Πριονέτο Ιούνιος 20, 2008 #101 Ιούνιος 20, 2008 τελικα να χτυπισουμε καμια 4850; ή να περιμενουμε 4870;Σε 5-6 θα εμφανιστεί και η 4870 οπότε θα έλεγα να περιμένεις λίγο να δεις τι ψάρια πιάνει και να πάρεις την απόφασή σου.
Strategos Ιούνιος 20, 2008 #102 Ιούνιος 20, 2008 η 4870 δεν θα ερθει σε 5-6 μερες θα ερθει 10 ιουλι και μετα. ετσι λενε στο xs τουλαχιστον.
revenant Ιούνιος 20, 2008 #103 Ιούνιος 20, 2008 Μονο με αλλαγη στην παστα καταφεραν να ριξουν temp απο 10 ως 15 βαθμους κατω στο idle,δοκιμασε το
AN7 OverClocker Ιούνιος 20, 2008 #104 Ιούνιος 20, 2008 ρε παιδια,ρε παιδια....Το έκανα...ούτε 1 βαθμό παρακάτω δεν είδα...........
revenant Ιούνιος 20, 2008 #105 Ιούνιος 20, 2008 ATI 4850 Review Reviewer: Jimmyz Review Link: VisionTek Radeon HD 4850 Review After having spent the better part of the last two days putting ATI's latest offering through it's paces I have to say it has been a surprise how much performance this card brings to the midrange market. It is capable of running crysis at 1680 x 1050 in dx10 with settings on high, frames rarely dip below 30 and the game actually feels smooth, quite an accomplishment in a single slot mid range card especially at this price point. The driver installations were simply and straightforward as were the packaging and accessories. This is a serious company and with a Lifetime Warranty to boot. That is something lacking with most board partners today. The card performs flawlessly, however out of the box the GPU was registering 79c at idle in catalyst overdrive window, after changing thermal paste and re-installing temps are more like 55 - 60c idle and load temperatures are also much improved. With the heat taken care of I tried Catalyst’s built in overclocking utility which allows up to 700 core and 1200 memory clocks, I tried 700/ 1100 and found it to be stable for bench testing and the hour of crisis I played.
Topdim2 Ιούνιος 20, 2008 #106 Ιούνιος 20, 2008 Super δεν λέω η 4850, αλλά πάλι το μάμησε η ΑΤΙ, με την 4870, πάλι καθυστέρηση, βυζιά βγάλαμε!!!! Ελπίζω να κάνει καμιά έκπληξη όπως αύτη με την 4850 και να την έχουμε πιο νωρίς, για να ολοκληρωθεί επιτέλους, το νέο μου PC.
sstav Ιούνιος 20, 2008 #107 Ιούνιος 20, 2008 ρε παιδια,ρε παιδια....Το έκανα...ούτε 1 βαθμό παρακάτω δεν είδα...........Καμμιά aftermarket ψύκτρα έχεις να δοκιμάσεις ;;;
cabdik Ιούνιος 20, 2008 #108 Ιούνιος 20, 2008 εγω δεν βλεπω καθυστερηση. οι ημερομηνιες που ειχαν ανακοινωθει, βλεπω οτι τηρουνται. πρωτα η 4850 και για τις 25 ιουνιου που εχει ανακοινωθει η 4870, θα περιμενουμε να δουμε. γιατι τοση βιασυνη για 5-6 μερες?
AN7 OverClocker Ιούνιος 20, 2008 #109 Ιούνιος 20, 2008 Καμμιά aftermarket ψύκτρα έχεις να δοκιμάσεις ;;;oxi
ProPitsiriko$ Ιούνιος 20, 2008 #110 Ιούνιος 20, 2008 Super δεν λέω η 4850, αλλά πάλι το μάμησε η ΑΤΙ, με την 4870, πάλι καθυστέρηση, βυζιά βγάλαμε!!!! Ελπίζω να κάνει καμιά έκπληξη όπως αύτη με την 4850 και να την έχουμε πιο νωρίς, για να ολοκληρωθεί επιτέλους, το νέο μου PC. Επιτιδες το κανει....η nVIDIA εχει αρχισει να τρεχει και να μην φτανει... Εβγαλε 9800GTX+ με λιγο μεγαλυτερα ρολογια μονο και μονο για να προσπαθισει να φτασει την 4850:) Χαμος θα γινει...στο τελος ετσι οπως τρεχει θα τρακαρει πουθενα Εγω θελω να σπασει τα ταμεια η Ati και η nVIDIA να παει στο.......ετσι για να μαθει....
sebastian Ιούνιος 20, 2008 #111 Ιούνιος 20, 2008 ATI I LOVE YOU! Μεσα στην εβδομαδα εχω ετοιμο crossfire και αρχιζω δοκιμες! Θα τα τιναξω τα frames στον αερα!!! ΚΟΛΑΣΗ!Nvidia ριξε τις τιμες στο μισο και ισως να σε παρουμε και εσενα καποια στιγμη!!!Περιμενω απαντηση απο AMD στην ΙΝΤΕΛ!!!! Ετσι να φαει και αυτη κανενα πακετο , ωστε να τρεχει παλι!!!!
