Vatos_locos Φεβρουάριος 4, 2009 #241 Φεβρουάριος 4, 2009 Real Temp 3 Real Temp, the Intel-loving CPU and GPU temperature monitoring tool has now been updated to version 3.00. The fresh release includes:- Core i7 temperature and frequency support including Turbo mode. - Nvidia temperature reporting with highest GPU temperature displayed in SLI mode. - Ability to run a file or shutdown based on user defined alarm temperature. - Updated interface with modern XP / Vista style and border in Mini Mode. - Start Minimized Vista issues finally fixed. - New RivaTuner plug-in support. - Extra information on the main screen and the retirement of the toggle button. - Switch to UNICODE for better international support. - Adjustable GUI colors and bold System Tray font option. - TJMax updated based on new Intel documentation and further testing. - Calibration formula simplified. - All new CPU Cool Down Test for a more thorough look at your sensors. - Clock Modulation & Minimize on Close options. - New CPU Load meter, log file headings and Distance to TJMax in the System Tray. - 101 other improvements including initial Windows 7 Beta support. [ATTACH]4883[/ATTACH]
sakis_the_fraud Φεβρουάριος 6, 2009 #242 Φεβρουάριος 6, 2009 Lavalys Everest 5.0 * Improved Hardware Monitoring module with Alerting feature * Support for Intel Core i7, Intel Atom and AMD Phenom II processors * Support for OpenGL 3.0 with OpenGL version compliancy test * Support for Windows 7 and a new auto-load feature under Windows Vista * Extended audio information: OpenAL and High Definition Audio pages * New information page for installed Windows Vista Sidebar Gadgets * GPGPU devices information for ATI Stream and nVIDIA CUDA
sakis_the_fraud Φεβρουάριος 9, 2009 #243 Φεβρουάριος 9, 2009 EVGA GPU Voltage Tuner 1.0 [ATTACH]4890[/ATTACH] [ATTACH]4891[/ATTACH] Owners of (a number of) EVGA GeForce GTX 200 series cards can now get more power out of their DirectX 10-supporting babies thanks to the newly-released GPU Voltage Tuner. As the name suggests, the application provided by EVGA enables users to easily increase the voltages of the graphics card to help overclock the core and shader frequencies to a whole other level.Available only for registered EVGA card owners, the GVT works with the GeForce 181.22 drivers (and everything above it), Windows XP, Vista and 7, and currently supports the following card models: EVGA GTX 260 - 896-P3-1260-XX - 896-P3-1262-XX - 896-P3-1263-XX - 896-P3-1264-XX - 896-P3-1265-XX - 896-P3-1266-XX - 896-P3-1267-XX - 896-P3-1268-XX - 896-P3-1269-XX - 896-P3-1270-XX EVGA GTX 280 - 01G-P3-1280-XX - 01G-P3-1282-XX - 01G-P3-1284-XX - 01G-P3-1286-XX - 01G-P3-1289-XX EVGA GTX 295 - 017-P3-1291-XX - 017-P3-1292-XX - 017-P3-1293-XX EVGA GPU Voltage Tuner v1.0 - Patch for vendor restriction & voltage limit removal (οχι που δεν θα εβγαζαν! ) Description: EVGA recently released a nice, user-friendly tool to allow users to adjust their graphic cards' voltages. However, as expectedly, they restricted this tool to only work on EVGA-branded graphic cards. They also imposed a voltage limit (perfectly understandable) to avoid people adjusting voltages through the roof and massively increasing RMA rates. With this patch, you, the user, are able to remove those imposed limits, including graphics card manufacturer/model limitations (tested only by GT200/212 users), and voltage limitations (now up to 2000 mV = 2.00v). Επειδη γινεται ενας ντορος με το patch και το ποιος θα το host-αρει, αν το λινκ δεν δουλευει στειλτε μου ενα πμ να το ανεβασω εγω καπου Η ατακα "μυριζει σουβλακια" προβλεπεται να ακουστει πολλες φορες...
