[hwbot] SuperPi 1M Ranking
SuperPi Ranking
SuperPi is a quick and easy way to measure processor / chipset performance.
download here
Rules
- don't use multiple nicknames
- only post scores belonging to you
- 1M calculation only
- include a screenshot of the result
Guidelines
- format your score as follows: [hwbot] score - system description [/hwbot]
- try not to use abbreviations. eg. 'opteron 146' is ok, '146' is too short.
- format processor overclock like 'A64 3200+ @ 2850Mhz' or 'A64 3200+ @ 2.85Ghz', format videocard speed as 'R9800 @ 350/333Mhz'.
- allowed score formats: '120.34' or '120.34s' or '120.34sec'
- don't use text layout (bold, italic) or hyperlinks in your system description.
bot info
moderators: GoriLLakoS, pclab, RootX, darkCount, Stelaras, TASOS, deadlock7, mortisboy, hipro5, Costas
members who changed team: Candyman (no team)
options: update ranking now
team ranking - hall of fame
rank - top 10 average - team name - weekly & monthly rankchange - links
1. 7.31 Team OCX - ~ ~ - website - forum
2. 7.44 AwardFabrik - ~ ~ - website - forum
3. 7.48 JMax-Hardware - ~ ~ - website - forum
4. 7.72 XtremeSystems - ~ ~ - website - forum
5. 7.77 OC Forums - ~ ~ - website - forum
6. 7.80 H.O.T. (Hellas O/C Team) - ~ ~ - website - forum
7. 7.93 i4memory.com - ~ ~ - website - forum
member ranking - hall of fame - more
  • 1. HIWA - 6.88 - [PcTuner Shark Oc Team Italy ] Thanks Ybris,PcTuner for support
    2. AndreYang (Team Taiwan) - 6.92 - no description
    3. k|ngp|n (XtremeSystems) - 7.03 - E8600@ Dragon F1 eXtreme | ASUS RAMPAGE EXTREME
    1. tsan - 7.17 sec - Core 2 E8600 (3.33Ghz)@6451mhz - no description
    2. mickeymouse - 7.3 sec - Core 2 E8600 (3.33Ghz)@6363mhz - no description
    3. gprhellas - 7.69 sec - Core 2 E8500 (3.17Ghz)@6030.60mhz - no description
    4. hipro5 - 7.73 sec - Core 2 QX9650 (3.00Ghz)@5853mhz - QX9650 Yorkfield @ 5853MHz - VGA = PCI SIS - PSU = 1200Watts hipro-tech - Rams = 900MHz (1800MHz DDR) CellShock PC14400 and Cas 6-6-5-13 - powered by a DDR Maximizer - CPU`s LN2 Pot by Gorillakos.
    5. Stelaras - 7.77 sec - Core 2 E8500 (3.17Ghz)@5950mhz - Core 2 Duo E8500@5950Mhz
    6. dread77 - 7.94 sec - Core 2 E8500 (3.17Ghz)@5849mhz - no description
    7. ΔΔΑ - 8.06 sec - Core 2 E8500 (3.17Ghz)@5776mhz - Intel Core 2 Duo E8500 @ MHz 5776 - DFI UT P35 - CPU LN2 Cooling -
    8. psilos - 8.07 sec - Core 2 E8600 (3.33Ghz)@5807mhz - testing the new cpu...
