Memtest86+ 4.00
New Features
- Major Architectural changes
- First pass twice faster (reduced iterations)
- Detect DDR2/3 brands and part numbers on Intel DDR2/3 chipsets
- Added detection for Intel "Clarkdale" CPU
- Added detection for Intel "Gulftown" CPU
- Added detection for AMD "Magny-Cours" CPU
- Added detection for Intel XMP Memory
- Added for CPU w/ 0.5/1.5/3/6/12/16/18/24MB L3
- Added "clean" DMI detection for DDR3/FBDIMM2
- Better detection of Integrated Memory Controllers
Bug Fixes
- Corrected detection for Intel "Lynnfield" CPU
- Corrected detection for AMD 45nm K10 CPU
- Solved crash with AMD Geode LX
- Complies with SMBIOS 2.6.1 specs
- Fixed compilation issues with gcc 4.2+
- Many others bug fixes
GPU-Z v0.3.5
0.3.5
* ATI Radeon HD 5870 (Cypress) fully supported (includes voltage monitoring)
* Added or improved support for NVIDIA FX5500, 9400 GT, G73, GTS 240, GT 140, FX 1800, GT 120 (Apple), FX 380, FX 350, GTX 295 Single PCB, Quadro CX, FX 5800, FX 4800, FX 3800, GTX 180M, GTX 260M, FX 2700M, G 110M, GT 120M, GT 220M, FX 1700M, G 105M, MCP79MX
* Added or improved support for ATI HD 4730, HD 4650 AGP, M92, M96, M98
* Added clock reading for Intel i910, i915, i945, 946
* Added support for DDR3 detection on G9x
* Added monitoring support for RV7xx based mobile chips
* Voltage controller "slaves" are now called "phases"
* Added Intel Havendale detection
* Fixed BIOS parsing on some newer HD 4870 cards
* Added voltage monitoring support for MSI N275GTX Lightning
TechPowerUp Radeon Bios Editor v1.22
* Added clock tuning wizard.
* Changed fan controller bug workaround settings' description to point out what it does a little better.
* Improved program's startup routine.
* Fixed "GetClockPos reported 0"-error that came up on loading several 4xx0-BIOSes.
* Added preliminary support for Radeon 5870. Note that I'm still not sure about 5850's DeviceID and that signature saving and loading will most likely not work properly on 5xx0s with this version. Furthermore, VT1165 programming is not functioning yet.
CPU-Tweaker 1.3 Beta 3
# Latest Changes
- Add support for Intel Core i5 & i7 (Lynnfield) CPUs
- DPI size limitation was removed
- Fix a bug with Unlock procedure With Lynnfield CPUs
δεν υπαρχει καποιο επισημο changelog, αλλα φαινεται να δινει την δυνατοτητα να αλλαξεις timings και στις μητρικες που δεν γινοταν.
ATIFlash 3.75
Revision History 3.75
* Exact changes unknown, supports HD 5870 / HD 5850 (Cypress)
Fraps 2.9.9
Changelog
2.9.9 - 29th Aug 2009
- Fixed missing audio in Adobe Premiere and Sony Vegas
- Fixed benchmarks not being written to benchmark folder
- Fixed loading crash when attempting to start Fraps
- Fixed stalling/stuttering after first 4 gig AVI segment
- Fixed mouse cursor image/transparency corruption
- Fixed mouse cursor offset in some applications
- Fixed crash when recording above 1920x1200 for some users
- Fixed crash after stopping video capture in Windows 2000
- Fixed crash in some DirectX10 applications
- Fixed random windows crashes with fraps.dll
- Fixed missing systray icon if explorer restarts
- Fixed frapsvid.dll and frapsv64.dll crashes when importing/playing video
- Fixed Run Fraps when Windows starts option
- Fixed Starcraft stalling during video capture
- Fixed limited CPU affinity of main Fraps process
- Fixed yellow corruption displayed in Plants vs Zombies
- Fixed capture speed of many older DDRAW games
EVGA Precision 1.8.1
- Added Nvidia GeForce G 210, GT 220 and GT 240 series graphics cards support
- EVGA On-Screen Display Server has been updated to version 3.5.0. Floating injection address hooking technology, which has been introduced in the previous version, is now disabled by default and can be enabled via the "Stealth mode" option in the server's properties
- Added hotkeys cross-links checking, Precision no longer allows defining the same hotkey for two different actions at the same time
- "Browse" button to "Screen capture" tab to allow users to change target folder for screenshots
- Added integration with external overclocking stability testing applications
RealTemp 3.35
Lots of minor changes behind the scenes including better support for Intel's new socket 1156 CPUs as well as their new Core i7 mobile CPUs.
