help psp downgrade
Ghost O/C
Γεια σας παιδια
Θελω να κανω downgrade στο psp και απο την εκδοση 3.50 να το παω στην 1.50
εχω τον downgrader ομως δεν καταλαβαινω ορισμενες οδηγιες και χρειαζομαι την βοηθεια σας
τα σημεια που δεν καταλαβαινω τα εχω αριθμισει
οδηγιες
Requirements
In order to downgrade a 3.50 PSP you will need the following:
1- Original LUMINES UMD (UK, US, JAP, (Korean unknown), Platinum will work too and Best.
- If you have a 3.10,3.11,3.30 or 3.40 firmware psp update to 3.50 and then use this downgrader.
updates can be found at www.pspcalo.co.nr in the "upgrade" section.
* WARNING, ANY DOWNGRADER HAS A CHANCE OF BRICKING A PSP. WHEN A *
* PSP IS BRICKED YOU WILL NOT BE ABLE TO USE IT ANYMORE. Noobz *
* HAVE DONE A LOT TO TRY AND MINIMISE THE RISK, BUT THERE IS *
* ALWAYS SOME LEVEL OF RISK WHICH YOU MUST ACCEPT IF YOU WANT TO *
* DOWNGRADE. WITH THIS INSTALLER CHANCHES ARE EXTREMLY LOW OF A *
* BRICK *
Must:
Plug Ac Adaptor plugged in.
Have battery more than 75% full.
Backup MemoryStick and then format it.
Instructions
Here are the steps to downgrade any 3.50 PSP to 1.50:
- Double click 3.50_downgrader.exe and extract the contents to memorystick, overwrite if asked.
2 - Load up Lumines
3 - It should get to loading savegame, then the screen will clear to black
and fill with a light blue colour, then the PSP will reset itself (if
this does not happen see section below)
- Check that HEN is running by going to system settings, then to
"System Information" and it should show up as system version
3.50 HEN
- If it is showing up as HEN then go to the GAME menu then Memory Stick and
run the PSPtm Update x.yz update
4 - If you have an unpatched TA-082 or higher motherboard, you will be
prompted to allow the downgrader to patch your motherboard so it
can be safely downgraded. The downgrader will not let you proceed
without patching, if your motherboard requires it.
- Before the downgrader does anything to your PSP it will ask
for you to agree to what it is doing, if you no longer want to
continue press the Right Shoulder Button (R-TRIGGER).
- Once you have agreed to start the downgrade do not unplug the
PSP, or try and restart it
- Once finished the PSP will ask you to press X, and reset itself
- If it comes up saying that the settings are corrupt, press x or o
to continue.
- All done now :-) Hopefully you now have a 1.50 PSP. Enjoy it responsibly.
Hint: If you psp has a blank screen after it resets, press the screen brightness
button a few times and it should sort it out.
After downgrading you can format MemoryStick again.
Warning
Do not upgrade back to 3.30+ on a ta-082 or ta-086 motherboard or you will brick your
psp, but you CAN upgrade to any version of oe. fanjita the creator said he'd make an
application to fix this problem soon.
pspgr.uni.cc Θα βρεις ολες τις πληροφοριες και ειναι στα ελληνικα!!! Και εγω εκει παω. ΚΟΙΤΑ ΤΑ ΦΟΡΟΥΜΣ εχουν αναλυτικες οδηγιες.
