TechPowerUp Radeon Bios Editor v1.25
  Παράθεση
* Added preliminary fan control for 5970 (EMC2103 fan controller). Big thanks to Diverge for making this possible!
* Added support for Radeon 5830, 5450 and 5570.
* Added signature file based overdrive hacking capability for 5xx0 cards. Thanks to Biker for extensive testing!
* Improved built-in hex editor search capability.
* Fixed another subvendor display issue, hopefully for good this time.
* Improved RAM interface detection.
* Fixed a rarely occurring bug (on mobile Radeon BIOSes only) regarding powerplay table.
* Added qualified error message if pre-2xx0 BIOS is detected.
* Fixed rare file opening issue.
* Updated WinFlash link.
* Fixed minor clock wizard issue.
* Added welcome message for first time users.
* Added feature to enable RivaTuner versions < v2.25 to cooperate with 5xx0 Radeons.
PhenomMsrTweaker v1.2
  Παράθεση
A utility to completely customize the Cool & Quiet feature of AMD K10 (Phenom etc.) processors. It may be used to overclock and/or undervolt the CPU. Its primary aim is to allow on-demand use of the powersaving Cool & Quiet feature even when running the CPU above its original speed.
PhenomMsrTweaker allows to fully customize two CPU performance states: multiplicator (per core), Vcore (CPU VID) and integrated Northbridge voltage (NB VID) of P-states 0 (performance) and 1 (powersaving).
Additionally, it provides a customizable replacement for the standard implementation of Cool & Quiet in the Windows driver and allows to control standard or custom Cool & Quiet via on-the-fly power scheme switching.
Fraps 3.1.2
  Παράθεση
3.1.2 - 4th Mar 2010
- Fixed STALKER: Call of Pripyat not loading with Fraps running
- Fixed slow recording speeds for some users in Battlefield: Bad Company 2
- Fixed Guild Wars crashing when moving between zones
- Fixed videos being recorded at double width on some nvidia configurations
- Fixed colors being inverted in video captured from some DX10 games
- Fixed multiple FRAPS32.DLL crashes
  • 3 weeks later...
CPU-Z 1.54
  Παράθεση
- Intel Core i7-880, Core i5-680, Core i3-550 processor support.
- Intel Xeon 5600 line (32nm) processor support.
- AMD Phenom II X6, Sempron II, Turion II, Turion II Ultra and Athlon II Mobile "Caspian" processor support.
- Nvidia GeForce 320M chipset support.
- AMD 870/880G/890GX + SB800/SB850 chipset support.
- Introduction of validation rooms.
http://www.cpuid.com/cpuz.php
  • 4 weeks later...
ComputeMark v1.2
  Παράθεση
Version 1.2 adds CrossFire/SLI support.
ComputeMark is first 100% DirectX 11 Compute Shader 5 benchmark. With Windows 7 and DirectX 11, we can use huge performance of our graphic cards for more (real life, daily used) applications. With ComputeMark we are able to measure this power of our graphic cards and tell which one is better.
ComputeMark typically utilizes 99% of GPU (hot hot hot) and 0-1% of CPU. Windows 7, DirectX 11 and DX11 graphic card are required.
[ATTACH]8087[/ATTACH]
[ATTACH]8088[/ATTACH]
  • 1 month later...
Geeks3D GPU Shark 0.2.0
  Παράθεση
GPU-Shark is a tiny GPU monitoring tool for GeForce and Radeon based graphics cards and is available for Windows only. GPU-Shark offers a global view of all your graphics cards in a single window.
  Παράθεση
Here is the complete changelog of version 0.2.0:
* New: added memory usage for NVIDIA cards.
* New: added the TDP (thermal design power) if available.
* New: added subvendor names: ASUS, Palit and Gigabyte.
* Change: removed the flickering effect that occured at each update.
* Change: when graphics drivers are not supported, GPU-Shark tries to display only OpenGL information.
* Change: Caption in View menu: Detailed mode or Simplified mode.
* Change: vertical scrollbar a bit shorter.
[ATTACH]8334[/ATTACH]
GeForce SLI Profile Tool
  Παράθεση
GeForce SLI Profile Tool is a simple utility, developed by NVIDIA, that enables SLI customers to export their SLI profiles to a text file, edit them, and then import them back into the driver.
[ATTACH]8335[/ATTACH]
  • 2 months later...
πράγματι μαματο
Χρήστο στο Registry cleaner τα high risk αρχεία να τα τσεκάρω η είναι πράγματι ρίσκο?
  • 1 month later...
  • 4 weeks later...
Πρόσφατα έψαχνα ένα προγραμματακι για να πάρω τον ήχο από video
Βρήκα το Video mp3 Extractor.
Πολύ απλά και γρήγορα έχεις τον ήχο σε mp3
