sakis_the_fraud Απρίλιος 2, 2008 #121 Απρίλιος 2, 2008 GPU-Z 0.1.8Changes in version 0.1.8: o Fixed SLI detection for Vista32 and Vista64 o Added automatic refresh of clocks and multi GPU status o Added support for NVIDIA Quadro FX Go1400, Quadro NVS 440, GeForce 7350 KE, 7300 GT, 8400 SE, 9800 GX2, 9800 GTX, 9500 GT, 8400, Quadro NVS 140M, 135M, FX 360M, 9300M G, 9500M GS, 8600M GT, 8700M GT, FX 3600M o Added support for G96 o Added support for ATI FireGL V8600, some RV635 and RV620 variants o Fixed fan speed monitoring for RV6xx o Fixed fillrate for 8800 GTS 512 o Fixed some subvendor names o Fixed shader calculation for M68 o Process size, Die size, DirectX Support will now show "Unknown" o Fixed crash when no sensors detected o Fixed NV44 ROP and shader calculation o Fixed crash when NVIDIA BIOS couldn't be read o Added Splash screen http://downloads.guru3d.com/GPU-Z-0.1.8-download-1856.html
sakis_the_fraud Απρίλιος 2, 2008 #122 Απρίλιος 2, 2008 CPU-Z 1.44.2 * NVIDIA 650i, 680i, 750a/780a, 750i, 780i, 790i chipsets (1.44.2). * Intel G35 chipset (1.44.2). * Updated support for VIA chipsets (1.44.2). * Support for the new validator (1.44.1). * Preliminary support for VIA Isaiah processor. * Support for all VIA Model D processors: VIA C7-M, VIA C7-D, VIA Eden, VIA Eden. * Memory timings on Intel 5400A/B MCH (Skulltrail). * Fix AMD Phenom detection issue on Windows Vista 64.http://www.cpuid.com/download/cpuz_144.zip
ermoulis Απρίλιος 2, 2008 #123 Απρίλιος 2, 2008 GPU-Z v0.1.9 <hr style="color: rgb(209, 209, 225);" size="1"> <!-- / icon and title --> <!-- message --> Fixed bluescreen when GPU-Z is startedFixed splash screen not going away in some casesFixed crash when GPU registers couldn't be accessed (thanks tDJ)Fixed shader count for NV44http://www.techpowerup.com/downloads...PU-Z.0.1.9.exe
sakis_the_fraud Απρίλιος 2, 2008 #124 Απρίλιος 2, 2008 NVIDIA BIOS Editor v4.0 * Added Support for GeForce 9800 GTX * Added Support for GeForce 9500 GT * Added Support for GeForce 8800M GTX * Added Support for GeForce 8600M GT * Fixed Bug with Fan Speed IC Settingshttp://www.mvktech.net/index.php?option=com_remository&func=fileinfo&filecatid=2537
sakis_the_fraud Απρίλιος 3, 2008 #125 Απρίλιος 3, 2008 AMD Overdrive 2.0.17This version supports the following chipsets: * RS740(770) * RS780(780) * RD790(790X & 790FX * Adds AMD 780G Chipset support * Adds AMD 780G IGP engine clock control in the Advanced Performance tuning menu * Enhanced AutoClock feature for Unlocked AMD CPUs (e.g. Phenom 9600BE, Athlon X2 5000+ Black Edition)http://downloads.guru3d.com/AMD-Overdrive-2.0.17-download-1893.html
sakis_the_fraud Απρίλιος 4, 2008 #126 Απρίλιος 4, 2008 HWiNFO32 v1.80changes in HWiNFO32 v1.80 * Added several new nVidia G96 and G98 models, GeForce 9800 GX2. * Added support of ADT7490 sensor. * Added S3 Chrome 400 Series. * Enhanced support of nVidia MCP73 (nForce 6x0i) and C73 (nForce 790i). * Added support of Enhanced Performance Profile 2 (for DDR3). * Added ATI Mobility Radeon HD 3430, 3650, Radeon HD 3300, 3430 and M86. * Added Intel Atom branding for Silverthorne and Diamondville CPUs. * Updated Intel XMP support to v1.1. * Added recognition of Intel Mobile Diamondville. * Improved memory module timing information. * Added monitoring of CPU power consumption and current for Giga-Byte boards supporting DES. * Added ATI FireMV 2260 and 2450. * Improved identification of LGA771-based Yorkfield (QX9775). * Added ATI Mobility RADEON HD 3850 X2, 3870, 3870 X2. * Enhanced identification of Cantiga SKUs. http://downloads.guru3d.com/HWiNFO32-version-1.80-download-1078.html
sakis_the_fraud Απρίλιος 18, 2008 #127 Απρίλιος 18, 2008 SiSoftware Sandra XII 2008 SP2 (14.20)http://downloads.guru3d.com/SiSoftware-Sandra-XII-2008-SP2-(14.20)-download-1391.html
sakis_the_fraud Απρίλιος 18, 2008 #128 Απρίλιος 18, 2008 MemSet 3.4 version (for 2000 /XP /Vista 32&64 bits)http://www.tweakers.fr/download/MemSet.exeMemSet 3.5 Betahttp://www.tweakers.fr/download/MemSet35beta.exeμου ειχαν ξεφυγει αυτα...
