Watercooling Picture Thread
bundymania
  • Replies 547
Yeaah, that was a BIG victory, the Kangaroos can´t stand the heat down there :D
Lights off, Spot on - the brandnew CPU Waterblock from Aquacomputer.de
There will be 3 versions: Nickel, Brass and Acetal !
2 more Pics from the AC Forum
New Version !
Both end caps are threaded Delrin, and newer IceCaps can be purchased and placed on with ease. They secure it with a smaller nylon thumb screw, but cracking is not an issue since they push on the Delrin portion. The light tube is threaded and secures into the base Delrin portion, and instead of the little cap that glued onto the top, they actually have threaded caps with a BN50 gasket to screw on them.
The base of the reservoir has two brass pins pressed into the Delrin. Each of the helix assemblies(Liquid Fusion), straight rod assemblies (RCX) and anti vortex assemblies (Reactor Core) has two small holes on the base that snaps into these pins. It allows the user to make these parts interchangeable.
