sakis_the_fraud Μάϊος 13, 2008 #141 Μάϊος 13, 2008 EVGA Precision v1.02Version 1.02 change log: * Added tray icon temperature monitoring feature * Added set of synchronization protocols aimed to improve Precision usage safety in conjunction with third party hardware monitoring tools * Added exception handling to PLL clock frequency monitoring routines * Precision settings are now stored in display adapter model specific profiles to allow keeping the settings when installing new version * Now the uninstaller allows you to keep Precision settings * Compact graph mode is enabled by default now * Now Precision reverts to default skin if corrupted skin is selected http://www.evga.com/articles/405.asp(αν και προσωπικα δεν βλεπω κατι διαφορετικο απο τα αντιστοιχα προγραμματα )Α-ΠΑ-ΡΑ-ΔΕ-ΚΤΟDear NGOHQ,It has come to our attention that you are republishing and offeringdownloads of the EVGA Precision utility content on your website NGOHQ.com.Your unauthorized use of material from EVGA.com is in violation of copyrights licensed by EVGA Corporation. If you do not immediately remove the copyrighted material from NGOHQ.com, and notify us in writing that you have done so, we will have no choice but to pursue legal action against you. We appreciate the mention of EVGA on your site but we cannot allow EVGA Precision utility to be offered for download, outside of EVGA's website, please direct downloads to the following EVGA website.Sincerely,Bobby HsiaLegal AdministratorΓια οσους δεν εχουν ορεξη να κανουνε login στο site της eVGA παρτε την 1.01http://rapidshare.com/files/114725872/EVGA_Precision_1.01.ZIP.html
sakis_the_fraud Μάϊος 20, 2008 #143 Μάϊος 20, 2008 Core Temp 0.99 final * Fix: Incorrect recognition of 45nm Mobile Intel CPUs. * Fix: CPU temperature not displayed in Core Temp window on Phenom CPUs (0.98 and 0.98.1). * Fix: CPU load would sometimes display -1% load. * Fix: AMD K8 would sometimes spike to 206C, the false reading is now ignored. * Fix: AMD K8 sometimes constantly reads -49C. * Fix: Core Temp does not show up automatically on G15 LCD with 2.02 driver. * Fix: Shared memory structure was not properly filled on multiprocessor systems. * Fix: System tray setting "Show highest temperature of each CPU\" only displays one temperature reading in a multi CPU system. * Fix: Certain problems with font resizing should now be fixed. * Fix: G15 LCD would not update after using soft buttons. * Fix: On temperature display mode change, high and low records were not reset. * Fix: Changing the reading interval in settings did not actually update, restart of Core Temp was needed to apply the change. * Fix: Incorrect VID detection on 45nm desktop Intel parts. * Add: Shared memory - developers now have access to Core Temp data. * Add: Register dump to text file function. * Add: Preliminary Atom (Silverthorne) support - Untested. * Add: Support for Intel Core 2 Duo E7000 45nm series. * Add: Option to show a single icon instead of temperature in the system tray. * Add: Custom font and size for G15 LCD screen or simply use the built in compact font and layout. (via Settings.ini) * Change: Improved detection of L2 cache on Intel chips for more accurate recognition. * Change: Rewritten temperature calculation to fix problems with shared memory. * Change: Default G15 LCD text layout and font changed. * Change: Doesn't create a log file containing session start and end times if logging is disabled. * Change: Settings.ini file is automatically created with default settings in case one doesn\'t already exist.http://downloads.guru3d.com/Core-Temp-0.99-Final-download-1929.html
sakis_the_fraud Μάϊος 22, 2008 #144 Μάϊος 22, 2008 Hyper PI 098.b http://home.pages.at/virgilioborges/hyper_pi_0.98b.zip Πολυ καλο προγραμμα για δοκιμες, αλλα απο οσο ξερω δεν γινεται να ανεβασεις σκορ με αυτο. screenshot thanks to Dinos111
sakis_the_fraud Μάϊος 23, 2008 #145 Μάϊος 23, 2008 EVGA Precision 1.1.0- Ability to view temperatures in the system tray- Core/Shader Clock Link/Unlink capability- Fan Speed manual or auto adjustment- Real-Time on-screen display support for ingame temp, framerate, and clock monitoring- Logitech Keyboard LCD Display support- In-app temp/clockspeed monitoring of GPU's (up to 4 supported)- Information button shows device, driver, memory size, BIOS Revision and SLI mode- Ability to choose different skins (three skins available)... plus, it allows up to 10 unique profiles and ability to assign hotkeys to these profilesΟχι δεν θα το κατεβασουμε απο το site σου EVGA!EVGA Precision 1.1.0