Changes include:
-the use of the i7 Turbo method to calculate the multiplier for all CPUs. If this causes a problem for older Core 2 CPUs that may have the internal timers disabled then you will need to add this line to the RealTemp.INI file to use the previous method:
MSRMulti=1
The new i7 Turbo based method when used on a modern Core i7 or i5 CPU with C3/C6 enabled in the bios will be able to show you the multiplier of the hardest working core which in my opinion and Intel's opinion, best represents how fast your CPU is actually working. This method also works well with Core 2 mobile CPUs that support Intel Dynamic Acceleration (IDA).
The i7 Turbo method allows Super Low Frequency Mode (SLFM) to be displayed correctly on the Core 2 mobile processors that support this feature. A multiplier of 3.0 at idle when this feature is enabled is typical.
-the elapsed timer has been fixed so it shouldn't lose time any more.
-a work around for an incorrect bios setting was found for the missing core issues that sometimes plagued Quad core owners.
-a Task Manager based load meter (TM Load) was added as an option. The original load meter is based on the percentage of time a CPU is in the C0 state which is very accurate for many CPUs. Mobile CPUs work completely different and this number does not accurately reflect the load of the CPU at idle so now you have an option.
-the XS Benchmark was changed slightly so now you can Cancel it while it is running and you shouldn't see any more, "Program isn't responding" messages when it is fully loaded testing.
-an option to display your temperatures in Fahrenheit was added. Just add this to your RealTemp.INI file.
Fahrenheit=1
-the Settings window has been reworked for better consistency in preparation for possible future upgrades.
-only maximum VID is displayed in the Settings window for Core 2 owners for less confusion. This option will display real time VID on the main screen.
-an option to Disable Turbo Mode on Core i5/i7 CPUs.
MSI AfterBurner 1.20
Afterburner v.1.2.0 (2009-10-12)
* Added NVIDIA G 210 and GT 240 series graphics cards support
* Added voltage control for custom design MSI N220GT and N240GT series graphics cards with uP6262 voltage regulators
* Added intitial AMD RADEON HD 5750 and AMD RADEON HD 5770 series graphics cards support
* Added Logitech keyboards LCD displays support. Now it is possible to display hardware monitor data in Logitech keyboards LCD
* Extended I2C address scanning range for uP6208 voltage regulators to allow supporting voltage control on non-MSI custom design graphics cards equipped with uP6208
* Fixed on-board memory size detection for AMD RADEON HD 5000 series graphics cards
* Now option also affects voltage control
* Fixed database entry for AMD RADEON HD 4890 series graphics cards. Afterburner no longer adjusts 2D voltage instead of 3D voltage on AMD RADEON HD 4890
* Fixed database entry for AMD RADEON HD 5850 series graphics cards. Afterburner no longer adjusts UVD voltage instead of 3D voltage on AMD RADEON HD 5850
* Automatic profiles manager is now restarted after resuming from suspended mode
* Revised VRM access synchronization protocol for safer simultaneous VRM polling by multiple software products at the same time
* Added setting to the context menu of detached hardware monitor window. When this option is disabled, hardware monitor window can be minimized to the taskbar while staying in detached mode
* Now it is possible to pause hardware monitor activity via option in the context menu of hardware monitor window
* Maximum allowed hardware polling period has been extended from 5 to 60 seconds
* Added configuration file setting allowing power users to display performance profiler status informaition in the hardware monitor window. The information allows estimating average CPU performance hit caused by hardware monitor and software automatic fan control layers
* Optimized timer message queue processing under high CPU load conditions for better hardware monitoring and software automatic fan control events handling
* Reduced CPU usage for simultaneous GPU clock frequency and GPU usage readings on AMD graphics cards, both values are being read in single pass now