sakis_the_fraud Απρίλιος 24, 2008 #129 Απρίλιος 24, 2008 Core Temp 0.98.1Version 0.98.1 * Fix: Core Temp sometimes crashes when another program tries to access the log file. - Still needs further testing. * Add: Show load percentage per core. * Add: Adjustable Tj.Max value via *.INI file. * Add: Option to start Core Temp with Windows. * Add: Support new Intel Mobile processors * Change: Maximum logging interval is now 99999ms instead of 9999ms. * Change: Log file layout. Shows current temperature, high\low temperature, core load, CPU speed.http://downloads.guru3d.com/Core-Temp-0.98-download-1829.html
sakis_the_fraud Απρίλιος 25, 2008 #130 Απρίλιος 25, 2008 SpeedFan 4.34 changelogDownload -> http://downloads.guru3d.com/SpeedFan-4.34-download-893.html
sakis_the_fraud Απρίλιος 29, 2008 #131 Απρίλιος 29, 2008 RivaTuner v2.09changeloghttp://downloads.guru3d.com/RivaTuner-v2.09-download-163.html
sakis_the_fraud Μάϊος 1, 2008 #132 Μάϊος 1, 2008 Σημερα επεσα κατα τυχη πανω του...3Dmark2006 Score CalculatorDownload 1.2Download 1.2 Mirror
papajim Μάϊος 2, 2008 #135 Μάϊος 2, 2008 H πρώτη έκδοση του EVGA Precision Tool 1.0 Eίναι κάτι παρόμιο με το fraps και to RivaTuner αλλά υποστηρίζει μόνο κάρτες γραφικών Nvidia 6, 7, 8, 9 Series Δικιμάστε το
sakis_the_fraud Μάϊος 3, 2008 #136 Μάϊος 3, 2008 Core Temp 0.99 BetaFix: Incorrect recognition of 45nm Mobile Intel CPUs.Fix: CPU temperature not displayed in Core Temp window on Phenom CPUs (0.98 and 0.98.1).Add: Shared memory. Developers now have access to Core Temp data.Add: Register dump to text file function.Add: Preliminary Atom (Silverthorne) support - Untested.http://www.alcpu.com/CoreTemp/CoreTempBeta.zip
sakis_the_fraud Μάϊος 3, 2008 #137 Μάϊος 3, 2008 GPU-Z 0.2.0- Added support for S3 graphics cards- Added screenshot upload feature (press F5 or click the camera icon)- Added NVIDIA GT200 detection- Updated RV770 detection- Vista64 is now listed as "Vista64" in the driver version readout- On Vista64, CrossFire status will be marked as "Unknown" until fix is found- Added dump to XML. Use command line parameter -dump gpuz.xml- More robust NVIDIA clock detection- Fixed G73 fillrate calculation- Added die size for RV350- Fixed R680 clock readings- Fixed R600 ROM reading code- Fixed sensors not refreshing properly sometimes- When unknown architecture detected, NVIDIA logo won't be shown anymore- Fixed random UNICODE characters on some architectures in upload progresshttp://www.techpowerup.com/downloads/1058/mirrors.php
GeorgeVasil Μάϊος 5, 2008 #138 Μάϊος 5, 2008 GPU-Z v0.2.1Fixed Vista32 / Vista64 detection. It was reversed in 0.2.0.http://www.techpowerup.com/downloads/1059/mirrors.php
sakis_the_fraud Μάϊος 10, 2008 #139 Μάϊος 10, 2008 CPU-z 1.45 Date 05/10/2008 News and corrections * Intel Atom Z500/Z510/Z520/Z530/Z540 processors. * Intel Core 2 Duo E7x00 processor. * AMD 45 nm Phenom (Dened & Shanghai) processors. * Intel P45 chipset.Exe file properties * MD5 (cpuz.exe 1.45) : DD4E540C04297CF93DC721166C13446Ehttp://www.cpuid.com/download/cpuz_145.zip
stelios Μάϊος 11, 2008 #140 Μάϊος 11, 2008 Δεν μπορούσαν να περιμένουν ακόμη μια μέρα για να το βγάλουν Δεν μπορω να κάνω validate μερικά cpuz τώρα!