    9. TASOS - 8.08 sec - Core 2 E8600 (3.33Ghz)@5735mhz - testing
    10. giorgos th. - 8.17 sec - Core 2 E8600 (3.33Ghz)@5688mhz - E8600 @ 5688mhz - Rampage extreme - SS -45C
    11. mortisboy - 8.19 sec - Core 2 E8500 (3.17Ghz)@5675mhz - no description
    12. Aristidis - 8.25 sec - Core 2 QX9770 (3.2Ghz)@5626mhz - no description
    13. elefsinaras - 8.27 sec - Core 2 QX9650 (3.00Ghz)@5628mhz - no description
    14. AN7 OverClocker - 8.28 sec - Core 2 E8500 (3.17Ghz)@5600mhz - no description
    15. zafiropo - 8.38 sec - Core 2 E8600 (3.33Ghz)@5546mhz - no description
    16. junior-21- - 8.7 sec - Core 2 E8400 (3.0Ghz)@5333.70mhz - Core 2 E8400 @ 5333.7 MHz
    17. F117 - 8.83 sec - Core 2 E8400 (3.0Ghz)@5269mhz - no description
    18. petr00kos - 8.97 sec - Core 2 E8400 (3.0Ghz)@5154mhz - ts00b ts00b
    19. BeetleJuice - 8.99 sec - Core 2 E8500 (3.17Ghz)@5154mhz - Intel Core 2 E8500 @ 5154MHz - Maximus Extreme - SS
    20. Thorlite - 9.03 sec - Core 2 E8500 (3.17Ghz)@5154mhz - no description
    21. Yz250 - 9.36 sec - Core 2 E6700 (2.66Ghz)@5467mhz - Core 2 Duo-E6700@5467Mhz-Abit QUAD_GT-LN2-GoriLLakoS Pot ver.1.02
    22. NIKOSE - 9.47 sec - Core 2 E8500 (3.17Ghz)@4927mhz - no description
    23. imposer - 9.48 sec - Core 2 E8500 (3.17Ghz)@4889mhz - no description
    24. kintaro - 9.48 sec - Core 2 E8500 (3.17Ghz)@4770mhz - no description
    25. CCC - 9.53 sec - Core 2 E8500 (3.17Ghz)@4861mhz - no description
    26. phil - 9.59 sec - Core 2 E8500 (3.17Ghz)@4908mhz - no description
    27. galanakop - 9.69 sec - Core 2 E8500 (3.17Ghz)@4640mhz - no description
    28. Thodoris21 - 9.69 sec - Core 2 E8600 (3.33Ghz)@4836.50mhz - no description
    29. fafoylis - 9.69 sec - Core 2 E8400 (3.0Ghz)@4775mhz - no description
    30. racer - 9.78 sec - Core 2 E8500 (3.17Ghz)@4750mhz - no description
    31. Shadowjump - 9.8 sec - Core 2 E8500 (3.17Ghz)@4678mhz - no description
    32. dom - 9.81 sec - Core 2 E6700 (2.66Ghz)@5280mhz - Intel Core 2 E6700 (2.66Ghz)@5280MHz - Core 2 Duo E6700@5280MHz - p5b vista - ul5400 4-3-2-10 - ln2
    33. eko - 9.83 sec - Core 2 E8500 (3.17Ghz)@4725mhz - no description
    34. dark22 - 9.84 sec - Core 2 E8400 (3.0Ghz)@4644mhz - E8400 3.0 @ 4644 MHz - ABIT IP35 PRO - Transcend aXe Ram 800MHz @ 1032 Mhz 4-4-4-12 Αεράτο
    35. zavlakas - 9.84 sec - Core 2 E8400 (3.0Ghz)@4698mhz - no description
    36. Chosen - 9.86 sec - Core 2 QX9650 (3.00Ghz)@4700mhz - QX9650 @ 11.5x409, Ballistix 667 @ 1090, 5-4-4-15
    37. ReaperX - 9.97 sec - Core 2 E8400 (3.0Ghz)@4680mhz - no description
    38. TiN - 9.97 sec - Core 2 E6600 (2.4Ghz)@5137mhz - second ln2 run
    39. Dagalidis - 9.99 sec - processor unknown - Intel Core 2 Duo E8400 @ 4695MHz - Full Aircooled
    40. Shadow Hunter - 10.08 sec - Core 2 E8400 (3.0Ghz)@4617.90mhz - no description
    41. Nick_p - 10.11 sec - Core 2 X6800 (2.93Ghz)@5064mhz - Intel core 2 duo - X6800 @ 5064Mhz - Commando P965 - OCZ flex xlc - simple tests on cascade
    42. soki - 10.23 sec - Core 2 E8400 (3.0Ghz)@4635mhz - Intel Core2 Duo E8400 @ 4635Mhz (9x515Mhz) 1.54Vcore @ Thermalright Ultra 120, TwinTech 8800GT 512MB @ 817/2000/1033 Mhz @ 1.23Vgpu @ Accelero S1, 4x1Gigabytes Transcend AxeRam DDR2800 @ 515Mhz @ 2.24Vmem @ 5-5-5-4-12-25, Gigabyte P35-DS3 @ F12 bios @ Vdr
    43. Spyrus - 10.28 sec - Core 2 E8400 (3.0Ghz)@4500mhz - 9x500@600-5-5-5-4-2T@Asus Maximus Formula@Corsair Value 800 on HR-07@TRUE120+Papst-Air
    44. GoriLLakoS - 10.31 sec - Core 2 QX6700 (2.66Ghz)@4900mhz - Core 2 Duo - QX6700 @ 4900Mhz - Asus P5K DLX - CellShock - Cascade
    45. biker - 10.41 sec - Core 2 E8400 (3.0Ghz)@4482mhz - no description
    46. LightBird - 10.5 sec - Core 2 E6850 (3.0Ghz)@4911mhz - no description
    47. cryo.nio - 10.56 sec - Core 2 E8500 (3.17Ghz)@4465.50mhz - Just beggining to learn the magic world of overclocking...
