μεχρι τοτε ας ολοκληρωσουν κανενα καλο mod.
ειδα οτι ετοιμαζουν απειρα αλλα ολα ειναι σε status <15%.
Changelog
* Added "Basic Setup" section (beginners guide how to get the server running with the least amount of work)
* Added "Anti-Cheat Protection" section
* Added "Crysis Internal Anti-Cheat Solution" description
* Adjusted "Hardware Recommendations"
* Adjusted "Server Update"
* Re-worked complete document for a better readability and understanding.
* Re-worked "Advanced Setup" section
* Updated "Standard Server Settings"
* Updated "Launching the Server"
* Updated "Punkbuster" description
* Updated "Server Command List"
Download
some benches.
Crysis Benchmark
The benchmark started at 25/3/2008 1:12:35 ?i
System Information
Operating system: Microsoft Windows XP
System memory: 2,0 GB
CPU: AMD Athlon 64 FX-60 Dual Core Processor
CPU speed: 2620 MHz
Sound system: SB Live! Audio [bC00]
VGA Information
Graphics card: NVIDIA GeForce 8800 GT
Memory: 512.0 MB
Current GPU speed: 640 MHz
Current memory speed: 950 MHz
Driver version: 6.14.0011.6921 (English)
VGA benchmark
Demo: Crytek Built-in
Quality: High
Renderer mode: DirectX 9
Antialising mode: Off
Filtering mode: None
MultiGPU support: Disabled
Boost renderer: Disabled
Use Custom Config File: No
Resolution: 1920x1200 (HD WideScreen)
Result(1): Minimum= 10.47 FPS Average= 23.83 FPS Max= 30.13 FPS
____________________________________________________________________________________________________________
The benchmark started at 25/3/2008 1:19:04 ?i
System Information
CPU speed: 2620 MHz
VGA Information
Memory: 512.0 MB
Current GPU speed: 702 MHz
Current memory speed: 1050 MHz
VGA benchmark
Quality: High
Result(1): Minimum= 12.56 FPS Average= 25.31 FPS Max= 31.69 FPS
_____________________________________________________________________________________________________________
Crysis Benchmark
The benchmark started at 25/3/2008 1:39:11 ?i
System Information
CPU speed: 2900 MHz
VGA Information
Memory: 512.0 MB
VGA benchmark
Quality: High
Result(1): Minimum= 17.43 FPS Average= 25.88 FPS Max= 32.62 FPS
Το τελειωσα και εγω με την σειρα μου...
Παααρα πολυ καλο game, μου τσακισε το cpu.:laughing::laughing:
εγω εχω ενα προβλημα με το gpu benchmark ενω εχω μεσα απο το game ρυθμισμενο 1680χ1050 high χωρις ΑΑ. οταν το τρεχει το τρεχει 1680χ1050 high με 4χ AA, πως θα ρυθμισω το gpu benchmark να τρεχει χωρις ΑΑ?
μα εβαλα τους σουπερ γαματους Χ-Treme G .
Οντως ειναι υπεργαματοι!
παιζω σε high 1920Χ1200 με καλο framerate!
γαμωτο και πανω που χαρηκα...:o
χαθηκαν οι ροδες....
  • 3 weeks later...
Ρε παιδες εχω φορτωσει το παιχνιδι σε vista 32 bit και καθως παιζω κανα δεκαλεπτο με τεταρτο με πεταει εξω εχοντας επιλεξει να παιξω με directx 9c αρχικα και οταν επιλεξω directx 10 μου παγωνει την εικονα και πρεπει να βγω με τον γνωστο τροπο (control,alt,del).υπαρχει καμια λυση?
σε αλλα παιχνίδια εχεις προβλημα? το συστημα σου ειναι κλοκαρισμένο?
Μολις περασα τους 174.88 και εβαλα το Crysis να δω αποδοση
To Fraps δειχνει 12-17 FPS(σε μια συγκεκριμενη μαχη που κανω ολες τις δοκιμες μου) ...ΑΛΛΑ το παιχνιδι πραγματικα πεταει :o
100% playable :clap:
*ολα very high@1920x1200