sakis_the_fraud Φεβρουάριος 10, 2009 #244 Φεβρουάριος 10, 2009 FurMark 1.6.5 ChangeLog: * Change: workaround for Catalyst 9.1 when Catalyst A.I is enabled: all textures used by FurMark are now in 4-channel RGBA format (in the previous versions, some textures were in 3-channel RGB format…). * Change: the OpenGL version used by the renderer is now displayed in stability test mode (near renderer’s description) - thanks to David Legrand * Change: by default the creation of an OpenGL 3.0 rendering context is disabled. If you want to enable it, just start FurMark in command line with the /gl3 parameter or use the batch file called Start-FurMark-OGL3.bat. * Change: small modifications in OpenGL 3.0 context creation. * Change: workaround for Catalyst 9.1 bug in glGetString(GL_VERSION) when an OpenGL 3.0 context is used. * Removed: timer check in contest mode. Με τους Catalyst 9.1 δεν παιζει καμια προγενεστερη εκδοση του Furmark.
sakis_the_fraud Φεβρουάριος 10, 2009 #245 Φεβρουάριος 10, 2009 NVIDIA NiBiTor V4.8 Added supported products:* GeForce 9500 GS * GeForce 9800 GTX+ * GeForce 9600M GS * GeForce 9650M GT * GeForce 9700M GT * GeForce 9800M GS * GeForce 9800M GT * Quadro FX 1500 * Quadro NVS 140M
GeorgeVasil Φεβρουάριος 14, 2009 #246 Φεβρουάριος 14, 2009 CPUZ 1.50 2/14/2009 * Improved support for AMD Phenom II processor. * New Intel Core i7 models. * Support for NVIDIA 740i chipset. * Several bug fixes. Exe file properties * MD5 (cpuz.exe 1.50) : E1C827C54F527404EDDA6D65DA0280D8
sakis_the_fraud Φεβρουάριος 16, 2009 #247 Φεβρουάριος 16, 2009 Rivatuner 2.23 What's new: * Added ForceWare 182.xx drivers family support. * Updated databases for Detonator and ForceWare drivers. Added databases for ForceWare 181.20, 181.22 and 182.05. * Added Catalyst 9.1 drivers family detection. * Updated PCI DeviceID database for NVIDIA display adapters. * Added reference fan duty cycle monitoring and low-level fan control tab for G92 based display adapters using integrated on-die fan controller (e.g. GeForce 9800GTX series). Please take a note that low-level fan control tab for display adapters using integrated fan controller is provided only as a workaround allowing you to control the fan if the drivers are completely unable to do it. It is strongly not recommended to use low-level fan control for integrated fan controllers if driver-level fan control functions properly. * Added heuristic driver version detection for unattached display devices (for example the secondary GPUs in SLI/Crossfire mode invisible to OS) under Windows Vista. * Improved driver-level overclocking and fan control for NVIDIA multi-GPU systems. * Improved hardware monitoring module, New sticky graphs mode was designed special for multi-GPU systems * Updated bundled RivaTunerStatisticsServer v3.1.0 utility: o Minor skin appearance changes, "Normal" application detection level has been renamed to "Low" for better understanding. o Improved hooking system injects code into OS kernel's LoadLibrary functions by precached offsets and improves compatibility with some protective systems, faking the real LoadLibrary function offsets (e.g. latest revisions of SecuRom coming with new games like Dead Space, Need for speed : Undercover etc). Now such games no longer crash on startup when the server is running and LoadLibrary hooking is enabled by selecting "High" application detection level. o Added pre-created profiles for 3D applications, which require non-standard On-Screen Display coordinate space settings (e.g. Codename Panzers : Phase Two and Alpha Prime). o Added pre-created profiles for new pseudo-3D applications. * Updated bundled D3DOverrider v2.0.0 utility * Added experimental display configuration tracking mode. Power users may enable this mode using DisplayConfigurationTracking registry entry to force RivaTuner to track changes in your display adapters configuration (e.g. toggling SLI mode on/off or disabling secondary display adapter in the device manager). RivaTuner will reinitialize logical devices list and restart hardware monitoring module on display configuration change. * Minor GUI changes and improvements. * Many more (check revision changes) Rivatuner GPU Monitor Vista Sidebar Gadget http://forums.guru3d.com/showthread.php?t=288037
sakis_the_fraud Φεβρουάριος 18, 2009 #248 Φεβρουάριος 18, 2009 Radeon Bios Editor v1.19 v 1.19 * Fixed a startup bug causing the main window not to show up. * Added experimental voltage register access. RBE automatically figures out if the card's equipped with a VT11xx. Just use register 15 for underclocking/undervolting and register 18 for overclocking. Register tweaking will override the voltage table. Still, you should adjust your powerplay settings according to the new register values.
