sakis_the_fraud Φεβρουάριος 11, 2008 #101 Φεβρουάριος 11, 2008 ComputerBase ATI BIOS Editor 0.9 Beta for ATI Radeon HD 3870 X2ComputerBase.de has released a BIOS editor which allows to modify the BIOS of all ATI Radeon HD3870 X2 cards. You can edit BootUp Clocks, 2D Clocks, Low Power 3D Clocks, High Power 3D Clocks, UVD Clocks and the VCore voltage.http://www.computerbase.de/downloads/treiber/grafikkarten/ati/computerbase_ati_bios-editor/
sakis_the_fraud Φεβρουάριος 13, 2008 #104 Φεβρουάριος 13, 2008 OverDrive 2.014BetaRequirements :1. Windows XP, Vista (32/64bit) 1024X768 @16BIT colors2. Mainboard chipset supported RS / RD / RX 700(780/790)3. AMD 64/NPT/10H/11H CPU4. BIOS must support OverDrive featuredownload: http://game.amd.com/us-en/drivers_overdrive.aspx
sakis_the_fraud Φεβρουάριος 17, 2008 #105 Φεβρουάριος 17, 2008 CPU-Z 1.44.1 * Support for the new validator (1.44.1) * Preliminary support for VIA Isaiah processor. * Support for all VIA Model D processors: VIA C7-M, VIA C7-D, VIA Eden, VIA Eden. * Memory timings on Intel 5400A/B MCH (Skulltrail). * Fix AMD Phenom detection issue on Windows Vista 64.http://www.cpuid.com/download/cpuz_144.zip
GeorgeVasil Φεβρουάριος 17, 2008 #106 Φεβρουάριος 17, 2008 NVIDIA BIOS Editor (NiBiTor) v3.7aChanges in this Version* Added Support for GeForce 8800 GS* Added Support for Quadro FX540* Added Support for GeForce 6800 XE* Fixed Auto Select TimingSet for G92 Based Cards* Update Vendor List for EVGA Support
GeorgeVasil Φεβρουάριος 19, 2008 #107 Φεβρουάριος 19, 2008 TechPowerUp GPU-Z v0.1.7 * Corrected several GeForce 9600 GT readings * Switched GPU and PCB temperature readings on ATI cards when using LM63 sensor * Some fields on the main screen will now show grey "unknown" instead of "0" when value unknown * Fixed HD 2900 GT ROP and shader count * Added HD 3850 AGP detection * Added 8400 GS detection * Fixed shader count on modded/unmodded R420 cards * Added Rage LT Pro detection * Fixed RS300 vertex shader count
pain423 Φεβρουάριος 22, 2008 #108 Φεβρουάριος 22, 2008 Notebook Hardware Control 2.0 www.p35-forum.de/files/nhc_2.0_pre_release_06.zip περισσότερες πληροφορίες www.pbus-167.com απ'οτι είδα δεν το είχε βάλει κανείς αν κάνω λάθος αγνοήστε το
sakis_the_fraud Φεβρουάριος 22, 2008 #109 Φεβρουάριος 22, 2008 nvFlash v5.63 NVIDIA nvFlash v5.63 Available (GeForce 9600 GT - G94 Support).The NVIDIA Firmware Update Utility (nvFlash) is used to update the firmware stored in the EEPROM of an NVIDIA display adapter. It can also be used to perform other tasks on the adapter such as saving a copy of the current firmware image to a file, displaying the version of the firmware image, or determining the EEPROM part present on a display adapter.http://downloads.guru3d.com/nvFlash-v5.63---NVIDIA-Firmware-Update-Utility-download-1862.html
GeorgeVasil Φεβρουάριος 23, 2008 #110 Φεβρουάριος 23, 2008 NVIDIA BIOS Editor (NiBiTor) v3.8Changes in this Version * Added Support for GeForce 9600 GT * Added Support for Quadro FX3700 * Added Support for Temp Compensation Value * Compensation used of Fan Speed IC Settings
GeorgeVasil Φεβρουάριος 23, 2008 #111 Φεβρουάριος 23, 2008 Memtest86+ V2.01- Solved a major bug in Memory Address Errors Reporting- Patched for Intel-Powered Mac - Pass duration 20% reduced- Solved a incoherency with pass progress indicator- Patched Makefile to compile on x86_64- Added support for 45 nm Mobile Core 2 w/ 3 Mo L2- Corrected Intel 3-Series (P35/X38) chipset init- Corrected a bug with SPD Display and ESB6300- Correct a detection bug on P965/G965 C-Stepping- Added support for i945GM/PM/GME & i946PL/GZ- Added support for iGM965/iGL960/iPM965/iGME965/iGLE960- Added detection for SiS 649/656/671/672- Added detection for i430MX/i430TX- Added an optional beep mode (pass completed w/o error)- Removed the blinking cursor- Bootable Memtest86+ ISO more compatible- Reverted Test #0 to cached