sakis_the_fraud Μάϊος 25, 2008 #146 Μάϊος 25, 2008 GPU-Z 0.2.2- Added support for variants of i945G, Q35, G31/G33, G84, G92, G96, GT200, G86M, G84M, C79- Improved RV770 and GT200 detection code- Updated NVIDIA temperature reading code- Fixed updater getting stuck during refresh- CrossFire on Vista64 now reported with note "unsure", instead of just "unknown"- Added mini graph to sensors- Screenshots are uploaded as PNG now- Added crash report error handler- Updated G70 number of ROPs- Added PCI Vendor Point of View- Improved S3 Chrome 400, S20, S18 and S8 detectionhttp://www.techpowerup.com/downloads/1077/mirrors.php
sakis_the_fraud Μάϊος 28, 2008 #147 Μάϊος 28, 2008 Precision V1.1.1 NEW IN v1.1.0! Link button state is no longer restored improperly when loading the profiles under certain conditionshttp://en.expreview.com/img/software/0805/EVGA_Precision_Setup_1.1.1.exe
sakis_the_fraud Μάϊος 29, 2008 #148 Μάϊος 29, 2008 NiBiTor v4.1changes in this Version * Added Support for GeForce 9600 GSOThis new version is build upon the logic of the previous version, with some minor fixes and a redesign to support as well unknown devices in a limited way. As always for extra features, settings and support please provide us your original BIOS, so that we can use it as reference to analyze the changes and to code the approriate support of the new video card or new features accordingly.http://www.mvktech.net/index.php?option=com_remository&func=fileinfo&filecatid=2577
sakis_the_fraud Μάϊος 31, 2008 #149 Μάϊος 31, 2008 GPU-Z 0.2.3- Fixed NVIDIA GeForce GTX 260/280 (GT200) support. Everything is working and tested now- Removed bogus 190°C PCB temp sensor on various NVIDIA cards- Added fan speed monitoring for NVIDIA- Fixed crash when switching devices during sensor refresh- Fixed ROP/Shader count on NVIDIA G72- Fixed graphs spilling over their client area- Fixed a number of other rare crashes- NVIDIA device ID 0x00F3 now correctly recognized as NV43- Improved crash reporting modulehttp://www.techpowerup.com/downloads/1095/mirrors.php
sakis_the_fraud Ιούνιος 1, 2008 #150 Ιούνιος 1, 2008 NVFlash 5.67The NVIDIA Firmware Update Utility (nvFlash) is used to update the firmware stored in the EEPROM of an NVIDIA display adapter. This version is for DOS.http://www.mvktech.net/index.php?option=com_remository&func=fileinfo&filecatid=2578
sakis_the_fraud Ιούνιος 13, 2008 #151 Ιούνιος 13, 2008 AMD OverDrive 2.11 betaThe new Overdrive checks for the system specs when installed, so those that have Intel, VIA, Nvidia, or any other chipset shouldn't bother to install it. It works only with AMD 7xx series, but if it can squeeze additional overclock from that Phenom CPU, it's worth a try.http://downloads.guru3d.com/AMD-Overdrive-2.1-beta-download-1945.html
sakis_the_fraud Ιούνιος 24, 2008 #152 Ιούνιος 24, 2008 GPU-Z v0.2.4 * Improved RV770 detection * Fixed another crash related to sensors when switching cards * More measures to get rid of 190° PCB sensors * Added preliminary support for RV730http://www.techpowerup.com/downloads/1104/mirrors.php
sakis_the_fraud Ιούνιος 27, 2008 #153 Ιούνιος 27, 2008 GPU Caps Viewer v1.4.2Version 1.4.2 - January 17, 2008 * Change: added Catalyst 8.1 to database. * Change: web links updated * Change: version 1.4.2 http://www.ozone3d.net/gpu_caps_viewer/
GeorgeVasil Ιούνιος 28, 2008 #154 Ιούνιος 28, 2008 CPU-Z 1.46 * AMD Puma platform (Turion & Turion Ultra "Griffin"). * AMD Black Edition processors. * Intel Xeon EX "Dunnington".Exe file properties * MD5 (cpuz.exe 1.46) : 65B6974AB50E1F3F0822FDA4C38B56D9Click Me
GeorgeVasil Ιούλιος 1, 2008 #155 Ιούλιος 1, 2008 GPU-Z 0.2.5 Fixed BIOS Reading on HD 4870. Please do not flash non-128K BIOSes to GDDR5 cards- Fixed GDDR5 bandwidth calculation- Fixed texture fillrate on RV770 and RV730- Added three extra on-die temperature sensors to RV770 monitoring- Removed states.dmp file creation- Fixed GPU activity readings on RV770- Changed devices list order to be more intuitive (by bus number now)- Added Shared Memory support, see the forum for more info- Fixed more 190°C PCB readings on NVIDIA- Catalyst Beta versions no longer displayed as version 2.2- Fixed sensor graph overflow- Sensor graphs will try to autoscale now- Fixed RV505 process size- Fixed memory bus width reading on some ATI RS300- Fixed rare crash when reading NVIDIA sensors- Fixed GDDR3 detection for G71http://www.techpowerup.com/downloads/1124/mirrors.php
