sakis_the_fraud Δεκέμβριος 8, 2007 #61 Κοινοποίηση Δεκέμβριος 8, 2007 HWMonitor 1.0.5.8HWMonitor is a hardware monitoring program that reads PC systems main health sensors : voltages, temperatures, fans speed.The program handles the most common sensor chips, like ITE® IT87 series, most Winbond® ICs, and others. In addition, it can read modern CPUs on-die core thermal sensors, as well has hard drives temperature via S.M.A.R.T, and video card GPU temperature.Special hardware monitors such as abit® uGuru and Gigabyte® ODIN™ power supplies serie are supported too.download - http://www.cpuid.com/hwmonitor.phpGPU-Z v0.1.3 * Fixed blank screen on some R5xx ASICs * Added detection for G92 based 8800 GTS * Fixed memory type being returned as DDR3 instead of GDDR3 on some NVIDIA GPUs * Fixed shader count on some NVIDIA GPUs * Added timeout to shut down when removing driver * Fixed 2D clocks being shown on some NVIDIA cards * Removed geometric clock delta returned as BIOS default shader clock * NV42 AGP id F6 is now correctly detected * Shortened High Tech Systems subvendor string to HIS * Adjusted item tab order on Validation page * Improved NVIDIA driver version detection on XP64 * Added support for original GeForce Quadro * Fixed crash on some GeForce FX and earlier cardsdownload - http://www.techpowerup.com/downloads/882/mirrors.php Link to comment Share on other sites More sharing options...
koumle Δεκέμβριος 8, 2007 Author #62 Κοινοποίηση Δεκέμβριος 8, 2007 NiBiTor v3.6 Link to comment Share on other sites More sharing options...
sakis_the_fraud Δεκέμβριος 8, 2007 #63 Κοινοποίηση Δεκέμβριος 8, 2007 Τα λινκ του memset δεν δουλευουν. τα βρηκα και τα 3 εδω http://www.overclocking-jp.eu/public/Tweakers/ Link to comment Share on other sites More sharing options...
sakis_the_fraud Δεκέμβριος 18, 2007 #64 Κοινοποίηση Δεκέμβριος 18, 2007 GPU-Z v0.1.40.1.4 * Added BIOS extraction features * Added BIOS upload to TechPowerUp VGA BIOS collection * Fixed high CPU usage after update is aborted * Added/Improved detection for NV40 0x0040, G80-600, G84, G86, G92, G98 * Changes to shader detection code for NV40, NV41, NV42, NV43, NV44, NV46, NV48, G70, G71, G72, G73 * Added Subvendor ID for Zotachttp://www.techpowerup.com/downloads/893/mirrors.php Link to comment Share on other sites More sharing options...
o polonos Δεκέμβριος 18, 2007 #65 Κοινοποίηση Δεκέμβριος 18, 2007 Ετσι ετσι μπραβο Σακη .... Ευτυχως που εισαι εσυ.... γιατι ο koumle ακομα στελνει e-mails..... Link to comment Share on other sites More sharing options...
koumle Δεκέμβριος 19, 2007 Author #66 Κοινοποίηση Δεκέμβριος 19, 2007 TechPowerUp GPU-Z v0.1.5Revision History0.1.5 * Online BIOS submission dupecheck now actually works * More changes to G70/G71 ROP/shader detection code (never ending story) * G71 AGP is now 90nm instead of 110nm * If default clocks on NVIDIA can not be determined via BIOS, try fallback via driver * Better driver communication to NVIDIA driver * Corrected shader detection for softmodded R300, R480 cards * Known issue: NVIDIA SLI status can not be detected under Vista Link to comment Share on other sites More sharing options...
inertiacreep Δεκέμβριος 19, 2007 #67 Κοινοποίηση Δεκέμβριος 19, 2007 Ορίστε ρε που κακολογείτε το παιδί... Άντε παμε για νεα έκδοση αύριο που θα βλέπει το 3-way sli Link to comment Share on other sites More sharing options...
CrazyAnt Δεκέμβριος 19, 2007 #68 Κοινοποίηση Δεκέμβριος 19, 2007 εγω παντως 8α μεινω στα8ερος στην αρχικη μου τοπο8ετηση! Αν δεν βγει η εκδοση 1.x.x den to pernav!!! (με τους ρυ8μους που βγαινουν οι εκδοσεις 8α αργισει γαιτι τωρα τελευταια χαλαρωσανε και δεν βγαζουν καινουρια εκδοση κα8ε μερα...χμμ,μηπως να αλλαξω γνωμη ) Link to comment Share on other sites More sharing options...
koumle Δεκέμβριος 19, 2007 Author #69 Κοινοποίηση Δεκέμβριος 19, 2007 Ορίστε ρε που κακολογείτε το παιδί... Link to comment Share on other sites More sharing options...
koumle Δεκέμβριος 24, 2007 Author #70 Κοινοποίηση Δεκέμβριος 24, 2007 HWMonitor 1.0.5.9Version 1.0.5.9 * Bug fix version. Link to comment Share on other sites More sharing options...
