ'αποστάσεως είναι τα Enraged Phantoms με το ασύλληπτα εκνευριστικό leech τους...
οι anarchs αφήνουν ένα flaming path Από κάτω τους μετά το charge και το οποίο δεν φαίνεται. Τσούζει πολύ και αν ο παλλικαράς παίζει hardcore, τον συμβουλεύω μόλις βλέπει anarchs να το καίει το grift και να φεύγει.
Εγώ αυτό θα έκανα..
Βασικά εγώ γενικά θα έλεγα την τελευταία βδομάδα που υπάρχουν τόσα θέματα με lag και d/c να αποφύγει το HC, ειδικά grift.
Έχει τιγκάρει το blizzoforum με τόπικ HC ψόφων.
είναι αργά να το ξεκινήσω; το βρήκα με 45 ευρά μαζί με expansion
Την είχα δει κι εγώ την προσφορά και έψησα δύο φίλους να το τσιμπήσουν το παιχνίδι! Είναι η καλύτερη περίοδος για να ξεκινήσεις, σενιόρ!
