Power Calibration Error
dj Tony
Τι σημαίνει; Δεν μπορώ να γράψω cd με το nero εδώ και κάτι μέρες και μου βγάζει αυτό το μήνυμα. Να και το log:
1C82-0000-19E5-MAAX-4000-5950-****
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2/11/2004 2:54:32 μμ
NT-SPTI used
Nero Version: 7.5.1.1
Internal Version: 7, 5, 1, 1
Recorder: <MAT****A DVD-RAM UJ-820S>Version: 1.00 - HA 1 TA 0 - 7.5.1.1
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <MAT****A DVD-RAM UJ-820S >Version: 1.00 - HA 1 TA 0 - 7.5.1.1
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1000VE-00KWT0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : MAT****A DVD-RAM UJ-820S atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
MAT****A DVD-RAM UJ-820S D: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 1022MB (1047472kB)
Free physical memory: 480MB (491884kB)
Memory in use : 53 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
22.5.2007
Audio CD
11:29:04 μμ #1 CDADOC -1 File Cdadoc.cpp, Line 1635
Audio item log info:
Audio document burn settings:
Burn mode: DAO,
CD Text: On,
Cache disk or network files: No,
Cache small files: No,
Cache files smaller than 65536 bytes.
Audio Multisession: No
List of audio tracks:
Track 01: Length: 05:20.25, Pause frames: 150, Filters: 0, Name: '1. 292645_Your_Body_Is_My_Body__Bpitch_Control__Original_Mix.mp3'.
Track 02: Length: 04:32.32, Pause frames: 150, Filters: 0, Name: '2. 292650_Paste_Back__Ekler_O_Shock__Original_Mix.mp3'.
Track 03: Length: 04:56.11, Pause frames: 150, Filters: 0, Name: '3. 292651_Sorry__Relish_Recordings__Original_Mix.mp3'.
Track 04: Length: 04:53.50, Pause frames: 150, Filters: 0, Name: '4. 292654_Wings_Of_Death__Infine_Music__Original_Mix.mp3'.
Total size: 19:50.43
11:29:04 μμ #2 Text 0 File Burncd.cpp, Line 3129
Buffer underrun protection activated
11:29:04 μμ #3 Text 0 File ThreadedTransfer.cpp, Line 540
ReadBuffer-Pipe got 81920KB of Memory
11:29:04 μμ #4 Text 0 File Reader.cpp, Line 126
Reader running
11:29:04 μμ #5 Text 0 File Writer.cpp, Line 123
Writer D: MAT****A DVD-RAM UJ-820S running
11:29:04 μμ #6 Text 0 File AudioCompilationImpl.cpp, Line 838
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
11:29:04 μμ #7 Text 0 File Burncd.cpp, Line 3443
Turn on Disc-At-Once, using CD-R/RW media
11:29:04 μμ #8 Text 0 File DlgWaitCD.cpp, Line 300
Last possible write address on media: 359847 ( 79:59.72)
Last address to be written: 89142 ( 19:50.42)
11:29:04 μμ #9 Text 0 File DlgWaitCD.cpp, Line 312
Write in overburning mode: NO (enabled: CD)
11:29:04 μμ #10 Text 0 File DlgWaitCD.cpp, Line 2851
Recorder: MAT****A DVD-RAM UJ-820S;
CDR code: 00 97 34 23; OSJ entry from: Mitsubishi Chemical
ATIP Data:
Special Info [hex] 1: C0 00 98, 2: 61 22 17 (LI 97:34.23), 3: 4F 3B 49 (LO 79:59.73)
Additional Info [hex] 1: 00 00 00 (invalid), 2: 00 00 00 (invalid), 3: 00 00 00 (invalid)
11:29:04 μμ #11 Text 0 File DlgWaitCD.cpp, Line 484
>>> Protocol of DlgWaitCD activities: <<<
