Tροφοδοσία Conroe/DS4
obijuan1983
You can note here the fan less cooling solution employed by ECS, also in this area is the 4/8 pin 12V-Aux power connector, nice to see the 8 pin option here. The 12V-Aux connector, when used in 8 pin mode, utilizes both 12V rails of dual rail PSU's.
http://www.viperlair.com/reviews/cpu_mobo/other/lga775/ecs965/index.shtml
8-pin EPS12V for a processor (you can use a standard 4-pin ATX12V connector without an adapter; but in case of top Pentium 4/D models and their eXtreme modifications you'd better use a PSU with a sterling EPS12V connector)
http://www.digit-life.com/articles2/mainboard/gigabyte-965p-dq6-i965p.html
Το γράφει και το manual της μητρικής το δεύτερο τετράπινο είναι για επεξεργαστές Extreme Edition που θέλουν extra τροφοδοσία.