sakis_the_fraud Φεβρουάριος 19, 2009 #249 Φεβρουάριος 19, 2009 GPU-Z 0.3.2 * Clock reading on ATI cards fixed * GT200b is now detected as 55 nm * Added detection for GeForce GT 120, GT 130, GT 130M, FX 5200, 9400 GT, 9600 GSO 512, FX 2700M, 9500 GS, Quadro FX 540M, Quadro FX 3700M, 9650M GT, Quadro FX 370M, 9400 IGP, 9300 IGP, 8200M G, and S3 Chrome 500 Series * Fixed screen corruption during screenshot of sensors tab * Added support to show lowest, highest and average reading on sensors tab (click on sensor value to switch) * Fixed Catalyst version reading
sakis_the_fraud Φεβρουάριος 24, 2009 #250 Φεβρουάριος 24, 2009 Driver Sweeper beta 2.0.0 Changelog 2.0.0 - Beta 2:New: * Added select/deselect in clean screen. * Added Bulgarian translation. * Many translations. Updated: * Improved startup time. Fixed: * Some translations not working and missing. * Made some buttons larger for translations. * Error at desktop icons. * Reboot not working on all systems. * Update check not working properly. * Drag and Drop in main menu.
GeorgeVasil Μάρτιος 4, 2009 #251 Μάρτιος 4, 2009 Rivatuner 2.24 Version 2.24:Minor bugfixes: * Fixed bug in hardware monitoring module causing hardware monitoring based scheduled tasks to be ignored due to improper initialization on RivaTuner startup. * Fixed erroneous 100MHz memory clock reading on G9x GPU series based display adapters caused by bug in memory clock frequency generator source clock detection code. * File system redirection is no longer disabled when executing a patch script under 64-bit OS to prevent the issues with missing file system browser dialog when pressing the "Continue" button. * Heights of sticky graphs in the group are now updated properly when manually editing fixed graph height settings in the properties of any graph of the group. * Fixed bug into startup daemon routine of RivaTunerStatisticsServer and D3DOverrider utilities causing these tools to be started and reside in memory without displaying tray icon under certain conditions. What's new: * Added database for ForceWare 182.06. * Added Catalyst 9.2 drivers family detection. * Updated PCI DeviceID database for ATI display adapters. * Improved Logitech G15 keyboard LCD support in hardware monitoring module: o RivaTuner no longer maps OSD text to Logitech keyboard LCD, now there is separate "Show in LCD" option in the data source properties window allowing you to define independent output configurations for OSD and LCD. Previously available power user oriented MapOSDToLCD regitry entry is no longer in use. o Previously available power user oriented LCD font size adjustment option is now also available in the data source properties. o New dynamic LCD re-connection mode ensures proper LCD output when LCD software is being restarted dynamically. * Added heuristic on-die fan PWM controller detection for G92 based display adapters to provide proper low-level fan control and reference fan duty cycle monitoring for both reference desing and alternate display adapters using the fan connected to alternate on-die PWM controller (e.g. Palit GeForce 9800GT series). * Improved detection algorithms for core and memory clock frequency generators switching to PCIE bus clock on NV40 and newer NVIDIA graphics processors. The algorithms are still experimental, so both core and memory clock frequency generator bypassing detection can be forcibly disabled via EnableNVPLLBypassingDetection and EnableMPLLBypassingDetection registry entries. * Updated RivaTunerStatisticsServer v3.1.1 bundled utility. This version is a maintenance release, it doesn't contain new features besides the fix mentioned above. * Updated D3DOverrider v2.0.1 bundled utility. This version is a maintenance release, it doesn't contain new features besides the fix mentioned above.
sakis_the_fraud Μάρτιος 13, 2009 #252 Μάρτιος 13, 2009 EVGA Precision v1.5.1 What’s new:* Precision settings no longer reset at Windows startup on multi-GPU systems. * Optimized runtime skin switching implementation for better appearance when switching between the skins with different window shapes.