sakis_the_fraud Μάρτιος 3, 2008 #113 Μάρτιος 3, 2008 RivaTuner v2.07changeloghttp://downloads.guru3d.com/RivaTuner-v2.07-download-163.html
sakis_the_fraud Μάρτιος 3, 2008 #114 Μάρτιος 3, 2008 hotfix for 3DMark06/05/03 and PCMark05Benchmarking heavy-weights at Futuremark have released another hotfix for their popular applications. Set to work with 3DMark03 Build 3.6.0, 3DMark05 Build 1.3.0, 3DMark06 Build 1.1.0 and PCMark05 Build 1.2.0, the hotfix comes to update the GPU core/memory clock detection library so as to make them compatible with the latest hardware releases.http://www.futuremark.com/download/hotfix_feb08/Futuremark_SystemInfo_Hotfix_Feb08_installer.exe
ea6gka Μάρτιος 6, 2008 #115 Μάρτιος 6, 2008 - Add: Vista x64 support - All drivers are now digitally signed!- Add: Logitech G15 keyboard support - see ReadMe!.txt for details.- Add: Support 45nm LGA775 Xeon series.- Fix: Opaque background in system tray wasn't 16x16 pixels.- Fix: Yonah based CPUs incorrectly detected.- Fix: 1333FSB Dual Core Conroe based Xeon incorrectly detected.- Fix: Dreaded cycle of "Driver can't load" messages if driver failed to load.- Fix: Socket AM2 Athlon-FX was not recognized.http://www.alcpu.com/CoreTemp/
sakis_the_fraud Μάρτιος 10, 2008 #116 Μάρτιος 10, 2008 Core Temp 0.97.1Changes in version 0.97.1: * Fix: Phenom did not display proper temperature in version 0.97. * Fix: Phenom randomly reports 255C (value ignored). * Fix: Phenom displays more than a single system tray icon per CPU. * Fix: Phenom 1/4 multipliers rounded improperly. * Change: C° and F° now will display °C and °F accordingly.http://downloads.guru3d.com/Core-Temp-0.97.1-download-1829.html
sakis_the_fraud Μάρτιος 10, 2008 #117 Μάρτιος 10, 2008 RivaTuner v2.08Minor bugfixes: * RivaTuner no longer crashes when RivaTuner module activation launcher item is scheduled to run at Windows startup. * Fixed association between low-level refresh overrider rules and target display adapter, broken due to low-level profiles association related changes in the previous version. * Minor UI and localization fixes. http://downloads.guru3d.com/RivaTuner-v2.08-download-163.html
sakis_the_fraud Μάρτιος 17, 2008 #118 Μάρτιος 17, 2008 OCCT 2.0.0a MONITORING - BugFixs : Now OCCT properly detect all 4 cores temperatures on some quad-cores CPU, and OCCT properly detects CPUs in Vista (some were problematic) - OCCT now supports ACPI Sensors and HDD Sensors (SMART) http://www.ocbase.com/perestroika_en/index.php?Download
sakis_the_fraud Μάρτιος 19, 2008 #119 Μάρτιος 19, 2008 NVIDIA BIOS Editor v3.9 (Nibitor)Changes in this Version * Added Support for GeForce 9800 GX2 * Added Support for GeForce 8800M GTShttp://downloads.guru3d.com/NVIDIA-BIOS-Editor-v3.9-(Nibitor)-download-1636.html
GeorgeVasil Μάρτιος 22, 2008 #120 Μάρτιος 22, 2008 EVEREST v4.50New features & improvements * Updated CPU and FPU benchmarks: 3-core, 6-core CPU support * Revamped System Stability Test module * Intel Skulltrail platform and i5400 chipset support * Support for the latest graphics technologies * DDR3 Extreme Memory Profile and EPP 2.0 detailsMoreLink