    48. George_13 - 10.59 sec - Core 2 E6850 (3.0Ghz)@4860mhz - First attempt with dry ice on a E6850... still testing
    49. Doom - 10.63 sec - Core 2 E6600 (2.4Ghz)@4791mhz - Core 2 Duo Conroe - E6600 @ 4791Mhz -Asus P5B DLX - Custom DD Phase
    50. patrik - 10.66 sec - Core 2 E8400 (3.0Ghz)@4500mhz - no description
SuperPi Core 2 Duo subranking - hall of fame - performance statistics - more
    3. c1rcu1tburn3r (XtremeHardware-OC-Team) - 7.03 - www.xtremehardware.it
generated by hwbot - http://www.hwbot.org - info@hwbot.org
  • Replies 2,7k
To bot θα μας καταγραφει(οσοι δηλαδη το βαλουν) ολους αλλα βγαζει μεσω ορο απο τους 10 πρωτους???
Εμενα με εβγαλε λαθος...εχω 730..και οχι 725..:D
Στο σαιτ με εχει με 725...
Διαβάστε και λίγο το faq στο hwbot.org, δεν κάνει κακό :p
Από ότι έχω καταλάβει, κρατάει τα 10 καλύτερα αποτελέσματα για σύγκριση με τις άλλες ομάδες και όσους του πεις να δείχνει, δείχνει.
Υπάρχει ένα θέμα όμως(μεταξύ των άλλων) ότι δεν επιτρέπει(στα χαρτιά) να ποστάρετε σκορ και σε άλλες ομάδες.
Οκ....το βρηκαμε το ενα...
Απο την αλλη...εγω ημουν στην ομαδα του XS...αλλα εχω χασει κωδικους,username τα παντα με λιγα λογια..
Οταν στο Hwbot παταω GoriLLakoS η στην ομαδα XS ή σε εμας μου βγαζει 5 αποτελεσματα αλλα Not verified.........
Τι συμβαινει....
Κανονικα αμα ημουν σε μια ομαδα , πρεπει απο μονος μου να αλλαξω και θα με αλλαξει μονο του σε ολα τα bench....αλλα εχω χασει τα παντα απο την πρωτη...και voila....:(
Αρχική απάντηση από Βασιλης
Τι συμβαινει....
SuperPi - 24.31 - GoriLLakoS - HellasOCTeam
Processor: Pentium M 725 @ 3049.80mhz - (compare)
Videocard: videocard unknown
Description: Dothan 1.6@3049.8Ghz Dry Ice
Verfication: screenshot
Scan date: 29-03-2006 03:08
Options: claim result as yours
Που σου βγάζει not verified?
[hwbot] greekfragma - 35.406 - Athlon 64 3800+ X2 @ 2.5Ghz - DFI NF4 UltraD - watercooled [/hwbot]
δοκιμαστικο και με πολυ πραμα να τρεχει εκεινη την ωρα.αμα ειναι να μπεντσαρω σοβαρα θα το καταλαβετε:tomato:
www.hwbot.org > results > search results > name=GoriLLakoS
και κοιτα τι βγαζει....τα μισα τα βγαζει σε εμας και τα αλλα μισα στο XS.....το 24.312 το ειχα βαλει και στο XS..αλλα μαλλον τωρα που περασε απο πανω το bot τα εκανε overwrite και ηρθαν εδω...
Απο την αλλη αμα πας members > search members και βαλει το GoriLLakoS εκει θα σου βγαλει 5 results , username not verified
EDIT: απ'οτι καταλαβα...απ'οποιο σιτε το βαζεις τελευταιο σε παιρνει με την ομαδα του.....κανε μια αναζητηση στον Hipro5.....εχει ενα αποτελεσμα στο Xtremeresources.....εκει το ποστaρε τελευταιο και καποιος εκανε update.....αλλα μετα εβαλε στο XS..και μπηκε και απο την σελιδα του XS στο hwbot.org.....τελικα ομως τα σκορ σε πιανου τον μεσω ορο μπηκαν???:blink:
απο λάθος έφαγα ένα μηδενικό στο clock το διόρθωσα έκανα Update
αλλά δεν πέρασε το νέο "κείμενο" στη λίστα
δεν ανανεώθηκε δλδ....
Η λίστα δεν ενημερώνεται αυτόματα με το που γίνεται κάποιο post.
Ενημερώνεται κάθε 2-3 ώρες. Μπορώ να την κάνω update αλλά μην περιμένετε με το που γίνεται post να εμφανίζεται και η καταχώρησή σας.
Αρχική απάντηση από RootX
Με το που πατας update ranking now γινεται ανανεωση και βγαινει κατυθειαν το σκορ...:D
Σώπααα ωράαα :p Για να μην σπαμάρετε το κομβίο δεν το ανέφερα.