GeorgeVasil Μάρτιος 19, 2009 #253 Μάρτιος 19, 2009 OCCT Perestroïka 3.0.1 Changelog (Since 3.0.0) :GPU:MEMTEST * Now compatible with GeForce cards with more than 512MB under Vista (A Cuda bugs was encountered, but i found a workaround) * Now 4 times faster (thanks to a switch to Cuda 2.1 which came with bugfixes in the SDK - new prerequisites though) * The test cannot be run on GeForce 7 or lower anymore MONITORING * OCCT now saves monitoring sensor based on sensor names when available, not on position in a list. Thus, when a sensor disappear, OCCT configuration is preserved * Engine has been updated - new CPU support,... * the maximpum CPU temp can now be set at a temp higher than 99°C (before, it could be done, but it was reset upon reloading OCCT at 80°C) TRANSLATION * Arabic and Romanian support have been added * Italian have been updated Enjoy !
sakis_the_fraud Μάρτιος 22, 2009 #254 Μάρτιος 22, 2009 Radeon Bios Editor v1.20 v 1.20 * Added hex editor. * Added alternative BIOS extraction method. * (Hopefully) fixed the 3650 Device-ID-bug for good. * Fixed a bug concerning weird 4670 fan settings.
GeorgeVasil Μάρτιος 25, 2009 #255 Μάρτιος 25, 2009 TechPowerUp GPU-Z v0.3.3 * Added support for RV740 (HD 4750, HD 4770) and RV790 (HD 4890) * Fixed G98 shader count * Fixed GT200 process size calculation * Added support for GTX 275
GeorgeVasil Απρίλιος 11, 2009 #256 Απρίλιος 11, 2009 RealTemp 3.20 RC3 I went back to the old C++ compiler for better compatibility and cleaned up a few minor bugs. As always, if there are any new issues, then let me know. I added a few minor things like adjustable heading colors and a system tray pop up for Nvidia owners showing the Min and Max temperature. Bludd: The Thermal Status area of RealTemp reports the status of the PROCHOT bit within Intel Core processors. It is independent of the core temperature but typically PROCHOT is activated when Distance to TJMax counts down to about 3. It can vary a little from processor to processor and it also seems to be effected by the rate at which the core temperature is increasing. RealTemp and other software usually only samples once per second. There is a register / flag in the processor that will be set even if PROCHOT is activated only momentarily. RealTemp reads that bit and will change OK to WARN if this flag goes off. If thermal throttling continues, this will change to HOT which shows that thermal throttling is in progress. This will cycle the multi down to 6.0 on Core 2 based chips and down to 12.0 for Core i7 CPUs to help control heat and hopefully keep the processor from ever reaching TJMax. This cycling is happening thousands of times a second so software only sampling once per second may not always report the lower multiplier depending on the timing of when it reads the temperature sensors. Here's my favorite example of thermal throttling in action. I ran Prime95 Small FFTs for 3 hours with the CPU fan turned off. Yepp, it got kind of warm but even with a mild 20% overclock and some additional core voltage, the CPU ran 100% stable like this for 3 hours. Only once in 3 hours did one core hit 100C as shown in the middle of the temperature graph. 3 cheers for Intel. Lousy temperature sensors but great processors. At 107C, the supposed CPU TCase sensor reading looks a little overly optimistic.