* Maximum limits has been extended from 1000 to 1500MHz for core clock graph and from 2000 to 2500MHz for shader clock and memory clock graphs
* Added readme file and option to display it in the installer
* Now tab is not displayed in advanced settings window if there are no fan control capable GPUs in the system
* Updated context help files, added more hints to button help
GPU-Z v0.3.6
0.3.6
* Added Infotips, they can be turned off in the system menu
* Added preliminary support for ATI Radeon HD 5900 (Hemlock), HD 5600 (Cedar), HD 5300 (Redwood)
* Added full support for HD 5850, HD 5770, HD 5750
* GPU-Z no longer crashes on ATI ULPS enabled CrossFire configurations
* Fillrate Pixel, Fillrate Texel, Memory Bandwidth will now correctly recalculate when clocks change
* Bus Interface, ATI shader count is now periodically refreshed
* Added support for HD 5850 voltages
* Second voltage on HD 5870 correctly named VDDCI
* ATI clock reading code fixed
* Fixed default clock reading on HD 5850
* Added Mutex to avoid collisions on long I2C operations
* Added basic detection for a lot of NVIDIA card fakes
* Added detection for ATI FireGL V7600, M92, RS880
* Added detection for NVIDIA GT 130, 9600 GE, Tesla C1060, G 220, GT 220, NVS 3100, GTS 160 M, NVS 160M, NVS 150M, G105M, GT 240M, G105M, G210M, G310M, ION LE
* Fixed die size and transistor count on G72 M
Fraps 2.9.99
- Fixed flickering video capture in Operation Flashpoint: Dragon Rising
- Fixed 30-bit color captures in Eve Online
- Fixed mouse cursor not being recorded in Conquer Online
- Other minor bug fixes
MSI AfterBurner 1.30
Afterburner v.1.3.0 (2009-10-19)
- Added voltage control for reference design AMD RADEON HD 4770 and AMD RADEON HD 5770 series graphics cards with L6788A voltage regulators
- Added voltage control for custom design MSI N240GT D3 series graphics cards with uP6262 voltage regulators
- Fixed database entry for AMD RADEON HD 4870 X2 graphics cards. Afterburner no longer adjusts 2D voltage instead of 3D voltage on AMD RADEON HD 4870 X2
  • 3 weeks later...
Fraps 3.0.0
What’s new:
* DirectX 11 support
* Compatible with Windows 7 final (RTM) and RC1 versions
* Stereoscopic 3D Vision video capture up to 1920×1200 for D3D9 games
* Force lossless RGB option to always capture video in pure form
* Ability to mix both game sound and external input such as microphone (Vista/Win7 only)
AMD Overdrive 3.1
AMD OverDrive™ Utility 3.1.0 (2009-9-20) Update list:
* 1. Added support for AMD Phenom II X4 965BE CPU
* 2. Added support for ATI DX11 “Evergreen” graphic cards
* 3. Added support for additional super IO chip: IT8712
* 4. Added support for AMD S1g4 and ASB2 socket type CPUs
* 5. Enhanced the fan speed control and hardware monitoring feature
* 6. Enhanced AMD Smart Profiles feature
* 7. Improved the CPU core multiplier settings method to change only the settings of the highest P-state
* 8. Enhanced the apply settings mechanism for memory timings by only applying the settings that were changed
* 9. Fixed a bug in AODDriver
* 10. Fixed the bug that GPU usage cannot be retrieved even with the latest graphic driver
Real Temp 3.40
Revision History
3.40
* Core i7/i5/Xeon Socket 1156 support including accurate turbo mode reporting.
* New information window for NVIDIA GPUs with improved SLI support.
* Correct reporting of Super Low Frequency Mode (SLFM) for Core 2 mobile CPUs.
* Correct reporting of Intel Dynamic Acceleration (IDA) for Core 2 mobile CPUs.
* Added VID reporting to the main GUI for Core 2 based CPUs.
* Added a Fahrenheit=1 INI file option.
* Added the option to view a Task Manager based or a C0% based load meter.
* Added the ability to toggle C1E state and view the SpeedStep (EIST) state.
* Improved dual and multi-monitor support including Anchor mode.
* Includes RealTemp GT, a 6 core version of RealTemp for Gulftown CPUs.
* Includes i7 Turbo, a high precision multiplier monitoring tool for all Core CPUs.
* Includes LoadTester, a variable load, single core testing program.
* Skull=1 or Skull=2 INI option for reading each CPU on a Dual Quad system.
* Thanks rge, burebista and somebody on TPU for all of your ideas and help.
http://www.techpowerup.com/downloads/1691/Real_Temp_3.40.html