GeorgeVasil Ιούλιος 11, 2008 #156 Ιούλιος 11, 2008 Core Temp 0.99.1Version 0.99.1 - 10th July, 2008- Fix: Layout when using upto 125% DPI.- Fix: Layout problem and extra systemtray icons with Phenom.- Fix: Potential crashes while saving a register dump file.- Fix: Core Temp icon wasn't showing in About box.- Fix: Menu shortcut keys were not available for all menu items.- Fix: A few old unnoticable bugs.- Add: Initial Intel Nehalem support.- Add: Initial support for AMD's Griffin cores - Untested.- Add: Improved Intel Atom support.- Add: Support latest AMD K8 CPUs.- Add: Support for HyperThreaded CPUs. Core Temp will only display the physical cores and average load on each core.- Add: Support for Pentium E5000 series.- Add: Display core and thread count per CPU.- Add: GUI Adjustments of Temperature offset and G15 applet via the Settings window.- Add: Create a screenshot function. Access from "Options" menu or by F9 shortcut.- Add: Shortcut key for register dump file: F7.- Add: Update register dump output: APIC ID, CPU number, Core number, Thread number.- Change: Move all settings to the ini file out of the registry.- Change: Rename ini file to CoreTemp.ini.- Change: Temperature offset adjustment works for AMD CPUs as well.- Change: Atom Tj.Max adjusted for more accurate readings.- Change: Cleaned up code a little bit.http://www.alcpu.com/CoreTemp/
sakis_the_fraud Ιούλιος 31, 2008 #157 Ιούλιος 31, 2008 GPU-Z v0.2.60.2.6 * Added full support for HD 4870 X2 * Added support for reading clocks on newer ATI drivers (R700) * Fix for realtime clock sensor showing double memory speed on RV770 GDDR5 * Added detection for GeForce 9800 GT, GeForce 9300 GE * Added support to start GPU-Z minimized (use -minimized) * Added tray icon when GPU-Z is minimized * Fixed crash when uploading large BIOS files * Fixed rare crash that could happen on some NVIDIA cards * Added detection for Intel Q43. G45 and some variants of G35, G965, GM965http://www.techpowerup.com/downloads/1132/mirrors.php
GeorgeVasil Αύγουστος 1, 2008 #158 Αύγουστος 1, 2008 Εχει βγει εδω και πολυ καιρο αλλα αξιζει μια θεση στην λιστα. Real Temp RealTemp is a temperature monitoring program designed for all Intel single Core, dual Core and quad Core processors. It's compatible with Windows 2000, XP or Vista, 32 or 64 bit. In Vista or if you are in a limited account, you will need to right click on the icon and run RealTemp as an Administrator so that the driver will be properly installed.New features include full System Tray support as well as more Calibration options. RealTemp can be found at its new home at TechPowerUp. http://www.techpowerup.com/realtemp/
sakis_the_fraud Αύγουστος 1, 2008 #159 Αύγουστος 1, 2008 GPU Caps Viewer v1.5.0 * New: added new demo: HW Geometry Instancing. Works with GeForce 8 (and higher), S3 Graphics Chrome 400 series (430 GT, 440 GTX). This demo requires the support of Shader Model 4.0 * New : added command line parameters to set the default size of demos's window. Example: c:\>gpucapsviewer /width=1920 /height=1200 * Change: improved HDR demo with radial blur. * Change: density of mesh plane (500k triangles) in the Vertex Texture Fetching demo. This demo works fine with NVIDIA GeForce 6+, S3 Graphics Chrome 400 (430 GT and 440 GTX) and should work one day with Radeon 2k/3k (bug in Catalyst?). * Bugfix: render target init for ATI and S3 Graphics (HDR demo). * New: added a simple splashscreen to give some startup information. * New: added NVIDIA PhysX driver detection. * Bugfix: msaa was set to 2X at initialization and this value prevents a correct init of S3 Graphics Chrome 430 GT. * Bugfix: small bug in the detection of GPU Caps Viewer version. * Bugfix: in opengl extensions list box, driver information was not correct. * Bugfix: small bug in drivers detection (XP and Vista). * Bugfix: small bug in GPU Caps Viewer installer (new version tries to install into old folder). * Change: added ForceWare 177.66 and Catalyst 8.7 to database. * Change: added detection of GeForce GTX 260/280 and Radeon 4850/4870/4870 X2. * Change: version 1.5.0 * Known issue: under Vista the temperature for GeForce based graphics cards is not displayed. http://downloads.guru3d.com/GPU-Caps-Viewer-1.5.0-download-1584.html
sakis_the_fraud Αύγουστος 1, 2008 #160 Αύγουστος 1, 2008 Και ενα ενδιαφερον προγραμματακι που βρηκα σημερα... CPUCalc is an overclocking-calculator able to "simulate" overclocking with many Intel and AMD processors.You just need to set your wished clock and it calculates all other settings, for example. It automatically sets the correct CPU-RAM-ratio and Referenceclock:HTT-Ratio. It´s also able to calculate the new TDP with the overclocked settings. [ATTACH]3452[/ATTACH] CPUCalc 1.7 * Added K10Calc and all Phenom-K10 processors * Fixed the link to the CPUCalc-forum. It now referring to the new CPUCalc-forum. * Many small unimportant things. http://downloads.guru3d.com/CPUCalc-1.7-download-2017.html
