koumle Οκτώβριος 1, 2007 Author #24 Οκτώβριος 1, 2007 HD Tune 2.54Version 2.54 releasedChanges: * Added option to change block size * Improved compatibility with Vista * Fixed problems with Fahrenheit temperature display
koumle Οκτώβριος 1, 2007 Author #25 Οκτώβριος 1, 2007 wPrime v1.54v1.54-----Added load and save to console.Increase thread count capability to 256.Included a 'cleanup' function in the console.Updated CPUz to v1.41
koumle Οκτώβριος 1, 2007 Author #26 Οκτώβριος 1, 2007 SetFSB 2.0.b.16aVersion 2.0.b.16a- Added RTM866-890.Supported VIA PT880Ultra chipset.2.0.b.16a changed SysInfo to Signed Device Driver. So, they work fine on Vista x64. [special thanks for hiyohiyo-san.]
koumle Οκτώβριος 3, 2007 Author #27 Οκτώβριος 3, 2007 PC Wizard 2008.1.80New support and improvements : * Chipset : Intel 945GU, Intel PM/GM965, Intel P35/P31/G33/G31, VIA P4M800/CE, ATI RC610/RS690/RS700/SC710, SiS 671. * Video : nVidia Geforce G80/G84/G86, ATI Radeon R600/RS690/X1200/X2300. * Disk : CFA Power Mode, SCT Command Transport, NV Cache features and AHCI Controllers. * Bios : SMBios 2.6 * Sensor : VIA C7 Diode temperature, Philips NE1618/NE1619(HECETA4), nVidia GeForce 8, ATI Video. * Password : Windows Live Messenger 8.0 recovery. * Network : Wireless 802.11a/802.11b/802.11g/802.11n detection type, Wireless HotSpot detection. * Memory : SDRAM-DDR3. * Device : Broadcom Bluetooth.Preliminary support : * AMD Processor : Athlon 64 X2 BE, Athlon 64 Mobile TK, Geode GX/LX/NX, Phenom X2/X4/FX. * Intel Processor : New Pentium , New Celeron, New Core 2 Duo (Penryn/Wolfdale/Yorkfield/Harpertown), New Core 2 Duo Mobile, Xeon 7200/7300, A100/A110. * Intel Processor : Itanium, Itanium 2, Itanium 2 Dual-Core. * Processor features : Centrino Pro, Dynamic Acceleration (IDA), Dynamic FSB, SSE4.1, SSE4.2, SSE5, FPU128. * Intel Chipset : GME965, GL/GLE960, G35, E7300. * nVidia Chipset : nForce 560, MCP73. * AMD/ATI Southbridge : SB700.Special support : * IA-64 System.
koumle Οκτώβριος 4, 2007 Author #28 Οκτώβριος 4, 2007 TechPowerUp GPU-Z v0.0.1Κάτι σαν CPU-Z αλλά για τις κά
sakis_the_fraud Οκτώβριος 7, 2007 #33 Οκτώβριος 7, 2007 εμενα παντως καμια απο τις 5 εκδοσεις δεν μου ανοιγει...
webhunter Οκτώβριος 7, 2007 #34 Οκτώβριος 7, 2007 Δες αν έχεις το net framework 2.0 και κάποια από τα updates του.
sakis_the_fraud Οκτώβριος 7, 2007 #35 Οκτώβριος 7, 2007 Δες αν έχεις το net framework 2.0 και κάποια από τα updates του.το εχω αυτο...
koumle Οκτώβριος 7, 2007 Author #36 Οκτώβριος 7, 2007 http://www.ocbase.com/perestroika_en/index.php?Download' rel="external nofollow">OCCT Perestro
koumle Οκτώβριος 7, 2007 Author #37 Οκτώβριος 7, 2007 TechPowerUp GPU-Z v0.0.6 * Improvements to validation code * Removed "Displays" * Added more devices to detectΜας έχουν τ
koumle Οκτώβριος 8, 2007 Author #39 Οκτώβριος 8, 2007 SetFSB 2.0.b.16hUpdated SetFSB : Version 2.0.b.16h Added ICS9LPRS914EKL,ICS951416BGLF.Supported Intel X38 and ATI RS690M chipset.Fixed CrystalCPUID/CrystalMark 2004R2/CrystalDMI interference.
koumle Οκτώβριος 11, 2007 Author #40 Οκτώβριος 11, 2007 TechPowerUp GPU-Z v0.0.7Revision History * Added Update Checker * Improved Shader Detection for ATI cards * Added support for future ATI GPUs * Various other improvements to detection code
