sakis_the_fraud Αύγουστος 10, 2008 #161 Αύγουστος 10, 2008 EVGA Precision 1.3.2 Παράθεση - Pause all activity in suspended mode- Detect core clock frequency generator switching to alternate clock source and fix incorrect readings under certain conditions (e.g. when shader/core clock ratio is equal to 2 and both clock domains are attached to the same source on GeForce GTX 260 / 280 series graphics cards)- Display both raw and traditional (ForceWare xxx.xx) versions when pressing "i" buttonhttp://www.toomanydownloads.com/index.php?option=com_mtree&task=viewlink&link_id=164&Itemid=54
sakis_the_fraud Αύγουστος 11, 2008 #162 Αύγουστος 11, 2008 AMD OverDrive V2.1.2 Παράθεση The new version includes several new features:*Sideport memory overclock option*SB700 fan control*fan disable option*new themehttp://www.expreview.com/img/software/AOD_212_English_FINAL_Setup.rar
sakis_the_fraud Αύγουστος 11, 2008 #163 Αύγουστος 11, 2008 CPUCalc 1.9.1 Παράθεση Changelog 1.9.1: * Added Intel Mobile Processors * Added Update-Function. CPUCalc can now check for updates. * Added Upload-CPUID-function. Your CPUID can be uploaded automatically. Please upload your CPUID so that later on CPUCalc can choose your CPU itself.http://downloads.guru3d.com/CPUCalc-1.9.1-download-2017.html#download
sakis_the_fraud Αύγουστος 12, 2008 #164 Αύγουστος 12, 2008 Αλλο ενα χρησιμο εργαλειο FluidMark V1.0.0 Παράθεση PhysX FluidMark is a physics benchmark based on NVIDIA PhysX engine. This benchmark performs a fluid simulation by imitating the renderering of lava. Real physics parameters such as viscosity are used. SPH (Smoothed Particle Hydrodynamics) algorithm is enabled to increase the realism of the simulation. [ATTACH]3474[/ATTACH] http://www.ozone3d.net/benchmarks/physx-fluidmark/index.php#download
sakis_the_fraud Αύγουστος 12, 2008 #165 Αύγουστος 12, 2008 NiBiTor V4.4 Παράθεση The new version adds support to GeForce 9800 GThttp://www.mvktech.net/index.php?option=com_remository&func=fileinfo&filecatid=2760
sakis_the_fraud Αύγουστος 13, 2008 #166 Αύγουστος 13, 2008 GPU-Z v0.2.7 Παράθεση * Added display for GPU release date. The data is incomplete, if you have more info please post in the sticky thread in the support forums. * Added display for transistor count * Added mouseover readings for sensors graph * Correctly named the three on-die sensors of RV770 and RV730 * Added support for voltage regulator monitoring on HD 4870 and HD 4870 X2 * RV770 GPU on HD 4870 X2 now called R700 * Added support for reading HD 4870 X2 3D clocks * Added display of CrossFire Sideport status on HD 4870 X2 * Added more RV730 device IDs * Added support for GeForce 9800 GT, 9800M GT, 9600M GT, 9700M GS/GT, 9500M G * Added detection for RS780D * Fixed incorrectly read ATI OD5 clocks * Fix for memory clock reading on RV730 * Fixed ROM reading on RV730 * Fixed crash when no supported card detected * Sensor graph width adjusted when scrollbars visiblehttp://www.techpowerup.com/downloads/1153/mirrors.php
sakis_the_fraud Αύγουστος 15, 2008 #167 Αύγουστος 15, 2008 CrystalCPUID V4.15.2.451 Παράθεση CrystalCPUID’s new verion V4.15.2.451 released. CrystalCPUID is a software similar to CPU-Z, but it has some other features as Intel SpeedStep Control and so on.http://crystalmark.info/download/index-e.html#CrystalCPUID