yanni Ιούνιος 20, 2008 #112 Ιούνιος 20, 2008 9800GTX+ είναι και στα 55nm. Νομίζω ότι αποτελεί και ένα τελευταίο test για αυτούς πριν αποφασίσουν να φτιάξουν και το τέρας (280) στα 55nm.
angel_f Ιούνιος 20, 2008 #113 Ιούνιος 20, 2008 ATI I LOVE YOU! Μεσα στην εβδομαδα εχω ετοιμο crossfire και αρχιζω δοκιμες! Θα τα τιναξω τα frames στον αερα!!! ΚΟΛΑΣΗ!Nvidia ριξε τις τιμες στο μισο και ισως να σε παρουμε και εσενα καποια στιγμη!!! Περιμενω απαντηση απο AMD στην ΙΝΤΕΛ!!!! Ετσι να φαει και αυτη κανενα πακετο , ωστε να τρεχει παλι!!!! Σε ακούσαμε.... Δεν κατεβάσεις τον τηλεβοα? Δεν ειναι λαϊκή αγορά εδώ
ProPitsiriko$ Ιούνιος 20, 2008 #114 Ιούνιος 20, 2008 Σε ακούσαμε.... Δεν κατεβάσεις τον τηλεβοα? Δεν ειναι λαϊκή αγορά εδώ σε ποιον αναφερεσαι ?
sebastian Ιούνιος 20, 2008 #115 Ιούνιος 20, 2008 Σε ακούσαμε.... Δεν κατεβάσεις τον τηλεβοα? Δεν ειναι λαϊκή αγορά εδώ Πραγματικα δεν το περιμενα ολο αυτο, κοιταω τα bench στα παιχνιδια γιατι εκει με ενδιαφερει περισσοτερο και δεν μπορω να το πιστεψω που μπορεσε να βγαλει τετοιο ΔΙΑΜΑΝΤΙ! ΑΤΙ ειχα και παλιοτερα , οπως το 9700 το 9800 προ, το χ800 , μετα πηγα nvidia και τωρα βλεπω με πολυ χαρα οτι θα μεινω ξανα με ΑΤΙ για πολυ καιρο! Στο μεταξυ δεν εχουμε απο 487ο πως παει, γιατι αν αξιζει τρελα να πω εκει απευθειας! Ποτε περιμενουμε benchs απο αυτην!
KoMM Ιούνιος 20, 2008 #116 Ιούνιος 20, 2008 ρε παιδια , ωραία όλα αυτά, αλλά κανα παιχνίδι της προκοπής θα βγει;Δηλαδή γιατί να πάρω καινούργια κάρτα;Για να ξαναπαίξω crysis-cod-oblivion (!) κτλ; Απορία το έχω, γιατί κάποιος να αλλάξει κάρτα τη στιγμή που έχει 8800gt-gtx+.
AN7 OverClocker Ιούνιος 20, 2008 #117 Ιούνιος 20, 2008 το θέμα είναι σε τι ανάλυση τα έχεις παίξει.Γιατί άλλο στα 1280χ1024 και άλλο 1920χ1200.Και γενικώς είναι σαν να μου λές,τι τον θές τον C2D?Και με το s939 όλα τα παιχνίδια τα παίζεις,μην σου πώ και με Athlon XP , άσχετα αν μερικά θα είναι στα 640χ480
sebastian Ιούνιος 20, 2008 #118 Ιούνιος 20, 2008 1920x1200 παιζω εγω σε 26αρι samsung! Αλλα πια το σκεφτομαι το 30αρι με το 2560χ1600!
KoMM Ιούνιος 20, 2008 #119 Ιούνιος 20, 2008 μα αν δεις όλα τα συγκριτικά οι παλιές κάρτες βγάζουν μια χαρα fps στα 1920χ1200 με ΑΑ και όλα τσίτα.Στην τελική βγάζεις το ΑΑ και όλα κομπλέ.Σχετικά με τους c2d είναι σα να μου λες ότι αξίζει η μετάβαση από 6χχχ σε 8χχχ.
alphaX Ιούνιος 20, 2008 #120 Ιούνιος 20, 2008 fragma, αν το έβλεπα σε ένα πινακάκι με 5-6 games ακόμα θα με έπειθε, αλλά 2 μόνο games δεν μπορούν να με πείσουν http://www.xtremesystems.org/forums/showthread.php?t=191574 Δεν ξερω αν το εχεις δει. Ειναι συγκριτικο , κ σε crossfire, με πολλα παιχνιδια και αρκετες αλλες καρτουλες. Δεν ειναι τοσο καλα οργανωμενα αλλα πιστευω ειναι πιο αξιοπιστα μιας κ ειναι απο απλο χρηστη.
