Dr.Paneas Ιούνιος 12, 2010 #90 Ιούνιος 12, 2010 I have b'n craving for such watercooling parts. For the nonce, I have a score to settle with aircoolers, I guess so. . .Can you give us some tips about how do you shoot these majestic pictures ? Credits to you. For credits you shall.
bundymania Ιούνιος 12, 2010 Author #91 Ιούνιος 12, 2010 I use a 7MP Canon Ixus 70 in macro mode with lowest ISO setting (must be 80 or 100) and a cheap tripod from an Ebay Seller. Besides that, i have several background plates, such as aluminium, or plexi and of course you need always enough light, to get sharp photos. For some editing i often use the Freeware Prg. "Photo Filtre" You can buy a 2000 EUR cam with expensive lenses and other tools, without getting nice photos, because the MOST important mosaic stone is the person behind the cam, which should have a good taste and the "eagle eye" to show the object in an interesting location and should have a bit fantasy to use tools like a 5 Eur Led lamp for some extra light effects - which i used for those GPU waterblock pics with the black alu background
Dr.Paneas Ιούνιος 12, 2010 #93 Ιούνιος 12, 2010 Thank you for your answer. I've just bought a cheap tripod from ebay, as you said Now, let me shoot another question, what's this white background ? Does it a plain A4 paper ? or some kind of aluminium or plexi glass ?
bundymania Ιούνιος 12, 2010 Author #94 Ιούνιος 12, 2010 It is a kind of POM/Acetal which i used there, 3mm, 40x40cm. One side is matte the other shiny. It costs about ~10 EUR @Ebay.Here you can find different sorts of aluminium:http://www.it-service.be/webshop/index.php?cPath=29_40
Dr.Paneas Ιούνιος 12, 2010 #95 Ιούνιος 12, 2010 Oh, I see now ! AluPanel 1mm 500x500mm Whiteor AcrylPanel 3mm AcrylPlex - 480x480mm Clearare these quite different ? I mean, how important thickness is ?
bundymania Ιούνιος 12, 2010 Author #97 Ιούνιος 12, 2010 Adjust contrast + Brightness and some more lightning, than it should be fine BTW: Otto and his team does not win, that is sad
bundymania Ιούνιος 13, 2010 Author #99 Ιούνιος 13, 2010 yes that´s a bit to much, just try to experiment with different settings