sakis_the_fraud Αύγουστος 16, 2008 #168 Αύγουστος 16, 2008 ExpertTool V4.0 Παράθεση Expertool V4.0 is a light weight ATI card utility. It is the first utility to provide fan speed control for HD 4850 and HD 4870. It is a international release, at lease it support both Chinese and English Windows.Supports All reference HD 4870/4850, did not tested with non-ref version.We encounter a small bug when playing with Expertool, the fixed speed can not adjusted lower to 50%.http://www.expreview.com/img/software/Expertool-ati.exe
sakis_the_fraud Αύγουστος 16, 2008 #169 Αύγουστος 16, 2008 Real Temp 2.70 Παράθεση Changes in Version 2.70 * Redesigned user interface (GUI) with larger temperature fonts. * Added a movable Mini-Mode that is turned on and off with a double left mouse click on the GUI. * Added an Anchor position so the GUI will move to a fixed screen position after a double right mouse click. * Anchor position can be customized by holding down the Shift key while double right clicking. * The correct physical core order of Quad core processors is now reported based on APIC ID. * Added reporting of Minimum and Maximum VID as well as current VID. * A new user selectable high temperature alarm with two alarms for Quad core processors. * More accurate MHz calculation as well as FSB and CPU multiplier reporting. * New program Up Time feature. * Bug fix for log file output when using a Single or Dual core processor. * Fixed and improved the Default button in the Settings window. * Button labels and functionality changed in Settings window to follow the Windows style guide. * Improved multi-threading and memory usage for better long term stability. * Start Minimized option improved for better Vista support. See the documentation for more info. * Option to save the Log file in .CSV format for easy Excel support. * Gamer Mode temporarily retired. http://www.techpowerup.com/downloads/1139/mirrors.php thanks to giorgos_saxo
sakis_the_fraud Αύγουστος 19, 2008 #170 Αύγουστος 19, 2008 Core Temp 0.99.2 Παράθεση Version 0.99.2 - 18th August, 2008- Fix: Start with Windows option was broken in 0.99.1.- Fix: Default color for the second system tray icon is invisible with WinXP blue theme.- Fix: Save screenshot function would create a corrupted BMP in some viewing software.- Fix: Nehalem does not report VID like earlier CPUs. VID field now disabled for Nehalem.- Fix: Incorrect 65nm Turion X2 code name detection.- Fix: Potential bug of improper K10 and up recognition.- Fix: Enabling distance to Tj.Max with "Highest temp." for system tray would show the largest distance to Tj.Max instead of smallest.- Fix: Vendor ID and Device ID values were reversed in the register dump file.- Fix: 3/4 temperatures logged for Phenom X3/X4 instead of 1.- Add: Support for Core Temp plugins. (Still in beta phase and not in GUI yet).- Add: Full support for AMD's Puma platform CPUs (in previous version reffered to as Griffin).- Add: Initial support for 45nm AMD processors.- Add: Update K8 and K10 recognition code to support all currently known CPUs.- Add: Default TDP detection for Nehalem.- Add: On the fly CPU speed detection.- Add: Close to system tray option.- Change: Log file is now produced in CSV format - easily import your logs into Excel.- Change: Logging interval is now in Seconds instead of miliseconds.- Change: Default logging interval is now 10 seconds.- Change: Logging is now off by default.http://www.alcpu.com/CoreTemp/CoreTemp.zip