11:29:04 μμ #12 Text 0 File ThreadedTransferInterface.cpp, Line 863
Setup items (after recorder preparation)
0: TRM_AUDIO_NOPRE (1. 292645_Your_Body_Is_My_Body__Bpitch_Control__Original_Mix.mp3)
2 indices, index0 (150) not provided
original disc pos #0 + 24025 (24025) = #24025/5:20.25
relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 24025 blocks [D: MAT****A DVD-RAM UJ-820S]
1: TRM_AUDIO_NOPRE (2. 292650_Paste_Back__Ekler_O_Shock__Original_Mix.mp3)
original disc pos #0 + 20432 (20432) = #20432/4:32.32
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 20432 blocks [D: MAT****A DVD-RAM UJ-820S]
2: TRM_AUDIO_NOPRE (3. 292651_Sorry__Relish_Recordings__Original_Mix.mp3)
original disc pos #0 + 22211 (22211) = #22211/4:56.11
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22211 blocks [D: MAT****A DVD-RAM UJ-820S]
3: TRM_AUDIO_NOPRE (4. 292654_Wings_Of_Death__Infine_Music__Original_Mix.mp3)
original disc pos #0 + 22025 (22025) = #22025/4:53.50
-> TRM_AUDIO_NOPRE, 2352, config 0, wanted index0 0 blocks, length 22025 blocks [D: MAT****A DVD-RAM UJ-820S]
11:29:04 μμ #13 Text 0 File ThreadedTransferInterface.cpp, Line 1079
Prepare recorder [D: MAT****A DVD-RAM UJ-820S] for write in CUE-sheet-DAO
DAO infos:
MCN: " "
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 4: Idx 0 Idx 1 Next Trk
1: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 0 352800 56859600, ISRC ""
2: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 56859600 57212400 105268464, ISRC ""
3: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 105268464 105621264 157861536, ISRC ""
4: TRM_AUDIO_NOPRE, 2352/0x00, FilePos 157861536 158214336 210017136, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
-150 | lead-in | 0 | 0x01 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x21 | 24025 | -150 | 0x00
0 | 1 | 1 | 0x21 | 24025 | 0 | 0x00
24025 | 2 | 0 | 0x21 | 20432 | 24025 | 0x00
24175 | 2 | 1 | 0x21 | 20432 | 24175 | 0x00
44607 | 3 | 0 | 0x21 | 22211 | 44607 | 0x00
44757 | 3 | 1 | 0x21 | 22211 | 44757 | 0x00
66968 | 4 | 0 | 0x21 | 22025 | 66968 | 0x00
67118 | 4 | 1 | 0x21 | 22025 | 67118 | 0x00
89143 | lead-out | 1 | 0x01 | 0 | 0 | 0x00
11:29:04 μμ #14 Text 0 File SCSIPassThrough.cpp, Line 39
SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME
11:29:04 μμ #15 Phase 32 File dlgbrnst.cpp, Line 1730
Simulation started at 4x (600 KB/s)
11:29:04 μμ #16 Text 0 File ThreadedTransferInterface.cpp, Line 2746
Verifying disc position of item 0 (relocatable, no disc pos, no patch infos, orig at #0): write at #0
11:29:04 μμ #17 Text 0 File ThreadedTransferInterface.cpp, Line 2746
Verifying disc position of item 1 (relocatable, no disc pos, no patch infos, orig at #0): write at #24175
11:29:04 μμ #18 Text 0 File ThreadedTransferInterface.cpp, Line 2746
Verifying disc position of item 2 (relocatable, no disc pos, no patch infos, orig at #0): write at #44757
11:29:04 μμ #19 Text 0 File ThreadedTransferInterface.cpp, Line 2746
