Q6600 O/C Help!!! :S
under
Paides help!
exw sthsei ena mhxanhmataki me ta parakatw:
CPU: Q6600 Kentsfield @ 2.4GHz @ 3.0GHz
RAM: 2x1Gb Kingston Hyperex 800
MoBo: Asus P5K-VM
HDD: 2x500Gb Seagate Sata II
GPU: Asus EN7300GT TOP
PSU: Thermaltake PurePower RX 750W
Case: Thermaltake LANbox LiTe
Exw kanei O/C me tis parakatw ru8mhseis (opws emfanizontai sto Everest):
-------------[ Overclock ]----------------------
CPU Properties:
CPU Type QuadCore Intel Core 2 Quad Q6600
CPU Alias Kentsfield
CPU Stepping G0
Engineering Sample No
CPUID CPU Name Intel® Core2 Quad CPU Q6600 @ 2.40GHz
CPUID Revision 000006FBh
Core Voltage 1.325 V
CPU Speed:
CPU Clock 3005.6 MHz (original: 2400 MHz, overclock: 25%)
CPU Multiplier 9.0x
CPU FSB 334.0 MHz (original: 266 MHz, overclock: 26%)
Memory Bus 400.7 MHz
DRAM:FSB Ratio 12:10
CPU Cache:
L1 Code Cache 32 KB per core
L1 Data Cache 32 KB per core
L2 Cache 2x 4 MB (On-Die, ASC, Full-Speed)
Motherboard Properties:
Motherboard ID 64-0304-000001-00101111-052507-Bearlake$A0782000_BIOS DATE: 05/25/07 18:44:41 VER: 08.00.12
Motherboard Name -- Asus P5K-VM (2 PCI, 1 PCI-E x4, 1 PCI-E x16, 4 DDR2 DIMM, Audio, Video, Gigabit LAN, IEEE-1394)
Chipset Properties:
Motherboard Chipset Intel Bearlake G33
Memory Timings 5-5-5-12 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memory Modules:
DIMM1: Kingston 9905316-026.A01LF 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
DIMM3: Kingston 9905316-026.A01LF 1 GB DDR2-667 DDR2 SDRAM (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz) (3-3-3-9 @ 200 MHz)
BIOS Properties:
System BIOS Date 05/25/07
Video BIOS Date 12/14/06
DMI BIOS Version 0304
Graphics Processor Properties:
Video Adapter Asus EN7300GT TOP
GPU Code Name G73 (PCI Express 1.0 x16 10DE / 0393, Rev A1)
GPU Clock 552 MHz (original: 550 MHz)
Memory Clock 499 MHz (original: 500 MHz)
Thelw na to anevasw parapanw alla h mhtrikh exei kapoies elleipseis (sto bios) sta settings... p.x.: Den exw North/South Bridge Voltages, FSB Termination Voltages kai den mporw na dwsw parapanw apo 2.10V sto DRAM...
Any help gia na ftasei parapanw swsta? Gnwrizw oti anevazontas to FSB Frequency anevazw alla den gnwrizw kala apo voltages kai tis mnhmes....
search it. έχει 10δες θέματα με τον q6600 με πάρα πολλές μητρικές. την δικιά σου δεν την ξέρω αλλά άμα ανεβαίνεις σιγά σιγά θα βρείς το μέγιστο.