GeorgeVasil Αύγουστος 20, 2008 #171 Αύγουστος 20, 2008 Speedfan 4.35 Παράθεση * released to the public the EXOTICS tab* fixed 120 DPI issue in CONFIGURE dialog* added full support for Areca RAID controllers* greatly improved SCSI support* added support for Abit uGuru 3 (uGuru 2005)* added full support for Intel FB-DIMM temperature readings* added full support for ITE IT8720F* added full support for Andigilog aSC7611* added full support for LM96000 (it was previously detected as LM85B)* added full support for Analog Devices ADT7490* added full support for SMSC SCH5327* fixed Windbond W83766HG hardware monitor detection on some Asus motherboards* improved CPU identification routines* added support for a new revision of the WINBOND W83637HF* added support for WINBOND W83637HF at unusual addresses* added support for Asus F8000 at unusual addresses* added identification of the SMSC SCH5514* added identification of SMSC EMC2300* added ITE IT8718F fifth fan speed reporting* added identification of Analog Devices ADP3228* added identification of ITE IT8512F* added identification of Winbond W83667HG SuperIO chip* identified a new revision of Fintek F71872 hardware monitor subsystem* added preliminary detection of the HECI driver* fixed a bug in SMSC LPC47M172 support code that prevented fan speeds to be properly reported* 45nm Intel CPUs with CPUID=0x10676 now use a Tjmax value of either 105C or 90C* added full support for nVidia MCP65 SMBus* added full support for nVidia MCP67 SMBus* added full support for nVidia MCP73 SMBus* added full support for nVidia MCP78S SMBus* added full support for VIA CX700M SMBus* added full support for Intel 82801JIB SMBus* fixed an issue where the Intel SMBus couldn't be accessed and messages like SMBus msg : SMB Error $14 : FAILED (50) were generated* enabled Intel ICH8M-E SMBus device, if needed* enabled 631xESB SMBus, if needed* enabled SMBus on Intel ICH9R, if needed* preliminary detection of AMD CD5536 SMBus* some SMBus addresses on Asus Striker Extreme are no longer scanned* SMBus is no longer scanned at address $2E on DELL XPS710* Tyan S2927 second SMBus is no longer scanned* some addresses on the SMBus of Asus P5NT WS are no longer scanned* some addresses on the SMBus of the Intel DX38BT are no longer scanned* some SMBus addresses are no longer scanned on Asus M2N32-SLI DELUXE* the second nForce SMBus is no longer scanned on FIC AU31* some addresses on the SMBus of Supermicro H8DCE are no longer scanned* added some SMBus scan exclusions for Intel D5400XS* added /NOGIVEIO command line parameter to disable access to giveio.sys* added /NOGEFORCEROM command line switch that will prevent SpeedFan from reading nVidia GeForce ROMs (useful if it takes too much time)* nVidia video BIOS is now stored in a file for later retrieval* fixed an access violation under Win9x with some nVidia video cards* battery status messages are no longer displayed* upon resume, all controlled fans are set to 100% for half a second, then set to their minimum fan speed* added new configuration option SHOWSTATICICON* enabled Intel 6300ESB SMBus if neededhttp://www.almico.com/sfdownload.php
koumle Αύγουστος 22, 2008 Author #172 Αύγουστος 22, 2008 Core Temp 0.99.3Version 0.99.3.0 - 22th August, 2008- Add: Correct TjMax values for 45nm Core 2 series, according to this document.- Fix: When TjMax = 0 (undefined) "Delta to Tjunction" was not added to the temperature string.
koumle Αύγουστος 22, 2008 Author #173 Αύγουστος 22, 2008 HWMonitor 1.10 * Support of new sensor chips (SMSC® LPC47M192, EMC6W201 and DME1737, Winbond® W83793). * Unicode version.