Verifying disc position of item 3 (relocatable, no disc pos, no patch infos, orig at #0): write at #67118
11:29:04 μμ #20 Text 0 File MMC.cpp, Line 17486
StartDAO : CD-Text - On
11:29:04 μμ #21 Text 0 File MMC.cpp, Line 22129
Set BUFE: Buffer underrun protection -> ON
11:29:04 μμ #22 Text 0 File MMC.cpp, Line 17716
CueData, Len=80
21 00 00 41 00 00 00 00
21 01 00 00 00 00 00 00
21 01 01 00 00 00 02 00
21 02 00 00 00 05 16 19
21 02 01 00 00 05 18 19
21 03 00 00 00 09 38 39
21 03 01 00 00 09 3a 39
21 04 00 00 00 0e 36 44
21 04 01 00 00 0e 38 44
01 aa 01 01 00 13 32 2b
11:34:43 μμ #23 Text 0 File WriterStatus.cpp, Line 116
<D: MAT****A DVD-RAM UJ-820S> start writing Lead-Out at LBA 89143 (15C37h), length 0 blocks
11:34:44 μμ #24 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
11:35:10 μμ #25 Phase 33 File dlgbrnst.cpp, Line 1730
Simulation completed successfully at 4x (600 KB/s)
11:35:11 μμ #26 Phase 36 File dlgbrnst.cpp, Line 1730
Burn process started at 4x (600 KB/s)
11:35:11 μμ #27 Text 0 File ThreadedTransferInterface.cpp, Line 2746
11:35:11 μμ #28 Text 0 File ThreadedTransferInterface.cpp, Line 2746
11:35:11 μμ #29 Text 0 File ThreadedTransferInterface.cpp, Line 2746
11:35:11 μμ #30 Text 0 File ThreadedTransferInterface.cpp, Line 2746
11:35:11 μμ #31 Text 0 File MMC.cpp, Line 17486
11:35:11 μμ #32 Text 0 File MMC.cpp, Line 22129
11:35:11 μμ #33 Text 0 File MMC.cpp, Line 17716
CueData, Len=80
11:35:24 μμ #34 SPTI -1106 File SCSIPassThrough.cpp, Line 291
D: CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1106)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 00 FF FF D4 BB 00 02 AA 00 00 00
Sense Area: 0xF1 00 03 FF FF D4 BB 0A 00 00 15 12 73 03
Buffer x05d70000: Len xffc0
0x20 00 00 00 00 00 01 19 1B 37 15 32 08 04 09 2F
0x19 07 24 20 12 19 2E 08 20 00 04 01 02 37 0C 20
0x13 17 24 20 10 26 3D 24 1E 12 00 28 10 24 08 34
11:35:24 μμ #35 CDR -1106 File Writer.cpp, Line 312
Power calibration error
11:35:24 μμ #36 Text 0 File ThreadedTransfer.cpp, Line 229
11:35:24 μμ #37 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
11:35:25 μμ #38 Phase 38 File dlgbrnst.cpp, Line 1730
Burn process failed at 4x (600 KB/s)
11:35:25 μμ #39 Text 0 File AudioCompilationImpl.cpp, Line 863
DRM: DRM burn session terminated.
11:35:25 μμ #40 Text 0 File AudioCompilationImpl.cpp, Line 892
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=9464 bytes, created 8/3/2007 2:51:00 πμ
File 'Drivers\PXHELP20.SYS': Ver=3.00.56a, size=43528 bytes, created 8/3/2007 2:51:00 πμ (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Μπορώ να κάνω κάτι ή πρέπει να αντικαταστήσω το dvd writer;
  • 3 weeks later...
Από ότι είδα σε ανάλογο thread μάλλον κάηκε και πρέπει να το αλλάξω. Ξέρει κανείς αν και πως μπορώ να διαπιστώσω αν είναι όντως έτσι και κατά δεύτερο λόγο να συστήσει κάποιο καλό drive για φορητό;
Το ΝΕΡΟ 7 μου ειχε και μενα ασταθεια με 32 μπιτ λογισμικο..
Βρες το Ροξιο..
το βρισκω πολυ καλυτερο...
Το Nero φταίει συνήθως. Γράψε με ένα άλλο πρόγραμμα να δεις.