GeorgeVasil Απρίλιος 24, 2009 #257 Απρίλιος 24, 2009 AMD Overdrive Overclocking Utility 3.01 Along with the two new Phenom processors, Advanced Micro Devices today releases an updated version of its Overdrive software. That's the company's utility for real-time monitoring, overclocking and tweaking of AMD chipsets. It is incredibly simple and easy to work with. To download the updated AMD Overdrive utility version 3.01, please click here. The link will also lead you to the full changelog.
sakis_the_fraud Απρίλιος 25, 2009 #258 Απρίλιος 25, 2009 SiSoft Sandra Lite XII SP3 15.96 Exciting new features * Hundreds of new reference test results thanks to our community of Beta testers. Our thanks for all their hard work. * Support for updated GPGPU Benchmarks: AMD Stream 1.4* and nVidia CUDA 2.1*. * Dynamic GPGPU work-load scheduler when using different GPGPU cards in the same system or a dedicated GPGPU card in a system with integrated graphics (IGP) when both support GPGPU features. * Improved measurement accuracy in Physical Disks, File Systems, Flash/SSD benchmarks (0.01ms instead of 1ms): now you can measure the fastest new SSDs and other flash devices more accurately. * Improved measurement accuracy in Memory Latency, Multi-Core Efficiency benchmarks (0.1ns instead of 1ns): now you can measure the fastest new processors and memory sub-systems more accurately. * VIA Nano (mobile) 64-bit processor in Windows Vista SP2*/Server 2008 SP2* and future Windows 7*/Server 2008 R2*. * Advanced test results management, including: customisation, import/export to common file formats, download of Ranked test results and integration with Price engines to determine the best value products on the market. With each release, we add new support for and compatibility to the latest hardware, architectures and operating systems, and this release is no exception. SiSoftware continues to work with hardware vendors to ensure the best support for new emerging hardware.
GeorgeVasil Απρίλιος 27, 2009 #259 Απρίλιος 27, 2009 nHancer 2.5.1 Advanced Control Panel and Profile Editor for nVidia cardsFeature Overview * Support of Forceware/GeForce drivers version 60 and later (with nHancer 2.4.5), including the new 185+ versions * Support of all GeForce cards, including the new GeForce GTX 2x0 lines * Supports Windows Vista, Windows 7 and DirectX 10 * Support for single card, SLI, Quad-SLI and DirectX 10 SLI systems * On-the-fly control of all global quality and performance-enhancing settings for all games * Create and manage fully automated profiles for all your games * Very easy to use, explains all options and their effects, like Anti Aliasing, Anisotropic Filtering, etc. * Special options for nVidia's SLI feature, allowing you to to use almost every game with SLI even if nVidia doesn't support it * Offers additional Anti Aliasing and Anisotropic Filtering modes, that are not available through nVidia's control panel * Allows the modification of fixed settings included in nVidia's predefined profiles. * Flexible user interface: change the size of the window and all sub areas * User interface and help texts available in various languages (right now English, German, Polish and Italian) * Coexists perfectly with nVidia's own control panel and other tools, like aTuner or RivaTuner. nHancer will immediately detect any changes made by any other tool. [ATTACH]5294[/ATTACH] nHancer 2.5.1 for 32 bit Systems (~ 1.9 MB) nHancer 2.5.1 for 64 bit Systems (~ 1.9 MB)
johnysb Απρίλιος 29, 2009 #260 Απρίλιος 29, 2009 HWM Blackbox v1.1 as you know there are many programs known as Everest or CPU-Z which shows features, speed, our micro instructions and other info from our hardware.so today I bring you an excellent free software is similar, with the difference that a little more updated cpu-z 1.50, such as grants to micro core 2 duo with their new logo (we started using intel the month of April), in addition to recognizing most perfectly motherboards and memories, you can control temperature, front side bus frequency, voltages, as well as an excellent viewfinder panel overclocking. is also fully compatible with Vista and Windows 7, actually includes benchmark type rating, which can only run on these operating systems [ATTACH]5297[/ATTACH] [ATTACH]5298[/ATTACH] [ATTACH]5299[/ATTACH] [ATTACH]5300[/ATTACH] [ATTACH]5301[/ATTACH] - x64 - x32