sakis_the_fraud Αύγουστος 23, 2008 #175 Αύγουστος 23, 2008 CPUCalc 1.9.4 Παράθεση Changelog 1.9.4:-X2 5400BE added.-Values can now be saved and loaded to .ccalc-files.-.ccalc-files can now be uploaded with the message at "Bugreport+ideas".-Many small things.http://www.cpucalc.com/download.php?d=9
sakis_the_fraud Αύγουστος 26, 2008 #176 Αύγουστος 26, 2008 FurMark v1.4.0 Παράθεση Version 1.4.0 - June 23, 2008 * New: added full QXSGA mode: 2560x2048. * New: added an extreme burning mode for stability test. This mode available in command line: /xtreme_burning Launch FurMark-Xtreme-Burning.bat. * New: added command line parameters (see the start-Benchmark-Standard-Mode.bat file for parameters list). Now you can control FurMark's resolution, msaa level, CPU affinity, etc., using command line. This new feature has been added to allow FurMark to be used with OCCT (www.ocbase.com). * Change: time in score dialog box is now in milliseconds. * Change: improved driver detection. * Known issue: under Vista with ForceWare graphics drivers (tested with 169.28 and 175.16), if the desktop resolution is equal to benchmark selected resolution, the swith back from fullscreen mode to windowed mode (at the end of the benchmark) fails and the user can't see the score dialog box. This issue has not been observed with Catalyst or S3 graphics drivers. A workaround is detailed in this post @ Geeks3D.com. http://www.ozone3d.net/benchmarks/fur/index.php#download
sakis_the_fraud Αύγουστος 28, 2008 #177 Αύγουστος 28, 2008 CPU-Z 1.47 Παράθεση News and corrections 1.47 * Intel Core i7 processor. * Intel Core 2 Duo S Mobile processors. * NVIDIA MCP79/7A chipset. * AMD 790GX / SB750 chipset.http://www.cpuid.com/download/cpuz_147.zip
Vatos_locos Αύγουστος 30, 2008 #178 Αύγουστος 30, 2008 JkDefraghttp://www.kessels.com/Jkdefrag/ Παράθεση JkDefrag is a disk defragmenter and optimizer for Windows 2000/2003/XP/Vista/2008/X64. Completely automatic and very easy to use, fast, low overhead, with several optimization strategies, and can handle floppies, USB disks, memory sticks, and anything else that looks like a disk to Windows. Included are a Windows version, a commandline version (for scheduling by the task scheduler or for use from administrator scripts), a screensaver version, a DLL library (for use from programming languages), versions for Windows X64, and the complete sources. προσωπική άποψη ? μ@μ@ει
giorgos_saxo Σεπτέμβριος 1, 2008 #179 Σεπτέμβριος 1, 2008 RivaTuner v2.10 http://www.techpowerup.com/70131/Download_-_Rivatuner_Version_2.10.html
GeorgeVasil Σεπτέμβριος 2, 2008 #180 Σεπτέμβριος 2, 2008 IntelBurnTest v1.6 ή αλλιώς Linpack. Ενα νέο Stress Tool Της Intel....(θα το εχετε πετυχει πολλες φορες στα O/C Threads του Xtremesystems). Δεν ξερω τι σκατα εχουν κανει..αλλα ειδα + 14 βαθμους σε σχεση με το Small FFTs του Prime 95. (58 -60 Prime 95 / 72-74 το Linpack) Παράθεση This is an extremely stressful program that willput even the most powerful X86/X64 CPU in the world at its knees. Load temp under Linpack will be up to 22*C higher than the competing software Prime95. Παράθεση Benefits of using Linpack:1. More accurate than Prime95 Small FFTs/Blend. 2. Takes less time to tell if your CPU/RAM is unstable than Prime95 (usually something like 8 minutes Linpack vs 40 hours under Prime95). 3. Use the same stress-testing engine that Intel uses to test their products before they are packed and put on shelves for sale. Benefits of using IntelBurnTest: 1. Simplifies usage of Linpack. 2. Direct output of results to the screen. 3. Simplifies the process of selecting a test size to use. 4. Better appearance. How to test CPU and RAM stability (summarized): 1. It is best to use a 64-bit OS with the 64-bit mode for the most accurate test result. 2. Use the most available RAM possible (IntelBurnTest can now do this on its own automatically). The more memory it uses, the more accurate. 3. Select the run # (should use at least 5). 4. Start running. Output should look something like this (unless if error detection is on*): [ATTACH]3623[/ATTACH] http://downloads.guru3d.com/IntelBurnTest-v1.6-download-2047.html#download