SkySurfer Δεκέμβριος 27, 2007 #71 Κοινοποίηση Δεκέμβριος 27, 2007 utilitiesposter koumle βάλε κι αυτό στη λίστα:CoreTemp για Vista x64http://forums.erodov.com/local_links.php?catid=18 Link to comment Share on other sites More sharing options...
sakis_the_fraud Δεκέμβριος 30, 2007 #72 Κοινοποίηση Δεκέμβριος 30, 2007 After four month, Memtest86 comes to 3.4a. But offical have no release note for this version this time. Memtest 3.4a download page We belive CPU-Z 1.42.3 is a leak version because offical page have no info about this version. Ofcourse it did not come with release note. CPU-Z 1.42.3 direct download Link to comment Share on other sites More sharing options...
koumle Ιανουάριος 1, 2008 Author #73 Κοινοποίηση Ιανουάριος 1, 2008 Core Temp 0.96Version 0.96 - 31st December, 2007- Add: System tray icons configuration.- Add: Support for Intel's latest CPUs.- Add: ClearType font support.- Add: Time\Date column to the log file.- Add: Always on top option.- Fix: Core Temp does not proprerly display temperature and CPU select fields.- Fix: Log file layout.- Fix: Hide\Show does not properly Minimize\Restore window.- Fix: Core code names aren't properly detected. (Intel)- Fix: Incorrect\Missing CPU rating when not using stock\maximum multiplier. (Intel)- Fix: Wrong CPU clock is reported when using EIST\non-maximum multiplier. (Intel)- Fix: Wrong detection of Merom based CPUs.- Fix: Single core Athlon 64s and Semprons reading -49C constantly. (Rare)- Fix: C2D M0 rev. report very low temperatures. (Tjmax to 100C)- Fix: Layout and display of tool tip text in the system tray. (Now shows a core per line)- Change: Log the start and end of a session even if logging is disabled.- Change: Settings and Systray settings windows appear in center of main window.- Change: Rename "Tjunction" field to "Tj. Max" to make things clearer. Link to comment Share on other sites More sharing options...
xrist Ιανουάριος 1, 2008 #74 Κοινοποίηση Ιανουάριος 1, 2008 ωραία..δείχνει και τον σωστό πολλαπλασιαστή με την συχνότητα που βάζεις. Link to comment Share on other sites More sharing options...
kallileo Ιανουάριος 1, 2008 #75 Κοινοποίηση Ιανουάριος 1, 2008 Δεν παιζει σε Vista Ultimate x64...παλι. Link to comment Share on other sites More sharing options...
vdeseris Ιανουάριος 1, 2008 #76 Κοινοποίηση Ιανουάριος 1, 2008 Core Temp 0.96- Change: Log the start and end of a session even if logging is disabled. Πολύ σπαστικό αυτό... Link to comment Share on other sites More sharing options...
SkySurfer Ιανουάριος 1, 2008 #77 Κοινοποίηση Ιανουάριος 1, 2008 Δεν παιζει σε Vista Ultimate x64...παλι. 2-3 post παραπάνω:http://forums.erodov.com/local_links.php?catid=18Το κατεβάζεις και το βάζεις σε ένα φάκελο. Αντικαθιστάς το exe με αυτό της έκδοσης 0.96. Link to comment Share on other sites More sharing options...
koumle Ιανουάριος 2, 2008 Author #78 Κοινοποίηση Ιανουάριος 2, 2008 PC Wizard 2008.1.82New support and improvements : * Minor Update : Bugs correction, new preliminary support and some improvements. Link to comment Share on other sites More sharing options...
koumle Ιανουάριος 2, 2008 Author #79 Κοινοποίηση Ιανουάριος 2, 2008 HWMonitor 1.06 * New interface. * Several bug fixes. Link to comment Share on other sites More sharing options...
koumle Ιανουάριος 2, 2008 Author #80 Κοινοποίηση Ιανουάριος 2, 2008 NiBiTor v3.7 Link to comment Share on other sites More sharing options...
